CXT-741G58A-SOT-23-6
    CISSOID
CXT-741G58A-SOT-23-6 数据手册
High Temperature Automotive Configurable Logic Gates Datasheet Version: 1.3 20-Dec-23 (Last Modification Date) (see note 1) General description Features The CXT-741Gxx are 4 high temperature configurable devices enabling 13 different logic functions: INV, BUFFER, AND, AND w/ inverted input, NAND, NAND w/ inverted input, OR, NOR, NOR w/ inverted input, XOR, NXOR, MUX and D Flip-Flop. • These devices are optimized for automotive applications and specified for operating junction temperature from -40°C up to +175°C (Tj), in excess of AEC-Q100 (Grade 0) qualification standard. • • • • • • Operating junction temperature: from -40°C to +175°C (Tj) Supply voltage: 1.65V to 5.5V Inputs can be driven by 3.3V or 5V signals, even for lower supply voltage Schmitt trigger inputs for high immunity to slow changing signals  16 mA output drive current CMOS low power consumption ESD: 2000V HBM or 200V MM Lead Free Finish & RoHS compliant Tiny package: SOT-23 6 leads AEC-Q100 Grade 0 & PPAP capable2 • • • A/3 A/3 Y/4 B/1 Y/4 B/1 C/6 C/6 CXT-741G57 CXT-741G58 D/3 A/3 Q/4 Y/4 B/1 CLK/1 C/6 CLRB/6 CXT-741G97 SOT-23-6 CXT-741G175 SOT-23-6 B 1 6 C CLK 1 6 CLRB GND 2 5 VDD GND 2 5 VDD A 3 4 Y D 3 4 Q Note 1 Please always refer to the latest datasheet version available at http://www.cissoid.com/files/files/products/galaxy/CXT-741GXX.pdf 2 Contact CISSOID about qualification status PUBLIC Doc. PDS-192011 V1.3 WWW.CISSOID.COM 1 of 12 High Temperature Automotive Configurable Logic Gates Datasheet 20-Dec-23 (Last Modification Date) Logic configurations CXT-741G57 3 4 1 6 VDD Configuration 1 2-Input AND Gate 2-Input NOR Gate with Both Inputs Inverted A B Y A B Y A 1 6 2 5 3 4 B Y VDD Configuration 2 2-Input NAND Gate with A Input Inverted 2-Input OR Gate with B Input Inverted A B Y A B Y A 1 6 2 5 3 4 B Y VDD Configuration 3 2-Input NAND Gate with B Input Inverted 2-Input OR Gate with A Input Inverted A B Y A B Y A 1 6 2 5 3 4 B Y VDD Configuration 4 2-Input NOR Gate 2-Input AND Gate with Both Inputs Inverted A B Y A B Y A 1 6 2 5 3 4 B Y VDD Configuration 5 2-Input XNOR Gate A B Y A 1 6 2 5 3 4 B Y VDD Configuration 6 A Y Inverter A PUBLIC Doc. PDS-192011 V1.3 WWW.CISSOID.COM 1 6 2 5 3 4 Y 2 of 12 High Temperature Automotive Configurable Logic Gates Datasheet 20-Dec-23 (Last Modification Date) Logic configurations CXT-741G58 3 4 1 6 VDD Configuration 1 2-Input NAND Gate 2-Input OR Gate with Both Inputs Inverted A B Y A B Y A 1 6 2 5 3 4 B Y VDD Configuration 2 2-Input AND Gate with A Input Inverted 2-Input NOR Gate with B Input Inverted A B Y A B Y A 1 6 2 5 3 4 B Y VDD Configuration 3 2-Input AND Gate with B Input Inverted 2-Input NOR Gate with A Input Inverted A B Y A B Y A 1 6 2 5 3 4 B Y VDD Configuration 4 2-Input OR Gate 2-Input NAND Gate with Both Inputs Inverted A B Y A B Y A 1 6 2 5 3 4 B Y VDD Configuration 5 2-Input XOR Gate A B Y A 1 6 2 5 3 4 B Y VDD Configuration 6 A Y Buffer A PUBLIC Doc. PDS-192011 V1.3 WWW.CISSOID.COM 1 6 2 5 3 4 Y 3 of 12 High Temperature Automotive Configurable Logic Gates Datasheet 20-Dec-23 (Last Modification Date) Logic configurations CXT-741G97 3 4 1 6 VDD A/B Configuration 1 A B 2 to 1 Multiplexer B Y A 1 6 2 5 3 4 A/B Y VDD Configuration 2 2-Input AND Gate 2-Input NOR Gate with Both Inputs Inverted A B Y A B Y B 1 6 2 5 3 4 A Y VDD Configuration 3 2-Input OR Gate with A Input Inverted 2-Input NAND Gate with B Input Inverted A B Y A B Y B 1 6 2 5 3 4 A Y VDD Configuration 4 2-Input NOR Gate with B Input Inverted 2-Input AND Gate with A Input Inverted A B Y A B Y B 1 6 2 5 3 4 A Y VDD Configuration 5 2-Input OR Gate A B Y B 1 6 2 5 3 4 A Y VDD Configuration 6 A Y Inverter PUBLIC Doc. PDS-192011 V1.3 WWW.CISSOID.COM 1 6 2 5 3 4 A Y 4 of 12 High Temperature Automotive Configurable Logic Gates Datasheet 20-Dec-23 (Last Modification Date) CXT-741G57/CXT-741G58/CXT-741G97/CXT-741G175 Absolute Maximum Ratings(see note 3) Symbol VDD VI VO IIK IOK IO TJ TSTG ESD HBM ESD MM Parameter Supply Voltage Range Input Voltage Range Voltage applied to output in high or low state Input Clamp Current (VI
CXT-741G58A-SOT-23-6 价格&库存
很抱歉,暂时无法提供与“CXT-741G58A-SOT-23-6”相匹配的价格&库存,您可以联系我们找货
