DCF222M34Y5UG60L0L0
DCF222M34Y5UG60L0L0
    SHM(南方宏明)
    插件,P=10mm
    等级:X1,Y1 2.2NF ±20% 400V 400V
DCF222M34Y5UG60L0L0 数据手册
瓷介电容器 Ceramic Capacitors 特性 Feature ■容量范围 Wide capacitance range from 100pF to 10000pF ■工作温度 Operating Temperature: -40℃~125℃ ■存储温度 Storage Temperature: -10℃~40℃ 应用 Applications 瓷介电容器适用于电子设备的电源电路噪声抑制电路中,也可用于天线耦合跨接和旁路电路中。 These products Can be used in noise suppression of power supply circuit for general electronic equipment, and might be used as antenna coupling, crossing and bypass circuit. 使用标准Applicable Standard 通过认证 APPROVAL 认证组织 ORGANIZATION 标准. SAFTY STANDARDS 证书 CERTIFICATE NO. UL CUL UL60384-14 E154899 CSA CAN/CSA-E60384-14 2405436 2405437 (VDE+ENEC)VD E IEC 60384 –14 40036393 40036246 SEMKO EN60384-14 1914801 KTC K60384 – 14 HU03004-16006A HU03004-16007A HU03004-16008A NEMKO EN60384-14 P19223823 DEMKO EN60384-14 D-03468-M1 FIMKO IEC 60384 –14 FI 40341 SEV IEC 60384 –14 19.0474 19.0475 CQC IEC 60384 –14 CQC15001124387 CQC15001124387 CQC15001127382 产品型号Part Number DCF 331 K 30 Y5P G 6 B L 0 □ □ 型号 Type: DCF:交流圆片瓷介电容器 DCG:超高压瓷片电容器 DCH:高压圆片瓷介电容器 电极材料: Electrode Material Copper or Silver electrode 电容量(Capacitance): 470:47pF 内部管理代码 Interior managing 471:470pF 472:2200pF 位引线间距 Lead spacing: 103:10000pF 5=5.0mm 电 容 量 允 许 偏 差 Capacitance Tolerance: M=20% Z=+80%-20% K=±10% J=±5% 引线式样 Lead style: L、P 见引线形状 see the lead style Figure1-2 and figure 1-5 位引线长度/包装方法/ Lead length/package: 尺寸代码 Size: 见规格详情 See the specification 温度特性 temperature characteristic: Y5P,Y5U,Y5V B=26.0±1.0mm, L=2.3±0.3mm D=4.5±0.5mm,J=3.2±0.3mm, W=3.4±0.3mm, K=2.8±0.5mm, F=12.7mm 编带/扇折,V=15.0mm 编带/扇折 引线直径 Lead diameter: 额定电压 Rated voltage: N=1KVDC 7=7.5mm 0=10mm P=2KVDC R=3KVDC G=X1 400VAC Y1 250VAC Q=X1 400VAC/Y2 250VAC 脚型 Lead style CP 线: 6=0.55±0.05mm 8=0.78±0.05mm 规格Specification SHM 产品代码 SHM Part No. 