CO75D6-100.000-33JDTSNL
    HCI(杭晶)
    SMD7050_6P
    有源晶振 100MHz ±10ppm 3.3V -40℃~+85℃ LVDS
CO75D6-100.000-33JDTSNL 数据手册
O OSCILLATOR UNIT WITH LVDS OUTPUT IN SMD 7.0X5.0MM S C I L L A T O R U N I T CO75D6 CERAMIC SEAM SEAL PACKAGE. PRODUCT FEATURES PRODUCT PHOTO (NOT IN SCALE)  Small dimensions 7.0x5.0x1.6 with 6 solder pads.  Highly reliable seam sealed ceramic package.  Wide frequency range.  Low jitter and phase noise.  RoHS compliant, LEAD-FREE and HALOGEN-FREE. APPLICATIONS  High speed communication  Telecom equipment  Handheld equipment PRODUCT SPECIFICATIONS CO75D6 PARAMETER Nominal frequency range CONDITIONS / REMARKS 10 ~ 800MHz Supply voltage 2.5VDC Supply current / Fund., Overtone or PLL 3.3VDC Other option possible 100mA Frequency stability ±25ppm Operating temperature range / Maximum, Fund mode lower ICC ±50ppm / ±100ppm –10 to +70°C or –40 to 85°C Output waveform and load LVDS / 100Ω See note below. Other options available. RL between outputs Output voltage level HIGH 1.40V Typical Output voltage level LOW 1.10V Typical Rise and Fall times 1.5ns @ 20~80~20%VCC Symmetry (duty cycle) 45~55% Phase Jitter RMS @ outputs cross point
CO75D6-100.000-33JDTSNL 价格&库存
很抱歉,暂时无法提供与“CO75D6-100.000-33JDTSNL”相匹配的价格&库存,您可以联系我们找货
