DCF102K36Y5PQ6BL7A0
DCF102K36Y5PQ6BL7A0
    SHM(南方宏明)
    插件,P=7.5mm
    Y5P
DCF102K36Y5PQ6BL7A0 数据手册
瓷介电容器 Ceramic Capacitors 特性 Feature ■容量范围 Wide capacitance range from 100pF to 10000pF ■工作温度 Operating Temperature: -40℃~125℃ ■存储温度 Storage Temperature: -10℃~40℃ 应用 Applications 瓷介电容器适用于电子设备的电源电路噪声抑制电路中,也可用于天线耦合跨接和旁路电路中。 These products Can be used in noise suppression of power supply circuit for general electronic equipment, and might be used as antenna coupling, crossing and bypass circuit. 使用标准Applicable Standard 通过认证 APPROVAL 认证组织 ORGANIZATION 标准. SAFTY STANDARDS 证书 CERTIFICATE NO. UL CUL UL60384-14 E154899 CSA CAN/CSA-E60384-14 2405436 2405437 (VDE+ENEC)VD E IEC 60384 –14 40036393 40036246 SEMKO EN60384-14 1914801 KTC K60384 – 14 HU03004-16006A HU03004-16007A HU03004-16008A NEMKO EN60384-14 P19223823 DEMKO EN60384-14 D-03468-M1 FIMKO IEC 60384 –14 FI 40341 SEV IEC 60384 –14 19.0474 19.0475 CQC IEC 60384 –14 CQC15001124387 CQC15001124387 CQC15001127382 产品型号Part Number DCF 331 K 30 Y5P G 6 B L 0 □ □ 型号 Type: DCF:交流圆片瓷介电容器 DCG:超高压瓷片电容器 DCH:高压圆片瓷介电容器 电极材料: Electrode Material Copper or Silver electrode 电容量(Capacitance): 470:47pF 内部管理代码 Interior managing 471:470pF 472:2200pF 位引线间距 Lead spacing: 103:10000pF 5=5.0mm 电 容 量 允 许 偏 差 Capacitance Tolerance: M=20% Z=+80%-20% K=±10% J=±5% 见规格详情 See the specification 温度特性 temperature characteristic: Y5P,Y5U,Y5V 引线式样 Lead style: L、J、 见引线形状 see the lead style Figure1-2 and figure 1-3 B=26.0±1.0mm, L=2.3±0.3mm D=4.5±0.5mm,J=3.2±0.3mm, W=3.4±0.3mm, K=2.8±0.5mm, F=12.7mm 编带/扇折,V=15.0mm 编带/扇折 引线直径 Lead diameter: 额定电压 Rated voltage: P=2KVDC G=X1 400VAC Y1 250VAC 0=10mm 位引线长度/包装方法/ Lead length/package: 尺寸代码 Size: N=1KVDC 7=7.5mm R=3KVDC Q=X1 400VAC/Y2 250VAC 脚型 Lead style CP 线: 6=0.55±0.05mm 8=0.78±0.05mm 规格Specification 产品尺寸(mm) 电容量 允许偏 差范围 Tolerance (%) 温度特性 Temperature Characteristic 100 ±10% Y2 300~ 220 DCF471K26Y5PQ6BL7A0 Y2 300~ DCF681K26Y5PQ6BL7A0 额定电 压 Rated voltage (KV) 标称容量 Nominal capacitance (pF) DCF101K26Y5PQ6BL7A0 Y2 300~ DCF221K26Y5PQ6BL7A0 SHM 产品代码 SHM Part No. 引线间 引线直径 Dmax. Tmax. 