CHT-PLA1971A-HM8A-T
CHT-PLA1971A-HM8A-T
    CISSOID
CHT-PLA1971A-HM8A-T 数据手册
CHT-EUROPA-A1230 Datasheet High Temperature 1200V/30A Dual SiC Schottky Diode Module Version: 1.2 14-Dec-23 (Last Modification Date) General description Features (per diode) CHT-EUROPA-A1230 is a high tempera- • Specified from -55 to +210°C (Tj) ture 1200V/30A Dual Silicon Carbide Schottky diode in a single hermetic mod- • Max Reverse Voltage VR : 1200V • Typ. Forward Voltage: 1.35V @ 30A • Max Continuous Current: 30A • Max Peak Rep Fwd Surge Current: 50A • Hermetic package with isolated case ule. It is suitable for applications such as DC-DC converters, PFC, or motor drives in high temperature environments. The two independent diodes can be used in parallel to deliver a total of 60A. This product is guaranteed for normal operation on the full range -55°C to +210°C (Tj). Each diode has a breakdown voltage in excess of 1200V. Schottky diode features fast switching, zero reverse recovery current. Benefits • Support of high-frequency switching (almost no switching losses) Functional Block Diagram • Reduced Heat Sink requirement • Extended lifetime and high reliability • Harsh environments and high temperature power converters Applications C2 NC NC • AC rectification bridge • Power Factor Correction • DC motor drives and actuator control • DC-DC converters PUBLIC Doc. SP-151811 V1.2 A2 C1 NC NC WWW.CISSOID.COM A1 1 of 7 CHT-EUROPA-A1230 Datasheet 14-Dec-23 (Last Modification Date) Package configuration and Pin Description 8 C2 7 A2 NC NC 6 C1 NC 5 A1 NC Pin ID 1 2 3 4 5 6 7 8 Pin Name NC NC NC NC A1 C1 A2 C2 Body PUBLIC Doc. SP-151811 V1.2 Pin Description Not connected Pin Not connected Pin Not connected Pin Not connected Pin Anode of Diode 1 (Power Pin) Cathode of Diode 1 (Power Pin) Anode of Diode 2 (Power Pin) Cathode of Diode 2 (Power Pin) Package body (isolated from Pins) WWW.CISSOID.COM Pin Finish Nickel Nickel Nickel Nickel Nickel Gold Nickel Gold Nickel 2 of 7 CHT-EUROPA-A1230 Datasheet 14-Dec-23 (Last Modification Date) Abs. Max. Ratings (per diode) DC Blocking Voltage Continuous Forward Current Max Junction temperature Tjmax Power dissipation at Tc=175°C (*) Operating Conditions (per diode) 1200V 30A 210°C 66W DC Blocking Voltage 1200V Continuous Forward Current 30A Rep. Peak Fwd Surge Current 50A Junction temperature -55°C to +210°C ESD Rating Human Body Model >2kV (*): per diode PUBLIC Doc. SP-151811 V1.2 WWW.CISSOID.COM 3 of 7 CHT-EUROPA-A1230 Datasheet 14-Dec-23 (Last Modification Date) Electrical characteristics (per diode) Unless otherwise stated, Tj =25°C. Bold figures point out values valid over the whole temperature range (T j =-55°C to +210°C). Parameter DC Blocking Voltage Symbol VDC Forward Voltage VF Reverse Current IR Total Capacitive Charge QC Total Capacitance C Condition Min 1200 Tj=25°C; IF=30A Tj=210°C; IF=30A Tj=25°C; VR=1200A Tj=210°C; VR=1200A I=30A,VR=600V,TJ =25°C,di/dt=500A/μs Tj=25°C; VR =0V;f = 1 MHz Tj=25°C; VR =200V;f = 1 MHz Tj=25°C; VR =400V;f = 1 MHz Typ Max 1.35 1.8 