CMP110N08B/CMB110N08B
80V N-Channel MOSFET
General Description
Product Summary
The 110N08B uses advanced trench
BVDSS
RDSON
ID
80V
6.5mΩ
110A
technology and design to provide
excellent RDS(ON) . This device is
Applications
LED power controller
suitable for PWM, load switching and
DC-DC & DC-AC converters
High current, High speed switching
general purpose applications.
Solenoid and relay drivers
Motor control, Audio amplifiers
Features
TO-220/263 Pin Configuration
Low On-Resistance
D
100% avalanche tested
G
G
D
RoHS Compliant
S
TO-220
(CMP110N08B)
S
TO-263
(CMB110N08B)
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
80
V
VGS
Gate-Source Voltage
±20
V
ID@TC=25℃
Continuous Drain Current
110
A
ID@TC=100℃
75
A
330
A
612
mJ
IDM
EAS
Pulsed Drain Current
1
Single Pulse Avalanche Energy
2
PD@TC=25℃
Total Power Dissipation
165
W
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
Rating
Unit
RθJA
Thermal Resistance Junction-ambient
62.5
℃/W
RθJC
Thermal Resistance Junction-case
0.8
℃/W
CA01P1
www.cmosfet.com
Page 1 of 2
Electrical Characteristics (TJ=25℃ , unless otherwise noted)
Symbol
BVDSS
Parameter
Conditions
Min.
Typ.
Max.
Unit
Drain-Source Breakdown Voltage
VGS=0V , ID=250uA
80
V
RDS(ON)
Static Drain-Source On-Resistance
VGS=10V , ID=40A
6.5
mΩ
VGS(th)
Gate Threshold Voltage
VDS=VGS , ID =250uA
2
4
V
VDS=64V, VGS=0V
1
VDS=64V, VGS=0V, TJ =55℃
5
uA
IDSS
Drain-Source Leakage Current
IGSS
Gate-Source Leakage Current
VGS = ±20V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=10 V , ID=15A
30
S
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
2.5
Ω
Qg
Total Gate Charge
I D = 50A
60
Qgs
Gate-Source Charge
V DS = 4 0 V
17
Qgd
Gate-Drain Charge
VGS = 10 V
12
Turn-On Delay Time
VDS = 4 0 V
RG = 3Ω
25
15
3900
650
50
Min.
Typ.
Max.
Unit
110
A
330
A
60
ns
Td(on)
Tr
Td(off)
Tf
Rise Time
Turn-Off Delay Time
Fall Time
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
I D =50A
VGS =10V
VDS=40V , VGS=0V , f=1MHz
nC
ns
pF
Diode Characteristics
Symbol
IS
Parameter
Continuous Source Current
Conditions
VG=VD=0V , Force Current
ISM
Pulsed Source Current
trr
Reverse Recovery Time
Qrr
Reverse Recovery Charge
IF =50A
dI/dt=100A/μs
150
nC
VSD
Diode Forward Voltage
VGS=0V , IS=80A
1.2
V
Note :
1. Repetitive rating; pulse width limited by max. junction temperature.
2. VDD= 40V, starting TJ=25℃, L=1mH , I D =35A , VG =10V.
This product has been designed and qualified for the counsumer market.
Cmos assumes no liability for customers' product design or applications.
Cmos reserver the right to improve product design ,functions and reliability wihtout notice.
CA01P1
www.cmosfet.com
Page 2 of 2
很抱歉,暂时无法提供与“CMP110N08B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+4.17582
- 10+3.45762
- 50+2.99592
- 100+2.64708
- 500+2.43162
- 1000+2.31876
