PRODUCT SPECIFICATION
SPEC. NO: T-0602-070F
新弘智
DATE: Aug.7,2018
CUSTOMER'S PRODUCT NAME:
EMTEK PRODUCT NAME:
CMF2520F-601-2P-T
THIS SPECIFICATION IS:
□ FULLY ACCEPTED
□ DENIED
□ ACCEPTED UNDER THE FOLLOWING CONDITIONS
SIGNATURE:
NAME(PRINT):
TITLE:
本文件內容全部或部份,未經兆欣科技股份有限公
司同意不得以任何形式複製或其他用途
All rights reserved.This document or parts thereof,may
not be reproduced by any means or used in any manner
witout written permission of EMTEK CO.,LTD.
DATE:
FACTORY:
39,Chingao Rd.,(305)Hsinpu,
Hsinchu Hsien,Taiwan,R.O.C
TEL: 03-5894-433
FAX: 03-5894-523
1/8
SPEC. NO.
T-0602-070F
1. Scope
This specification applies ferrite Chip common mode filters CMF2520F-Series
to be delivered to user.
2. Product Identification
CMF 2520 F - 601 - 2P - T
(1) (2) (3) (4) (5) (6)
(1) Product name
(2) Shapes and dimensions
(3) Shielding Type
(4) Impedance【 at 100MHz】
601:600Ω
(5) Number of Line
2P:2-Line
(6) Taping Type
3. Shapes and Dimensions [Dimensions in mm]
A
B
Epoxy
C
A : 2.5 ± 0.2
B : 2.0 ± 0.2
C : 1.2 ± 0.1
Terminations
Wires
①
④
Equivalent circuit
(0.5)
(0.5)
②
(0.45)
③
①
④
②
③
No Polarity
(0.45)
Drawn by
Checked by
Approved by
2/8
SPEC. NO.
T-0602-070F
4. Electrical Characterisitics
4-1 Electrical Spec.
CMF2520F-900-2P-T
Common-Mode
Impedance
Z(Ω) at 100MHz
90±25%
CMF2520F-301-2P-T
Our Product Part Number
DC
Rated
Rated Current
Resistance
Voltage
Idc(A) Max.
Rdc(Ω) Max.
Vdc(V)max.
0.25
0.5
300±25%
0.35
0.4
CMF2520F-601-2P-T
600±25%
0.45
0.3
CMF2520F-102-2P-T
1000±25%
0.80
0.2
4-2Characteristics(Reference)
CMF2520F-301-2P-T
10000
Z (common mode)
Z(differential mode)
Impedance(Ω)
1000
100
10
1
1
10
Frequency(MHz)
100
1000
3/8
SPEC. NO.
4-3 Test Equipment
4-3-1 Impedance
Measured by using Agilent E4991A RF Impedance Analyzer.
Measurement terminal
①
④
②
③
4-3-2 DC Resistance
Measured by using Chroma 16502 mill ohm meter.
①
④
②
③
4-3-3 Insulation Resistance
Measured by using Chroma 19073
Measurement voltage : 50v .
①
④
②
③
T-0602-070F
4/8
SPEC. NO.
T-0602-070F
5.Reliability Test
Operating temperature : -25 to +85℃
Item
Solder
ability
Storage temp and humidity : 20~25℃ ,60%RH max.
Specifications
Test conditions
It can be connected on the
Apply cream solder to the test circuit board .
Recommendation soldering condition.
It is mounted on the recommendation soldering condition.
Dip pads in flux and dip in solder pot( 96.5 Sn/3.5 Ag
solder) at 255°C ±5°C.
Terminal
strength
The terminal electrode and the ferriteSolder a chip to test substrate , and then laterally apply a
must not be damaged.
load 0.5Kg in the arrow direction.
Strength on The terminal electrode and the ferriteSoldering a chip to a test substrate ,
bend the substrate by 2mm and then return.
pc board
bending
45
45
Width side
40
100
length
10
Force
Dimensions in mm
R10
Test board : Glass base epoxy multiplayer board pc board pattern.