额定电 压 Rated voltage (VAC) 标称容量 Nominal capacitance (pF) 电容量允 许偏差范 围 Tolerance (%) 温度特性 Temperature Characteristic DCF101K22Y5PG53L0A0 Y1 250~ 100 ±10% DCF101K26Y5PG63L0A0 Y1 250~ 100 DCF101K26Y5PG6JL0A0 Y1 250~ DCF101K26Y5PG6JP0A0 产品尺寸(mm) 直径 厚度 引线 引线直径 Dmax. Tmax. 间距 d (mm) (mm) (mm) F(mm) 散件/ 编带 Y5P(B) 5.5 6.0 10.0 0.48±0.05 散件 ±10% Y5P(B) 6.8 6.0 10.0 0.55±0.05 散件 100 ±10% Y5P(B) 6.8 6.0 10.0 0.55±0.05 散件 Y1 250~ 100 ±10% Y5P(B) 6.8 6.0 10.0 0.55±0.05 散件 DCF101K26Y5PG6UK0A0 Y1 250~ 100 ±10% Y5P(B) 6.8 6.0 10.0 0.55±0.05 编带 DCF101K26Y5PG6VL0A0 Y1 250~ 100 ±10% Y5P(B) 6.8 6.0 10.0 0.55±0.05 编带 DCF101K26Y5PG6WL0A0 Y1 250~ 100 ±10% Y5P(B) 6.8 6.0 10.0 0.55±0.05 散件 DCF101K26Y5PG6WP0L0 Y1 250~ 100 ±10% Y5P(B) 6.8 6.0 10.0 0.55±0.05 散件 DCF101M26Y5UG6WP0A0 Y1 250~ 100 ±20% Y5U(E) 6.8 6.0 10.0 0.55±0.05 散件 DCF102K36Y5PQ6VL7A0 Y2 250~ 1000 ±10% Y5P(B) 9.8 5.0 7.5 0.55±0.05 编带 DCF102K36Y5PQ6WL7A0 Y2 250~ 1000 ±10% Y5P(B) 9.8 5.0 7.5 0.55±0.05 散件 DCF102K43Y5PG6BL0A0 Y1 250~ 1000 ±10% Y5P(B) 11.5 6.0 10.0 0.55±0.05 散件 DCF102K43Y5PG6VP0A0 Y1 250~ 1000 ±10% Y5P(B) 11.5 6.0 10.0 0.55±0.05 编带 DCF102M26Y5UG60L0A0 Y1 250~ 1000 ±20% Y5U(E) 6.8 6.0 10.0 0.55±0.05 散件 DCF102M26Y5UG65L0A0 Y1 250~ 1000 ±20% Y5U(E) 6.8 6.0 10.0 0.55±0.05 散件 DCF102M26Y5UG68L0A0 Y1 250~ 1000 ±20% Y5U(E) 6.8 6.0 10.0 0.55±0.05 散件 DCF102M26Y5UG6AL0A0 Y1 250~ 1000 ±20% Y5U(E) 6.8 6.0 10.0 0.55±0.05 散件 DCF102M26Y5UG6BL0A0 Y1 250~ 1000 ±20% Y5U(E) 6.8 6.0 10.0 0.55±0.05 散件 DCF102M26Y5UG6JK0A0 Y1 250~ 1000 ±20% Y5U(E) 6.8 6.0 10.0 0.55±0.05 散件 DCF102M26Y5UG6JL0A0 Y1 250~ 1000 ±20% Y5U(E) 6.8 6.0 10.0 0.55±0.05 散件 DCF102M26Y5UG6JP0A0 Y1 250~ 1000 ±20% Y5U(E) 6.8 6.0 10.0 0.55±0.05 散件 DCF102M26Y5UG6UL0A0 Y1 250~ 1000 ±20% Y5U(E) 6.8 6.0 10.0 0.55±0.05 编带 DCF102M26Y5UG6VL0A0 Y1 250~ 1000 ±20% Y5U(E) 6.8 6.0 10.0 0.55±0.05 编带 DCF102M26Y5UQ68L7A0 Y2 250~ 1000 ±20% Y5U(E) 6.8 5.0 7.5 0.55±0.05 散件 DCF102M26Y5VG6BL0A0 Y1 250~ 1000 ±20% Y5V(F) 6.8 6.0 10.0 0.55±0.05 散件 