CTSCMICRO19-100/5-T
CTSCMICRO19-100/5-T
    HOBUT
CTSCMICRO19-100/5-T 数据手册
MICRO 19 SPLIT CORE CTs with optional plug-in short circuit link DESCRIPTION The “Micro 19” range of split core CTs are amongst the smallest available and can be supplied with choice of screw clamp terminals, flying leads and unique plug-in short circuit link. APPLICATION For installation into existing networks in complete safety. The CT will not operate until the plug-in link is removed. SPECIFICATIONS DIMENSIONS (mm) 19 • Conforms to BS EN 60044-1/IEC 60044-1 • Rated system voltage 0.72/3kV • Ambient temperature range -30ºC to 55ºC • Class 1 (phase angle < 2 degrees for 100A at 50% rated current) • 5A and 0.333V secondary output • VA rating: 100/150A = 0.5VA, 200A = 1VA, 250A = 2VA 15 19 78 Options • M3.5 screw clamp secondary terminals • Plug-in short circuit link • 1 metre flying leads 45 58 49 Plug-in short circuit link M3.5 Terminals RANGE OPTIONS Product Code CTSCMICRO19 (5A secondary output) Ratio M3.5 Terminals M3.5 Terminals + Short Circuit Link Flying Leads Flying Leads + Short Circuit Link Plug-in Short Circuit Link -100/5 -125/5 -150/5 -T -T-S -L -L-S -200/5 -250/5 CTSCMICRO19 (0.333V secondary output) Flying Leads (1m long) -100/0.333 -125/0.333 -150/0.333 -T Not Available -L Not Available -200/0.333 -250/0.333 Order Example: A Micro 19 split core CT with ratio of 200/5 with M3.5 terminals and short circuit link is CTSCMICRO19-200/5-T-S Our policy is one of continuous development and therefore specifications may change without notice. HOWARD BUTLER LTD CROWN WORKS, LINCOLN ROAD WALSALL WS1 2EB ENGLAND Tel: 01922 640003 Fax: 01922 723626 International Tel: +44 1922 640003 E-mail: sales@hobut.co.uk http://www.hobut.co.uk
CTSCMICRO19-100/5-T 价格&库存
很抱歉,暂时无法提供与“CTSCMICRO19-100/5-T”相匹配的价格&库存,您可以联系我们找货
