CMF2012H4-121-2P-T
CMF2012H4-121-2P-T
    EMTEK(兆欣)
    共模电感 SMD,2x1.2x1.2mm
CMF2012H4-121-2P-T 数据手册
PRODUCT SPECIFICATION SPEC. NO: 新弘智 DATE: T-0602-058J Aug.7,2018 CUSTOMER'S PRODUCT NAME: EMTEK PRODUCT NAME: CMF2012H4-Series THIS SPECIFICATION IS: □ FULLY ACCEPTED □ DENIED □ ACCEPTED UNDER THE FOLLOWING CONDITIONS SIGNATURE: NAME(PRINT): TITLE: DATE: FACTORY: 本文件內容全部或部份,未經兆欣科技股份有限公 司同意不得以任何形式複製或其他用途 All rights reserved.This document or parts thereof,may not be reproduced by any means or used in any manner witout written permission of EMTEK CO.,LTD. 39,Chingao Rd.,(305)Hsinpu, Hsinchu Hsien,Taiwan,R.O.C TEL: 03-5894-433 FAX: 03-5894-523 1/13 SPEC. NO. PRODUCT SPECIFICATION T-0602-058J 1. Scope This specification applies ferrite Chip common mode filters CMF2012H4-Series to be delivered to user. 2. Product Identification CMF 2012 H4 - 900 - 2P - T (1) (2) (3) (4) (5) (6) (1) Product name (2) Shapes and dimensions (3) Shielding Type (4) Impedance【 at 100MHz】 65min. (90typ.) (5) Number of Line 2P:2-Line (6) Taping Type 3. Shapes and Dimensions [Dimensions in mm] B C A A : 2.0 ± 0.2 B : 1.2 ± 0.2 C : 1.2 ± 0.2 Terminations Wires ① ④ Equivalent circuit (0.4) (0.4) ② (0.45) ③ ① ④ ② ③ No Polarity (0.45) Drawn by Checked by Approved by 2/13 SPEC. NO. PRODUCT SPECIFICATION T-0602-058J 4. Electrical Characterisitcs 4-1 Electrical Spec. Common-Mode Cut-off The Our cutoff Product frequencyies in differential mode for CMF2012H2 is 6GHz respectively. Rated DC Resistance Rated Current Impedance Voltage Part Number Frequency Rdc(Ω) Max. Idc(mA) Max. Insulation Resistance Z(Ω) at 100MHz Vdc(V) (GHz)Typ. CMF2012H4-420-2P-T 42±25% 0.12 400 20 5.0 (MΩ)Min. 10 CMF2012H4-500-2P-T 50±25% 0.30 400 20 5.0 10 CMF2012H4-600-2P-T 60±25% 0.31 320 20 4.0 10 CMF2012H4-670-2P-T 67±25% 0.31 320 20 4.0 10 CMF2012H4-900-2P-T 65min. (90typ.) 0.25 300 20 4.0 10 CMF2012H4-121-2P-T 120±25% 0.25 300 20 4.0 10 4-2-1 Characteristics(Reference) CMF2012H4-420-2P-T 10000 Z (common mode) Z(differential mode) 1000 Z ( ohm) 100 10 1 0.1 10 100 1000 Frequency(MHz) CMF2012H4-121-2P-T 10000 Z (common mode) Z(differential mode) 1000 Impedance ( ohm) 1 100 10 1 1 10 Frequency(MHz) 100 1000 3/13 PRODUCT SPECIFICATION 4-2-2 Insertion loss(Reference) CMF2012H4-420-2P-T CMF2012H4-420-2P-T SPEC. NO. T-0602-058J 4/13 PRODUCT SPECIFICATION 4-2-2 Insertion loss(Reference) CMF2012H4-500-2P-T CMF2012H4-500-2P-T SPEC. NO. T-0602-058J 5/13 PRODUCT SPECIFICATION SPEC. NO. 4-2-2 Insertion loss(Reference) CMF2012H4-670-2P-T CMF2012H4-670-2P-T HDMI Choke Impedance Graphic result T-0602-058J 6/13 PRODUCT SPECIFICATION 4-2-2 Insertion loss(Reference) CMF2012H4-900-2P-T CMF2012H4-900-2P-T SPEC. NO. T-0602-058J 7/13 PRODUCT SPECIFICATION 4-2-2 Insertion loss(Reference) CMF2012H4-121-2P-T CMF2012H4-121-2P-T SPEC. NO. T-0602-058J 8/13 SPEC. NO. PRODUCT SPECIFICATION T-0602-058J 4-3 Test Equipment 4-3-1 Impedance Measured by using Agilent E4991A RF Impedance Analyzer. The cutoff frequencyies in differential mode for CMF2012H2 is 6GHz respectively. Measurement terminal ① ④ ② ③ 4-3-2 DC Resistance Measured by using Chroma 16502 mill ohm meter. Measurement terminal ① ④ ② ③ Measurement terminal 4-3-3 Insulation Resistance Measurement terminal ① ④ ② ③ 9/13 PRODUCT SPECIFICATION SPEC. NO. T-0602-058J 5. Reliability Test Operating temperature : -40 to +105℃ Storage temp and humidity : 20~25℃ ,60%RH max. Specifications conditions The Item cutoff frequencyies in differential mode for CMF2012H2 is 6GHzTest respectively. Apply cream solder to the test circuit board . Solder ability It can be connected on the It is mounted on the recommendation soldering condition. Recommendation soldering condition. Terminal The terminal electrode and Solder a chip to test substrate , and then strength the ferrite must not be laterally apply a load 0.5Kg in the arrow damaged. direction. Strength on pc board bending The terminal electrode and the ferrite must not be damaged. Soldering a chip to a test substrate , bend the substrate by 2mm and then return. Test board : Glass base epoxy multiplayer board pc board pattern. PC board pattern : Recommended PC board pattern. 