CMT-PLA3SB12340AA
CMT-PLA3SB12340AA
    CISSOID
CMT-PLA3SB12340AA 数据手册
3-Phase 1200V/340A SiC MOSFET Intelligent Power Module CMT-PLA3SB12340A-Preliminary Datasheet Version: 1.6 15-Dec-23 (Last Modification Date) General description CMT-PLA3SB12340A is a 3-phase 1200V/340A SiC MOSFET Intelligent Power Module integrating the power switches and the gate driver based on CISSOID HADES2® chipset. With its lightweight flat AlSiC baseplate, this module addresses high power density converters offering a SiC power module designed for operation at high junction temperature (up to 175°C). This solution gives access to the full benefits of SiC PUBLIC Doc. PDS-212182 V1.6 technology to achieve high power density thanks to low switching losses and high temperature operation. The integration of the gate driver together with the power module give direct access to a fully validated and optimized solution in terms of switching speed and losses, robustness againt dI/dt and dV/dt and protection of the power stages (Desat, UVLO, AMC, SSD). WWW.CISSOID.COM 1 of 22 CMT-PLA3SB12340A Datasheet 15-Dec-23 (Last Modification Date) Key Features • Single power supply (VCC): • VDS breakdown voltage: 1200V • Low RDSON1: typ 3.25mΩ - • Max Continuous current: - • Max 125°C operating ambient temperature (gate driver) 340A typ. @ Tc=25°C 295A typ. @ Tc=90°C • Isolation (primary – secondary): • Thermal resistance: 0.183 °C/W typ. • Max 175°C operating junction temperature (power devices) Eon: 8.42 mJ - Eoff: 7.05 mJ - - • Isolation (baseplate – power pins): 3600VAC @50Hz (1min) • Common mode transient immunity: - typ 11pF per phase 5V Schmitt trigger input Active-High (Active-Low as an option) • Open-drain fault reporting: - per side (top or bottom) per phase as an option • Turn-On/Off delay: 180ns typ. >50kV/µs • Under voltage lockout (UVLO) • Dimensions: - 3600VAC @50Hz (1min) • PWM input signal • Switching frequency: 50kHz Max2 - - • Parasitic capacitance: • Switching Energy@ 600V/300A: - +12V to +18V 104(W) x 154(L) X 34(H) (all in mm) • Weight: 550g - On VCC On internally generated secondary supplies • Desaturation protection 1 Package resistance excluded 2 With Gate driver temperature derating from 25KHz to 50KHz (see curve at page 17) • Soft Shutdown turn-off (SSD) • Negative gate drive (-3V) • Active Miller Clamping (AMC) • Gate-Source Short-circuit Protection Ordering Information Product Name CMT-PLA3SB12340A PUBLIC Doc. PDS-212182 V1.6 Ordering Reference CMT-PLA3SB12340AA WWW.CISSOID.COM Marking CMT-PLA3SB12340AA 2 of 22 CMT-PLA3SB12340A Datasheet 15-Dec-23 (Last Modification Date) Block diagram VDCW+ VX-WT VREF FLT-WT VREF WH-WT X PWM-WT CLK DC/DC WL-WT VH-WT VDC- VCC VX-WT W VL-WT VH-WB GND VDC- VX-WB VL-WB VX-WB VREF FLT-WB VREF VH-WB X PWM-WB CLK VL-WB VDCV+ VX-VT VREF FLT-VT VDCW- VREF VH-VT X PWM-VT CLK DC/DC VL-VT VH-VT VDC- VCC VX-VT V VL-VT VH-VB GND VDC- VX-VB VL-VB VX-VB VREF FLT-VB VREF VH-VB X PWM-VB CLK VL-VB VDCU+ VX-UT VREF FLT-UT VDCV- VREF VH-UT X PWM-UT CLK DC/DC VL-UT VH-UT VDC- VCC VX-UT U VL-UT VH-UB GND VDCVL-UB FLT-UB VX-UB VX-UB VREF VREF VH-UB X PWM-UB CLK VL-UB PUBLIC Doc. PDS-212182 V1.6 WWW.CISSOID.COM VDCU- 3 of 22 CMT-PLA3SB12340A Datasheet 15-Dec-23 (Last Modification Date) Pinout3 “VDCU+, VDCV+, VDCW+”, “VDCU-, VDCV-, VDCW-” are not connected to each other internally 3 PUBLIC Doc. PDS-212182 V1.6 WWW.CISSOID.COM 4 of 22 CMT-PLA3SB12340A Datasheet 15-Dec-23 (Last Modification Date) Pinout (cnt’d) Interface Pin Pin name VDCU+ VDCUVDCV+ VDCVVDCW+ VDCWU V W Description U Phase positive power supply U Phase negative