DCF102M26Y5VG6UP0A0 Y1 250~ 1000 ±20% Y5V(F) 6.8 6.0 10.0 0.55±0.05 编带 DCF102M26Y5VG6WL0A0 Y1 250~ 1000 ±20% Y5V(F) 6.8 6.0 10.0 0.55±0.05 散件 DCF102M26Y5VQ6VL7A0 Y2 250~ 1000 ±20% Y5V(F) 6.8 5.0 7.5 0.55±0.05 编带 DCF102M30Y5UQ6JK7A0 Y2 250~ 1000 ±20% Y5U(E) 7.8 5.0 7.5 0.55±0.05 散件 DCF102M30Y5UQ6VP7A0 Y2 250~ 1000 ±20% Y5U(E) 7.8 5.0 7.5 0.55±0.05 编带 DCF102M30Y5UQ6WP7A0 Y2 250~ 1000 ±20% Y5U(E) 7.8 5.0 7.5 0.55±0.05 散件 DCF102M34Y5UG6JL0A0 Y1 250~ 1000 ±20% Y5U(E) 9.0 6.0 10.0 0.55±0.05 散件 DCF102M34Y5UG6JP0A0 Y1 250~ 1000 ±20% Y5U(E) 9.0 6.0 10.0 0.55±0.05 散件 DCF102M34Y5UG6VK0A0 Y1 250~ 1000 ±20% Y5U(E) 9.0 6.0 10.0 0.55±0.05 编带 DCF102M34Y5UG6VL0A0 Y1 250~ 1000 ±20% Y5U(E) 9.0 6.0 10.0 0.55±0.05 编带 DCF103M56Y5UQ66L7A0 Y2 250~ 10000 ±20% Y5U(E) 14.7 5.0 7.5 0.55±0.05 散件 DCF103M56Y5UQ6JK7A0 Y2 250~ 10000 ±20% Y5U(E) 14.7 5.0 7.5 0.55±0.05 散件 DCF103M56Y5VQ68L7A0 Y2 250~ 10000 ±20% Y5V(F) 14.7 5.0 7.5 0.55±0.05 散件 DCF103M56Y5VQ6JK0A0 Y2 250~ 10000 ±20% Y5V(F) 14.7 5.0 10.0 0.55±0.05 散件 DCF103M56Y5VQ6UL7A0 Y2 250~ 10000 ±20% Y5V(F) 14.7 5.0 7.5 0.55±0.05 编带 DCF103M69Y5VG6BL0AJ Y1 250~ 10000 ±20% Y5V(F) 18.0 6.0 10.0 0.55±0.05 散件 DCF103M69Y5VG8UL0L0 Y1 250~ 10000 ±20% Y5V(F) 18.0 6.0 10.0 0.78±0.05 编带 DCF103Z56Y5VQ6JK7AB Y2 250~ 10000 +80%-20% Y5V(F) 14.7 5.0 7.5 0.55±0.05 散件 DCF152M30Y5UG6BL0A0 Y1 250~ 1500 ±20% Y5U(E) 7.8 6.0 10.0 0.55±0.05 散件 DCF152M30Y5UG6UK0A0 Y1 250~ 1500 ±20% Y5U(E) 7.8 6.0 10.0 0.55±0.05 编带 DCF152M30Y5UQ6BL7A0 Y2 250~ 1500 ±20% Y5U(E) 7.8 5.0 7.5 0.55±0.05 散件 DCF152M36Y5UG6BL0AA Y1 250~ 1500 ±20% Y5U(E) 9.8 6.0 10.0 0.55±0.05 散件 DCF152M36Y5UG6UL0A3 Y1 250~ 1500 ±20% Y5U(E) 9.8 6.0 10.0 0.55±0.05 编带 DCF152M36Y5UG6WL0A0 Y1 250~ 1500 ±20% Y5U(E) 9.8 6.0 10.0 0.55±0.05 散件 DCF221K22Y5PG6VL0A0 Y1 250~ 220 ±10% Y5P(B) 5.5 6.0 10.0 0.55±0.05 编带 DCF221K24Y5PG5LL0A8 Y1 250~ 220 ±10% Y5P(B) 6.0 6.0 10.0 0.48±0.05 散件 DCF221K24Y5PG6VL0DM Y1 250~ 220 ±10% Y5P(B) 