CR2477N
CR2477N
    RENATA(瑞纳达)
CR2477N 数据手册
CR2477N 3V Lithium Battery Swiss Made Technical Data Sheet Specifications Dimensions 0 -0.4 Ref. Ø22.4 22,4 ∅ 7,7 Li / MnO2 3V 950 mAh 1.0 mA 2.5 mA 8.3 g -40 - +85 °C < 1% / year 5,3 Chemical System Nominal Voltage Rated Capacity Standard Discharge Current Max. Cont. Discharge Current Average Weight Operating Temperature* Self Discharge at 23°C ∅ 24,5 0 -0.3 Performance Discharge performance at 23°C 3.5 3.0 3.0 2.5 2.5 Voltage [V] Voltage [V] Discharge performance at 23°C 3.5 2.0 2.67 kΩ 4.7 kΩ 1.5 2.0 6.81 kΩ 1.0 1.0 0.5 0.5 0.0 16.2 kΩ 0.0 0 400 800 1200 1600 2000 0 1000 Time [h] 2000 3000 4000 5000 6000 Time [h] Temperature performance Cell capacity at various loads Load 4.7kΩ 1150 3.5 1000 3.0 Capacity [mAh] 70°C Voltage [V] 12 kΩ 1.5 2.5 2.0 -20°C 1.5 0°C 23°C 1.0 70°C 850 -20°C 700 550 23°C 0°C 70°C 400 250 0.5 100 0.0 0 400 800 1200 1600 1 2000 10 100 Load [kΩ] Time [h] * In applications where the battery is exposed to temperatures above 70 °C, please contact Renata for consultancy. Information and contents in this data sheet are for reference purpose only. They do not constitute any warranty or representation and are subject to change without notice. For most current information and further details, please contact your Renata representative. Rev. CR2477N. 06 / 12.06 Renata SA CH-4452 Itingen/Switzerland Tel. +41 (0)61 975 75 75 Fax. +41 (0)61 975 75 95 sales@renata.com www.renata.com
CR2477N
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款红外发射二极管。
2. 器件简介:EL817是一种红外发射二极管,用于红外线发射,常用于遥控器等设备。
3. 引脚分配:EL817有两个引脚,分别为阳极和阴极。
4. 参数特性:工作电压范围为1.4V至1.8V,工作电流为50mA,发射波长为940nm。
5. 功能详解:EL817主要功能是发射红外线,用于无线通信。
6. 应用信息:广泛应用于遥控器、红外线通信等领域。
7. 封装信息:EL817采用黑色塑料封装,尺寸为5.7mm x 2.8mm。
CR2477N 价格&库存
很抱歉,暂时无法提供与“CR2477N”相匹配的价格&库存,您可以联系我们找货
