DCS104Z26Y5VF5BL5A0
DCS104Z26Y5VF5BL5A0
    SHM(南方宏明)
    插件,P=5mm
    100NF -20%~+80% 50V
DCS104Z26Y5VF5BL5A0 数据手册
DCS 型半导体圆片瓷介电容器 TYPE DCS SEMI-CONDUCTIVE DISC CERAMIC CAPACITORS 特性 Feature ■容量范围 Wide capacitance range from 100pF to 1000000pF ■工作温度 Operating Temperature: -40℃~125℃ ■存储温度 Storage Temperature: -10℃~40℃ 应用 Applications DCS 型半导体圆片瓷介电容器的陶瓷芯片属于表面层半导体结构,其电容器具有大容量、小 体积等特点,适用于滤波、旁路、耦合等电路中。 This disc ceramic capacitors belong to surface layer semi-conductive construction,have characteristics such as higher capacitance,small size etc.,They are best suited for use in filter circuit,bypass circuit and coupling circuit etc.. 产品型号Part Number DCS 104 M 26 Y5V F 6 B L 5 □□ 型号 Type: DCS:半导体圆片瓷介电容器 电容量(Capacitance): 470:47pF 内部管理代码 Interior managing 471:470pF 472:2200pF 103:10000pF 电 容 量 允 许 偏 差 Capacitance Tolerance: M=20% Z=+80%-20% K=±10% J=±5% 尺寸代码 Size: 见规格详情 See the specification 温度特性 temperature characteristic: Y5P,Y5U,Y5V 额定电压 Rated voltage: F=50VDC H=100VDC 位引线间距 Lead spacing: 5=5.0mm 7=7.5mm 0=10mm 引线式样 Lead style: L、J、 见引线形状 see the lead style Figure1-2 and figure 1-3 位引线长度/包装方法/ Lead length/package: B=20min.mm, 6=6.0±0.5mm 0=10.0±0.5mm,8=8.0±0.5mm, W=3.4±0.3mm, A=7.0±0.5mm, 3=3.0±0.3mm F=12.7mm 编带/扇折,V=15.0mm 编带/扇折 引线直径 Lead diameter: CP 线: 6=0.55±0.05mm =0.48±0.05mm 脚型 Lead style 规格Specification 产品尺寸(mm) 额定电 压 Rated voltage (KV) 标称容量 Nominal capacitance (pF) 电容量允 许偏差范 围 Tolerance (%) 温度特性 Temperature Characteristic DCS103K20Y5PF6FJ5A0 50VDC 10000 ±10% Y5P 5.0 4.0 5.0 0.55±0.05 DCS103M20Y5UF5AL5A0 50VDC 10000 ±20% Y5U 5.0 4.0 5.0 0.48±0.05 DCS103M20Y5VF6FL5A0 50VDC 10000 ±20% Y5V 5.0 4.0 5.0 0.55±0.05 DCS104M26Y5UF50L5A0 50VDC 100000 ±20% Y5U 6.5 4.0 5.0 0.48±0.05 DCS104M26Y5UF5BL5A0 50VDC 100000 ±20% Y5U 6.5 4.0 5.0 0.48±0.05 DCS104M26Y5UF5WL5A0 50VDC 100000 ±20% Y5U 6.5 4.0 5.0 0.48±0.05 DCS104M26Y5UF6AJ5A0 50VDC 100000 ±20% Y5U 6.5 4.0 5.0 0.55±0.05 DCS104M26Y5UF6FJ5A0 50VDC 100000 ±20% Y5U 6.5 4.0 5.0 0.55±0.05 DCS104M26Y5UH6FJ5A0 100VDC 100000 ±20% Y5U 6.5 4.0 5.0 0.55±0.05 DCS104M26Y5VF6FJ5A0 50VDC 100000 ±20% Y5V 6.5 4.0 5.0 0.55±0.05 DCS104M26Y5VFEFL5A0 50VDC 100000 ±20% Y5V 6.5 4.0 5.0 0.58±0.05 镀锡铜线 DCS104Z26Y5VF56L5A0 50VDC 100000 +80% to -20% Y5V 6.5 4.0 5.0 0.48±0.05 DCS104Z26Y5VF58L5A0 50VDC 100000 +80% to -20% Y5V 6.5 4.0 5.0 0.48±0.05 DCS104Z26Y5VF5BL5A0 50VDC 100000 +80% to -20% Y5V 6.5 4.0 5.0 0.48±0.05 SHM 产品代码 SHM Part No. 直径 厚度 引线 引线直径 Dmax. Tmax 间距 d (mm) (mm) (mm) F(mm) 散 件/ 编 带 编 带 散 件 编 带 散 件 散 件 散 件 散 件 散 件 编 带 编 带 编 带 散 件 散 件 散 件 DCS104Z26Y5VF6BL5A0 50VDC 100000 +80% to -20% Y5V 6.5 4.0 5.0 0.55±0.05 DCS104Z26Y5VF6FJ5A0 50VDC 100000 +80% to -20% Y5V 6.5 4.0 5.0 0.55±0.05 DCS104Z26Y5VF6FJ5BQ 50VDC 100000 +80% to -20% Y5V 6.5 4.0 5.0 0.55±0.05 DCS104Z26Y5VF6FJ5ER 50VDC 100000 +80% to -20% Y5V 6.5 4.0 5.0 0.55±0.05 DCS104Z26Y5VF6FL5BQ 50VDC 100000 +80% to -20% Y5V 6.5 4.0 5.0 0.55±0.05 DCS104Z26Y5VFEFJ5A0 50VDC 100000 +80% to -20% Y5V 6.5 4.0 5.0 DCS104Z26Y5VFEFL5A0 50VDC 100000 +80% to -20% Y5V 6.5 4.0 5.0 0.58±0.05 镀锡铜线 0.58±0.05 镀锡铜线 DCS104Z26Y5VH63L5A0 100VDC 100000 +80% to -20% Y5V 6.5 4.0 5.0 0.55±0.05 DCS104Z26Y5VH6FJ5A0 100VDC 100000 +80% to -20% Y5V 6.5 4.0 5.0 0.55±0.05 散 件 编 带 编 带 编 带 编 带 编 带 编 带 散 件 编 带 电性能指标 Electrical Performance 序号 No. 项目名称 Item 1 容量和误差 C @25℃,1 kHz and 0.1 Vrms 参照规格表 See the specification 2 损耗系数 DF @25℃,1 kHz and 0.1 Vrms 5% max.( Ⅲ类瓷 Y5V & Y5U) 3.5% max.( Ⅲ类瓷 Y5P) 3 绝缘电阻 IR @额定电压 VDC,60S 1000MΩmin 150%额定电压 无击穿或飞弧。 No visible damage 50V 耐电压 Rate Voltage 4 技术要求 Specification 100V 温度特性 temperature characteristic 5 Y5P ±10% Y5U +22% to -56% Y5V +22% to -82% 标志 Marking 例如 e. g 22#号产品以下 ≤ 22# 正面 Front B 221 · 反面 Back 空白 Blank 26#号产品以下 =26# F 104 M · 空白 Blank 30#产品以上 ≥30# B 472 K SHM 空白 Blank 编带样式 Taping style 备注 1 DCS104Z26Y5VF6FL5BQ 的标志: 正面 Front 104
DCS104Z26Y5VF5BL5A0 价格&库存
很抱歉,暂时无法提供与“DCS104Z26Y5VF5BL5A0”相匹配的价格&库存,您可以联系我们找货
DCS104Z26Y5VF5BL5A0
    • 20+0.13792
    • 200+0.10854
    • 1000+0.08554
    • 2000+0.07571
    • 10000+0.06718
    • 20000+0.06264
