DCC 型温度补偿圆片瓷介电容(I类)
TYPE DCC TEMPERATURE COMPENSATION DISC CAPACITORS (CLASSⅠ)
特性 Feature
■容量范围 Wide capacitance range from 1pF to 10000pF
■工作温度 Operating Temperature: -40℃~125℃
■存储温度 Storage Temperature: -10℃~40℃
应用 Applications
I类温度补偿型圆片瓷介电容器的电容量随温度改变呈线性变化,适用于调谐回路和需要补偿
温度效应的电路中。
Temperature compensating disc capacitors have a ceramic that is formulated to provide a predictable
linear capacitance change versus temperature. This predictable linear capacitance change allows the
temperature compensating disc capacitors to be used in circuit applications such as tuned circuits.
产品型号Part Number
DCC 101
J 20
SL
F
6
F
J
5
型号 Type:
DCC:温度补偿型圆片瓷介电容器
电容量(Capacitance):
509:5pF
内部管理代码
Interior
managing
470:47pF
471:470pF
472:2200pF
电 容 量 允 许 偏 差
Capacitance Tolerance:
M=20%
D=±0.5pF
K=±10%
J=±5%
7=7.5mm 0=10mm
引线式样 Lead style:
位引线长度/包装方法/
Lead length/package:
见规格详情
See the specification
温度特性
temperature characteristic:
COH SL
额定电压 Rated voltage:
H=100VDC
5=5.0mm
L、J、
见引线形状 see the lead style
Figure1-2 and figure 1-3
尺寸代码 Size:
F=50VDC
位引线间距 Lead spacing:
R=3KVDC
G=X1 400VAC Y1 250VAC Q=X1 400VAC/Y2 250VAC
B=20max.mm, 6=6.0±0.5mm
D=4.5±0.5mm, 8=8.0±0.5mm
W=3.4±0.3mm, K=2.8±0.5mm,
F=12.7mm 编带/扇折,V=15.0mm 编带/扇折
引线直径 Lead diameter:
CP 线:
6=0.55±0.05mm 5=0.48±0.05mm
脚型 Lead style
规格Specification
产品尺寸(mm)
额定电
压
Rated
voltage
(KV)
标称容量
Nominal
capacitance
(pF)
电容量允许
偏差范围
Tolerance
温度特性
Temperature
Characteristic
DCC101J20SL F6FJ5A0
50VDC
100
±5%
SL
5.0
3.0
5.0
0.55±0.05
DCC101J26COHF6FJ5A0
50VDC
100
±5%
COH
6.5
3.0
5.0
0.55±0.05
DCC121J20SL F6FJ5A0
50VDC
120
±5%
SL
5.0
3.0
5.0
0.55±0.05
DCC200J20COHF6FJ5A0
50VDC
±5%
COH
5.0
3.0
5.0
0.55±0.05
DCC220J20COHF6FJ5A0
50VDC
22
±5%
COH
5.0
3.0
5.0
0.55±0.05
DCC220K20COHF56L5A0
50VDC
22
±10%
COH
5.0
3.0
5.0
0.48±0.05
DCC220K20COHF58L5A0
50VDC
22
±10%
COH
5.0
3.0
5.0
0.48±0.05
DCC221J20SL F6FJ5A0
50VDC
220
±5%
SL
5.0
3.0
5.0
0.55±0.05
DCC270J20COHF6FJ5A0
50VDC
27
±5%
COH
5.0
3.0
5.0
0.55±0.05
DCC300J20COHF6FJ5A0
50VDC
30
±5%
COH
5.0
3.0
5.0
0.55±0.05
DCC331J22SL F6FJ5F0
50VDC
330
±5%
SL
5.5
3.0
5.0
0.55±0.05
DCC391J22SL F6FJ5A0
50VDC
390
±5%
SL
5.5
3.0
5.0
0.55±0.05
DCC470J20COHF6FJ5A0
50VDC
47
±10%
COH
5.0
3.0
5.0
0.55±0.05
DCC470J20SL F6FJ5A0
50VDC
47
±5%
SL
5.0
3.0
5.0
0.55±0.05
SHM 产品代码
SHM Part No.
直径 厚度 引线
引线直径
Dmax. Tmax 间距
d (mm)
(mm) (mm) F(mm)
散
件/
编
带
编
带
编
带
编
带
编
带
编
带
散
件
散
件
编
带
编
带
编
带
编
带
编
带
编
带
编
带
DCC471J26SL F6FJ5A0
50VDC
470
±5%
SL
6.5
3.0
5.0
0.55±0.05
DCC509D20COHF6FJ5A0
50VDC
5
±0.5pF
COH
5.0
3.0
5.0
0.55±0.05
DCC560J20COHF6FJ5A0
50VDC
56
±5%
COH
5.0
3.0
5.0
0.55±0.05
DCC561J34SL F6FJ5A0
50VDC
560
±5%
SL
8.5
3.0
5.0
0.55±0.05
DCC820J20SL F6FJ5A0
50VDC
82
±5%
SL
5.0
3.0
5.0
0.55±0.05
DCC820J26COHF6FJ5A0
50VDC
82
±5%
COH
6.5
3.0
5.0
0.55±0.05
电性能指标 Electrical Performance
序号
No.
项目名称 Item
1
容量和误差 C
@25℃,1 MHz and 1 Vrms
2
品质因素 Q
3
绝缘电阻 IR
@50 VDC,60S
10000MΩmin
300%额定电压
无击穿或飞弧。
No visible damage
4
5
耐电压
Rate
Voltage
温度特性
temperature
characteristic
技术要求 Specification
参照规格表
Q≥400+20Cr (Cr<30pF)
Q≥1000 (Cr≥30pF)
50VDC
SL
﹢140~-1000(10-6/℃)
COH
0±60*10-6/℃
Y5P
±10%
Y5U
+22% to -56%
Y5V
+22% to -82%
编
带
编
带
编
带
编
带
编
带
编
带
标志 Marking
例如 e. g
22#号产品以下
≤ 22#
26#号产品以下
=26#
30#产品以上
≥30#
正面
Front
反面
Back
空白
Blank
空白
Blank
空白
Blank
编带样式 Taping style
DCC220K20COHF56L5A0 价格&库存
很抱歉,暂时无法提供与“DCC220K20COHF56L5A0”相匹配的价格&库存,您可以联系我们找货
