CP5.241
CP5.241
    PULS
    AC/DC DIN RAIL SUPPLY 24V 120W
CP5.241 数据手册
CP5.241, CP5.241-C1, CP5.241-S1, CP5.241-S2, CP5.242 24V, 5A, 120W, SINGLE PHASE INPUT CP-Series POWER SUPPLY ▪ ▪ ▪ ▪ ▪ ▪ ▪ ▪ ▪ ▪ ▪ ▪ AC 100-240V Wide-range Input Width only 32mm Efficiency up to 94.3% Excellent Partial Load Efficiency 20% Output Power Reserves (PowerBoost) Easy Fuse Breaking – 3 times nominal current for 12ms Safe HiccupPLUS Overload Mode Active Power Factor Correction (PFC) Minimal Inrush Current Surge Full Power Between -25°C and +60°C DC OK Relay Contact 3 Year Warranty PRODUCT DESCRIPTION SHORT-FORM DATA The Dimension CP-Series are cost optimized power supplies without compromising quality, reliability and performance. The CP-Series is part of the DIMENSION power supply family. Output voltage Adjustment range Output current The CP5.241 power supplies come with three connection terminal options: screw, spring-clamp or push-in terminals, which are optimized for automated wiring. The CP5.241-C1 is equipped with conformal coating preferred for the use in harsh environments and the CP5.242 features an enhanced DC input voltage range. The most outstanding features of these units are the small size, the high efficiency, the electronic inrush current limitation, active PFC and the wide operational temperature range. The devices also offer PowerBoost: Power reserves of 20%, which may even be used continuously at temperatures up to +45°C. Additionally, they can deliver 3 times the nominal output current for 12ms which helps to trip fuses on faulty output branches. High immunity to transients and power surges as well as low electromagnetic emission, a DC OK signal contact for remote monitoring, and a large international approval package for a variety of applications makes this unit suitable for nearly every situation. ORDER NUMBERS Power Supply CP5.241 CP5.241-C1 CP5.241-S1 CP5.241-S2 CP5.242 Accessory ZM10.WALL PowerBoost Input voltage AC Mains frequency Input current AC Power factor Input voltage DC Input current DC AC Inrush current Efficiency Losses Hold-up time Temperature range Size (WxHxD) Weight DC 24V Nominal 24 - 28V Factory setting 24.1V 5.0 – 4.3A Up to +60°C ambient 3.8 – 3.2A At +70°C ambient Derate linearly between +60°C and +70°C 6.0A Up to +45°C ambient Linear decrease to nominal power between +45°C and +60°C AC 100-240V -15%/+10% 50-60Hz ±6% 1.09 / 0.6A At 120 / 230Vac 0.98 / 0.91 At 120 / 230Vac DC 110-150V ±20% For CP5.241 (-xx) DC 110-300V ±20% For CP5.242 1.21 / 0.43A At 110 / 300Vdc 5 / 6Apeak At 120 / 230Vac 93.6 / 94.3% At 120 / 230Vac 8.2 / 7.3W At 120 / 230Vac 35 / 35ms At 120 / 230Vac -25°C to +70°C 32x124x102mm Without DIN rail 440g MAIN APPROVALS Screw terminals Screw terminals and conformal coating Spring-clamp terminals Push-in terminals Screw terminals and enhanced DC input For details and the complete approval list, see chapter 19. UL 61010-2-201 ATEX IECEx Wall/Panel mount bracket Class I Div 2 Oct. 2023 / Rev. 1.4 DS-CP5.241-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 24V, 5A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 1/30 CP5.241, CP5.241-C1, CP5.241-S1, CP5.241-S2, CP5.242 24V, 5A, 120W, SINGLE PHASE INPUT CP-Series INDEX Page 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. Intended Use .....................................................................3 Installation Instructions .....................................................3 AC-Input.............................................................................5 DC-Input ............................................................................6 Input Inrush Current ..........................................................7 Output ...............................................................................8 Hold-up Time ...................................................................10 DC OK Relay Contact ........................................................10 Efficiency and Power Losses ............................................11 Functional Diagram..........................................................12 Front Side and User Elements..........................................12 Connection Terminals ......................................................13 Lifetime Expectancy .........................................................14 MTBF ...............................................................................14 EMC .................................................................................15 Environment ....................................................................16 Safety and Protection Features .......................................17 Dielectric Strength ...........................................................18 Approved, Fulfilled or Tested Standards..........................19 Page 20. Regulatory Product Compliance ......................................20 21. Physical Dimensions and Weight .....................................21 22. Accessories ......................................................................22 22.1. ZM10.WALL - Wall/Panel Mount Bracket ............. 22 22.2. YR2.DIODE - Redundancy Module ........................ 23 22.3. YR20.242 - Redundancy Module .......................... 23 22.4. YR20.246 - Redundancy Module with Automated Load Sharing.......................................................... 23 22.5. UF20.241 Buffer Module ...................................... 24 23. Application Notes ............................................................25 23.1. Peak Current Capability ........................................ 25 23.2. Charging of Batteries ............................................ 26 23.3. Series Operation ................................................... 26 23.4. Parallel Use to Increase Output Power................. 26 23.5. Parallel Use for Redundancy ................................ 27 23.6. Operation on Two Phases..................................... 29 23.7. Use in a Tightly Sealed Enclosure ......................... 29 23.8. Mounting Orientations ......................................... 30 The information given in this document is correct to the best of our knowledge and experience at the time of publication. If not expressly agreed otherwise, this information does not represent a warranty in the legal sense of the word. As the state of our knowledge and experience is constantly changing, the information in this data sheet is subject to revision. We therefore kindly ask you to always use the latest issue of this document (available under www.pulspower.com). No part of this document may be reproduced or utilized in any form without our prior permission in writing. Packaging and packaging aids can and should always be recycled. The product itself may not be disposed of as domestic refuse. TERMINOLOGY AND ABREVIATIONS PE and symbol PE is the abbreviation for Protective Earth and has the same meaning as the symbol . Earth, Ground This document uses the term “earth” which is the same as the U.S. term “ground”. t.b.d. To be defined, value or description will follow later. AC 230V A figure displayed with the AC or DC before the value represents a nominal voltage with standard tolerances (usually ±15%) included. E.g.: DC 12V describes a 12V battery disregarding whether it is full (13.7V) or flat (10V) 230Vac A figure with the unit (Vac) at the end is a momentary figure without any additional tolerances included. 