power supply V Phase positive power supply V Phase negative power supply W Phase positive power supply W Phase negative power supply Half-Bridge output U Half-Bridge output V Half-Bridge output W Pin 1 Pin 2 PWM-UT PWM-UB Pin 3 TEMP-U Pin 4 RSTN Pin 5 Pin 6 Pin 7 Pin 8 PWM-VT VDCM PWM-VB GND Pin 9 FLT-T-V Pin 10 GND Pin 11 FLT-B-U Pin 12 VCC Pin 13 TEMP-V Pin 14 Pin 15 Pin 16 VCC PWM input high-side phase U PWM input low-side phase U Phase U temperature measurement output Reset signal (active low); while low, forces all PWM to inactive state PWM input high-side phase V DC BUS voltage monitoring output PWM input low-side phase V Gate driver negative power supply Phase V fault output or 3 phase high-side (=top) fault output Gate driver negative power supply Phase U fault output or 3 phase low-side (=bottom) fault output Gate driver positive power supply Phase V temperature measurement output Gate driver positive power supply GND Pin 17 FLT-W Pin 18 TEMP-W Pin 19 Pin 20 PWM-WT PWM-WB POWER CONTROL PUBLIC Doc. PDS-212182 V1.6 Gate driver negative power supply Phase W fault output (not used in case of fault reporting per side) Phase W temperature measurement output PWM input high-side phase W PWM input low-side phase W WWW.CISSOID.COM 5 of 22 CMT-PLA3SB12340A Datasheet 15-Dec-23 (Last Modification Date) Max Absolute Ratings “SiC Power MOSFET’s” Parameter Symbol Drain – Source Voltage VDS MOSFET Continuous Drain Current Pulsed Drain Current Junction temperature Case and Storage temperatures Stray Inductance ID IDpulse Tj TC,TSTG LStray Package resistance @ 25°C4 Clearance distance Creepage distance CTI-Comparative Tracking Index Mounting Torque Weight 4 MP MBP g Condition Tj=25°C Tj=175°C VGS =15V, TC=25°C, Tj15 mm min 175 4 2 550 N-m N-m g Package resistance temperature coefficient: 0.39%/°C PUBLIC Doc. PDS-212182 V1.6 WWW.CISSOID.COM 6 of 22 CMT-PLA3SB12340A Datasheet 15-Dec-23 (Last Modification Date) Max Absolute Ratings “Gate Driver” Parameter VCC-GND PWM-XT/PWM-XB/RSTN wrt GND FLT-B-U/ FLT-T-V/FLT-W wrt GND Min. -0.5 -0.5V -0.5V 175 CTI-Comparative Tracking Index Junction Temperature Storage and Operating Temperature ESD Rating (Human Body Model) between VCC/GND/PWM-XT/PWM-XB/RSTN/FLT-X pins5 -40 1.5 Max. 18 5.5 18 Units V V V 175 125 °C °C kV Max. Units Isolation Parameter VDCX+/VDCX-/U/V/W wrt to VCC/GND/PWMXT/PWM-XB/FLT-X Any of “VDCX+/VDCX/U/V/W/VCC/GND/PWMXT/PWM-XB/FLT-X wrt to baseplate Parasitic capacitance Condition Min. AC @50Hz (for 1mn) Typ. 3600 V @ 1000VDC >1 GΩ Between high-side and primary (per phase) 11 pF DC Bus Voltage Monitoring6 Parameter Symbol DC BUS voltage monitoring output Isolation between VDCM and VDCV+/VDCU- Condition VDCM Typ Unit 0.0033*Diff(VDCV+,VDCU-) V >40 MΩ 1200VDC; 175°C Temperature Monitoring Parameter Symbol Temperature monitoring output NTC resistance NTC isolation wrt power device terminals7 TEMP-U TEMP-V TEMP-W NTCR Condition Typ Unit NTCR (Ohm)*5/( NTCR (Ohm)+1500) V 5000 Ω >10 GΩ TNTC=25°C 1200VDC; 175°C Steinhart-Hart Coefficients for NTCR versus Temperature computation: 1/(TNTC-273.15) = A+B*ln(R)+C*ln3(R) TNTC< (273.15+25)K TNTC> (273.15+25)K A 9.931*10-4 9.923*10-4 B 2.658*10-4 2.664*10-4 C 1.563*10-7 1.496*10-7 5 Because of functional isolation requirement between «VDCX+/VDCX-/U/V/W» and « VCC/GND/PWM-XT/PWMXB/FLT-X » pins, no ESD performance can be guaranteed between those 2 pin groups. 