ATLAS IT
ATLAS IT
    3PEAK(思瑞浦)
    PEAK - ATLAS IT - Cable Continuity Tester, 70 mm, 20 mm
ATLAS IT 数据手册
Atlas IT network cable analyser Model: UTP05 electronic design ltd PRODUCT BRIEF The Intelligent Choice The Peak Atlas IT Network Cable Analyser has just got smarter, much smarter. The Atlas IT has always been a fabulous tool for identifying and analysing RJ45 based network cables, sockets and patch panels. Now this instrument features new intelligent software that can identify cable configurations even if there are faults in the cabling. It will even tell you the differences that it has detected between your faulty cable and the intended cable configuration. Simply connect one end of your network cable to the Atlas IT and the other end to the Atlas IT Terminator and press the test button. Within seconds, the Atlas IT will analyse the full connection pattern between one end of the cable and the other end. It then instantly identifies the cable type (based on the connection pattern) and displays this on it's easy-to-read green-mode display. The Atlas IT now features an enhanced cable library, enabling the intelligent identification of cable configuration, such as: "Straight-Through Patch Cables", "Crossover Cables", "Token Ring Cables", "Ethernet Economiser Adapters" and many more. If any problems in the cabling are detected, such as shorted, swapped or missing connections, then the Atlas IT will clearly identify these on it's display, showing exactly which connections require attention. Key Features: ! ! ! ! ! ! ! ! Supplied with carry case Automatic identification of cable configuration: Straight-Through patch (4, 6 and 8 way types), Crossover (several types), TokenRing, Cisco Twisted, Ethernet Economisers and many more. Identification of fault types including missing/broken wires, shorted wires and swapped wires. Display of standard wiring colours. Compatible with optional identified terminators, great for multiple cable runs. Protected against voltages present on live voice and data systems. Supplied with 2 miniature terminators, ideal for tight spaces. Clear and user-friendly scrollable display. Spare battery, ethernet chart and user guide supplied. Identify multiple cable runs with the optional identified terminators Please note that specifications of our products are subject to change without notice. E&OE. Peak Electronic Design Limited West Road House, West Road, Buxton, Derbyshire, SK17 6HF. Tel.+44 (0)1298 70012, Fax. +44 (0)1298 70046 See us on the Web: www.peakelec.co.uk Email: sales@peakelec.co.uk 02/08
ATLAS IT 价格&库存
很抱歉,暂时无法提供与“ATLAS IT”相匹配的价格&库存,您可以联系我们找货
