CHT-PLA9486A-TDFP16-T
    CISSOID
    80V 900MA
CHT-PLA9486A-TDFP16-T 数据手册
CHT-ELARA DATASHEET 80V High Temperature Quad Diode Version: 1.6 14-Dec-23 (Last Modification Date) General description Features The CHT-ELARA is a high temperature • Specified from -55 to +225°C (Tj) 80V/500mA quad diode in a hermetically • Reverse voltage: VR = 80V (max) sealed TDFP16 ceramic package. It is de- • Forward current: IF = 450 mA (max signed to achieve high performance in an extremely wide temperature range: typical @ 225°C (Tj) and VF = 1.5V) • Forward voltage: operation temperature goes from -55°C to 225°C while keeping leakage currents low. VF = 0.6V (typ. @ IF = 1mA) • Junction capacitance: This quad diode can be used in a variety of Cj=15pF (typ. @ VR = 25V) applications, including rectification, clamp- • Dielectric isolation: min 80V ing and general purpose. • Monolithic design o Excellent matching between on-die diodes A1 o C1 A2 C2 Superior thermal tracking • Low thermal resistance • Package: Hermetically sealed TDFP16 ceramic package C3 A3 C4 A4 • Validated at 225°C for 1000 hours (and still on-going) CHT-ELARA Applications • Full bridge rectification • Power supplies • General purpose diode PUBLIC Doc. DS-141653 V1.6 WWW.CISSOID.COM 1 of 9 CHT-ELARA Datasheet 14-Dec-23 (Last Modification Date) Package Configuration1,2 A1 A1 1 16 C1 A1 2 15 C1 A2 3 14 C2 A2 4 13 C2 C3 5 12 A3 C3 6 11 A3 C4 7 10 A4 C4 8 9 A4 A1 Pin # Pin name Pin description A1 Anode diode 13 (should be connected to the most negative voltage of the application (even if diode “A1-K1” is not used) 2 A1 Anode diode 13 should be connected to the most negative voltage of the application (even if diode “A1-K1” is not used) 3 A2 Anode diode 2 4 A2 Anode diode 2 5 C3 Cathode diode 3 6 C3 Cathode diode 3 7 C4 Cathode diode 4 8 C4 Cathode diode 4 9 A4 Anode diode 4 10 A4 Anode diode 4 11 A3 Anode diode 3 12 A3 Anode diode 3 13 C2 Cathode diode 2 14 C2 Cathode diode 2 15 C1 Cathode diode 1 16 C1 Cathode diode 1 1 1 Pins with the same name are internally connected Package heat sink (exposed pad) is internally connected to terminal A1 3 See Mode of operations section 2 PUBLIC Doc. DS-141653 V1.6 WWW.CISSOID.COM 2 of 9 CHT-ELARA Datasheet 14-Dec-23 (Last Modification Date) Absolute Maximum Ratings Reverse voltage VR Forward surge current IFSM Power dissipation Tc=25°C Junction temperature Tj Operating Conditions 80V 1A 3W 250°C Reverse voltage VR Continuous forward current IF Forward voltage VF Power dissipation Tc=25°C Junction temperature 0V to 80V 0mA to 900mA 0V to 2V 3W -55°C to +225°C PUBLIC Doc. DS-141653 V1.6 WWW.CISSOID.COM 3 of 9 CHT-ELARA Datasheet 14-Dec-23 (Last Modification Date) Electrical characteristics (per diode) Unless otherwise stated, Tj = 25°C. Bold figures point out values valid over the whole temperature range (T j = -55°C to +225°C). Parameter Forward voltage Symbol VF Condition IF=1mA, Tj=25°C VF=1.5V; Tj=25°C Forward current IF Reverse leakage current IR Breakdown reverse voltage Junction capacitance Reverse recovery time4 V(BR) Cj trr Peak reverse recovery current Irrp VR=25V; f = 1 MHz VR = 80V IF = 900 mA Ta = 25°C Symbol ΘJC ΘJA Condition TDFP16 package TDFP16 package Min VF=1.5V; Tj=225°C VR=80V, Tj=25°C VR=80V, Tj=225°C Typ 0.65 450 Max 450 2 2.5 Unit V mA 15 57 mA nA uA V pF ns 750 mA 80 Thermal Characteristics Parameter Junction to case thermal resistance5 Junction to air thermal resistance6 Min Typ 11 70 Max Unit °C/W °C/W 4 trr measured between point where current crosses zero and current reaches 10% of peak reverse recovery current 5 Power equally distributed through the 4 diodes 6 Power equally distributed through the 4 diodes; see Safe operating area, power dissipation, and PCB layout considerations section PUBLIC Doc. DS-141653 V1.6 WWW.CISSOID.COM 4 of 9 CHT-ELARA Datasheet 14-Dec-23 (Last Modification Date) Typical Performance Characteristics (applicable to each diode) 1.00E+00 1.00E+00 9.00E-01 8.00E-01 1.00E-01 Forward Current If (A) Forward Current If (A) 7.00E-01 6.00E-01 5.00E-01 4.00E-01 1.00E-02 1.00E-03 3.00E-01 2.00E-01 1.00E-04 225°C 225°C 175°C 175°C 125°C 1.00E-01 125°C 25°C 0.00E+00 0.00E+00 25°C -55°C 5.00E-01 1.00E+00 1.50E+00 2.00E+00 1.00E-05 0.00E+00 2.50E+00 -55°C 5.00E-01 1.00E+00 DC Forward Voltage Vf (V) 2.00E+00 2.50E+00 DC Forward Voltage Vf (V) Figure 1: Forward current vs. forward voltage and temperature (linear scale). Figure 2: Forward current vs. forward voltage and temperature (log10 scale). 