DCC220K20COHF58L5A0
DCC220K20COHF58L5A0
    SHM(南方宏明)
    插件,P=5mm
    22PF ±10% 50V
DCC220K20COHF58L5A0 数据手册
DCC 型温度补偿圆片瓷介电容(I类) TYPE DCC TEMPERATURE COMPENSATION DISC CAPACITORS (CLASSⅠ) 特性 Feature ■容量范围 Wide capacitance range from 1pF to 10000pF ■工作温度 Operating Temperature: -40℃~125℃ ■存储温度 Storage Temperature: -10℃~40℃ 应用 Applications I类温度补偿型圆片瓷介电容器的电容量随温度改变呈线性变化,适用于调谐回路和需要补偿 温度效应的电路中。 Temperature compensating disc capacitors have a ceramic that is formulated to provide a predictable linear capacitance change versus temperature. This predictable linear capacitance change allows the temperature compensating disc capacitors to be used in circuit applications such as tuned circuits. 产品型号Part Number DCC 101 J 20 SL F 6 F J 5 □□ 型号 Type: DCC:温度补偿型圆片瓷介电容器 电容量(Capacitance): 509:5pF 内部管理代码 Interior managing 470:47pF 471:470pF 472:2200pF 电 容 量 允 许 偏 差 Capacitance Tolerance: M=20% D=±0.5pF K=±10% J=±5% 7=7.5mm 0=10mm 引线式样 Lead style: 位引线长度/包装方法/ Lead length/package: 见规格详情 See the specification 温度特性 temperature characteristic: COH SL 额定电压 Rated voltage: H=100VDC 5=5.0mm L、J、 见引线形状 see the lead style Figure1-2 and figure 1-3 尺寸代码 Size: F=50VDC 位引线间距 Lead spacing: R=3KVDC G=X1 400VAC Y1 250VAC Q=X1 400VAC/Y2 250VAC B=20max.mm, 6=6.0±0.5mm D=4.5±0.5mm, 8=8.0±0.5mm W=3.4±0.3mm, K=2.8±0.5mm, F=12.7mm 编带/扇折,V=15.0mm 编带/扇折 引线直径 Lead diameter: CP 线: 6=0.55±0.05mm 5=0.48±0.05mm 脚型 Lead style 规格Specification 产品尺寸(mm) 额定电 压 Rated voltage (KV) 标称容量 Nominal capacitance (pF) 电容量允许 偏差范围 Tolerance (%) 温度特性 Temperature Characteristic DCC101J20SL F6FJ5A0 50VDC 100 ±5% SL 5.0 3.0 5.0 0.55±0.05 DCC101J26COHF6FJ5A0 50VDC 100 ±5% COH 6.5 3.0 5.0 0.55±0.05 DCC121J20SL F6FJ5A0 50VDC 120 ±5% SL 5.0 3.0 5.0 0.55±0.05 DCC200J20COHF6FJ5A0 50VDC 20 ±5% COH 5.0 3.0 5.0 0.55±0.05 DCC220J20COHF6FJ5A0 50VDC 22 ±5% COH 5.0 3.0 5.0 0.55±0.05 DCC220K20COHF56L5A0 50VDC 22 ±10% COH 5.0 3.0 5.0 0.48±0.05 DCC220K20COHF58L5A0 50VDC 22 ±10% COH 5.0 3.0 5.0 0.48±0.05 DCC221J20SL F6FJ5A0 50VDC 220 ±5% SL 5.0 3.0 5.0 0.55±0.05 DCC270J20COHF6FJ5A0 50VDC 27 ±5% COH 5.0 3.0 5.0 0.55±0.05 DCC300J20COHF6FJ5A0 50VDC 30 ±5% COH 5.0 3.0 5.0 0.55±0.05 DCC331J22SL F6FJ5F0 50VDC 330 ±5% SL 5.5 3.0 5.0 0.55±0.05 DCC391J22SL F6FJ5A0 50VDC 390 ±5% SL 5.5 3.0 5.0 0.55±0.05 DCC470J20COHF6FJ5A0 50VDC 47 ±10% COH 5.0 3.0 5.0 0.55±0.05 DCC470J20SL F6FJ5A0 50VDC 47 ±5% SL 5.0 3.0 5.0 0.55±0.05 SHM 产品代码 SHM Part No. 直径 厚度 引线 引线直径 Dmax. Tmax 间距 d (mm) (mm) (mm) F(mm) 散 件/ 编 带 编 带 编 带 编 带 编 带 编 带 散 件 散 件 编 带 编 带 编 带 编 带 编 带 编 带 编 带 DCC471J26SL F6FJ5A0 50VDC 470 ±5% SL 6.5 3.0 5.0 0.55±0.05 DCC509D20COHF6FJ5A0 50VDC 5 ±0.5pF COH 5.0 3.0 5.0 0.55±0.05 DCC560J20COHF6FJ5A0 50VDC 56 ±5% COH 5.0 3.0 5.0 0.55±0.05 DCC561J34SL F6FJ5A0 50VDC 560 ±5% SL 8.5 3.0 5.0 0.55±0.05 DCC820J20SL F6FJ5A0 50VDC 82 ±5% SL 5.0 3.0 5.0 0.55±0.05 DCC820J26COHF6FJ5A0 50VDC 82 ±5% COH 6.5 3.0 5.0 0.55±0.05 电性能指标 Electrical Performance 序号 No. 项目名称 Item 1 容量和误差 C @25℃,1 MHz and 1 Vrms 2 品质因素 Q @25℃,1 MHz and 1 Vrms 3 绝缘电阻 IR @50 VDC,60S 10000MΩmin 300%额定电压 无击穿或飞弧。 No visible damage 4 5 耐电压 Rate Voltage 温度特性 temperature characteristic 技术要求 Specification 参照规格表 See the specification Q≥400+20Cr (Cr<30pF) Q≥1000 (Cr≥30pF) 50VDC SL ﹢140~-1000(10-6/℃) COH 0±60*10-6/℃ Y5P ±10% Y5U +22% to -56% Y5V +22% to -82% 编 带 编 带 编 带 编 带 编 带 编 带 标志 Marking 例如 e. g 22#号产品以下 ≤ 22# 26#号产品以下 =26# 30#产品以上 ≥30# 正面 Front 反面 Back 空白 Blank 空白 Blank 空白 Blank 编带样式 Taping style
DCC220K20COHF58L5A0 价格&库存
很抱歉,暂时无法提供与“DCC220K20COHF58L5A0”相匹配的价格&库存,您可以联系我们找货
DCC220K20COHF58L5A0
    • 50+0.11880
    • 500+0.09342
    • 2000+0.07366
    • 5000+0.06524
    • 25000+0.05789
    • 50000+0.05400
