CMSA5950A
CMSA5950A
    CMOS(广东场效应半导体)
    DFN-8(5x6)
    CMSA5950A采用先进技术,可实现出色的导通电阻RDS(ON)。该器件适用于开关电源(SMPS)的低端场效应晶体管(FET)、负载开关及通用应用。
CMSA5950A 数据手册
CMSA5950A P-Channel Enhancement Mode Field Effect Transistor General Description Product Summary The CMSA5950A uses advanced BVDSS RDSON -100V 52mΩ technology to provide excellent RDS (ON) . This device is suitable ID -50A Applications to be used as the low side FET Load Switch in SMPS,load switching and Power Management in Notebook Computer,Portable general purpose. Equipment and Battery Powered Systems. Features DFN-8 5x6 Pin Configuration Fast switching speed D D D D D Lower On-resistance 100% EAS Guaranteed S Simple Drive Requirement Pin 1 Absolute Maximum Ratings S S G G S DFN-8 5x6 Type Package Marking CMSA5950A DFN-8 5*6 CMSA5950A Symbol Parameter Rating Units VDS Drain-Source Voltage -100 V VGS Gate-Source Voltage ±20 V ID@TC=25℃ Continuous Drain Current -50 A IDM Pulsed Drain Current -150 A 1 EAS Single Pulse Avalanche Energy 450 mJ PD@TC=25℃ Total Power Dissipation 140 W TSTG Storage Temperature Range -55 to 150 ℃ TJ Operating Junction Temperature Range -55 to 150 ℃ Thermal Data Symbol Parameter RθJA Junction-to-Ambient RθJC Junction-to-Case CA03O1 www.cmosfet.com Typ. Max. Unit --- 25 ℃/W --- 1 ℃/W Page 1 of 2 CMSA5950A P-Channel Enhancement Mode Field Effect Transistor Electrical Characteristics (TJ=25℃ , unless otherwise noted) Symbol Parameter BVDSS Drain-Source Breakdown Voltage RDS(ON) Static Drain-Source On-Resistance VGS(th) Min. Typ. Max. Unit VGS=0V , ID=-250uA Conditions -100 --- --- V VGS=-10V, ID=-10A --- --- 52 VGS=-6V , ID=-8A --- --- 62 Gate Threshold Voltage VGS=VDS , ID =-250uA -2 --- -4 V IDSS Drain-Source Leakage Current VDS=-100V , VGS=0V , TJ=25℃ --- --- -1 uA IGSS Gate-Source Leakage Current VGS = ±20V , VDS=0V --- --- ±100 nA mΩ gfs Forward Transconductance VDS=-10V , ID=-10A --- 21 --- S Rg Gate Resistance VDS=0V , VGS=0V , f=1MHz --- 46 --- Ω Qg Total Gate Charge --- 41 --- Qgs Gate-Source Charge --- 8 --- Qgd Td(on) Tr Td(off) Tf Gate-Drain Charge VDS=-50V , ID=-5A VGS=-10V Turn-On Delay Time --- 9 --- --- 14 --- Rise Time VDD=-50V, VGS=-10V, RG=6Ω --- 40 --- Turn-Off Delay Time ID=-5A --- 100 --- nC ns Fall Time --- 105 --- Ciss Input Capacitance --- 6100 --- Coss Output Capacitance --- 194 --- Crss Reverse Transfer Capacitance --- 13 --- Min. Typ. Max. Unit --- --- -50 A --- --- -150 A --- --- -1.2 V VDS=-50V, VGS=0V , f=1MHz pF Diode Characteristics Symbol Parameter IS Continuous Source Current ISM Pulsed Source Current VSD Diode Forward Voltage Conditions VG=VD=0V , Force Current VGS=0V , IF =-10A Note : 1.The test condition is VDD=30V , VGS=10V , L=1mH , I AS=30A This product has been designed and qualified for the counsumer market. Cmos assumes no liability for customers' product design or applications. Cmos reserver the right to improve product design ,functions and reliability wihtout notice. CA03O1 www.cmosfet.com Page 2 of 2
CMSA5950A 价格&库存
很抱歉,暂时无法提供与“CMSA5950A”相匹配的价格&库存,您可以联系我们找货