距 d (mm) 直径 厚度 引线长 度L (mm)/编 带方式 (mm) (mm) F(mm) Y5P(B) 6.8 5.0 7.5±1.0 0.55±0.05 25min. ±10% Y5P(B) 6.8 5.0 7.5±1.0 0.55±0.05 25min. 470 ±10% Y5P(B) 6.8 5.0 7.5±1.0 0.55±0.05 25min. Y2 300~ 680 ±10% Y5P(B) 6.8 5.0 7.5±1.0 0.55±0.05 25min. DCF102K36Y5PQ6BL7A0 Y2 300~ 1000 ±10% Y5P(B) 9.8 5.0 7.5±1.0 0.55±0.05 25min. DCF102M26Y5VQ6BL7A0 Y2 300~ 1000 ±20% Y5V(F) 6.8 5.0 7.5±1.0 0.55±0.05 25min. DCF102M34Y5UQ6BL7A0 Y2 300~ 1000 ±20% Y5U(E) 9.0 5.0 7.5±1.0 0.55±0.05 25min. DCF222M34Y5VQ6BL7A0 Y2 300~ 2200 ±20% Y5V(F) 9.0 5.0 7.5±1.0 0.55±0.05 25min. DCF222M39Y5UQ6BL7A0 Y2 300~ 2200 ±20% Y5U(E) 10.5 5.0 7.5±1.0 0.55±0.05 25min. DCF332M36Y5VQ6BL7A0 Y2 300~ 3300 ±20% Y5V(F) 9.8 5.0 7.5±1.0 0.55±0.05 25min. DCF332M46Y5UQ6BL7A0 Y2 300~ 3300 ±20% Y5U(E) 12.3 5.0 7.5±1.0 0.55±0.05 25min. DCF472M39Y5VQ6BL7A0 Y2 300~ 4700 ±20% Y5V(F) 10.5 5.0 7.5±1.0 0.55±0.05 25min. DCF103M56Y5VQ6BL7A0 Y2 300~ 10000 ±20% Y5V(F) 14.7 5.0 7.5±1.0 0.55±0.05 25min. DCF101K26Y5PG6BL0A0 Y1 400~ 100 ±10% Y5P(B) 6.8 6.0 10.0±1.0 0.55±0.05 25min. DCF221K26Y5PG6BL0A0 Y1 400~ 220 ±10% Y5P(B) 6.8 6.0 10.0±1.0 0.55±0.05 25min. DCF331K30Y5PG6BL0A0 Y1 400~ 330 ±10% Y5P(B) 7.8 6.0 10.0±1.0 0.55±0.05 25min. DCF471K34Y5PG6BL0A0 Y1 400~ 470 ±10% Y5P(B) 9.0 6.0 10.0±1.0 0.55±0.05 25min. DCF102M34Y5UG6BL0A0 Y1 400~ 1000 ±20% Y5U(E) 9.0 6.0 10.0±1.0 0.55±0.05 25min. DCF152M36Y5UG6BL0A0 Y1 400~ 1500 ±20% Y5U(E) 9.8 6.0 10.0±1.0 0.55±0.05 25min. DCF222M34Y5VG6BL0A0 Y1 400~ 2200 ±20% Y5V(F) 9.0 6.0 10.0±1.0 0.55±0.05 25min. DCF222M39Y5UG6BL0A0 Y1 400~ 2200 ±20% Y5U(E) 10.5 6.0 10.0±1.0 0.55±0.05 25min. DCF332M39Y5VG6BL0A0 Y1 400~ 3300 ±20% Y5V(F) 10.5 6.0 10.0±1.0 0.55±0.05 25min. DCF472M46Y5VG6BL0A0 Y1 400~ 4700 ±20% Y5V(F) 12.3 6.0 10.0±1.0 0.55±0.05 25min. 电性能指标 Electrical Performance 序号 No. 项目名称 Item 1 容量和误差 C @25℃, 1 kHz and 1 Vrms 参照规格表 See the specification 2 损耗系数 DF @25℃, 1 kHz and 1 Vrms 2.5% max. 3 绝缘电阻 IR @500 VDC,60S 10000MΩmin X1/Y2 2600Vrms X1/Y1 4000Vrms 无击穿或飞弧。 No visible damage 4 5 耐电压 Rate Voltage 温度特性 temperature characteristic 技术要求 Specification Y5P ±10% Y5U +22% to -56% Y5V +22% to -82% 标志 Marking 例如 e. g 正面 SHM X1 400~ Y1 400~ E 102M F 反面
DCF102K36Y5PQ6BL7A0 价格&库存
很抱歉,暂时无法提供与“DCF102K36Y5PQ6BL7A0”相匹配的价格&库存,您可以联系我们找货