2.50E-06 0.8 0.7 2.00E-06 0.6 DC Reverse Current Ir (A) DC Forward Voltage Vf (V) 1.50E+00 0.5 0.4 0.3 0.2 0.1 1.50E-06 1.00E-06 5.00E-07 0 -100 -50 0 50 100 150 200 250 0.00E+00 -80 Temperature (°C) -70 -60 -50 -40 -30 -20 -10 0 DC Reverse Voltage Vr (V) Figure 3: Forward voltage (at forward current IF=1mA) vs. temperature. Figure 4: Reverse leakage current vs. reverse voltage (Tj = 225°C) PUBLIC Doc. DS-141653 V1.6 WWW.CISSOID.COM 5 of 9 CHT-ELARA Datasheet 14-Dec-23 (Last Modification Date) Mode of operations CHT-ELARA can be used in a variety of different applications: Stand-Alone diodes Clamping function Each diode can be used independently of each other. However, A1 pin should be connected to the most negative voltage of the application (even if diode “A1-K1” is not used). “SIGNAL” is clamped between positive “PS+” and negative “PS-“ power supplies. A1 pin must be connected to the negative power supply (even if diode “A1-K1” is not used). PS- A1 C1 A2 A1 C1 A2 C2 C3 A3 C4 A4 C2 C3 A3 PS+ C4 SIGNAL CHT-ELARA A4 Rectification function CHT-ELARA Full-bridge rectifier In this configuration, A1 pin should be connected to the rectified negative voltage. CHT-ELARA can also be used in applications where a positive and a negative power supplies are generated through a transformer. A1 C1 PS- A1 C1 A2 C2 REF ~ A2 C2 C3 A3 C4 C3 A3 C4 A4 + CHT-ELARA A4 CHT-ELARA PS+ ~ PUBLIC Doc. DS-141653 V1.6 WWW.CISSOID.COM 6 of 9 CHT-ELARA Datasheet 14-Dec-23 (Last Modification Date) Safe operating area, power dissipation, and PCB layout considerations The maximum power dissipation is determined by the maximum junction temperature rating, the ambient temperature, and junction-to-ambient thermal resistance: PDMAX =(TJMAX−TA)/RθJA Where TJMAX=225°C and RθJA=RθJC+RθCA with RθJC=11°C/W and RθCA (to be determined) is function of the size of the copper mounting pad and thermal coupling to the TDFP16. The graph below indicates the junction-toair thermal resistance of the TDFP package mounted on PCB versus the surface of the copper thermal pads on the PCB. The designer should refer to this graph when designing his PCB layout, taking into account his own operating configuration: expected power dissipation and the maximum expected ambient operating temperature. 100 Junction-to-Ambient thermal resistance(°C/W) The tiny TDFP package used for CHTELARA requires adequate PCB layout in order to achieve efficient thermal dissipation, the minimization of the junction operating temperature, and maximizing the power dissipation taking advantage of the temperature behavior capability of CHTELARA. The junction-to-air overall thermal resistance of CHT-ELARA in TDFP package relies, to a large extend, on the implementation of the copper mounting pads that act as a heatsink for the integrated circuit. The design must take into consideration the size of the copper pad and its placement on either of the board surfaces, or both. 80 60 Ta = 25°C Still Air Polyimide board 40 20 0 0 1 2 3 4 5 6 Top& Bottom copper mounting pad area (cm2) PUBLIC Doc. DS-141653 V1.6 WWW.CISSOID.COM 7 of 9 CHT-ELARA Datasheet 14-Dec-23 (Last Modification Date) Package Dimensions 3.20 1.2 0.18 0.15 0.89 2.80 3.90 2.80 Min 6.00 / Max 6.50 0.635 0.5-0.75 5.00 5.50 0.18 7.50 Max TDFP16 physical dimensions (mm +/- 10%) PUBLIC Doc. DS-141653 V1.6 WWW.CISSOID.COM 8 of 9 CHT-ELARA Datasheet 14-Dec-23 (Last Modification Date) Ordering Information Product Name CHT-ELARA Ordering Reference CHT-PLA9486A-TDFP16-T Package TDFP16 Marking CHT-PLA9486A Contact & Ordering CISSOID S.A. Headquarters and contact EMEA: CISSOID S.A. – Rue Francqui, 11 – 1435 Mont Saint Guibert - Belgium T : +32 10 48 92 10 - F: +32 10 88 98 75 Email: sales@cissoid.com Sales Representatives: Visit our website: http://www.cissoid.com Disclaimer Neither CISSOID, nor any of its directors, employees or affiliates make any representations or extend any warranties of any kind, either express or implied, including but not limited to warranties of merchantability, fitness for a particular purpose, and the absence of latent or other defects, whether or not discoverable. In no event shall CISSOID, its directors, employees and affiliates be liable for direct, indirect, special, incidental or consequential damages of any kind arising out of the use of its circuits and their documentation, even if they have been advised of the possibility of such a damage. The circuits are provided “as is”. CISSOID has no obligation to provide maintenance, support, updates, or modifications. PUBLIC Doc. DS-141653 V1.6 WWW.CISSOID.COM 9 of 9
CHT-PLA9486A-TDFP16-T 价格&库存
很抱歉,暂时无法提供与“CHT-PLA9486A-TDFP16-T”相匹配的价格&库存,您可以联系我们找货
