13-5-A1
13-5-A1
    HOBUT
13-5-A1 数据手册
13 SERIES MOULDED CASE CURRENT TRANSFORMERS DESCRIPTION A range of compact low cost moulded case current transformers suitable for primary currents from 40A to 300A with built in sealable terminal covers. APPLICATION For transforming various primary currents into 5A or 1A standard secondary using up to 20mm diameter cables. FEATURES • DIN rail mounting clip supplied. • Built in sealable terminal covers. • Mounting feet supplied. • Narrow width - 45mm. TECHNICAL SPECIFICATION • Conforms to IEC185, BS 7626, BSEN 60044-1 and IEC 60044-1. • Rated system voltage 0.72/3kV. • Ambient temperature range -30°C to 85°C. • Continuous current 1.2 x rated current. Built in sealable terminal covers RANGE VA 40A 50A 60A 75A 80A 100A 120A 150A 200A 250A 300A 1 A1 B1 C1 D1 E1 F1 G1 H1 J1 K1 L1 DIMENSIONS (mm) Class 3 1.5 2.5 5 1 – B2 C2 D2 E2 F2 G2 H2 J2 K2 L2 – – – – – – – H4 J4 K4 L4 – B5 C5 D5 E5 F5 G5 H5 J5 K5 L5 – – – D3 E3 F3 G3 H3 J3 K3 L3 Class 1 1.5 2.5 5 – – C6 D6 E6 F6 G6 H6 J6 K6 L6 – – – – – – – – – – – – – – – – – – – – – – – – – – F9 F10 – – – G9 G10 G11 – – H9 H10 H11 – J8 J9 J10 J11 – K8 K9 K10 K11 K12 L8 L9 L10 L11 L12 – – – – – F7 G7 H7 J7 K7 L7 1 Class 0.5 1.5 2.5 5 45 30 21 65 27 1A secondary available by request. Order Example: A moulded case current transformer type 13, with 5A secondary and 200A primary 2.5VA class 1 is part number 13-5-J7 Our policy is one of continuous development and therefore specifications may change without notice. HOWARD BUTLER LTD CROWN WORKS, LINCOLN ROAD WALSALL WS1 2EB ENGLAND Tel: 01922 640003 Fax: 01922 723626 International Tel: +44 1922 640003 E-mail: sales@hobut.co.uk http://www.hobut.co.uk
13-5-A1 价格&库存
很抱歉,暂时无法提供与“13-5-A1”相匹配的价格&库存,您可以联系我们找货
