Specification Sheet for SMD Power Inductor
Specification Sheet for Approved
Customer Name:
Customer Part No.:
Ceaiya Part No:
CRH201610S 系列
Spec No:
L2016
【For Customer Approval Only】
If you Approval, Please Stamp
【RoHS Compliant Parts】
Approved
By
Checked By
李庆辉
查
Prepared By
凯
劳水花
Shenzhen Ceaiya Electronics Co., Ltd.
地址 1: 深圳市龙华区观澜街道银星智界一期综合楼 716 号
地址 2:广东省东莞清溪镇青滨东路 105 号力合紫荆智能制造中心 10 栋
Http//www.ceaiya.com
Tel: 0769-89135516
Fax: 0769-89135519
1
【Version of Changed Record】
Rev.
Effective Date
Changed Contents
Change Reasons
Approved By
A0
2019.09.09
New release
Li qing hui
2
1. Scope
This specification applies to the CRH201610S Series of wire wound SMD power inductor.
2. Product Description and Identification (Part Number)
1) Description:
CRH201610S series of Wire wound SMD power inductor.
2) Product Identification (Part Number)
CRH 201610 S - 2R2 M
T
①
②
③
④
⑤
⑥
①
Type
CRH
② External Dimensions(L×W×H) 【mm】
Ferrite Inductor
③
201610
2.0×1.6×1.0
Feature type
S
⑤
Standard Product
④
Inductance Tolerance
N
±30%
M
±20%
⑥
Nominal Inductance
Example
Example
1R0
1.0uH
100
10uH
101
100uH
Packing
T
Tape Carrier Package
3. Electrical Characteristics
Please refer to Item 5.
1) Operating temperature range (individual chip without packing): -40℃ ~ +125℃ (Including Self-heating).
2) Storage temperature range (packaging conditions): -10℃ ~ +40℃ and RH 70% (Max.).
4. Shape and Dimensions (Unit:mm)
Dimensions and recommended PCB pattern for reflow soldering, please see fig4-1 and Table4-1
Fig4-1.
Table 4-1.
A
B
C
D
E
F
G
H
I
2.0 ± 0.2
1.6± 0.2
1.05Max
1.2±0.2
0.60±0.2
0.8 ± 0.2
1.6Ref
0.70 Ref
0.70 Ref
3
5. Electrical Characteristics
Typ
Isat (A)
Max Typ
Irise(A)
Max
Typ
Test
Condition
40
33
3.70
4.10
2.80
3.10
1MHz /1.0V
41
3.00
3.70
2.40
2.90
1MHz /1.0V
0.47
50
2.30
2.85
2.30
2.60
1MHz /1.0V
CRH201610S-R68MT
0.68
63
1.95
2.45
2.00
2.20
1MHz /1.0V
CRH201610S-1R0MT
1.0
96
1.65
1.85
1.45
1.60
1MHz /1.0V
CRH201610S-1R5MT
1.5
145
1.35
1.65
1.10
1.20
1MHz /1.0V
CRH201610S-2R2MT
2.2
215
1.20
1.45
1.05
1.15
1MHz /1.0V
CRH201610S-3R3MT
3.3
290
1.00
1.20
0.85
0.95
1MHz /1.0V
CRH201610S-4R7MT
4.7
400
0.75
0.90
0.70
0.80
1MHz /1.0V
CRH201610S-6R8MT
6.8
610
0.70
0.85
0.55
0.60
1MHz /1.0V
CRH201610S-8R2MT
8.2
730
0.68
0.78
0.53
0.60
1MHz /1.0V
CRH201610S-100MT
10
800
0.65
0.70
0.50
0.60
1MHz /1.0V
CRH201610S-120MT
12
1100
0.62
0.70
0.36
0.42
1MHz /1.0V
CRH201610S-150MT
15
1300
0.50
0.56
0.30
0.38
1MHz /1.0V
CRH201610S-220MT
22
1400
0.32
0.38
0.30
0.36
1MHz /1.0V
DCR(mΩ)
Part Number
Inductance
(uH)
Tolerance
Max
CRH201610S-R24MT
0.24
CRH201610S-R33MT
0.33
CRH201610S-R47MT
Note:※1: Rated current: Isat(max.)or Irise(max.),whichever is smaller;
※2: Saturation Current: Max. Value, DC current at which the inductance drops less than 30% from its value
without current; Typ. Value, DC current at which the inductance drops 30% from its value without current;
※3: Irise: DC current that causes the temperature rise (△T) from 20℃ ambient.