6 There is no galvanic isolation on this measurement but monitored voltage goes through four 10 MOhms resistors (respecting 7.1mm creepage over the resistor chain); at 1200V, there is a max current of 30µA 7 Isolation is provided by the gel inside the power module PUBLIC Doc. PDS-212182 V1.6 WWW.CISSOID.COM 7 of 22 CMT-PLA3SB12340A Datasheet 15-Dec-23 (Last Modification Date) Electrical Characteristics ”Power module” Unless otherwise stated: (VCC-GND)=15V, TC=25°C. Bold underlined values indicate values over the whole temperature range (-40°C < TJ < +175°C). “SiC Power MOSFET’s” Parameter Symbol Condition Tj=25°C ; IDS = 0.02A; VDS = VGS Threshold voltage VTH Tj=175°C ; IDS = 0.02A; VDS = VGS VGS =-3V, VDS=1200V, Tj=25°C Drain cut-off current IDSS VGS =-3V, VDS =1200V, Tj=175°C VGS =15V, ID=300A, Tj=25°C Static drain-to-source reRDSon sistance8 VGS =15V, ID=300A, Tj=175°C Breakdown drain-to-source VBRDS VGS =-3V; IDS = 500 µA voltage (DC characterization) Input capacitance CISS VGS =0VDC, VDS =600VDC f = 100 kHz Output capacitance COSS VAC = 25mV Feedback capacitance CRSS Turn-on delay time Td(ON) Rise time Tr Turn-off delay time Td(OFF) VDS=600V; VGS= -3/15V; IDS = 300A; L = 50µH Fall time Tf Turn-On Switching Energy Eon Turn-Off Switching Energy Eoff Gate to Source Charge QGS Tj=25°C ;VDS= 600V; Gate to Drain Charge QGD IDS = 300A; VGS = -3/15V Total Gate Charge QG TJ=25°C Short-circuit protection threshISCth TJ=175°C old Maximum short-circuit duration tSC Min 1.8 Typ 2.15 Max 3.5 Unit V 1.7 V 1 50 3.25 5.15 µA µA mΩ mΩ 4 1200 V 30 1.3 76 134 158 212 57 8.42 7.05 292 285 910 nF nF pF ns ns ns ns mJ mJ nC nC nC 1145 750 2 A A µs “SiC Reverse Diode” Parameter Diode Forward Voltage Symbol Condition Tj=25°C ; ISD = 300A; VGS =-3V VF Tj=175°C ; ISD = 300A; VGS =-3V Continuous Diode Forward Current Diode Pulse Current Typ 5.18 4.5 Max Unit V V ISD,DC VGS =-3V, Tc=25°C, Tj LOW Non Overlap delay LOW => HIGH PWM data path PWM frequency9 Duty cycle Anti-glitch filter window Propagation delay (PWM-XB/PWM-XT →U/V/W) (50% to 10%) Propagation delay (PWM-XB/PWM-XT → U/V/W) (50% to 10%) 50 100 500 kHz % ns 180 ns 600 ns 0 Direct Mode; excluding anti-glitch filter delay Local Mode; excluding anti-glitch filter delay Fault latching time Timer value (Primary or Secondary faults) Timer variation Under-voltage Lockout on VCC (UVLO_P) UVLO_P High Threshold UVLO_P Low Threshold Delay from UVLO_P detection to FLT-X @ fault level Under-voltage Lockout on secondaries gate driver supplies(UVLO_S) UVLO_S High Threshold UVLO_S Low Threshold Delay from UVLO_S detection to FLT-X @ fault level Desaturation detection (DESAT_H, DESAT_L) Desaturation Threshold wrt to power switch source Desaturation Blanking time Delay from Desaturation detection to FLT-X in fault state 9 Please refer 14 -30 to ms +25 % 9.75 8.2 V V 200 ns 16.8 15.5 V V 600 ns 4.6 1 V µs 600 ns section Gate driver temperature derating for operation above 25kHz (page 17) PUBLIC Doc. PDS-212182 V1.6 WWW.CISSOID.COM 9 of 22 CMT-PLA3SB12340A Datasheet 15-Dec-23 (Last Modification Date) Soft Shutdown gate fall time VGS from 15V to 0V 1 µs Typical performances (per switch) Figure 1: Drain current vs VDS (VGS=15V, tp < 200µs)10 Figure 2: On-state drain source resistance vs. Drain current (VGS =15V, tp < 200µs)10 Figure 3: Normalized on-state drain source resistance (IDS=300A, VGS =15V, tp < 200µs)10 Figure 4: Drain current vs VGS voltage (VDS=20V, tp < 200µs) Figure 5 : 3rd quadrant characteristics (VGS=15V, tp < 200µs)10 Figure 6: 3rd quadrant characteristics (VGS=3V, tp < 200µs)10 10 Package resistance excluded PUBLIC Doc. PDS-212182 V1.6 WWW.CISSOID.COM 10 of 22 CMT-PLA3SB12340A Datasheet 15-Dec-23 (Last Modification Date) Typical performances (per switch) (cnt’d) Figure 