6.0 6.0 10.0 0.55±0.05 编带 DCF221K26Y5PG6GL0A0 Y1 250~ 220 ±10% Y5P(B) 6.8 6.0 10.0 0.55±0.05 散件 DCF221K26Y5PG6VL0A0 Y1 250~ 220 ±10% Y5P(B) 6.8 6.0 10.0 0.55±0.05 编带 DCF221K26Y5PQ6BL7A6 Y2 250~ 220 ±10% Y5P(B) 6.8 5.0 7.5 0.55±0.05 散件 DCF221K30Y5PG6JK0AB Y1 250~ 220 ±10% Y5P(B) 7.8 6.0 10.0 0.55±0.05 散件 DCF221K30Y5PG6VK0BT Y1 250~ 220 ±10% Y5P(B) 7.8 6.0 10.0 0.55±0.05 编带 DCF222M30Y5UQ6BL7A0 Y2 250~ 2200 ±20% Y5U(E) 7.8 5.0 7.5 0.55±0.05 散件 DCF222M30Y5UQ6VL7A0 Y2 250~ 2200 ±20% Y5U(E) 7.8 5.0 7.5 0.55±0.05 编带 DCF222M34Y5UG60L0L0 Y1 250~ 2200 ±20% Y5U(E) 9.0 6.0 10.0 0.55±0.05 散件 DCF222M34Y5UG6BL0A0 Y1 250~ 2200 ±20% Y5U(E) 9.0 6.0 10.0 0.55±0.05 散件 DCF222M34Y5UG6DL0A0 Y1 250~ 2200 ±20% Y5U(E) 9.0 6.0 10.0 0.55±0.05 散件 DCF222M34Y5UG6UK0A0 Y1 250~ 2200 ±20% Y5U(E) 9.0 6.0 10.0 0.55±0.05 编带 DCF222M34Y5UG6UL0A0 Y1 250~ 2200 ±20% Y5U(E) 9.0 6.0 10.0 0.55±0.05 编带 DCF222M34Y5UG6UP0A0 Y1 250~ 2200 ±20% Y5U(E) 9.0 6.0 10.0 0.55±0.05 编带 DCF222M34Y5UG6VL0A0 Y1 250~ 2200 ±20% Y5U(E) 9.0 6.0 10.0 0.55±0.05 编带 DCF222M34Y5UG6WL0A0 Y1 250~ 2200 ±20% Y5U(E) 9.0 6.0 10.0 0.55±0.05 散件 DCF222M34Y5UG6WP0A0 Y1 250~ 2200 ±20% Y5U(E) 9.0 6.0 10.0 0.55±0.05 散件 DCF222M34Y5UGE4L0A0 Y1 250~ 2200 ±20% Y5U(E) 9.0 6.0 10.0 0.58±0.05 散件 DCF222M34Y5UGEVL0A0 Y1 250~ 2200 ±20% Y5U(E) 9.0 6.0 10.0 0.58±0.05 编带 DCF222M34Y5UGEWL0A0 Y1 250~ 2200 ±20% Y5U(E) 9.0 6.0 10.0 0.58±0.05 散件 DCF222M34Y5UQ66L7A0 Y2 250~ 2200 ±20% Y5U(E) 9.0 5.0 7.5 0.55±0.05 散件 DCF222M34Y5UQ6BL7A0 Y2 250~ 2200 ±20% Y5U(E) 9.0 5.0 7.5 0.55±0.05 散件 DCF222M34Y5UQ6JK7A0 Y2 250~ 2200 ±20% Y5U(E) 9.0 5.0 7.5 0.55±0.05 散件 DCF222M34Y5UQ6UP7A0 Y2 250~ 2200 ±20% Y5U(E) 9.0 5.0 7.5 0.55±0.05 编带 DCF222M34Y5UQ6VJ7A0 Y2 250~ 2200 ±20% Y5U(E) 9.0 5.0 7.5 0.55±0.05 编带 DCF222M34Y5UQEUL0A0 Y2 250~ 2200 ±20% Y5U(E) 9.0 5.0 10.0 0.58±0.05 编带 DCF222M34Y5UQEVK7A0 Y2 250~ 2200 ±20% Y5U(E) 9.0 5.0 7.5 0.58±0.05 编带 DCF222M34Y5UQEWK7A0 Y2 250~ 2200 ±20% Y5U(E) 9.0 5.0 7.5 0.58±0.05 散件 DCF222M34Y5UQEWL7A0 Y2 250~ 2200 ±20% Y5U(E) 9.0 5.0 7.5 0.58±0.05 散件 DCF222M34Y5VG60L0A2 Y1 250~ 2200 ±20% Y5V(F) 9.0 6.0 10.0 0.55±0.05 散件 DCF222M34Y5VG6JK0A0 Y1 250~ 2200 ±20% Y5V(F) 9.0 6.0 10.0 0.55±0.05 散件 DCF222M34Y5VG6UL0B8 Y1 250~ 2200 ±20% Y5V(F) 9.0 6.0 10.0 0.55±0.05 编带 DCF222M34Y5VG6VL0BU Y1 250~ 2200 ±20% Y5V(F) 9.0 6.0 10.0 0.55±0.05 编带 DCF222M34Y5VG6WL0A2 Y1 250~ 2200 ±20% Y5V(F) 9.0 6.0 10.0 0.55±0.05 散件 DCF222M34Y5VGEUL0A0 Y1 250~ 2200 ±20% Y5V(F) 9.0 6.0 10.0 0.58±0.05 编带 DCF222M34Y5VGEUL0L0 Y1 250~ 2200 ±20% Y5V(F) 9.0 6.0 10.0 0.58±0.05 编带 DCF222M34Y5VQ6JL7A0 Y2 250~ 2200 ±20% Y5V(F) 9.0 5.0 7.5 0.55±0.05 散件 DCF222M36Y5UG6BL0A0 Y1 250~ 2200 ±20% Y5U(E) 9.8 6.0 10.0 0.55±0.05 散件 DCF222M36Y5UG6UP0CW Y1 250~ 2200 ±20% Y5U(E) 9.8 6.0 10.0 0.55±0.05 编带 DCF222M36Y5UG7DK0A0 Y1 250~ 2200 ±20% Y5U(E) 9.8 6.0 10.0 0.65±0.05 散件 DCF222M36Y5UG7JK0AB Y1 250~ 2200 ±20% Y5U(E) 9.8 6.0 10.0 0.65±0.05 散件 DCF222M36Y5UG7JL0AB Y1 250~ 2200 ±20% Y5U(E) 9.8 6.0 10.0 0.65±0.05 散件 DCF222M36Y5UQ6BL7A0 Y2 250~ 2200 ±20% Y5U(E) 9.8 5.0 7.5 0.55±0.05 散件 DCF222M36Y5UQ6UL7A0 Y2 250~ 2200 ±20% Y5U(E) 9.8 5.0 7.5 0.55±0.05 编带 DCF222M36Y5UQ6VK7GK Y2 250~ 2200 ±20% Y5U(E) 9.8 5.0 7.5 0.55±0.05 编带 DCF222M36Y5UQ6WL7A0 Y2 250~ 2200 ±20% Y5U(E) 9.8 5.0 7.5 0.55±0.05 散件 DCF222M39Y5UG6DW0A2 Y1 250~ 2200 ±20% Y5U(E) 10.5 6.0 10.0 0.55±0.05 散件 DCF222M39Y5UG6JK0A0 Y1 250~ 2200 ±20% Y5U(E) 10.5 6.0 10.0 0.55±0.05 散件 DCF222M39Y5UG6JL0A0 Y1 250~ 2200 ±20% Y5U(E) 10.5 6.0 10.0 0.55±0.05 散件 DCF222M39Y5UG6UL0A0 Y1 250~ 2200 ±20% Y5U(E) 10.5 6.0 10.0 0.55±0.05 编带 DCF222M39Y5UG6WL0A0 Y1 250~ 2200 ±20% Y5U(E) 10.5 6.0 10.0 0.55±0.05 散件 DCF222M39Y5UG6WP0A0 Y1 250~ 2200 ±20% Y5U(E) 10.5 6.0 10.0 0.55±0.05 散件 DCF222M39Y5UG9VPAGB Y1 250~ 2200 ±20% Y5U(E) 10.5 6.0 10.0 0.58±0.05 编带 DCF222M39Y5UQ6WP7A0 Y2 250~ 2200 ±20% Y5U(E) 10.5 5.0 7.5 0.55±0.05 散件 