HU 2450N-1-LF
HU 2450N-1-LF
    RENATA(瑞纳达)
    RENATA - HU 2450N-1-LF - Battery Holder, 2450 x 1, Through Hole
HU 2450N-1-LF 数据手册
SMD and Through Hole Battery Holders Maximum Dimensions SMT Holders Type For Use with Renata cell A B C D E F Weight (g) SMTU 1225-1 CR1225 23.7 20.3 12.5 12.7 4.8 21.1 .68 SMTU 2032-1 CR2032 32.0 28.5 20.0 16.1 5.4 29.3 .95 SMTU 2430-1 CR2430 36.5 33.0 24.5 16.1 4.9 33.8 1.05 SMTU 2450N-1 CR2450N 36.6 33.0 24.5 16.1 7.5 33.8 1.45 SMTU 2477N-1 CR2477N 36.7 33. 24.5 16.1 10.3 33.8 1.65 Maximum Dimensions Through-hole Holders Type For Use with Renata cell A B C D E F Weight (g) HU 1225-1 CR1225 20.3 12.5 12.7 4.6 18.7 .68 .68 HU 2032-1 CR2032 28.5 20.0 16.1 5.2 26.9 .95 .95 HU 2430-1 CR2430 33.0 24.5 16.1 4.7 31.5 1.05 1.05 HU 2450N-1 CR2450N 33.0 24.5 16.1 7.3 31.5 1.45 1.45 HU 2477N-1 CR2477N 33.0 24.5 16.1 10.1 31.5 1.65 1.65 Characteristics: Easy and fast replacement of battery Positive retension of button cell Clear separation of connections Safety against shorts Safety against inverse polarity (polarized) Solid design Specifications: Holder material: heat resistant, glass fiber filled LCP. Flammability rating UL94V-0. Dimensional stability under heat HDT/A (1.82N/mm2) according to ASTM D648:243 degreeC. Battery contacts: spring stainless steel 301 tin/lead plated throughout, thickness 10µm. Solder contacts: spring stainless steel 301 tin/lead plated throughout, thickness 10µm.
HU 2450N-1-LF
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一种光耦器件,用于隔离输入和输出电路,保护电路不受外部干扰。
3. 引脚分配:EL817有6个引脚,分别为1脚阳极,2脚阴极,3脚集电极,4脚发射极,5脚门极,6脚集电极。
4. 参数特性:工作温度范围为-40℃至+85℃,隔离电压为5000Vrms。
5. 功能详解:EL817通过光电效应实现信号传输,具有高速响应和低功耗特点。
6. 应用信息:广泛应用于通信、工业控制、医疗设备等领域。
7. 封装信息:采用DIP-6封装。
HU 2450N-1-LF 价格&库存
很抱歉,暂时无法提供与“HU 2450N-1-LF”相匹配的价格&库存,您可以联系我们找货