50Hz vs. 60Hz As long as not otherwise stated, AC 230V parameters are valid at 50Hz mains frequency. may A key word indicating flexibility of choice with no implied preference. shall A key word indicating a mandatory requirement. should A key word indicating flexibility of choice with a strongly preferred implementation. Oct. 2023 / Rev. 1.4 DS-CP5.241-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 24V, 5A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 2/30 CP5.241, CP5.241-C1, CP5.241-S1, CP5.241-S2, CP5.242 24V, 5A, 120W, SINGLE PHASE INPUT CP-Series 1. INTENDED USE This device is designed for installation in an enclosure and is intended for commercial use, such as in industrial control, process control, monitoring, measurement, Audio/Video, information or communication equipment or the like. Do not use this device in equipment, where malfunctioning may cause severe personal injury or threaten human life without additional appropriate safety devices, that are suited for the end-application. If this device is used in a manner outside of its specification, the protection provided by the device may be impaired. 2. INSTALLATION INSTRUCTIONS WARNING - Risk of electrical shock, fire, personal injury or death. Turn power off before working on the device and protect against inadvertent re-powering. Do not open, modify or repair the device. Use caution to prevent any foreign objects from entering into the housing. Do not use in wet locations or in areas where moisture or condensation can be expected. Do not touch during power-on, and immediately after power-off. Hot surface may cause burns. Obey the following installation instructions: This device may only be installed and put into operation by qualified personnel. This device does not contain serviceable parts. The tripping of an internal fuse is caused by an internal defect. If damage or malfunction should occur during installation or operation, immediately turn power off and send unit to the factory for inspection. Install device in an enclosure providing protection against electrical, mechanical and fire hazards. Install the device onto a DIN rail according to EN 60715 with the input terminals on the bottom and the output terminals on the top of the device. Other mounting orientations require a reduction in output current. Make sure that the wiring is correct by following all local and national codes. Use appropriate copper cables that are designed for a minimum operating temperature of 60°C for ambient temperatures up to +45°C, 75°C for ambient temperatures up to +60°C and 90°C for ambient temperatures up to +70°C. Ensure that all strands of a stranded wire enter the terminal connection. Use ferrules for wires on the input terminals. Unused screw terminals should be securely tightened. The device is designed for pollution degree 2 areas in controlled environments. No condensation or frost is allowed. The enclosure of the device provides a degree of protection of IP20. The housing does not provide protection against spilled liquids. The isolation of the device is designed to withstand impulse voltages of overvoltage category III according to IEC 60664-1. The device is designed as “Class of Protection I” equipment according to IEC 61140. Do not use without a proper PE (Protective Earth) connection. The device is suitable to be supplied from TN, TT or IT mains networks. The continuous voltage between the input terminal and the PE potential must not exceed 300Vac. The input can also be powered from batteries or similar DC sources. The continuous voltage between the supply voltage and the PE/ground potential must not exceed 360Vdc. A disconnecting means shall be provided for the input of the device. The device is designed for convection cooling and does not require an external fan. Do not obstruct airflow and do not cover ventilation grid! The device is designed for altitudes up to 5000m. Above 2000m a reduction in output current and over voltage category is required. Oct. 2023 / Rev. 1.4 DS-CP5.241-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 24V, 5A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 3/30 CP5.241, CP5.241-C1, CP5.241-S1, CP5.241-S2, CP5.242 24V, 5A, 120W, SINGLE PHASE INPUT CP-Series Keep the following minimum installation clearances: 40mm on top, 20mm on the bottom, 5mm left and right side. Increase the 5mm to 15mm in case the adjacent device is a heat source. When the device is permanently loaded with less than 50%, the 5mm can be reduced to zero. The device is designed, tested and approved for branch circuits up to 32A (IEC) and 30A (UL) without additional protection device. If an external fuse is utilized, do not use circuit breakers smaller than 6A B- or C-Characteristic to avoid a nuisance tripping of the circuit breaker. The maximum surrounding air temperature is +70°C. The operational temperature is the same as the ambient or surrounding air temperature and is defined 2cm below the device. The device is designed to operate in areas between 5% and 95% relative humidity. (Except CP5.242) Installation Instructions for Hazardous Location Areas The device is suitable for use in Class I Division 2 Groups A, B, C, D locations and for use in Group II Category 3 (Zone 2) environments. Classification: ATEX: EPS 19 ATEX 1 201 X, II 3G Ex ec nC IIC T4 Gc / IECEx EPS 19.0078X WARNING EXPLOSION HAZARDS! Installation in standard mounting orientation with the input terminals on the bottom of the unit. For non-standard mounting orientations a reduction of output current is required. Do not disconnect the device or operate the voltage adjustment unless power has been switched off or the area is known to be nonhazardous. A suitable enclosure must be provided for the end product which has a minimum protection of IP54 and fulfils the requirements of the EN 60079-0. Oct. 2023 / Rev. 1.4 DS-CP5.241-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 24V, 5A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 4/30 CP5.241, CP5.241-C1, CP5.241-S1, CP5.241-S2, CP5.242 24V, 5A, 120W, SINGLE PHASE INPUT CP-Series 3. AC-INPUT The device is suitable to be supplied from TN, TT or IT mains networks with AC voltage. For suitable DC supply voltages see chapter 4. Nom. Allowed voltage L or N to earth Max. AC 100-240V 85-264Vac 264-300Vac 300Vac Input frequency Turn-on voltage Shut-down voltage Nom. Typ. Typ. 50–60Hz 80Vac 74Vac External input protection See recommendations in chapter 2. Input current Power factor Crest factor Typ. Typ. Typ. AC 100V 1.30A 0.99 1.7 AC 120V 1.09A 0.98 1.8 AC 230V 0.60A 0.91 2.2 Start-up delay Rise time Typ. Typ. 420ms 80ms 380ms 80ms 385ms 80ms Typ. 100ms 100ms 110ms Max. 200mV 200mV 200mV Turn-on overshoot Occasionally for maximal 500ms Continuous, according to IEC 60664-1 ±6% Steady-state value, see Fig. 3-1 Steady-state value, see Fig. 3-1 Fig. 3-1 Input voltage range Rated input range Fig. 3-2 Turn-on behavior, definitions Input Voltage max. 500ms Turn-on Shut -dow n POUT VIN Start-up delay 264V 300Vac Fig. 3-3 Input current vs. output current at 24V output voltage (a) 1.25 (b) 0.75 Rise Time Fig. 3-4 Power factor vs. output current at 24V output voltage Power Factor, typ. Input Current, typ. 1.5A 1.0 - 5% Output Voltage 85V At 24V, 5A, see Fig. 3-3 At 24V, 5A, see Fig. 3-4 At 24V, 5A, The crest factor is the mathematical ratio of the peak value to RMS value of the input current waveform. See Fig. 3-2 At 24V, 5A const. current load, 0mF load capacitance, see Fig. 3-2 At 24V, 5A const. current load, 5mF load capacitance,, see Fig. 3-2 See Fig. 3-2 a) 100Vac b) 120Vac c) 230Vac 1.0 0.95 (a) (b) 0.9 (c) 0.5 0.85 0.25 0.8 (a) 100Vac, (b) 120Vac, (c) 230Vac Output Current (c) Output Current 0 0.5 1 Overshoot AC input AC input range 2 3 4 5 6A 0.75 1 2 3 4 5 Oct. 2023 / Rev. 1.4 DS-CP5.241-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 24V, 5A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 6A 5/30 CP5.241, CP5.241-C1, CP5.241-S1, CP5.241-S2, CP5.242 24V, 5A, 120W, SINGLE PHASE INPUT CP-Series 4. DC-INPUT The device is suitable to be supplied from a DC input voltage. Use a battery or a similar DC source. A supply from the intermediate DCbus of a frequency converter is not recommended and can cause a malfunction or damage the unit. Connect +pole to L, –pole to N and the PE terminal to an earth wire or to the machine ground. DC input Nom. DC 110-150V 88-180Vdc 88-360Vdc ±20% For CP5.241, CP5.241-C1, CP5.241-S1, CP5.241-S2 ±20% For CP5.242 For CP5.241, CP5.241-C1, CP5.241-S1, CP5.241-S2 For CP5.242 Nom. DC 110-300V Typ. Typ. Max. 1.21A 0.43A 360Vdc At 110Vdc, at 24V, 5A At 300Vdc, at 24V, 5A Continuous, according to IEC 60664-1 Typ. Typ. 74Vdc 67Vdc Steady state value Steady state value DC input range DC input current Allowed Voltage (+) or (-) input to Earth Turn-on voltage Shut-down voltage Fig. 4-1 Wiring for DC Input Battery + Power Supply AC L N PE - + Load DC Oct. 2023 / Rev. 1.4 DS-CP5.241-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 24V, 5A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 6/30 CP5.241, CP5.241-C1, CP5.241-S1, CP5.241-S2, CP5.242 24V, 5A, 120W, SINGLE PHASE INPUT CP-Series 5. INPUT INRUSH CURRENT An active inrush limitation circuit (NTCs, which are bypassed by a relay contact) limits the input inrush current after turn-on of the input voltage. The charging current into EMI suppression capacitors is disregarded in the first microseconds after switch-on. Inrush current AC 100V 8Apeak 5Apeak 5Apeak 0.4A²s Max. Typ. Typ. Max. Inrush energy Fig. 5-1 Typical turn-on behaviour at nominal load, 120Vac input and 25°C ambient Input current 2A/DIV 50ms/DIV Input voltage 200V/DIV Output voltage 4A AC 120V 7Apeak 4Apeak 5Apeak 0.5A²s AC 230V 7Apeak 4Apeak 6Apeak 1A²s At 40°C, cold start At 25°C, cold start At 40°C, cold start At 40°C, cold start Fig. 5-2 Typical turn-on behaviour at nominal load, 230Vac input and 25°C ambient Input current 2A/DIV 4A 50ms/DIV Input voltage 200V/DIV Output voltage Oct. 2023 / Rev. 1.4 DS-CP5.241-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 24V, 5A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 7/30 CP5.241, CP5.241-C1, CP5.241-S1, CP5.241-S2, CP5.242 24V, 5A, 120W, SINGLE PHASE INPUT CP-Series 6. OUTPUT The output provides a SELV/PELV rated voltage, which is galvanically isolated from the input voltage. The output is designed to supply any kind of loads, including capacitive and inductive loads. If extreme large capacitors, such as EDLCs (electric double layer capacitors or “UltraCaps”) with a capacitance > 0.3F are connected to the output, the unit might charge the capacitor in an intermittent mode. The output is electronically protected against overload, no-load and short-circuits. In case of a protection event, audible noise may occur. Output voltage Adjustment range Max. 24V 24-28V 30.0V Factory settings Line regulation Load regulation Ripple and noise voltage Typ. Max. Max. Max. Max. 24.1V 10mV 50mV 50mVpp 200mVpp Output current Nom. 5A At 24V and up to +60°C ambient temperature Nom. 3.8A At 24V and +70°C ambient temperature Nom. 4.3A At 28V and up to +60°C ambient temperature Nom. 3.2A At 28V and +70°C ambient temperature Derate linearly between +60°C and +70°C, see chapter 16 Nom. 6A At 24V and up to +45°C ambient temperature Nom. 5.1A At 28V and up to +45°C ambient temperature PowerBoost decreases linearly to nominal power between +45°C and +60°C, see chapter 16 PowerBoost1) Nom. Guaranteed value This is the maximum output voltage which can occur at the clockwise end position of the potentiometer due to tolerances. It is not a guaranteed value which can be achieved. ±0.2%, at full load and cold unit Between 85 and 300Vac Between 0A and 6A, static value, see Fig. 6-1 Load >0.2A, Bandwidth 20Hz to 20MHz, 50Ohm Load 1...4ms closed 0.9* VADJ 100ms open closed Oct. 2023 / Rev. 1.4 DS-CP5.241-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 24V, 5A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 10/30 CP5.241, CP5.241-C1, CP5.241-S1, CP5.241-S2, CP5.242 24V, 5A, 120W, SINGLE PHASE INPUT CP-Series 9. EFFICIENCY AND POWER LOSSES Efficiency Average efficiency*) Power losses *) Typ. Typ. Typ. AC 100V 92.9% 92.7% 91.3% AC 120V 93.6% 93.5% 91.7% AC 230V 94.3% 94.5% 92.0% Typ. Typ. Typ. Typ. 1.3W 4.6W 9.2W 11.3W 1.3W 4.4W 8.2W 9.8W 1.4W 4.1W 7.3W 8.4W At 24V, 5A At 24V, 6A (PowerBoost) 25% at 1.25A, 25% at 2.5A, 25% at 3.75A. 25% at 5A At 24V, 0A At 24V, 2.5A At 24V, 5A At 24V, 6A (PowerBoost) The average efficiency is an assumption for a typical application where the power supply is loaded with 25% of the nominal load for 25% of the time, 50% of the nominal load for another 25% of the time, 75% of the nominal load for another 25% of the time and with 100% of the nominal load for the rest of the time. Fig. 9-1 Efficiency vs. output current at 24V, typ. Fig. 9-2 Losses vs. output current at 24V, typ. Efficiency Power Losses 95% 94 93 92 91 90 89 88 87 (c) (b) (a) 12W (a) (a) 100Vac (b) 120Vac (c) 230Vac 10 (b) (c) 8 6 (a) 100Vac (b) 120Vac (c) 230Vac 4 2 Output Current 1 2 3 4 5 Output Current 0 0 6A 1 2 3 4 5 Fig. 9-3 Efficiency vs. input voltage at 24V, 5A, typ. Fig. 9-4 Losses vs. input voltage at 24V, 5A, typ. Efficiency Power Losses 95% 11W 94 10 93 9 92 8 91 7 6A 6 90 Input Voltage 89 100 120 180 Input Voltage 5 230 264Vac 100 120 180 230 264Vac Oct. 2023 / Rev. 1.4 DS-CP5.241-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 24V, 5A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 11/30 CP5.241, CP5.241-C1, CP5.241-S1, CP5.241-S2, CP5.242 24V, 5A, 120W, SINGLE PHASE INPUT CP-Series 10. FUNCTIONAL DIAGRAM Fig. 10-1 Functional diagram L N Input Fuse Input Filter Input Rectifier Inrush Current Limiter Power Converter PFC Converter Output Filter Output Voltage Regulator Temperature Shutdown Output OverVoltage Protection Output Power Manager + + VOUT DC-ok LED Output