CT160-5-F7
CT160-5-F7
    HOBUT
CT160-5-F7 数据手册
16 SERIES (Type 160) MOULDED CASE CURRENT TRANSFORMERS WOUND PRIMARY RANGE DESCRIPTION A range of compact low cost moulded case current transformers suitable for primary currents from 1A to 50A with built in terminal covers and M6 screw terminals for primary current connection. APPLICATION For transforming various primary currents into 5A or 1A standard secondary. TECHNICAL SPECIFICATION FEATURES • • • • Built in sealable terminal covers. Mounting feet supplied. DIN rail mounting clip supplied. Narrow width - 60mm. RANGE • Conforms to IEC185, BS 7626, BSEN 60044-1 and IEC 60044-1. • Rated system voltage 0.72/3kV. • Ambient temperature range -30°C to 85°C. • Continuous current 1.2 x rated current. VA 2.5 5 5A Secondry Class 1 2.5 5 1/5 A3 A4 A7 Class 3 DIMENSIONS (mm) Hinged Terminal Cover A8 2.5/5 B3 B4 B7 B8 5/5 C3 C4 C7 C8 7.5/5 D3 D4 D7 D8 8/5 E3 E4 E7 E8 10/5 F3 F4 F7 F8 15/5 G3 G4 G7 G8 20/5 H3 H4 H7 H8 25/5 J3 J4 J7 J8 30/5 K3 K2 K7 K8 40/5 L3 L4 L7 L8 50/5 M3 M4 M7 M8 101 1A secondary available by request. Other accuracies and VAs available by request. 85 60 43 Order Example: A 16 series Type 160 wound primary current transformer with 5A secondary and 30A primary 5VA class 1 is part number 160-5-K8 Our policy is one of continuous development and therefore specifications may change without notice. HOWARD BUTLER LTD CROWN WORKS, LINCOLN ROAD WALSALL WS1 2EB ENGLAND Tel: 01922 640003 Fax: 01922 723626 International Tel: +44 1922 640003 E-mail: sales@hobut.co.uk http://www.hobut.co.uk
CT160-5-F7 价格&库存
很抱歉,暂时无法提供与“CT160-5-F7”相匹配的价格&库存,您可以联系我们找货