DCF222M46Y5UG6WP0AA Y1 250~ 2200 ±20% Y5U(E) 12.3 6.0 10.0 0.55±0.05 散件 DCF331K26Y5PG6JK0A0 Y1 250~ 330 ±10% Y5P(B) 6.8 6.0 10.0 0.55±0.05 散件 DCF331K26Y5PG6JP0A0 Y1 250~ 330 ±10% Y5P(B) 6.8 6.0 10.0 0.55±0.05 散件 DCF331K26Y5PG6VLAFK Y1 250~ 330 ±10% Y5P(B) 6.8 6.0 10.0 0.55±0.05 编带 DCF331K30Y5PG63L0A0 Y1 250~ 330 ±10% Y5P(B) 7.8 6.0 10.0 0.55±0.05 散件 DCF331K30Y5PG6VK0BT Y1 250~ 330 ±10% Y5P(B) 7.8 6.0 10.0 0.55±0.05 编带 DCF331K30Y5PG6VPAFWV Y1 250~ 330 ±10% Y5P(B) 7.8 6.0 10.0 0.55±0.05 编带 DCF331M26Y5UG6WL0A0 Y1 250~ 330 ±20% Y5U(E) 6.8 6.0 10.0 0.55±0.05 散件 DCF331M30Y5UG63P1A2 Y1 250~ 330 ±20% Y5U(E) 7.8 6.0 10.5 0.55±0.05 散件 DCF332M36Y5UQ6BL7A0 Y2 250~ 3300 ±20% Y5U(E) 9.8 5.0 7.5 0.55±0.05 散件 DCF332M36Y5UQ6JK7A0 Y2 250~ 3300 ±20% Y5U(E) 9.8 5.0 7.5 0.55±0.05 散件 DCF332M36Y5VQ6UP7A0 Y2 250~ 3300 ±20% Y5V(F) 9.8 5.0 7.5 0.55±0.05 编带 DCF332M36Y5VQ6VL0A0 Y2 250~ 3300 ±20% Y5V(F) 9.8 5.0 10.0 0.55±0.05 编带 DCF332M36Y5VQ6VL7A0 Y2 250~ 3300 ±20% Y5V(F) 9.8 5.0 7.5 0.55±0.05 编带 DCF332M36Y5VQ6WL7A2 Y2 250~ 3300 ±20% Y5V(F) 9.8 5.0 7.5 0.55±0.05 散件 DCF332M39Y5UG6BL0A0 Y1 250~ 3300 ±20% Y5U(E) 10.5 6.0 10.0 0.55±0.05 散件 DCF332M39Y5UG6JK0A0 Y1 250~ 3300 ±20% Y5U(E) 10.5 6.0 10.0 0.55±0.05 散件 DCF332M39Y5UG6WK0A0 Y1 250~ 3300 ±20% Y5U(E) 10.5 6.0 10.0 0.55±0.05 散件 DCF332M39Y5UG6WL0A0 Y1 250~ 3300 ±20% Y5U(E) 10.5 6.0 10.0 0.55±0.05 散件 DCF332M39Y5UG7JK0AB Y1 250~ 3300 ±20% Y5U(E) 10.5 6.0 10.0 0.65±0.05 散件 DCF332M46Y5UQ60L7AA Y2 250~ 3300 ±20% Y5U(E) 12.3 5.0 7.5 0.55±0.05 散件 DCF332M46Y5UQ6WP7A0 Y2 250~ 3300 ±20% Y5U(E) 12.3 5.0 7.5 0.55±0.05 散件 DCF470K26Y5PG6AL0A0 Y1 250~ 47 ±10% Y5P(B) 6.8 6.0 10.0 0.55±0.05 散件 DCF470K30SL G6VK0BT Y1 250~ 47 ±10% SL 7.8 6.0 10.0 0.55±0.05 编带 DCF471K26Y5PG6BL0A0 Y1 250~ 470 ±10% Y5P(B) 6.8 6.0 10.0 0.55±0.05 散件 DCF471K26Y5PG6VL0A0 Y1 250~ 470 ±10% Y5P(B) 6.8 6.0 10.0 0.55±0.05 编带 DCF471K26Y5PG6WL0A0 Y1 250~ 470 ±10% Y5P(B) 6.8 6.0 10.0 0.55±0.05 