7: Typical capacitances vs VDS (Tj=25°C ; f = 100 kHz, VAC =25mV) Figure 8 : Typical capacitances vs VDS (Tj=25°C ; f = 100 kHz, VAC =25mV) Figure 9: Threshold vs temp (IDS=20mA; VGS=VDS) Figure 10 : Switching Energy Figure 11 : Reverse Recovery Energy Figure 12 : Max dV/dt vs Drain current VDS IDS 10% VDS 10% VDS 10% IDS 10% IDS ESW (on) Figure 13 : Max Turn-off dI/dt vs Drain current PUBLIC Doc. PDS-212182 V1.6 ESW (on) Figure 14 : Switching energy computation WWW.CISSOID.COM 11 of 22 CMT-PLA3SB12340A Datasheet 15-Dec-23 (Last Modification Date) Typical performances (per switch) (cnt’d) Figure 15: MOSFET Junction to Case Thermal Impedance Figure 16: Forward Bias Safe Operating Area (FBSOA) Figure 17 : Reverse Bias Safe Operating Area (RBSOA) Figure 18: Continuous Drain Current Derating vs Case temperature Figure 19 : Maximum Power Dissipation Derating vs Case temperature Figure 20 : Typical Output Current Capability vs Switching Frequency (Inverter Application) PUBLIC Doc. PDS-212182 V1.6 WWW.CISSOID.COM 12 of 22 CMT-PLA3SB12340A Datasheet 15-Dec-23 (Last Modification Date) Gate Driver Circuit Functionality Description Under-Voltage Lockout (UVLO) Main features of the CMT-PLA3SB12340A gate driver are: - Isolated data transmission (robust to high dV/dt) (data and fault) on both high and low side channels - Adjustable fault timer with automatic restart - Safe start-up sequence through monitoring of the main supply (UVLO) and of the voltage regulators output (through Power-Good function) - Permanent and programmable Under-Voltage Lockout (UVLO) monitoring on external and internally generated power switch supplies - Desaturation detection function with programmable blanking time and threshold protecting power switches in case of abnormal current levels - Soft-Shutdown transistor and control performing power device graceful shutdown in case of fault and so preventing too high dI/dt in the power stage - Flyback DC-DC converter (one per phase) with cycle-by-cycle current limit for short circuit protection - High-precision (typ 3%) high-level gate voltage generation - Single-ended Schmitt-trigger PWM inputs - Open-drain low-ohmic (typ. 25Ω) fault output - Support of 2 separate incoming PWM channels and of locally generated non-overlapped PWM signals (per phase) (configuration via jumper) - Configurable 500ns (typ) spike filter on incoming PWM signal for enhanced noise robustness - Anti-overlap protection on incoming PWM signals - Gate-2-Source short-circuit protection - Support of 100% duty-cycle PWM - Very low parasitic capacitance between secondaries and primary CMT-PLA3SB12340A gate driver board monitors constantly: PUBLIC Doc. PDS-212182 V1.6 - VCC power supply High-side secondary supplies (typ +15V/-3V) Low-side secondary supplies (typ +15V/-3V) At primary side, the monitored power supply is “VCC-GND”; to avoid oscillation when (VCC-GND) is close to the UVLO threshold, a hysteresis is implemented. At each secondary side, the monitored power supply is “VDD_L-VSS_L”/ “VDD_H-VSS_H”; to avoid oscillation when (VDD_x-VSS_x) is close to the UVLO threshold, a hysteresis is implemented. Refer to the chapter Fault Management for details about fault behavior and management. On-board power supplies The on-board isolated power supply (per phase) is a regulated flyback DC-DC converter providing both high-side and lowside channels with the positive and negative supply voltages required to drive the power FETs. It offers high voltage isolation between the channels, high dV/dt sustainability and very low parasitic