CTSCM40100/5
CTSCM40100/5
    HOBUT
    HOBUT - CTSCM40100/5 - Current Transformer, Split Core, 100:5, Class 3, 2.5 VA, 40 mm, 50Hz / 60Hz
CTSCM40100/5 数据手册
SPLIT-CORE CURRENT TRANSFORMERS CLIP-TOGETHER RANGE DESCRIPTION Split-core transformer, with a unique clip-together feature. Supplied in a moulded case with 1 metre flying leads. Suitable for primary ranges up to 800A with 5A secondary. APPLICATION For installation into existing networks without disconnecting cable circuits. The fast action clip function ensures a high speed permanent installation. 11840 SPECIFICATIONS • Conforms to IEC185, BS 7626, BSEN 60044-1 and IEC 60044-1. • Rated system voltage 0.72/3kV. • Ambient temperature range -30°C to 80°C. • Frequency range 50-60Hz. • Insulation level 3kV for 1 minute. • Continuous current, 1.2 x rated current. • Enclosure flame retardancy UL94VO. RANGE DIMENSIONS (mm) Primary Current VA CLASS 100A 1 (2.5) 1 (3) 150A 1.5 (2.5) 1 (3) 200A 2.5 1 250A 2.5 1 116 104.5 300A 2.5 1 400A 5 1 500A 5 1 600A 5 1 800A 5 1 30 40 35.5 Our policy is one of continuous development and therefore specifications may change without notice. HOWARD BUTLER LTD CROWN WORKS, LINCOLN ROAD WALSALL WS1 2EB ENGLAND Tel: 01922 640003 Fax: 01922 723626 International Tel: +44 1922 640003 E-mail: sales@hobut.co.uk http://www.hobut.co.uk
CTSCM40100/5 价格&库存
很抱歉,暂时无法提供与“CTSCM40100/5”相匹配的价格&库存,您可以联系我们找货
