HSC1206-27NJ-T
HSC1206-27NJ-T
    EMTEK(兆欣)
    SMD
    功率电感 SMD
HSC1206-27NJ-T 数据手册
PRODUCT SPECIFICATION SPEC. NO: 新弘智 T-0619-028X DATE:Aug.7,2018 CUSTOMER'S PRODUCT NAME: EMTEK PRODUCT NAME: HSC1206-Series THIS SPECIFICATION IS: □ FULLY ACCEPTED □ DENIED □ ACCEPTED UNDER THE FOLLOWING CONDITIONS SIGNATURE: NAME(PRINT): TITLE: 本文件內容全部或部份,未經兆欣科技股份有限公 司同意不得以任何形式複製或其他用途 All rights reserved.This document or parts thereof,may not be reproduced by any means or used in any manner witout written permission of EMTEK CO.,LTD. DATE: FACTORY: 39,Chingao Rd.,(305)Hsinpu, Hsinchu Hsien,Taiwan,R.O.C TEL: 03-5894-433 FAX: 03-5894-523 1/10 SPEC. NO. PRODUCT SPECIFICATION T-0619-028X 1. Scope This specification applies Ceramic Chip Inductance HSC1206-Series to be delivered to user. 2. Product Identification HSC 1206 - R62 □ - T (1) (2) (3) (4) (5) (1) Dimemsion (2) Type (3) Inductance R62 : 620 nH (4) Tolerance G=±2%,J=±5%,K=±10% (5) Taping Type 3. Shapes and Dimensions A max. : 3.56 mm B max. : 2.16 mm C max. : 1.52 mm D ref. E: : 0.51 mm 0.51 mm Equivalent circuit No Polarity Drawn by Checked by Approved by 2/10 SPEC. NO. PRODUCT SPECIFICATION T-0619-028X 4. Electrical Characteristics Customer Part Number Our Product Part Number Inductance Inductance (nH)/MHz Tolerance Q /MHz Min. SRF (MHz) Min. Rdc (Ω) Max. Irms (mA) Max. 1st 2nd 3rd Color Coding HSC1206-6N8□-T 6.8/100 J,K 30/300 5500 0.07 1000 Blue Gray Black HSC1206-8N2□-T 8.2/100 J,K 15/300 3200 0.18 1000 Black Gray Black HSC1206-10N□-T 10/100 J,K 40/300 4000 0.08 1000 Brown Black Black HSC1206-12N□-T 12/100 J,K 40/300 3200 0.08 1000 Brown Red Black HSC1206-15N□-T 15/100 J,K 40/300 3200 0.10 1000 Brown Green Black HSC1206-22N□-T 22/100 J,K 50/300 2200 0.10 1000 Red Red Black HSC1206-24N□-T 24/100 J,K 50/300 2000 0.10 1000 Red Yellow Black HSC1206-27N□-T 27/100 G,J,K 50/300 1800 0.11 1000 Red Violet Black HSC1206-33N□-T 33/100 J,K 55/300 1800 0.14 1000 Orange Orange Black HSC1206-39N□-T 39/100 J,K 55/300 1800 0.12 1000 Orange White Black HSC1206-47N□-T 47/100 G,J,K 55/300 1500 0.19 1000 Yellow Violet Black HSC1206-56N□-T 56/100 J,K 55/300 1450 0.22 1000 Green Blue Black HSC1206-62N□-T 62/100 J,K 55/300 1200 0.20 1000 Blue Red Black HSC1206-68N□-T 68/100 J,K 55/300 1200 0.27 900 Blue Gray Black HSC1206-82N□-T 82/100 J,K 55/300 1150 0.26 860 Gray Red Black HSC1206-91N□-T 91/100 J,K 55/300 1100 0.24 900 White Brown Black HSC1206-R10□-T 100/100 J,K 55/300 1100 0.26 850 Brown Black Brown HSC1206-R12□-T 120/100 J,K 60/300 1100 0.32 800 Brown Red Brown HSC1206-R15□-T 150/100 J,K 60/300 950 0.36 750 Brown Green Brown HSC1206-R18□-T 180/50 G,J,K 60/300 900 0.43 700 Brown Gray Brown HSC1206-R22□-T 220/50 J,K 60/300 760 0.50 670 Red Red Brown HSC1206-R27□-T 270/50 G,J,K 55/300 730 0.56 630 Red Violet Brown HSC1206-R30□-T 300/50 G,J,K 45/150 700 0.58 600 Orange Black Brown 3/10 SPEC. NO. PRODUCT SPECIFICATION T-0619-028X 4. Electrical Characteristics Customer Part Number Our Product Part Number Inductance Inductance (nH)/MHz Tolerance Q /MHz Min. SRF (MHz) Min. Rdc (Ω) Max. Irms (mA) Max. Color Coding 1st 2nd 3rd HSC1206-R33□-T 330/50 G,J,K 45/150 650 0.62 590 Orange Orange Brown HSC1206-R36□-T 360/50 J,K 45/150 600 0.65 550 Orange Blue Brown HSC1206-R39□-T 390/50 G,J,K 45/150 600 0.75 530 Orange White Brown HSC1206-R43□-T 430/50 J,K 47/150 600 1.25 510 Yellow