capacitance. Cycle-by-cycle current monitoring at primary side is implemented to protect the board against short-circuit. High accuracy (typ 3%) is achieved on all secondary positive supplies. WWW.CISSOID.COM 13 of 22 CMT-PLA3SB12340A Datasheet 15-Dec-23 (Last Modification Date) Interface towards controller Desaturation detection PWM inputs The purpose of the desaturation function is to detect that the voltage at the drain of the power switch, in “ON” state, is higher than a given threshold. This informs the logic part of the system about possible damage of the power arm (e.g. a short circuit at the arm level leading to an overcurrent in the power switch). PWM-XB and PWM-XT input interface is based on 5V Schmitt-Trigger input receivers and is Active High. Active Low is available as an option. CMT-PLA3SB12340A gate driver board implements 2 protection functions on the PWM data paths: - Anti-glitch: any negative or positive glitch on PWM-XB/PMW-XT signals smaller than a programmed value is ignored by the board; this is increasing immunity of incoming signals against external noise; the PWM signals are delayed by the corresponding antiglitch time tMINPW (ns)= 1* [CGLIx (pF)] - The desaturation threshold (voltage on transistor VDS) is configured by on-board resistors and can be tuned according to the table below. Rdesat value Anti-overlap: this circuit prevents PWM-XB and PMWH from being active at the same time. FAULT outputs 0KΩ 5KΩ 10KΩ 12KΩ Desat threshold (V) 25°C 125°C 1.18 1.47 2.6 2.87 4.01 4.27 4.6 4.83 (default) The output buffers operate as an opendrain driver with a very low Ron resistance (typ. 25Ω), enabling the use of low value pull-up resistance for increased noise immunity. An on-board 10k pull-up resistance (connected to internal 5V supply) is present on each fault output to ease initial testing. By default, there is one fault output per side [top/bottom] (one fault per phase is available as an option11). 15KΩ 20KΩ 5.42 6.84 5.66 7.06 At system level, the de-saturation detection should only be taken into account after a defined time following the low-to-high transition on the power device gate. This “blanking” time tDESAT_D is implemented and adjusted by an on-board capacitor CDESATD (68pF installed) and can be calculated as follows: tDESATD (ns)= 14* [CDESATD (pF) + 7] Isolated data transmission CMT-PLA3SB12340A gate driver board uses integrated digital isolators. Those devices provide isolation, immunity against high dV/dt and low parasitic capacitance. In case no power supply is present at the secondary side, a fault is generated at the primary side. 11 The sensing of the power device drain voltage is performed through a high voltage sensing diode whom cathode is connected to the power switch drain and whom anode is connected to a current source (typ 2mA) and a sensing circuit. If after tDESAT_D time, the DESAT comparator output indicates that the transistor VDS level is higher than the programmed threshold value, an internal DESAT fault is generated. Refer to the chapter Fault Management for details about fault behavior and management. When the desaturation fault is detected, the power module gate is gracefully discharged thanks to the Soft-Shutdown circuit to avoid high dI/dt at power module turn-off Contact CISSOID if you require this option PUBLIC Doc. PDS-212182 V1.6 WWW.CISSOID.COM 14 of 22 CMT-PLA3SB12340A Datasheet 15-Dec-23 (Last Modification Date) Active Miller Clamping In case of high positive dV/dt and despite the negative drive of the power module gate, a parasitic turn-on of the gate could take