Voltage Monitor DC-ok Relay DC-ok Contact 11. FRONT SIDE AND USER ELEMENTS Fig. 11-1 Front side CP5.241, CP5.241-C1 CP5.241-S1 CP5.241-S2 CP5.242 A Input Terminals N, L Line input PE (Protective Earth) input B Output Terminals Two identical + poles and two identical - poles + Positive output – Negative output (return) C Output Voltage Potentiometer D DC OK LED (green) On, when the output voltage is >90% of the adjusted output voltage E DC OK Relay Contact The DC OK relay contact is synchronized with the DC OK LED. See chapter 8 for details. Oct. 2023 / Rev. 1.4 DS-CP5.241-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 24V, 5A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 12/30 CP5.241, CP5.241-C1, CP5.241-S1, CP5.241-S2, CP5.242 24V, 5A, 120W, SINGLE PHASE INPUT CP-Series 12. CONNECTION TERMINALS The terminals are IP20 Finger safe constructed and suitable for field- and factory wiring. CP5.241, CP5.241-C1, CP5.242 Type Solid wire Stranded wire American Wire Gauge Max. wire diameter (including ferrules) Recommended tightening torque Wire stripping length Screwdriver Input Screw terminal Max. 6mm2 Max. 4mm2 AWG 20-10 2.8mm Max. 1Nm 7mm 3.5mm slotted or crosshead No 2 Output Screw terminal Max. 6mm2 Max. 4mm2 AWG 20-10 2.8mm Max. 1Nm 7mm 3.5mm slotted or crosshead No 2 CP5.241-S1 Type Input Quick-connect spring-clamp terminal Max. 6mm2 Max. 4mm2 AWG 20-10 2.8mm 10mm - Output Quick-connect springclamp terminal Max. 6mm2 Max. 4mm2 AWG 20-10 2.8mm 10mm - Input Push-in terminal Max. 2.5mm2 Max. 2.5mm2 Max. 1.5mm2 AWG 24-12 2.3mm 10mm 3.0mm slotted to open the spring Output Push-in terminal Max. 2.5mm2 Max. 2.5mm2 Max. 1.5mm2 AWG 24-12 2.3mm 10mm 3.0mm slotted to open the spring Solid wire Stranded wire American Wire Gauge Max. wire diameter (including ferrules) Wire stripping length Screwdriver CP5.241-S2 Type Solid wire Stranded wire Stranded wire with ferrules American Wire Gauge Max. wire diameter (including ferrules) Wire stripping length Screwdriver DC OK-Signal Push-in terminal Max. 1.5mm2 Max. 1.5mm2 AWG 24-16 1.6mm 7mm 3mm slotted to open the spring DC OK-Signal Push-in terminal Max. 1.5mm2 Max. 1.5mm2 AWG 24-16 1.6mm 7mm 3mm slotted to open the spring DC OK-Signal Push-in terminal Max. 1.5mm2 Max. 1.5mm2 Max. 1.5mm2 AWG 24-16 1.6mm 7mm 3mm slotted to open the spring Daisy chaining: Daisy chaining (jumping from one power supply output to the next) is allowed as long as the average output current through one terminal pin does not exceed 25A or 15A for the CP5.241-S2. If the current is higher, use a separate distribution terminal block as shown in Fig. 12-2. Fig. 12-1 Daisy chaining of outputs Power Supply + + - - Output Fig. 12-2 Using distribution terminals Distribution Terminals Power Supply + + - - Output Load + - Power Supply + + - - Power Supply + + Output - - Output Load + - Maximal 15A continuous for CP5.241-S2 Maximal 25A continuous for all other units Oct. 2023 / Rev. 1.4 DS-CP5.241-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 24V, 5A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 13/30 CP5.241, CP5.241-C1, CP5.241-S1, CP5.241-S2, CP5.242 24V, 5A, 120W, SINGLE PHASE INPUT CP-Series 13. LIFETIME EXPECTANCY The Lifetime expectancy shown in the table indicates the minimum operating hours (service life) and is determined by the lifetime expectancy of the built-in electrolytic capacitors. Lifetime expectancy is specified in operational hours and is calculated according to the capacitor’s manufacturer specification. The manufacturer of the electrolytic capacitors only guarantees a maximum life of up to 15 years (131 400h). Any number exceeding this value is a calculated theoretical lifetime which can be used to compare devices. Lifetime expectancy AC 100V 265 000h 748 000h 128 000h 363 000h 81 000h 228 000h AC 120V 270 000h 764 000h 143 000h 405 000h 96 000h 271 000h AC 230V 274 000h 775 000h 166 000h 469 000h 119 000h 336 000h At 24V, 2.5A and 40°C At 24V, 2.5A and 25°C At 24V, 5A and 40°C At 24V, 5A and 25°C At 24V, 6A and 40°C At 24V, 6A and 25°C 14. MTBF MTBF stands for Mean Time Between Failure, which is calculated according to statistical device failures, and indicates reliability of a device. It is the statistical representation of the likelihood of a unit to fail and does not necessarily represent the life of a product. The MTBF figure is a statistical representation of the likelihood of a device to fail. A MTBF figure of e.g. 1 000 000h means that statistically one unit will fail every 100 hours if 10 000 units are installed in the field. However, it cannot be determined if the failed unit has been running for 50 000h or only for 100h. For these types of units the MTTF (Mean Time To Failure) value is the same value as the MTBF value. MTBF SN 29500, IEC 61709 MTBF MIL HDBK 217F AC 100V 800 000h 1 402 000h 339 000h AC 120V 807 000h 1 414 000h 343 000h AC 230V 867 000h 1 510 000h 368 000h 490 000h 496 000h 529 000h 81 000h 83 000h 89 000h 109 000h 111 000h 119 000h At 24V, 5A and 40°C At 24V, 5A and 25°C At 24V, 5A and 40°C; Ground Benign GB40 At 24V, 5A and 25°C; Ground Benign GB25 At 24V, 5A and 40°C; Ground Fixed GF40 At 24V, 5A and 25°C; Ground Fixed GF25 Oct. 2023 / Rev. 1.4 DS-CP5.241-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 24V, 5A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 14/30 CP5.241, CP5.241-C1, CP5.241-S1, CP5.241-S2, CP5.242 24V, 5A, 120W, SINGLE PHASE INPUT CP-Series 15. EMC The EMC behavior of the device is designed for applications in industrial environment as well as in residential, commercial and light industry environments. The device is investigated according to EN 61000-6-1, EN 61000-6-2, EN 61000-6-3 and EN 61000-6-4. EMC Immunity Electrostatic discharge EN 61000-4-2 Electromagnetic RF field Fast transients (Burst) EN 61000-4-3 EN 61000-4-4 Surge voltage on input EN 61000-4-5 Surge voltage on output EN 61000-4-5 Surge voltage on DC OK Conducted disturbance Mains voltage dips EN 61000-4-5 EN 61000-4-6 EN 61000-4-11 Voltage interruptions Powerful transients EN 61000-4-11 VDE 0160 Contact discharge Air discharge 80MHz-2.7GHz Input lines Output lines DC OK signal (coupling clamp) L→N L → PE, N → PE +→+ / - → PE DC OK signal → PE 0.15-80MHz 0% of 100Vac 40% of 100Vac 70% of 100Vac 0% of 200Vac 40% of 200Vac 40% of 200Vac 70% of 200Vac 0% of 200Vac (=0V) Over entire load range 8kV 15kV 20V/m 4kV 2kV 2kV 2kV 4kV 1kV 2kV 1kV 20V 0Vac, 20ms 40Vac, 200ms 70Vac, 500ms 0Vac, 20ms 80Vac, 200ms, 4A 140Vac, 500ms 5000ms 750V, 0.3ms Criterion A Criterion A Criterion A Criterion A Criterion A Criterion A Criterion A Criterion A Criterion A Criterion A Criterion A Criterion A Criterion A Criterion C Criterion A Criterion A Criterion A Criterion C Criterion A Criterion C Criterion A Performance criterions: A: The device shows normal operation behavior within the defined limits. C: Temporary loss of function is possible. The device may shut-down and restarts by itself. No damage or hazards for the device will occur. EMC Emission Conducted emission input lines Conducted emission output lines Radiated emission Harmonic input