散件 DCF471K26Y5PQ6VL7A0 Y2 250~ 470 ±10% Y5P(B) 6.8 5.0 7.5 0.55±0.05 编带 DCF471K30Y5PQ6BL7A0 Y2 250~ 470 ±10% Y5P(B) 7.8 5.0 7.5 0.55±0.05 散件 DCF471K30Y5PQ6VK7A0 Y2 250~ 470 ±10% Y5P(B) 7.8 5.0 7.5 0.55±0.05 编带 DCF471K30Y5PQEVL7A6 Y2 250~ 470 ±10% Y5P(B) 7.8 5.0 7.5 0.58±0.05 编带 DCF471K34Y5PG62P0A0 Y1 250~ 470 ±10% Y5P(B) 9.0 6.0 10.0 0.55±0.05 散件 DCF471K34Y5PG6JK0A0 Y1 250~ 470 ±10% Y5P(B) 9.0 6.0 10.0 0.55±0.05 散件 DCF471K34Y5PG6UL0A0 Y1 250~ 470 ±10% Y5P(B) 9.0 6.0 10.0 0.55±0.05 编带 DCF471K34Y5PG6UP0A0 Y1 250~ 470 ±10% Y5P(B) 9.0 6.0 10.0 0.55±0.05 编带 DCF471K34Y5PG6VK0A0 Y1 250~ 470 ±10% Y5P(B) 9.0 6.0 10.0 0.55±0.05 编带 DCF471K34Y5PG6WL0A0 Y1 250~ 470 ±10% Y5P(B) 9.0 6.0 10.0 0.55±0.05 散件 DCF471K34Y5PGEVL0L0 Y1 250~ 470 ±10% Y5P(B) 9.0 6.0 10.0 0.58±0.05 编带 DCF471M26Y5UG6BL0A0 Y1 250~ 470 ±20% Y5U(E) 6.8 6.0 10.0 0.55±0.05 散件 DCF471M26Y5UG6JK0A0 Y1 250~ 470 ±20% Y5U(E) 6.8 6.0 10.0 0.55±0.05 散件 DCF471M26Y5UG6VLAGA Y1 250~ 470 ±20% Y5U(E) 6.8 6.0 10.0 0.55±0.05 编带 DCF471M26Y5UG6WL0A0 Y1 250~ 470 ±20% Y5U(E) 6.8 6.0 10.0 0.55±0.05 散件 DCF471M34Y5UG6WP0A0 Y1 250~ 470 ±20% Y5U(E) 9.0 6.0 10.0 0.55±0.05 散件 DCF472M39Y5UQ6BL7A0 Y2 250~ 4700 ±20% Y5U(E) 10.5 5.0 7.5 0.55±0.05 散件 DCF472M39Y5UQ6JK7A0 Y2 250~ 4700 ±20% Y5U(E) 10.5 5.0 7.5 0.55±0.05 散件 DCF472M39Y5UQ6UL7A0 Y2 250~ 4700 ±20% Y5U(E) 10.5 5.0 7.5 0.55±0.05 编带 DCF472M39Y5UQ6VL7BU Y2 250~ 4700 ±20% Y5U(E) 10.5 5.0 7.5 0.55±0.05 编带 DCF472M39Y5UQ6WK7A0 Y2 250~ 4700 ±20% Y5U(E) 10.5 5.0 7.5 0.55±0.05 散件 DCF472M39Y5UQ6WL7A0 Y2 250~ 4700 ±20% Y5U(E) 10.5 5.0 7.5 0.55±0.05 散件 DCF472M39Y5UQ6WP7A0 Y2 250~ 4700 ±20% Y5U(E) 10.5 5.0 7.5 0.55±0.05 散件 DCF472M39Y5VQ6BL0A0 Y2 250~ 4700 ±20% Y5V(F) 10.5 5.0 10.0 0.55±0.05 散件 DCF472M39Y5VQ6JK7A0 Y2 250~ 4700 ±20% Y5V(F) 10.5 5.0 7.5 0.55±0.05 散件 DCF472M39Y5VQ6JL7A0 Y2 250~ 4700 ±20% Y5V(F) 10.5 5.0 7.5 0.55±0.05 散件 DCF472M46Y5UG6BL0A0 Y1 250~ 4700 ±20% Y5U(E) 12.3 6.0 10.0 