PC board pattern : Recommended PC board pattern.
5/8
Item
Specifications
High
Appearance : Ferrite shall not be
temperature damaged.
resistance
SPEC. NO.
T-0602-070F
Test conditions
Temperature : +85±2℃
Applied voltage : Rated voltage
Applied current : Rated current
initial value.
Testing time : 500±12 hours
insulation resistance: >10(MΩ)
Measurement : After placing for 24 hours min.
DC resistance : standard value
Humidity
resistance
inside.
Humidity : 90 to 95%RH
Thermal
cycle
Temperature : -25℃,+85℃
kept stabilized for 30 minutes each.
Cycle : 100 cycle
1 cycle
+85℃
30 min.
-25℃
Low
temperature
resistance
Vibration
3 min.
30 min.
Temperature : -25±2℃
damaged.
Frequency : 10 to 50 Hz
Amplitude : 1.52 mm
Dimension and times : X ,Y and Z directions
for 2 hours each.
6/8
SPEC. NO.
T-0602-070F
6. Recommended Soldering Conditions (Please use this product by reflow soldering)
6-1 Recommended Footprint
Termination Number : Please refer to the equivalent circuit in chapter 3.
1.5
0.5
6-2 Recommended Reflow Pattern
Reflow : until two times
10sec. Min.
255℃
217℃
Natural cooling
150sec Max..
150℃
60sec. Min.
6-3 Iron Soldering
Use a solder iron of less than 30W when soldering ,do not allow the soldering iron tip
directly touch the ferrite body outside of terminal electrode.
5 seconds max. at 260℃.
7. Attention in Case of Using
In case of using product ,please avoid following matters:
Splashing water or salt water
Dew condenses
Toxic gas (Hydrogen sulfide, Sulfurous acid ,Chlorine, Ammonia)
Vibrations or shocks which exceed the specified condition
Please be careful for the stress to this product by board flexure or something
after the mounting.
7/8
SPEC. NO.
T-0602-070F
8. Others
8-1 Operating temperature range : -25~+85℃
8-2 Storage condition : Temperature 20~25℃ , Relative Humidity 40% ~ 60%
8-3 Recommended wire wound inductors should be used within 6 months from the time of delivery.
9.Packaging
The packaging must be done not to receive any damage during transporting
and storing.
9-1 Tape dimensions
P
Ko
P1
P0
W
Bo
t
Ao
( Dimensions in mm; Tolerance:±0.1)
Symbol
W
P
P0
P1
Ao
Bo
Ko
t
Dimension
8
4
4
2
2.25
2.8
1.35
0.22
9-2 Reel dimensions
D
( Dimensions in mm )
Symbol
C
B
A
B
C
D
E
A
E
T
180
60
13
14.4
8.4
8/8
SPEC. NO.
T-0602-070F
9-3 Tapping figure
Top cover tape
Carrier tape
Sprocket hole
Cavity (chip insert)
9-4 Packaging Form
There shall not continuation more than two vacancies of the product.
(360 mm)
Blank
Chip
50 pitches
Blank
Leader.
70 pitches
Material of carrier tape : Polystyrene
Material of cover tape : Polyester
9-5 Cover Tape Peel Strength
The force for tearing off cover tape is 0.05~0.69(N) in the arrow direction at
the following conditions:
Temperature : 5 ~ 35℃
Humidity : 45 ~ 85%
Atmospheric pressure : 860 ~ 1060 hpa
160 ~ 180。
Top cover tape
Base tape
9-6 Packing Quantity
φ180 mm reel T type : 2000 pcs./reel
很抱歉,暂时无法提供与“CMF2520F-102-2P-T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.91268
- 50+1.50444
- 150+1.32948
- 500+1.11122
- 2500+1.01402
- 5000+0.95570