current (PFC) Voltage fluctuations, flicker EN 55011, EN 55032, FCC Part 15, CISPR 11, CISPR 32 Class B IEC/CISPR 16-1-2, IEC/CISPR 16-2-1 Limits for local DC power networks fulfilled Class B Fulfilled for Class A equipment Fulfilled, tested with constant current loads, non pulsing EN 55011, EN 55032 EN 61000-3-2 EN 61000-3-3 This device complies with FCC Part 15 rules. Operation is subjected to following two conditions: (1) this device may not cause harmful interference, and (2) this device must accept any interference received, including interference that may cause undesired operation. Switching Frequencies PFC converter Main converter Auxiliary converter 30kHz to 140kHz 60kHz to 140kHz 30kHz to 60kHz Input voltage and output load dependent Output load dependent Output load dependent Oct. 2023 / Rev. 1.4 DS-CP5.241-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 24V, 5A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 15/30 CP5.241, CP5.241-C1, CP5.241-S1, CP5.241-S2, CP5.242 24V, 5A, 120W, SINGLE PHASE INPUT CP-Series 16. ENVIRONMENT Operational temperature -25°C to +70°C Storage temperature -40°C to +85°C Output derating 3W/K Between +60°C and +70°C 0.33A/1000m or 5K/1000m For altitudes >2000m, see Fig. 16-2 The derating is not hardware controlled. The user has to take this into consideration to stay below the derated current limits in order not to overload the unit. 5 to 95% r.h. According to IEC 60068-2-30 110-54kPa See Fig. 16-2 for details Up to 5000m See Fig. 16-2 for details III According to IEC 60664-1 for altitudes up to 2000m II According to IEC 60664-1, for altitudes above 2000m 2 According to IEC 62477-1, not conductive 2-17.8Hz: ±1.6mm; According to IEC 60068-2-6 17.8-500Hz: 2g 2 hours / axis 30g 6ms, 20g 11ms According to IEC 60068-2-27 3 bumps per direction, 18 bumps in total Shock and vibration is tested in combination with DIN rails according to EN 60715 with a height of 15mm and a thickness of 1.3mm and standard orientation. Some audible noise may be emitted from the power supply during no load, overload or short circuit. Humidity Atmospheric pressure Altitude Over-voltage category Degree of pollution Vibration sinusoidal Shock Audible noise Operational temperature is the same as the ambient or surrounding temperature and is defined as the air temperature 2cm below the unit. For storage and transportation Fig. 16-1 Output current vs. ambient temp. (Inom 5A; Iout with PowerBoost = 6A) Fig. 16-2 Output current vs. altitude Allowed Output Current at 24V Allowed Output Current at 24V 6A B 6A C B 5A 5A A 3.8A A... Tamb < 60°C B... Tamb < 45°C C... Short term A... 85 to 264Vac, continuous B... short term 0 -25 0 45 A 4A 60 70°C Ambient Temperature Altitude 0m AP*) 110kPa 2000m 80kPa 5000m 54kPa *) Atmospheric pressure Oct. 2023 / Rev. 1.4 DS-CP5.241-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 24V, 5A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 16/30 CP5.241, CP5.241-C1, CP5.241-S1, CP5.241-S2, CP5.242 24V, 5A, 120W, SINGLE PHASE INPUT CP-Series 17. SAFETY AND PROTECTION FEATURES Isolation resistance Min. 500MOhm Min. 500MOhm Min. 500MOhm Min. 500MOhm PE resistance Max. 0.1Ohm Output over-voltage protection Typ. Max. 30.5Vdc 32.0Vdc In case of an internal defect, a redundant circuit limits the maximum output voltage. The output shuts down and performs three restart attempts. If the failure continues, the output shuts down. Cycle input power to reset. I According to IEC 61140 A PE (Protective Earth) connection is required IP 20 According to EN/IEC 60529 Included Output shut-down with automatic restart. Temperature sensors are installed on critical components inside the unit and turn the unit off in safety critical situations, which can happen e.g. when ambient temperature is too high, ventilation is obstructed or the derating requirements are not followed. There is no correlation between the operating temperature and turn-off temperature since this is dependent on input voltage, load and installation methods. MOV (Metal Oxide For protection values see chapter 15 (EMC). Varistor) Included Not user replaceable slow-blow high-braking capacity fuse 0.10mA / 0.27mA At 100Vac, 50Hz, TN-,TT-mains / IT-mains 0.13mA / 0.38mA At 120Vac, 60Hz, TN-,TT-mains / IT-mains 0.20mA / 0.60mA At 230Vac, 50Hz, TN-,TT-mains / IT-mains 0.13mA / 0.35mA At 110Vac, 50Hz, TN-,TT-mains / IT-mains 0.17mA / 0.51mA At 132Vac, 60Hz, TN-,TT-mains / IT-mains 0.27mA / 0.81mA At 264Vac, 50Hz, TN-,TT-mains / IT-mains Class of protection Degree of protection Over-temperature protection Input transient protection Internal input fuse Touch current (leakage current) Typ. Typ. Typ. Max. Max. Max. At delivered condition between input and output, measured with 500Vdc At delivered condition between input and PE, measured with 500Vdc At delivered condition between output and PE, measured with 500Vdc At delivered condition between output and DC OK contacts, measured with 500Vdc Resistance between PE terminal and the housing in the area of the DIN rail mounting bracket. Oct. 2023 / Rev. 1.4 DS-CP5.241-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 24V, 5A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 17/30 CP5.241, CP5.241-C1, CP5.241-S1, CP5.241-S2, CP5.242 24V, 5A, 120W, SINGLE PHASE INPUT CP-Series 18. DIELECTRIC STRENGTH The output voltage is floating and has no ohmic connection to the ground. The output is insulated to the input by a double or reinforced insulation. Type and routine tests are conducted by the manufacturer. Field tests may be conducted in the field using the appropriate test equipment which applies the voltage with a slow ramp (2s up and 2s down). Connect all input-terminals together as well as all output poles before conducting the test. When testing, set the cut-off current settings to the value in the table below. We recommend that either the + pole or the – pole shall be connected to the protective earth system. This helps to avoid situations in which a load starts unexpectedly or can not be switched off when unnoticed earth faults occur. Type test 60s A 2500Vac B 3000Vac C 1000Vac D 500Vac Routine test 5s 2500Vac 2500Vac 500Vac 500Vac 2000Vac > 10mA 2000Vac > 10mA 500Vac > 20mA 500Vac > 1mA Fig. 18-1 Dielectric strength Input DC-ok B*) L N B A Field test 5s Field test cut-off current settings D Output Earth, PE C + - B*) When testing input to DC OK ensure that the maximal voltage between DC OK and the output is not exceeded (column D). We recommend connecting DC OK pins and the output pins together when performing the test. Oct. 2023 / Rev. 1.4 DS-CP5.241-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 24V, 5A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 18/30 CP5.241, CP5.241-C1, CP5.241-S1, CP5.241-S2, CP5.242 24V, 5A, 120W, SINGLE PHASE INPUT CP-Series 19. APPROVED, FULFILLED OR TESTED STANDARDS IEC 61010-2-201 CB Scheme Certificate Electrical Equipment for Measurement, Control and Laboratory Use - Particular requirements for control equipment UL 61010-2-201 UL Certificate Listed equipment for category NMTR - Electrical Equipment for