10/13 SPEC. NO. PRODUCT SPECIFICATION T-0602-058J 5. Reliability Test Item Specifications Test conditions +105±2℃ : Ferrite shall not be Temperature High The cutoff Appearance frequencyies in differential mode for :CMF2012H2 is 6GHz respectively. Applied voltage : Rated voltage temperature damaged. resistance Impedance : Within ±20% of Applied current : Rated current the initial value. insulation resistance: > 10(MΩ) DC resistance : standard value inside. Testing time : 50±12 hours Measurement : After placing for 24 hours min. Humidity resistance Temperature : +85±2℃ Humidity : 90 to 95%RH Applied current : Rated current Applied voltage : Rated voltage Testing time : 500±12 hours Measurement : After placing for 24 hours min. Thermal cycle Temperature : -40℃,+105℃ kept stabilized for 30 minutes each. Cycle : 5 cycle Measurement : After placing for 24 hours min. 1 cycle +105℃ -40℃ Low temperature resistance Vibration 30 min. 3 min 30 min. Temperature : -40±2℃ Testing time : 48±12 hours Measurement : After placing for 24 hours min. Appearance : Ferrite shall not be Frequency : 10 to 50 Hz damaged. Amplitude : 1.52 mm Dimension and times : X ,Y and Z directions for 2 hours each. 11/13 SPEC. NO. PRODUCT SPECIFICATION T-0602-058J 6.Packaging The packaging must be done not to receive any damage during transporting and storing 6-1The Tape cutoff dimensions frequencyies in differential mode for CMF2012H2 is 6GHz respectively. Ko P1 P0 P W Bo t Ao ( Dimensions in mm; Tolerance:±0.1) Symbol W P P0 P1 Ao Bo Ko t Dimension 8 4 4 2 1.5 2.25 1.35 0.24 6-2 Reel dimensions w φA t t Symbol R Dimension in mm T φA φB 180+0,-3 φC 13±0.2 D 2.2±0.5 W 9.0±0.3 t 1.2 R 1 φB φC D 6-3 Tapping figure Top cover tape Carrier tape Sprocket hole Cavity (chip insert) 60+1,-0 12/13 PRODUCT SPECIFICATION SPEC. NO. T-0602-058J 6-4 Packaging Form There shall not continuation more than two vacancies of the product. The cutoff frequencyies in differential mode for CMF2012H2 is 6GHz respectively. (360 mm) Blank Chip (50 pitches) Blank Leader. (70 pitches) Material of carrier tape : Polystyrene Material of cover tape : Polyester 6-5 Cover Tape Peel Strength The force for tearing off cover tape is 0.05~0.69(N) in the arrow direction at the following conditions: Temperature : 5 ~ 35℃ Humidity : 45 ~ 85% Atmospheric pressure : 860 ~ 1060 hpa 160 ~ 180。 Top cover tape Base tape 6-6 Packing Quantity φ180 mm reel T type : 2000 pcs./reel 13/13 SPEC. NO. PRODUCT SPECIFICATION T-0602-058J 7. Recommended Soldering Conditions (Please use this product by reflow soldering) 7-1 Recommended Footprint Termination Number : Please refer to the equivalent circuit in chapter 3. 0.4 0.4 The cutoff frequencyies in differential mode 2.6for CMF2012H2 is 6GHz respectively. 1.2 0.8 1.0 7-2 Recommended Reflow Pattern 10sec. Max. 255℃ 217℃ Natural cooling 150sec Max.. 150℃ 60sec. Min. 7-3 Iron Soldering Use a solder iron of less than 30W when soldering ,do not allow the soldering iron tip directly touch the ferrite body outside of terminal electrode. 4 seconds max. at 260℃. 8. Attention in Case of Using In case of using product ,please avoid following matters: Splashing water or salt water Dew condenses Toxic gas (Hydrogen sulfide, Sulfurous acid ,Chlorine, Ammonia) Vibrations or shocks which exceed the specified condition Please be careful for the stress to this product by board flexure or something after the mounting. 9. Other Recommended wire wound inductors should be used within 6 months from the time of delivery.
CMF2012H4-121-2P-T 价格&库存
很抱歉,暂时无法提供与“CMF2012H4-121-2P-T”相匹配的价格&库存,您可以联系我们找货
CMF2012H4-121-2P-T
    • 5+0.70514
    • 50+0.54962
    • 150+0.47186
    • 500+0.41354
    • 2500+0.36688
    • 5000+0.34344
    库存:10