Orange Brown HSC1206-R47□-T 470/50 G,J,K 47/150 550 1.30 490 Yellow Violet Brown HSC1206-R56□-T 560/35 G,J,K 45/150 470 1.45 460 Green Blue Brown HSC1206-R62□-T 620/35 G,J,K 45/150 465 1.52 455 Blue Red Brown HSC1206-R68□-T 680/35 G,J,K 45/150 460 1.55 450 Blue Gray Brown HSC1206-R75□-T 750/35 J,K 45/150 440 2.25 320 Violet Green Brown HSC1206-R82□-T 820/35 J,K 45/150 420 1.82 400 Gray Red Brown HSC1206-R91□-T 910/35 J,K 45/150 410 2.75 350 White Brown Brown HSC1206-1R0□-T 1000/35 J,K 45/150 400 2.80 320 Brown Black Red HSC1206-1R2□-T 1200/35 J,K 45/150 380 3.20 300 Brown Red Red J,K 25/25.2 200 3.90 300 Brown Gray Red HSC1206-1R8□-T 1800/7.96 1. All specifications are calibrated with Coilcraft 1206CS series 2. When ordering, please specify tolerance and packaging codes. Ex: HSC1206-R62G-T Tolerance :G=±2%,J = ±5%,K=±10% Packaging : Clear tape and reel { standard }. * 3. L , Q , SRF: Agilent E4991A RF Impedance/Material Analyzer+ Agilent 16197A Test Fixtures (The electrical specification test by the smallest gap position), or equivalent 4. Rdc : Chroma 16502 Milliohm meter, or equivalent. 5. Irms for a 25℃ rise above 25℃ ambient. 6. Operating temperature range from -40℃ to 125℃. * Parts/Reel: 7” 2,000 Tape Width: 8mm 4/10 PRODUCT SPECIFICATION SPEC. NO. T-0619-028X Ls V.S Frequency HSC1206-R82J-T HSC1206-R36J-T HSC1206-47NJ-T HSC1206-15NJ-T HSC1206-R12J-T Inductance(μH) 10 1 0.1 0.01 1 10 Frequency(MHz) 100 1000 Q V.S Frequency HSC1206-R82J-T HSC1206-R36J-T HSC1206-R12J-T HSC1206-47NJ-T HSC1206-15NJ-T 1000 100 Q 10 1 1 10 Frequency(MHz) 100 1000 5/10 PRODUCT SPECIFICATION 5. Material list Item Material Core Al2O3 96% Wire Copper wire Epoxy UV Epoxy SPEC. NO. T-0619-028X 6/10 PRODUCT SPECIFICATION SPEC. NO. T-0619-028X 6. Reliability Test Item Solderability Specifications Test conditions The metalized area must have 90% Dip pads in flux and dip in solder pot( 96.5 Sn/3.5 Ag minimum solder coverage. solder) at 255°C ±5°C. Resistance to There must be no case deformation or Inductors shall be reflowed onto a PC board using soldering heat change in dimensions. 96.5 Sn/3.5 Ag solder paste. Inductance must not change more than Solder process shall be at a maximum temperature the stated tolerance. of 260°C. For 96.5 Sn/3.5 Ag solder paste:>217°C for 90 seconds There must be no case deformation or change in dimensions. Inductance must not change more than the stated tolerance. Solder specimen inductor on the test printed circuit board. Apply vibrations in each of the x,y and z directions for 2 hours for a total of 6 hours. High temperature resistance There must be no case deformation or change in dimensions. Inductance must not change more than the stated tolerance. Inductors shall be subjected to temperature 125±2℃ for 50±12 hours. Static Humidity Inductors must not have a shorted or openwinding. Inductors shall be subjected to temperature 85±2℃ and 90 to 95%RH. for ten 24-hours. Vibration Frequency : 10~50 Hz Amplitude : 1.5mm Measure the test items after leaving the inductors at room temperature and humidity for 2 hours. Measure the test items after leaving the inductors at room temperature and humidity for 2 hours. Component adhesion (push test) Inductors shall be subjected to 1.8Kg Inductors shall be reflow soldered (255°C ±5°C for 10 seconds) to a tinned copper substrate. A force gauge shall be applied to the side of the component. The device must withstand the stated force without a failure of the termination. 