For Max. Value, △T<40℃; for Typ. Value, △T is approximate 40℃.
The part temperature (ambient + temp. rise) should not exceed 125℃ under worst case operating conditions.
Circuit design, component placement, PCB trace size and thickness, airflow and other cooling provisions all affect
the part temperature. Part temperature should be verified in the end application.
6. Structure
The structure of CRH201610S product.
NO.
Components
Material
①
Core
Ni-Zn Ferrite
②
Wire
Polyurethane system enameled copper wire
③
Magnetic Glue
Epoxy resin and magnetic powder
④
Electrodes
AgNiSn or FeNiCu + Sn Alloy
△f: Clearance between terminal and the surface of plate must be 0.1mm max when coil is placed on a flat plate.
4
7. Reliability Test
Items
7.1
Terminal
Strength
Requirements
Test Methods and Remarks
No removal or split of the termination or other defects
shall occur.
1) Solder the inductor to the testing jig (glass epoxy
board shown in Fing.7.1-1) using eutectic solder. Then
apply a force in the direction of the arrow.
2) 10N force.
3) Keep time: 5±2s
X
Y
7.2
High
Temperature
Fig.7.1-1
1. No visible mechanical damage.
2. Inductance change: Within ±10%
1) Storage Temperature :125+/-5℃
2) Duration : 96 ±4 Hours
3) Recovery : then measured at room ambient
temperature after placing 24 hours.
7.3
1) Temperature and time: -40±5℃
Low
2) Duration: 96 4 hours
3) TRecovery : then measured at room ambient
1) Frequency range:10HZ~55HZ~10HZ
Temperature
7.4
Vibration test
2) Amplitude:1.5mm p-p
3) Direction:X,Y,Z
4) Time:1 minute/cycle,2hours per axis
7.5
High
Temperature
Storage Tested
7.6
Resistance to
Soldering Heat
1) Storage Temperature :60+/-2℃
2) Relative Humidity :90-95% RH
3) Duration : 96 ±4 Hours
4) Recovery : then measured at room ambient
1) Re-flowing Profile: Please refer to Fig.7.6-1
2) Test board thickness: 1.0mm
3) Test board material: glass epoxy resin
4) The chip shall be stabilized at normal condition for
1~2 hours before measuring
Fig.7.6-1
7.7
1) Temperature and time: -40±3℃ for 30±3 min→105℃
Thermal Shock
for 30±3min, please refer to Fig.7.7-1.
2) Transforming interval: Max, 3 minute
105℃
3) Tested cycle: 100 cycles
Max 3 minute
Fig.7.7-1
5
8.Packaging and Marking:
8-1.Carrier Tape Dimensions:
P
P2
P0
F
W
E
ITEM
W
A0
B0
K0
P
F
E
D0
P0
P2
T
DIM
8.00
2.00
2.40
1.20
4.00
3.5
1.75
1.50
4.00
2.00
0.25
TOLE
±0.3
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
+0.1
±0.1
±0.1
±0.05
8-2.Taping Dimensions:
8-3.Reel Dimensions:
A
Carrier Tape Reel
B
C
N
G
Type
A
8mm
178
B
20.7±0.8
8-4. Packaging Quantity:
2KPCS/ Reel 20KPCS/ Inner Box
C
13±0.4
G
N
T
9
60
10.8
80KPCS/ Outer Box
6
9. Visual Inspection Standard of Product
7
很抱歉,暂时无法提供与“CRH201610S-2R2MT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.27908
- 100+0.22254
- 300+0.19422
- 2000+0.16396
- 4000+0.14704
- 10000+0.13851
