164-5-H8
164-5-H8
    HOBUT
164-5-H8 数据手册
16 SERIES MOULDED CASE CURRENT TRANSFORMERS DESCRIPTION A range of compact moulded case current transformers suitable for primary currents from 30A to 800A with built in sealable terminal covers. APPLICATION For transforming various primary currents into 5A or 1A standard secondary using 20/30/40mm busbars or cables. 11840 RANGE (Type 162) Class 3 Class 1 1.5 2.5 1 Class 0.5 VA 1 1.5 2.5 1 1.5 2.5 30A A1 – – – – – – – – 40A B1 B2 – – – – – – – 50A C1 C2 – C4 – – – – – 60A D1 D2 D3 D4 D5 – – – – 80A E1 E2 E3 E4 E5 – – – – RANGE (Type 164) Class 3 FEATURES • Built in sealable terminal covers. • Mounting feet supplied. • Narrow width - 60mm. • Din rail clip as optional extra. TECHNICAL SPECIFICATION • Conforms to IEC185, BS 7626, BSEN 60044-1 and IEC 60044-1. • Rated system voltage 0.72/3kV. • Ambient temperature range -30°C to 85°C. • Continuous current, 1.2 x rated current. DIMENSIONS (mm) Class 1 Class 0.5 VA 2.5 5 10 2.5 5 10 2.5 5 10 100A A1 – – A4 – – – – – 150A B1 – – B4 – – – – – 200A C1 – – C4 – – C7 – – 250A D1 D2 – D4 – – D7 – – 300A E1 E2 – E4 – – E7 – – 400A F1 F2 – F4 F5 – F7 – – 500A G1 G2 G3 G4 G5 – G7 G8 – 600A H1 H2 H3 H4 H5 – H7 H8 – 31 21 800A J1 J2 J3 J4 J5 J6 J7 J8 – 41 42.5 Type 164 Type 162 60 60 45 30 78 32 11 13 20 1A secondary available by request. Order Example: A moulded case current transformer type 164, with 5A secondary and 400A primary 5VA class 1 is part number 164-5-F5 Our policy is one of continuous development and therefore specifications may change without notice. HOWARD BUTLER LTD CROWN WORKS, LINCOLN ROAD WALSALL WS1 2EB ENGLAND Tel: 01922 640003 Fax: 01922 723626 International Tel: +44 1922 640003 E-mail: sales@hobut.co.uk http://www.hobut.co.uk
164-5-H8 价格&库存
很抱歉,暂时无法提供与“164-5-H8”相匹配的价格&库存,您可以联系我们找货