7/10 PRODUCT SPECIFICATION Item SPEC. NO. T-0619-028X Specifications Test conditions Low There must be no case deformation or Inductors shall be subjected to temperature temperature change in dimensions. -40±2℃ for 48±12 hours. resistance Inductance must not change more than Measure the test items after leaving the inductors the stated tolerance. at room temperature and humidity for 1 to 2 hours. Resistance to There must be no case deformation, solvent change in dimensions, or obliteration Inductors must withstand 6 minutes of alcohol or water. of marking. Thermal There must be no case deformation or Inductors shall be subjected to 10 cycles to the shock change in dimensions. the following temperature cycle: Inductance must not change more than the stated tolerance. 1 cycle 30 min. 30 sec +125℃ -40℃ 30 min. Measure the test items after leaving the inductors at room temperature and humidity for 2 hours. 8/10 PRODUCT SPECIFICATION SPEC. NO. T-0619-028X 7.Packaging The packaging must be done not to receive any damage during transporting and storing. 7-1 Tape dimensions Ko P1 P0 P W Bo t Ao Symbol Dimension Tolerance ( Dimensions in mm) Ko t W P P0 P1 Ao Bo 8 4 4 2 2.14 3.56 1.5 0.22 ±0.10 ±0.10 ±0.10 ±0.10 ±0.05 ±0.05 ±0.05 ±0.05 7-2 Reel dimensions D Symbol C B A B C D E A E 7-3 Tapping figure Top cover tape Carrier tape Sprocket hole Cavity (chip insert) ( Dimensions in mm ) T 180 60 13 14.4 8.4 9/10 PRODUCT SPECIFICATION SPEC. NO. T-0619-028X 7-4 Packaging Form There shall not continuation more than two vacancies of the product. (360 mm) Blank (50 pitches) Chip Blank (70 pitches) Leader. 7-5 Cover Tape Peel Strength The force for tearing off cover tape is 0.1~0.6(N) in the arrow direction at the following conditions: Temperature : 5 ~ 35℃ Humidity : 45 ~ 85% Atmospheric pressure : 860 ~ 1060 hpa 160 ~ 180。 Top cover tape Base tape 7-6 Packing Quantity φ180 mm reel type : 2,000 pcs./reel 10/10 PRODUCT SPECIFICATION SPEC. NO. T-0619-028X 8. Recommended Soldering Conditions (Please use this product by reflow soldering) 8-1 Recommended Footprint 1.02 1.78 1.02 1.93 8-2 Recommended Reflow Pattern Reflow : until two times 10 sec. Min. 255℃ 217℃ Natural cooling 150sec. Max. 150℃ 60sec. Min. 8-3 Iron Soldering Use a solder iron of less than 30W when soldering ,do not allow the soldering iron tip directly touch the Ceramic body outside of terminal electrode. 4 seconds max. at 260℃. 9. Attention in Case of Using In case of using product ,please avoid following matters: Splashing water or salt water Dew condenses Toxic gas (Hydrogen sulfide, Sulfurous acid ,Chlorine, Ammonia) Vibrations or shocks which exceed the specified condition Please be careful for the stress to this product by board flexure or something after the mounting. 10. Others 10-1 Operating temperature range : Ferrite Series : -25~+85℃ Ceramic Series : -40~+125℃ 10-2 Storage condition : Temperature 20°~25℃﹐Relative Humidity 40%~60% 10-3 Recommended wire wound inductors should be used within 6 months from the time of delivery.
HSC1206-27NJ-T 价格&库存
很抱歉,暂时无法提供与“HSC1206-27NJ-T”相匹配的价格&库存,您可以联系我们找货
HSC1206-27NJ-T
    • 5+1.25972
    • 50+1.00386
    • 150+0.89424
    • 500+0.75741
    • 2500+0.69650
    • 5000+0.65988
