CT132TRAN150A-5/10V
CT132TRAN150A-5/10V
    HOBUT
    HOBUT - CT132TRAN150A-5/10V - CURRENT TRANSDUCER, 10VDC, DINRAIL
CT132TRAN150A-5/10V 数据手册
CT132TRAN CURRENT SENSOR/ CURRENT TRANSDUCER DESCRIPTION A range of current sensors / current transducers available with 0-5V / 0-10V DC self powered output or 4-20mA loop powered output. APPLICATION For transforming low currents of 10A-150A AC into standard DC output signals. FEATURES • • • • • TECHNICAL SPECIFICATION Built in seakable terminal covers Base or DIN rail mounting Customers selectable 0.5V / 10V DC output Small size High accuracy 0.5 all models Accuracy: Class 0.5, EN 60688 Response Time: 200msec Output: 5V/10V DC (self powered) (1m ohm load) 4-20mA DC (15-30V DC loop powered) (max load 600ohms @ 24V DC) Temperature Range: -15ºC to +50ºC Isolation: 4kV 50Hz (1 sec) Operating Range: 0-120% nominated FS Frequency Range: 45/65Hz RANGE DIMENSIONS (mm) INPUT OUTPUT 5/10V DC 4/20mA DC 10A CT132TRAN10A-5/10V CT132TRAN10A-4/20mA 20A CT132TRAN20A-5/10V CT132TRAN20A-4/20mA 50A CT132TRAN50A-5/10V CT132TRAN50A-4/20mA 100A CT132TRAN100A-5/10V CT132TRAN100A-4/20mA 150A CT132TRAN150A-5/10V CT132TRAN150A-4/20mA Order Example: A CT132TRAN with 50A input and 5/10V DC output is part number CT132TRAN50A-5/10V 45 30 65 21 27 Our policy is one of continuous development and therefore specifications may change without notice. CROWN WORKS, LINCOLN ROAD WALSALL WS1 2EB ENGLAND Tel: 01922 640003 Fax: 01922 723626 International Tel: +44 1922 640003 E-mail: sales@hobut.co.uk http://www.hobut.co.uk November 2014 HOWARD BUTLER LTD
CT132TRAN150A-5/10V 价格&库存
很抱歉,暂时无法提供与“CT132TRAN150A-5/10V”相匹配的价格&库存,您可以联系我们找货
