CHT-PLA1122A-TO257-T
    CISSOID
CHT-PLA1122A-TO257-T 数据手册
Version: 1.1 14-Dec-23 Last Modification Date) CHT-IO-1210 DATASHEET High Temperature 1200V/10A Silicon Carbide Schottky Diode General description Features CHT-IO-1210 high temperature 1200V/10A • Specified from -55 to +210°C (Tj) Silicon Carbide Schottky Diode is designed • Reverse voltage: VR = 1200V (max) to achieve high performance in an extreme- • Forward current: IF = 10A (max @ 210°C (Tj) and VF = 1.7V) ly wide temperature range: typical operation temperature goes from -55°C to 210°C • Forward voltage: VF=1.2V (typ.@ 25°C (Tj) and IF=10A) while keeping leakage current low. This device is packaged in a hermetically • Junction capacitance: sealed TO-257 metal package especially designed and qualified to sustain high tem- Cj=93pF (typ. @ VR = 400V) • Hermetically sealed TO-257 metal perature and power cycling. This package offers high voltage isolation between pins package • Pins electrically isolated from the and with respect to the case, facilitating the mounting on a heatsink. case Applications The diode can be used in a variety of appli- • Free Wheeling cations, • Full bridge rectification including rectification, free- wheeling, clamping and general purpose. • Power supplies • General purpose diode PUBLIC Doc. PDS-151815 V1.1 WWW.CISSOID.COM 1 of 7 CHT-IO-1210 Datasheet 14-Dec-23 (Last Modification Date) Package Configuration FRONT VIEW C A 1 2 3 TO257 (Pin1= Cathode; Pin2= Anode Pin3= NC) (case floating) PUBLIC Doc. PDS-151815 V1.1 WWW.CISSOID.COM 2 of 7 CHT-IO-1210 Datasheet 14-Dec-23 (Last Modification Date) Absolute Maximum Ratings Reverse voltage VR Forward surge current IFSM Junction temperature Tj Operating Conditions 1200V 12A 210°C Reverse voltage VR 0V to 1200V Continuous forward current IF 0A to 10A Forward voltage VF 0V to 3.5V Junction temperature -55°C to +210°C PUBLIC Doc. PDS-151815 V1.1 WWW.CISSOID.COM 3 of 7 CHT-IO-1210 Datasheet 14-Dec-23 (Last Modification Date) Electrical characteristics Unless otherwise stated, Tj = 25°C. Bold figures point out values valid over the whole temperature range (T j = -55°C to +210°C). Parameter Symbol Condition IF=10A, Tj=25°C IF=10A, Tj=210°C VR=1200V, Tj=25°C VR=1200V, Tj=210°C Forward voltage VF Reverse leakage current IR Breakdown reverse voltage V(BR) Junction capacitance Cj VR=400V,Tj=25°C,f= 100kHz Symbol Condition Min Typ 1.5 1.7 20 500 Max 1200 Unit V V µA uA V 93 pF Thermal Characteristics Parameter Junction-to-Case Thermal resistance RΘJC Min Typ 1.1 Max Unit °C/W PUBLIC Doc. PDS-151815 V1.1 WWW.CISSOID.COM 4 of 7 CHT-IO-1210 Datasheet 14-Dec-23 (Last Modification Date) Typical performances 30 1.00E-03 -55°C 25°C 125°C 25 1.00E-04 210°C 175°C 1.00E-05 20 175°C 1.00E-06 IR [A] IF [A] 210°C 15 125°C 25°C 1.00E-07 -55°C 10 1.00E-08 5 1.00E-09 0 1.00E-10 0 0.5 1 1.5 2 2.5 3 3.5 0 4 200 400 600 VF[V] 800 1000 1200 VR[V] Figure 1: Diode IF vs VF Figure 2: Diode IR vs VR 1.8 1.00E-08 1.7 1.6 Capacitance (F) 1.00E-09 V TH[V] 1.5 1.4 1.3 1.00E-10 1.2 1.1 1.00E-11 1 0 -50 0 50 100 150 200 250 Figure 3: Diode VF vs Temp (IF = 10 A) 50 100 150 200 250 300 350 400 450 500 Reverse Voltage V R (V) Temperature [°C] Figure 4:Typical capacitance vs VR (Tj=25°C ; f = 100 kHz, VAC =25mV) PUBLIC Doc. PDS-151815 V1.1 WWW.CISSOID.COM 5 of 7 CHT-IO-1210 Datasheet 14-Dec-23 (Last Modification Date) Package Dimensions 5.0 10.6 1.0 17.5-18.5 16.5 13.5 10.6 Ø3.5 2.54 2.9 Ø0.8 TO257 dimensions in mm (+/- 10%) Ordering Information Product Name CHT-IO-1210 Ordering Reference CHT-PLA1122A-TO257-T Package TO257 Marking CHT-PLA1122A PUBLIC Doc. PDS-151815 V1.1 WWW.CISSOID.COM 6 of 7 CHT-IO-1210 Datasheet 14-Dec-23 (Last Modification Date) Contact & Ordering CISSOID S.A. Headquarters and contact EMEA: CISSOID S.A. – Rue Francqui, 11 – 1435 Mont Saint Guibert - Belgium T : +32 10 48 92 10 - F: +32 10 88 98 75 Email: sales@cissoid.com Sales Representatives: Visit our website: http://www.cissoid.com Disclaimer Neither CISSOID, nor any of its directors, employees or affiliates make any representations or extend any warranties of any kind, either express or implied, including but not limited to warranties of merchantability, fitness for a particular purpose, and the absence of latent or other defects, whether or not discoverable. In no event shall CISSOID, its directors, employees and affiliates be liable for direct, indirect, special, incidental or consequential damages of any kind arising out of the use of its circuits and their documentation, even if they have been advised of the possibility of such a damage. The circuits are provided “as is”. CISSOID has no obligation to provide maintenance, support, updates, or modifications. PUBLIC Doc. PDS-151815 V1.1 WWW.CISSOID.COM 7 of 7
CHT-PLA1122A-TO257-T 价格&库存
很抱歉,暂时无法提供与“CHT-PLA1122A-TO257-T”相匹配的价格&库存,您可以联系我们找货