Measurement, Control and Laboratory Use - Particular requirements for control equipment Applicable for US and Canada E-File: E198865 CB Scheme Certificate IEC 62368-1 Audio/video, information and communication technology equipment - Safety requirements Output safety level: ES1 IEC 62368 ATEX (except CP5.242) Agency Certificate (Bureau Veritas) EN 60079-0 Explosive atmospheres - General requirements EN 60079-7, EN 60079-15 Equipment protection by type of protection "e" and "n" Certificate: EPS 19 ATEX 1 201 X Temperature Code: T4 Type of Protection: ec nC IECEx (except CP5.242) IECEx Certificate IEC 60079-0 Explosive atmospheres - General requirements IEC 60079-7, IEC 60079-15 Equipment protection by type of protection "e" and "n" Certificate: IECEx EPS 19.0078X Temperature Code: T4 Type of Protection: ec nC Class I Div 2 (except CP5.242) UL Certificate Listed equipment for category NRAD - Listed equipment Industrial Control Equipment for Use in Hazardous Locations Applicable for US and Canada E-File: E327416 Temperature Code: T4 Groups: A, B, C and D IEC 61558-2-16 Test Certificate Safety of transformers, reactors, power supply units and similar products for supply voltages up to 1100 V Particular requirements and tests for switch mode power supply units and transformers for switch mode power supply units Test Report Voltage Sag Immunity for Semiconductor Processing Equipment Tested for AC 208V L-L or L-N mains voltages, nominal output voltage and nominal output load Paint Wetting Impairment Substances Test (or LABS-Test) Tested for Zone 2 and test class C1 according to VDMA 24364-C1-L/W for solvents and water-based paints SEMI F47 VDMA 24364 Oct. 2023 / Rev. 1.4 DS-CP5.241-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 24V, 5A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 19/30 CP5.241, CP5.241-C1, CP5.241-S1, CP5.241-S2, CP5.242 24V, 5A, 120W, SINGLE PHASE INPUT CP-Series 20. REGULATORY PRODUCT COMPLIANCE EU Declaration of Conformity The CE mark indicates conformance with the - EMC directive - Low-voltage directive - RoHS directive REACH Regulation (EU) Manufacturer's Declaration EU regulation regarding the Registration, Evaluation, Authorisation and Restriction of Chemicals (REACH) fulfilled. EU Regulation (EC) 1907/2006. WEEE Regulation Manufacturer's Declaration EU Regulation on Waste Electrical and Electronic Equipment Registered as business to business (B2B) products. EU Regulation 2012/19/EU KC KC Korean Certification Korean - Registration of Broadcasting and Communication Equipment Registered under Clause3, Article 58-2 of Radio Waves Act. Registration No. R-R-PUG-CP5_241. (except CP5.241-S2) CCC CCC Certificate China Compulsory Certification (CNCA-C23-01:2019) Certificate for devices made in Suzhou/China (PULS Electronics): 2021122303114443 Certificate for devices made in Chomutov/Czech Republic (PULS investiční): 2021122303114444 CCC-Ex UKCA UKCA Declaration of Conformity Trade conformity assessment for England, Scotland and Wales The UKCA mark indicates conformity with the UK Statutory Instruments 2016 No.1091, 2016 No.1107 (CP5.241, CP5.241-C1, CP5.241-S1, CP5.241-S1) 2016 No.1101 (CP5.242) 2012 No.3032 Oct. 2023 / Rev. 1.4 DS-CP5.241-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 24V, 5A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 20/30 CP5.241, CP5.241-C1, CP5.241-S1, CP5.241-S2, CP5.242 24V, 5A, 120W, SINGLE PHASE INPUT CP-Series 21. PHYSICAL DIMENSIONS AND WEIGHT Width Height Depth Weight DIN rail Housing material Installation clearances Penetration protection CP5.241, CP5.241-C1, CP5.242 32mm 124mm 102mm The DIN rail depth must be added to the unit depth to calculate the total required installation depth. 440g Use 35mm DIN rails according to EN 60715 or EN 50022 with a height of 7.5 or 15mm. Body: Aluminium alloy Cover: Zinc-plated steel See chapter 2 Small parts like screws, nuts, etc. with a diameter larger than 3.5mm Fig. 21-1 Front view CP5.241-S1 CP5.241-S2 All dimensions in mm Fig. 21-2 Side view All dimensions in mm Oct. 2023 / Rev. 1.4 DS-CP5.241-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 24V, 5A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 21/30 CP5.241, CP5.241-C1, CP5.241-S1, CP5.241-S2, CP5.242 24V, 5A, 120W, SINGLE PHASE INPUT CP-Series 22. ACCESSORIES 22.1. ZM10.WALL - WALL/PANEL MOUNT BRACKET This bracket is used to mount the devices on a wall/panel without utilizing a DIN rail. The bracket can be mounted without detaching the DIN rail brackets. Fig. 22-1 Isometric view Fig. 22-4 Wall/panel mounting, front view Fig. 22-2 Isometric view- Fig. 22-3 Isometric view Fig. 22-5 Hole pattern for wall mounting Fig. 22-6 Wall/panel mounting, side view Oct. 2023 / Rev. 1.4 DS-CP5.241-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 24V, 5A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 22/30 CP5.241, CP5.241-C1, CP5.241-S1, CP5.241-S2, CP5.242 24V, 5A, 120W, SINGLE PHASE INPUT CP-Series 22.2. YR2.DIODE - REDUNDANCY MODULE The YR2.DIODE is a dual redundancy module, which can be used to build 1+1 or N+1 redundant systems. The device is equipped with two 10A nominal input channels, which are individually decoupled by utilizing diode technology. The output can be loaded with a nominal 20A continuous current. The device does not require an additional auxiliary voltage and is self-powered even in case of a short circuit across the output. For a safe and vibration resistant wiring, the device is equipped with time saving quick connect spring clamp terminals. The unit is very narrow and only requires 32mm width on the DIN rail. See chapter 23.5 for wiring information. 22.3. YR20.242 - REDUNDANCY MODULE The YR20.242 is a dual redundancy module, which can be used to build 1+1 or N+1 redundant systems. The device is equipped with two input channels, each rated for 20A for ambient temperatures up to +70°C and are individually decoupled by utilizing MOSFET technology. The inputs can also be operated up to 24A when the ambient temperature does not exceed +45°C. The output can be loaded with nominal 20A at +70°C or 24A at 45°C continuous current. Using MOSFETSs instead of diodes reduces heat generation, losses and voltage drop between input and output. Due to these advantages, the unit is very narrow and only requires 32mm width on the DIN rail. The device does not require an additional auxiliary voltage and is self-powered even in case of a short circuit across the output. See chapter 23.5 for wiring information. 