place, inducing shoot-through current on the power arm. To prevent this, CMT-PLA3SB12340A gate driver board implements an Active Miller Clamping function by bypassing the gate resistance with a low ohmic path (implemented with a transistor) when the gate is driven negative. This transistor also helps to limit the amplitude of negative kick on the power module gate in case of negative dV/dt. Fault Management Fault management is taking place on each phase independently. At primary side, fault is generated by any of those situations: - Main power supply (VCC) is below the UVLO threshold Primary linear voltage regulator (generating the 5V output required by the on-board logic) is below the internal Power Good level The primary fault state is combined with the faults returned by the secondary devices according to Table 2. At each of the secondary side, fault is generated by any of those situations: - - Those faults are internally combined to generate a unique fault signal. This internal fault signal is latched for 14msec. While the fault is latched, the gate driver is turned off. At the transition between “no fault” and “fault” situation, the gate driver circuit is gracefully shut down. After the predefined latch time period, the gate driver circuit returns to normal operation: - - Those faults are internally combined to generate a unique fault signal. This internal fault signal is latched for 14msec. While the fault is latched: - Both FLT-X pins are tied to “0” Both power switches are turned off On board DC-DC Converter is off After the predefined latch time period, the phase controller will attempt to return to normal operation: - If the fault is still present, the phase will stay in the fault state till the fault disappears - If the fault disappeared (e.g. temporary UVLO situation), the phase will go out of FAULT state and return to normal operation (DC-DC Converter turned on and data paths active); still, on the PWM path, transition to normal operation will happen on the next positive edge of the incoming PWM signal. PUBLIC Doc. PDS-212182 V1.6 Power supply is below the UVLO threshold Secondary voltage regulator (5V) output voltage is below the PowerGood threshold Desaturation situation is detected by the DESAT comparator Prim fault If the fault is still present, the gate driver is kept turned off till the fault disappears If the fault disappeared (e.g. temporary UVLO situation), normal operation will resume on the next positive edge of incoming PWM signal No Lowside fault No Highside fault No No Yes No No No Yes No Yes Yes Yes or No Yes Yes or No FLT-B-U (Bottom) FLT-T-V (Top) High-Z (pulled up) Pulled down High-Z (pulled up) High-Z (pulled up) Pulled down High-Z (pulled up) Pulled down Pulled down Pulled down Pulled down Table 1: FAULT aggregation table (Default option:reporting per side) Prim fault No Low-side fault No High-side fault No No No No Yes Yes No Yes Yes or No No Yes Yes Yes or No FLT-X High-Z (pulled up) Pulled down Pulled down Pulled down Pulled down Table 2: FAULT aggregation table WWW.CISSOID.COM 15 of 22 CMT-PLA3SB12340A Datasheet 15-Dec-23 (Last Modification Date) RSTN (Reset) behaviour While in Low-State, pin RSTN forces all PWM input signals to “0”, turning off all SiC MOSFET gates in Direct mode and turning off the High-Side SiC MOSFET and keeping Low-Side SiC MOSFET on in Local Mode The choice between those 2 modes of operation is made via the 2 pin header jumper JP1 (located at primary side, one per phase): - JP1 ON: Local mode JP1 OFF: Direct mode Protections CMT-PLA3SB12340A gate driver is