F3PAM602-10A
F3PAM602-10A
    HOBUT
F3PAM602-10A 数据手册
BATTERY CONDITION & CHARGING INDICATORS DESCRIPTION A range of ammeters and voltmeters with tough moving magnet or polarised moving iron movements designed for low cost indication of d.c. or rectified a.c. 11840 F3PAM Dimensions (mm) Application: Suppressed zero battery condition indicators designed to monitor the state of lead acid batteries. 12.5V) 25.0V) 38.0V) 50.5V) ±8% of range Polarised moving iron -20ºC to +40ºC 6.3 or 4.7mm faston tags Snap into panel High intensity LED indicating system on. Black or white dial F3DM 40.5 Dia 48 41.5 Dia 45º X Calibration accuracy: Movement: Temperature range: Terminations: Fixing: Options: to to to to 9 15 10 Standard Range: 12V (yellow zone 10.5 24V (yellow zone 21.0 36V (yellow zone 31.5 48V (yellow zone 42.0 48 Panel cutout (View from front) Panel thickness X mm 1.0 - 1.5 2.0 - 2.5 51.0 52.5 Dimensions (mm) Application: Ammeters normally used to indicate charge or discharge currents on vehicle battery charging systems. 4.75 56 Standard Range: 0/5A, 0/8A, 0/10A, 0/12A, 0/15A, 0/20A, 0/30A, 0/40A, 0/50A, 0/60A, 0/75A 38.1 20.6 4 8/0/8A, 12/0/12A, 30/0/30A, 50/0/50A, 60/0/60A Calibration accuracy: Movement: Temperature range: Terminations: Fixing: Options: 23.8 35 ±8% of f.s.d. Polarised moving iron -20ºC to +40ºC 2BA up to 20A 1/4 BSF above 20A U clip Illumination slots available Black or white dial 51 Panel cutout BATTERY CONDITION & CHARGING INDICATORS F3VAM Dimensions (mm) Application: Ammeters normally used to indicate charge or discharge currents on vehicle battery charging systems. Illumination slots supplied as standard. 28.5 19 4.75 46 4 Standard Range: 8/0/8A, 12/0/12A, 30/0/30A Calibration accuracy: ±8% of f.s.d. Movement: Polarised moving iron Temperature range: -20ºC to +40ºC Terminations: 2BA or 4BA studs Fixing: U clip (bezel mounting clips available upon request) Options: Black or white dial F3DM/CT 17.46 42 Dia Panel cutout Dimensions (mm) Application: This clip-on meter is designed to give a quick indication of current & direction of flow. There are no connections to be made, it simply clips over the conductor & operates on the induction principle. 56 4.75 29.6 20.6 17 Standard Range: 30/0/30A, 75/0/75A Supplied with white dial Calibration accuracy: ±10% of f.s.d. Movement: Moving magnet Temperature range: -20ºC to +40ºC Cable size: For best results use with cable sizes 5mm to 10mm diameter Cable size 5mm to 10mm SPECIAL DIALS The products detailed in this publication are our standard range, but for large quantity orders, HOBUT engineers will be pleased to work with customers to design individual dials to their specifications. Our policy is one of continuous development and therefore specifications may change without notice. HOWARD BUTLER LTD CROWN WORKS, LINCOLN ROAD WALSALL WS1 2EB ENGLAND Tel: 01922 640003 Fax: 01922 723626 International Tel: +44 1922 640003 E-mail: sales@hobut.co.uk Web: www.hobut.co.uk
F3PAM602-10A 价格&库存
很抱歉,暂时无法提供与“F3PAM602-10A”相匹配的价格&库存,您可以联系我们找货