22.4. YR20.246 - REDUNDANCY MODULE WITH AUTOMATED LOAD SHARING The YR20.246 is a dual redundancy module, which can be used to build 1+1 redundant systems. The device is equipped with two input channels, each rated for 10A for ambient temperatures up to +70°C and are individually decoupled by utilizing MOSFET technology. The inputs can also be operated up to 12A when the ambient temperature does not exceed +45°C. The output can be loaded with nominal 20A at +70°C or 24A at 45°C continuous current. Using MOSFETSs instead of diodes reduces heat generation, losses and voltage drop between input and output. Due to these advantages, the unit is very narrow and only requires 32mm width on the DIN rail. The device does not require an additional auxiliary voltage and is self-powered even in case of a short circuit across the output. The device is equipped with an automated load sharing feature, which balances the load current between the two input channels. It also monitors the function of the redundancy circuitry and provides a signal if the output current is too high, which could prevent redundancy if one power supply fails. The signal also reports too low or too high input voltages. See chapter 23.5 for wiring information. Oct. 2023 / Rev. 1.4 DS-CP5.241-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 24V, 5A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 23/30 CP5.241, CP5.241-C1, CP5.241-S1, CP5.241-S2, CP5.242 24V, 5A, 120W, SINGLE PHASE INPUT CP-Series 22.5. UF20.241 BUFFER MODULE The UF20.241 buffer module is a supplementary device for DC 24V power supplies. It delivers power to bridge typical mains failures or extends the hold-up time after the AC power is turned off. When the power supply provides a sufficient voltage, the buffer module stores energy in the integrated electrolytic capacitors. When the mains voltage is lost, the stored energy is released to the DC-bus in a regulated process. The buffer module can be added in parallel to the load circuit at any given point and does not require any control wiring. One buffer module can deliver 20A additional current and can be added in parallel to increase the output ampacity or the hold-up time. Oct. 2023 / Rev. 1.4 DS-CP5.241-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 24V, 5A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 24/30 CP5.241, CP5.241-C1, CP5.241-S1, CP5.241-S2, CP5.242 24V, 5A, 120W, SINGLE PHASE INPUT CP-Series 23. APPLICATION NOTES 23.1. PEAK CURRENT CAPABILITY The unit can deliver peak currents (up to several milliseconds) which are higher than the specified short term currents. This helps to start current demanding loads. Solenoids, contactors and pneumatic modules often have a steady state coil and a pick-up coil. The inrush current demand of the pick-up coil is several times higher than the steady-state current and usually exceeds the nominal output current. The same situation applies when starting a capacitive load. The peak current capability also ensures the safe operation of subsequent circuit breakers of load circuits. The load branches are often individually protected with circuit breakers or fuses. In case of a short or an overload in one branch circuit, the fuse or circuit breaker need a certain amount of over-current to open in a timely manner. This avoids voltage loss in adjacent circuits. The extra current (peak current) is supplied by the power converter and the built-in large sized output capacitors of the power supply. The capacitors get discharged during such an event, which causes a voltage dip on the output. The following three examples show typical voltage dips for resistive loads: Fig. 23-1 10Apeak current for 50ms , typ. (2x the nominal current) Fig. 23-2 25Apeak current for 5ms , typ. (5x the nominal current) Output Voltage 24V Output Voltage 24V 25A 14V 16V 10A Output Current 0A 1ms/DIV 0A 10ms/DIV Output Current Fig. 23-3 15Apeak current for 12ms , typ. (3x the nominal current) 24V 15A Output Voltage 10.5V 12ms 0A Output Current 10ms/DIV Peak current voltage dips Please note: The DC OK relay triggers when the voltage dips more than 10% for longer than 1ms. Typically from 24V to 16V Typically from 24V to 16.5V Typically from 24V to 14V At 10A for 50ms and resistive load At 25A for 2ms and resistive load At 25A for 5ms and resistive load Oct. 2023 / Rev. 1.4 DS-CP5.241-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 24V, 5A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 25/30 CP5.241, CP5.241-C1, CP5.241-S1, CP5.241-S2, CP5.242 24V, 5A, 120W, SINGLE PHASE INPUT CP-Series 23.2. CHARGING OF BATTERIES The power supply can be used to charge lead-acid or maintenance free batteries. Two 12V SLA or VRLA batteries are needed in series connection. Instructions for charging batteries: a) Use only matched batteries when putting 12V types in series. b) Ensure that the ambient temperature of the power supply stays below 40°C for mains voltage of AC 120V or higher and 35°C for a mains voltage of AC 100V. c) Use a 10A circuit breaker or a blocking diode between the power supply and the battery. d) Ensure that the output current of the power supply is below the allowed charging current of the battery. e) The return current to the power supply is typically 8mA. This return current can discharge the battery when the power supply is switched off except in case a blocking diode is utilized. f) Set the output voltage, measured at no load and at the battery end of the cable, very precisely to the end-of-charge voltage. The voltage should be set to 27.8V at 10°C, 27.5V at 20°C, 27.15V at 30°C and 26.8V at 40°C ambient temperature. Unit A 23.3. SERIES OPERATION Input Devices of the same type can be connected in series for higher output voltages. It is possible to connect as many units in series as needed, providing the sum of the output voltage does not exceed 150Vdc. Voltages with a potential above 60Vdc must be installed with a protection against touching. Avoid return voltage (e.g. from a decelerating motor or battery) which is applied to the output terminals. Keep an installation clearance of 15mm (left / right) between two power supplies and avoid installing the power supplies on top of each other. Do not use power supplies in series in mounting orientations other than the standard mounting orientation. + Output + Unit B Load Input + - - Output Pay attention that leakage current, EMI, inrush current, harmonics will increase when using multiple devices. 23.4. PARALLEL USE TO INCREASE OUTPUT POWER Devises can be paralleled to increase the output power. The output voltage shall be adjusted to the same value (±100mV) with the same load conditions on all devices, or the devices can be left with the factory settings. The ambient temperature is not allowed to exceed +40°C. If more than three devices are connected in parallel, a fuse or circuit breaker with a rating of 10A is required on each output. Alternatively, a diode or redundancy module can also be utilized. Unit A Input + Output + Unit B Load Input + - - Output Energize all devices at the same time. It also might be necessary to cycle the input power (turn-off for at least five seconds), if the output was in overload or short circuits and the required output current is higher than the current of one unit. Keep an installation clearance of 15mm (left / right) between two devices and avoid installing devices on top of each other. Do not use devices in parallel in mounting orientations other than the standard mounting orientation or in any other condition where a reduction of the output current is required (e.g. altitude). Pay attention that leakage current, EMI, inrush current will increase when using multiple devices. Oct. 2023 / Rev. 1.4 DS-CP5.241-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 24V, 5A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 26/30 CP5.241, CP5.241-C1, CP5.241-S1, CP5.241-S2, CP5.242 24V, 5A, 120W, SINGLE PHASE INPUT CP-Series 23.5. PARALLEL USE FOR REDUNDANCY 1+1 Redundancy: Devices can be paralleled for redundancy to gain higher system availability. Redundant systems require a certain amount of extra power to support the load in case one device fails. The simplest way is to put two devices in parallel. This is called a 1+1 redundancy. In case one device fails, the other one is automatically able to support the load current without any interruption. It is essential to use a redundancy module to decouple devices from each other. This prevents that the defective unit becomes a load for the other device and the output voltage cannot be maintained any more. 1+1 redundancy allows ambient temperatures up to +70°C. Pay attention that leakage current, EMI, inrush current, harmonics will increase when using multiple devices. Recommendations for building redundant power systems: - Use separate input fuses for each device. Use separate mains systems for each device whenever it is possible. Monitor the individual devices. Therefore, use the DC OK signal of the device. It is desirable to set the output voltages of all devices to the same value (± 100mV) or leave it at the factory setting. N+1 Redundancy: Redundant systems for a higher power demand are usually built in a N+1 method. E.g. four devices, each rated for 5A are paralleled to build a 15A redundant system. Pay attention that leakage current, EMI, inrush current, harmonics will increase when using multiple devices. Keep an installation clearance of 15mm (left / right) between two devices and avoid installing the devices on top of each other. Do not use devices in parallel in mounting orientations other than the standard mounting orientation or in any other condition, where a reduction of the output current is required. For N+1 redundancy the ambient temperature is not allowed to exceed +40°C. Wiring examples: Fig. 23-4 1+1 Redundant configuration for 5A load current with a dual redundancy module Fig. 23-5 1+1 Redundant configuration with active load share for 5A load current with a dual redundancy module Failure Monitor - - Output 24V,5A DCOK o o Power Supply + + - + + Redundancy Module DCOK opt ional DCOK o o + + DCOK o o Power Supply Input L N PE - - Output 24V,5A o o Power Supply Input + - - Output 24V,5A Power Supply Output Input + + - - Output 24V,5A YR20.242 L N PE I - Input Input 2 1 - 1 Input YR20.246 Redundancy Module I L N N Note: A YR2.DIODE can also be used instead of a YR20.242 Load Share Warning Failure Monitor Output - L N PE + max. 5A Load I PE o o o o Load Share OK 5A Load L 2 Input Redudnadcy OK Input L N PE + + I opt ional + + PE Oct. 2023 / Rev. 1.4 DS-CP5.241-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 24V, 5A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 27/30 CP5.241, CP5.241-C1, CP5.241-S1, CP5.241-S2, CP5.242 24V, 5A, 120W, SINGLE PHASE INPUT CP-Series Fig. 23-6 N+1 Redundant configuration for 15A load current with multiple power supplies and redundancy modules Failure Monitor + + - - Output 24V,5A DCOK o o Power Supply + - + + + Redundancy Module DCOK - + + DCOK o o Power Supply Input + - - Output 24V,5A o o Power Supply Output Input - - Output 24V,5A YR20.242 Input L N PE L N PE + - + - + + DCOK YR20.242 Redundancy Module o o Power Supply Output - - - Output 24V,5A Input Input 2 1 Input + L N PE 15A Load opt ional L N PE I - Input Input 2 1 I I I L N PE Note: A YR2.DIODE can also be used instead of a YR20.242 Oct. 2023 / Rev. 1.4 DS-CP5.241-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 24V, 5A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 28/30 CP5.241, CP5.241-C1, CP5.241-S1, CP5.241-S2, CP5.242 24V, 5A, 120W, SINGLE PHASE INPUT CP-Series 23.6. OPERATION ON TWO PHASES Power Supply The power supply can also be used on two-phases of a three-phase-system. Such a phase-to-phase connection is allowed as long as the supplying voltage is below 240V+10%. 240V +10% max. Ensure that the wire, which is connected to the N-terminal, is appropriately fused. L1 L3 The maximum allowed voltage between a Phase and the PE must be below 300Vac. AC L N PE L2 DC 23.7. USE IN A TIGHTLY SEALED ENCLOSURE When the power supply is installed in a tightly sealed enclosure, the temperature inside the enclosure will be higher than outside. In such situations, the inside temperature defines the ambient temperature for the power supply. The following measurement results can be used as a reference to estimate the temperature rise inside the enclosure. The power supply is placed in the middle of the box, no other heat producing items are inside the box The temperature sensor inside the box is placed in the middle of the right side of the power supply with a distance of 1cm. The following measurement results can be used as a reference to estimate the temperature rise inside the enclosure. Enclosure size Input voltage Load Temperature inside the box Temperature outside the box Temperature rise Case A 110x180x165mm Rittal Typ IP66 Box PK 9516 100, plastic 230Vac 24V, 4A; (=80%) 38.3°C 26.1°C 12.2K Case B 110x180x165mm Rittal Typ IP66 Box PK 9516 100, plastic 230Vac 24V, 5A; (=100%) 39.6°C 25.5°C 14.1K Oct. 2023 / Rev. 1.4 DS-CP5.241-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 24V, 5A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 29/30 CP5.241, CP5.241-C1, CP5.241-S1, CP5.241-S2, CP5.242 24V, 5A, 120W, SINGLE PHASE INPUT CP-Series 23.8. MOUNTING ORIENTATIONS Mounting orientations other than input terminals on the bottom and output on the top require a reduction in continuous output power or a limitation in the maximum allowed ambient temperature. The listed lifetime and MTBF values from this datasheet apply only for the standard mounting orientation. The following curves give an indication for allowed output currents for altitudes up to 2000m. Fig. 23-7 Mounting Orientation A (Standard orientation) Allowed Output Current at 24V OUTPUT 6A 5A Power Supply 3.8A 0 INPUT +45 +60 +70°C Ambient Temperature Fig. 23-8 Mounting Orientation B (Upside down) Allowed Output Current at 24V INPUT 6A 4A Pow er Supply 0 OUTPUT +30 +60 +70°C Ambient Temperature Fig. 23-9 Mounting Orientation C (Table-top mounting) Allowed Output Current at 24V 6A 3.5A 0 +25 +60 +70°C Ambient Temperature Allowed Output Current at 24V 6A OUTPUT Pow er Supply INPUT Fig. 23-10 Mounting Orientation D (Horizontal cw) 3.5A 0 +25 +60 +70°C Ambient Temperature Allowed Output Current at 24V INPUT Pow er Supply 6A OUTPUT Fig. 23-11 Mounting Orientation E (Horizontal ccw) 3.5A 0 +25 +60 +70°C Ambient Temperature Oct. 2023 / Rev. 1.4 DS-CP5.241-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 24V, 5A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 30/30
CP5.241 价格&库存
很抱歉,暂时无法提供与“CP5.241”相匹配的价格&库存,您可以联系我们找货
CP5.241
  • 1+1897.373261+245.45420
库存:176
CP5.241
    • 1+1559.39921
    库存:166
    CP5.241
      • 1+1509.73200
      库存:20
