BATTERY CONDITION &
CHARGING INDICATORS
DESCRIPTION A range of ammeters and voltmeters
with tough moving magnet or
polarised moving iron movements
designed for low cost indication of
d.c. or rectified a.c.
11840
F3PAM
Dimensions (mm)
Application: Suppressed zero battery
condition indicators designed to monitor
the state of lead acid batteries.
12.5V)
25.0V)
38.0V)
50.5V)
±8% of range
Polarised moving iron
-20ºC to +40ºC
6.3 or 4.7mm faston tags
Snap into panel
High intensity LED
indicating system on.
Black or white dial
F3DM
40.5
Dia
48
41.5
Dia
45º
X
Calibration
accuracy:
Movement:
Temperature
range:
Terminations:
Fixing:
Options:
to
to
to
to
9 15
10
Standard Range:
12V (yellow zone 10.5
24V (yellow zone 21.0
36V (yellow zone 31.5
48V (yellow zone 42.0
48
Panel cutout
(View from front)
Panel thickness
X mm
1.0 - 1.5
2.0 - 2.5
51.0
52.5
Dimensions (mm)
Application: Ammeters normally used to
indicate charge or discharge currents on
vehicle battery charging systems.
4.75
56
Standard Range:
0/5A, 0/8A, 0/10A, 0/12A, 0/15A, 0/20A,
0/30A, 0/40A, 0/50A, 0/60A, 0/75A
38.1
20.6
4
8/0/8A, 12/0/12A, 30/0/30A, 50/0/50A,
60/0/60A
Calibration
accuracy:
Movement:
Temperature
range:
Terminations:
Fixing:
Options:
23.8
35
±8% of f.s.d.
-20ºC to +40ºC
2BA up to 20A
1/4 BSF above 20A
U clip
Illumination slots available
Black or white dial
51
Panel cutout
BATTERY CONDITION &
CHARGING INDICATORS
F3VAM
Dimensions (mm)
Illumination slots supplied as standard.
28.5
19
4.75
46
4
Standard Range: 8/0/8A, 12/0/12A,
30/0/30A
Calibration
accuracy:
±8% of f.s.d.
Movement:
Temperature
range:
-20ºC to +40ºC
Terminations:
2BA or 4BA studs
Fixing:
U clip (bezel mounting
clips available upon
request)
Options:
Black or white dial
F3DM/CT
17.46
42 Dia
Panel cutout
Dimensions (mm)
Application: This clip-on meter is designed
to give a quick indication of current & direction of flow. There are no connections to be
made, it simply clips over the conductor &
operates on the induction principle.
56
4.75
29.6
20.6
17
Standard Range: 30/0/30A, 75/0/75A
Supplied with white dial
Calibration
accuracy:
±10% of f.s.d.
Movement:
Moving magnet
Temperature
range:
-20ºC to +40ºC
Cable size:
For best results use with
cable sizes 5mm to
10mm diameter
Cable size
5mm to 10mm
SPECIAL DIALS
The products detailed in this publication are our standard
range, but for large quantity orders, HOBUT engineers
will be pleased to work with customers to design
individual dials to their specifications.
Our policy is one of continuous development and therefore specifications may change without notice.
HOWARD BUTLER LTD
CROWN WORKS, LINCOLN ROAD
WALSALL WS1 2EB ENGLAND
Tel: 01922 640003 Fax: 01922 723626
International Tel: +44 1922 640003
E-mail: sales@hobut.co.uk
Web: www.hobut.co.uk
很抱歉,暂时无法提供与“F3PAM-24V”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+114.53285
- 5+107.21214
- 10+102.34749
- 20+99.35751
- 50+97.37606