0.55±0.05 散件 DCF472M46Y5UG6JL0A0 Y1 250~ 4700 ±20% Y5U(E) 12.3 6.0 10.0 0.55±0.05 散件 DCF472M46Y5VG6BL0L0 Y1 250~ 4700 ±20% Y5V(F) 12.3 6.0 10.0 0.55±0.05 散件 DCF472M46Y5VG6UL0BU Y1 250~ 4700 ±20% Y5V(F) 12.3 6.0 10.0 0.55±0.05 编带 DCF472M46Y5VG6VL0L0 Y1 250~ 4700 ±20% Y5V(F) 12.3 6.0 10.0 0.55±0.05 编带 DCF472M46Y5VG6WL0A0 Y1 250~ 4700 ±20% Y5V(F) 12.3 6.0 10.0 0.55±0.05 散件 DCF472M46Y5VGCWL0L0 Y1 250~ 4700 ±20% Y5V(F) 12.3 6.0 10.0 0.65±0.05 散件 DCF472M53Y5UQ69L7A0 Y2 250~ 4700 ±20% Y5U(E) 14.0 5.0 7.5 0.55±0.05 散件 DCF472M56Y5UG6WL0A0 Y1 250~ 4700 ±20% Y5U(E) 14.7 6.0 10.0 0.55±0.05 散件 DCF472M56Y5UG6WP0A0 Y1 250~ 4700 ±20% Y5U(E) 14.7 6.0 10.0 0.55±0.05 散件 DCF680K24Y5PG5LL9CV Y1 250~ 68 ±10% Y5P(B) 6.0 6.0 9.0 0.48±0.05 散件 DCF681K30Y5UG6JP0A0 Y1 250~ 680 ±10% Y5U(E) 7.8 6.0 10.0 0.55±0.05 散件 DCF681K30Y5UG9VPAGB Y1 250~ 680 ±10% Y5U(E) 7.8 6.0 10.0 0.58±0.05 编带 DCF681K36Y5PG6BL0A0 Y1 250~ 680 ±10% Y5P(B) 9.8 6.0 10.0 0.55±0.05 散件 DCF681K36Y5PG6JK0A0 Y1 250~ 680 ±10% Y5P(B) 9.8 6.0 10.0 0.55±0.05 散件 DCF681K36Y5PG6WL0A0 Y1 250~ 680 ±10% Y5P(B) 9.8 6.0 10.0 0.55±0.05 散件 DCF681K36Y5PGEUL0A0 Y1 250~ 680 ±10% Y5P(B) 9.8 6.0 10.0 0.58±0.05 编带 DCF681M30Y5UG63L0A0 Y1 250~ 680 ±20% Y5U(E) 7.8 6.0 10.0 0.55±0.05 散件 DCF681M30Y5UG6JK0A0 Y1 250~ 680 ±20% Y5U(E) 7.8 6.0 10.0 0.55±0.05 散件 DCF681M30Y5UG6UK0A0 Y1 250~ 680 ±20% Y5U(E) 7.8 6.0 10.0 0.55±0.05 编带 电性能指标 Electrical Performance 序号 No. 项目名称 Item 1 容量和误差 C @25℃, 1 kHz and 1 Vrms 参照规格表 See the specification 2 损耗系数 DF @25℃, 1 kHz and 1 Vrms 2.5% max. 3 绝缘电阻 IR @500 VDC,60S 10000MΩmin X1/Y2 2600Vrms X1/Y1 2500Vrms 无击穿或飞弧。 No visible damage 4 5 耐电压 Rate Voltage 温度特性 temperature characteristic 技术要求 Specification Y5P ±10% Y5U +22% to -56% Y5V +22% to -82% 标志 Marking 例如 e. g Y1 电容器 正面 反面 SHM X1 400~ Y1 250~ E 102M F Y2 电容器 正面 SHM X1 400~ Y2 250~ E 102M F 反面
DCF222M34Y5UG60L0L0 价格&库存
很抱歉,暂时无法提供与“DCF222M34Y5UG60L0L0”相匹配的价格&库存,您可以联系我们找货