80 800 Unit V V V µA µA 122 nC TBD TBD TBD pF pF pF Thermal Characteristics (per diode) Parameter Junction-to-Case Thermal resistance PUBLIC Doc. SP-151811 V1.2 Symbol Condition RΘJC Min Typ 0.7 WWW.CISSOID.COM Max Unit °C/W 4 of 7 CHT-EUROPA-A1230 Datasheet 14-Dec-23 (Last Modification Date) Typical performances 30 1.00E-03 125°C 25 1.00E-04 175°C 210°C 25°C 1.00E-05 20 175°C 1.00E-06 IR [A] IF [A] 210°C 15 125°C 1.00E-07 25°C -55°C 10 1.00E-08 5 1.00E-09 -55°C 0 1.00E-10 0 0.5 1 1.5 2 2.5 0 VF[V] Figure 1: Diode IF vs VF PUBLIC Doc. SP-151811 V1.2 200 400 600 800 1000 1200 VR[V] Figure 2: Diode IR vs VR WWW.CISSOID.COM 5 of 7 CHT-EUROPA-A1230 Datasheet 14-Dec-23 (Last Modification Date) Package Dimensions 31.0 6.55 9.44 17.87 CISSOID CHT-PLAxxxxx lot/code 29.09 4.5 7.36 29.67 Origin (0,0) 6.05 10.55 17.91 22.41 23.09 15.93 11.43 6.93 2.43 1.52 CISSOID CHT-PLAxxxxx lot/code 1.52 4.5 Ø3.5 -3.66 23.67 27.33 HM8A dimensions in mm (+/- 10%) Ordering Information Product Name CHT-EUROPA-A1230 Ordering Reference CHT-PLA1971A-HM8A-T Package HM8A Marking CHT-PLA1971A Related products Product Name Function Ordering Reference CHT-EUROPA-A1220 Dual 1200V/20A Schottky Diode Module CHT-PLA3143A-HM8A-T PUBLIC Doc. SP-151811 V1.2 WWW.CISSOID.COM 6 of 7 CHT-EUROPA-A1230 Datasheet 14-Dec-23 (Last Modification Date) Contact & Ordering CISSOID S.A. Headquarters and contact EMEA: CISSOID S.A. – Rue Francqui, 11 – 1435 Mont Saint Guibert - Belgium T : +32 10 48 92 10 - F: +32 10 88 98 75 Email: sales@cissoid.com Sales Representatives: Visit our website: http://www.cissoid.com Disclaimer Neither CISSOID, nor any of its directors, employees or affiliates make any representations or extend any warranties of any kind, either express or implied, including but not limited to warranties of merchantability, fitness for a particular purpose, and the absence of latent or other defects, whether or not discoverable. In no event shall CISSOID, its directors, employees and affiliates be liable for direct, indirect, special, incidental or consequential damages of any kind arising out of the use of its circuits and their documentation, even if they have been advised of the possibility of such a damage. The circuits are provided “as is”. CISSOID has no obligation to provide maintenance, support, updates, or modifications. PUBLIC Doc. SP-151811 V1.2 WWW.CISSOID.COM 7 of 7
CHT-PLA1971A-HM8A-T
物料型号:CHT-EUROPA-A1230
器件简介:该模块是一款高温1200V/30A的双硅碳化物肖特基二极管,适用于高温环境下的DC-DC转换器、PFC或电机驱动等应用。两个独立的二极管可以并联使用,提供总共60A的电流。产品保证在-55°C至+210°C的全温度范围内正常运行。
引脚分配:模块共有8个引脚,其中5号和7号引脚为二极管的阳极,6号和8号引脚为阴极。1号至4号引脚未连接。
参数特性: - 工作温度范围:-55°C至+210°C - 最大反向电压:1200V - 典型正向电压:1.35V(30A时) - 最大连续电流:30A - 最大峰值正向浪涌电流:50A
功能详解: - 支持高频开关,几乎无开关损耗 - 减少散热器需求 - 延长寿命和高可靠性 - 适用于恶劣环境和高温功率转换器
应用信息: - 交流整流桥 - 功率因数校正 - 直流电机驱动和执行器控制 - DC-DC转换器
封装信息:采用密封封装,具有隔离的外壳。
电气特性和热特性表格提供了详细的技术参数,包括阻断电压、正向电压、反向电流、总电容电荷、总电容、结到外壳的热阻等。
典型性能图展示了在不同温度下二极管的正向电流与正向电压的关系,以及反向电流与反向电压的关系。
订购信息提供了产品的封装类型、标记和相关产品的订购参考。
CHT-PLA1971A-HM8A-T 价格&库存
很抱歉,暂时无法提供与“CHT-PLA1971A-HM8A-T”相匹配的价格&库存,您可以联系我们找货