protected on each channel against: - Gate overvoltage Gate undervoltage Gate-source permanent circuit short- Non-Overlap Generation CMT-PLA3SB12340A gate driver board offers 2 modes of operation: - - Direct Mode: PWM-XB and PWMXT are generated independently outside CMT-PLA3SB12340A gate driver board. In this case, proper non overlapping must be generated externally. Local Mode: PWM-XB and PWMXT are generated from one input signal (PWM-XT) and proper non overlapping timing is managed locally on each phase of CMTPLA3SB12340A gate driver board (cfr Figure 21) PWM-XT When in Local Mode, an on-board capacitance (Cnovd) defines the non-overlap delay according to following formula: tNOV_D (ns)=5.5 * CNOVD (pF) Board power dissipation Current consumption of the CMTPLA3SB12340A gate driver board (VCC=15V; VDCX+=0V) can be computed as follows: 𝐼𝑖𝑛 = 170𝑚𝐴 + 8.4 ∗ 𝐹𝑠 Where: - G_HS G_LS tNOV_D tNOV_D Figure 21: Local Mode operation Iin: Input current (in mA) (wrt to VCC = 15V) Fs: Switching frequency (in kHz) The duty cycle of the PWM-XB/PWM-XT signals has almost no influence on the current consumption (assuming PWM-XB and PWM-XT duty cycles are complementary). To stay within specifications of the internal secondary voltages, the maximum average Iin current should be 1000 mA (for VCC =15V). PUBLIC Doc. PDS-212182 V1.6 WWW.CISSOID.COM 16 of 22 CMT-PLA3SB12340A Datasheet 15-Dec-23 (Last Modification Date) Temperature measurement Gate driver temperature derating Temperature of each phase is measured using an NTC resistance mounted on the power module DBC. The CMT-PLA3SB12340A gate driver has been designed to operate at 125°C ambient upto 25kHz switching frequency. Above 25 kHz, a derating according to the graph below needs to be applied. The NTC resistance variation with respect to temperature is reported in Figure 22: NTC resistance vs tempand obeys to the formula provided in section Max Absolute Ratings. Figure 24: Gate driver temperature derating Figure 22: NTC resistance vs temp The NTC resistance value is converted into an analog voltage fed to the connector pins TEMP-U, TEMP-V, TEMP-W. Figure 23: TEMP-X voltage vs tempshows the relationship between TEMP-X voltage and NTC temperature. 5 4.5 TEMP-X pin voltage (V) 4 3.5 3 2.5 2 1.5 1 0.5 0 -55 -5 45 95 145 195 Temperature (°C) Figure 23: TEMP-X voltage vs temp PUBLIC Doc. PDS-212182 V1.6 WWW.CISSOID.COM 17 of 22 CMT-PLA3SB12340A Datasheet 15-Dec-23 (Last Modification Date) Timing Diagrams Figure 25 illustrates the CMT-PLA3SB12340A gate driver board low-side driver dynamic behavior in normal operation and fault conditions. Normal Case PWM-XB 1 Fault UVLO Normal Case 6 2 7 G_LS UVLO 3 FLT-X Internal timer 4 Normal Case PWM-XB 1 tFLTD 5 FAULT Desat Normal Case 3 7 8 G_LS D_LS tDESATD DESAT BLANK tDESATD FLT-X 2 4 Internal timer 5 tFLTD 6 Figure 25: Timing diagram CMT-PLA3SB12340A low-side gate driver behaviour In Normal operation In DESAT fault situation On PWM-XB rising edge (1), rising edge is generated on G_LS (after propagation delay through CMT-PLA3SB12340A gate driver board). After rising edge on G_LS, low-side power module is turned ON and midpoint node is going to “0” state (voltage equals to Ron * current flowing through the power device). D_LS node is also pulled down and after blanking time (tDESAT_D), no desaturation fault is detected and FLT-X remains high. On PWM-XB rising edge (3), rising edge is generated on G_LS (after propagation delay through CMT-PLA3SB12340A gate driver board) After rising edge on G_LS, low-side power module is turned ON; because of a desaturation fault, D_LS node does not reach its normal “0” level. Thanks to the DESAT comparator, CMT-PLA3SB12340A gate driver board detects this fault situation and turns off gracefully G_LS. Power device is turned off. FLT-X signal is pulled down. Fault is cleared after fault timer expiry. On PWM-XB falling edge (2), falling edge is generated on G_LS (after propagation delay through CMT-PLA3SB12340A gate driver board) After falling edge on G_LS, the low-side power device is turned OFF. PUBLIC Doc. PDS-212182 V1.6 WWW.CISSOID.COM 18 of 22 CMT-PLA3SB12340A Datasheet 15-Dec-23 (Last Modification Date) In UVLO fault situation Glossary UVLO status is monitored inside the secondary devices (and inside primary device as well; for clarity, only secondary UVLO situation is described here). When UVLO comparator (5) detects an under-voltage situation, G_LS is gracefully shut down FLT-X signal is pulled down. Fault is cleared after fault timer expiry. Name D_HS S_HS G_HS D_LS S_LS G_LS PUBLIC Doc. PDS-212182 V1.6 WWW.CISSOID.COM Description Drain of any high-side switch Source of any high-side switch Gate of any high-side switch Drain of any low-side switch Source of any low -side switch Gate of any low -side switch 19 of 22 CMT-PLA3SB12340A Datasheet 15-Dec-23 (Last Modification Date) Mechanical drawing PUBLIC Doc. PDS-212182 V1.6 WWW.CISSOID.COM 20 of 22 CMT-PLA3SB12340A Datasheet 15-Dec-23 (Last Modification Date) Physical dimensions (mm) Base plate material: AlSiC Power pins finish: Ni Gate driver control pins finish: Au Gate driver control connector: Molex 87831-2020 Item Baseplate fixing screws DC Bus Power connector bolts Phase power connector bolts Gate driver female counter connector board-2-cable Gate driver female counter connector board-2-board Recommended reference M4x10 ISO 7380-2 A2 TX M6x12 ISO 7380-2-A2-TX M6x12 ISO 7380-2-A2-TX Comments Assumes min 0.7 mm DC power connector thickness Assumes min 1.6 mm phase connector thickness Molex 51110 SERIES Molex 78787-2054(Tin) or 79107-7009(Gold). Note: The product is delivered with a bag of 6 square M5 nuts. Those nuts are meant to replace the 6 square M6 nuts fitted into the power tabs for customers who bought from Advanced Conversion capacitance with part number 700A360,700A361,906A115, 906A116, 906A117. PUBLIC Doc. PDS-212182 V1.6 WWW.CISSOID.COM 21 of 22 CMT-PLA3SB12340A Datasheet 15-Dec-23 (Last Modification Date) Contact & Ordering CISSOID S.A. Headquarters and contact EMEA: CISSOID S.A. – Rue Francqui, 11 – 1435 Mont Saint Guibert - Belgium T : +32 10 48 92 10 – F : +32 10 88 98 75 Email : sales@cissoid.com Sales Representatives: Visit our website: http://www.cissoid.com Disclaimer Neither CISSOID, nor any of its directors, employees or affiliates make any representations or extend any warranties of any kind, either express or implied, including but not limited to warranties of merchantability, fitness for a particular purpose, and the absence of latent or other defects, whether or not discoverable. In no event shall CISSOID, its directors, employees and affiliates be liable for direct, indirect, special, incidental or consequential damages of any kind arising out of the use of its circuits and their documentation, even if they have been advised of the possibility of such a damage. The circuits are provided “as is”. CISSOID has no obligation to provide maintenance, support, updates, or modifications. PUBLIC Doc. PDS-212182 V1.6 WWW.CISSOID.COM 22 of 22
CMT-PLA3SB12340AA 价格&库存
很抱歉,暂时无法提供与“CMT-PLA3SB12340AA”相匹配的价格&库存,您可以联系我们找货
CMT-PLA3SB12340AA
    CMT-PLA3SB12340AA
