DCT102M20Y5UF6FJ5A0
DCT102M20Y5UF6FJ5A0
    SHM(南方宏明)
    插件,P=5mm
    特性:容量范围:100pF至10000pF。工作温度:-40°C至125°C。存储温度:-10°C至40°C。应用:旁路电路。耦合电路
DCT102M20Y5UF6FJ5A0 数据手册
DCT 型高介电常数圆片瓷介电容器(II类) TYPE DCT HIGH DIELECTRIC CONSTANT DISC CERAMIC CAPACITORS(Class II) 特性 Feature ■容量范围 Wide capacitance range from 100pF to 10000pF ■工作温度 Operating Temperature: -40℃~125℃ ■存储温度 Storage Temperature: -10℃~40℃ 应用 Applications DCT 型圆片瓷介电容器的特点:介电常数高,容量大,体积小。适用于旁路、耦合、隔直流和 滤波等电路中。 Type DCT disc capacitors have characteristics such as higher dielectric constant, higher Capacitance, smaller size. They are suitably used in bypass circuit,coupling circuit, filter circuit,and isolating circuit.. 产品型号Part Number DCT 101 K 20 Y5P F 6 F J 5 □□ 型号 Type: DCT:高介电常数圆片瓷介电容器 电容量(Capacitance): 470:47pF 内部管理代码 Interior managing 471:470pF 472:2200pF 103:10000pF 电 容 量 允 许 偏 差 Capacitance Tolerance: M=20% Z=+80%-20% K=±10% J=±5% 尺寸代码 Size: 见规格详情 See the specification 温度特性 temperature characteristic: Y5P,Y5U,Y5V 额定电压 Rated voltage: F=50VDC H=100VDC 位引线间距 Lead spacing: 5=5.0mm 7=7.5mm 0=10mm 引线式样 Lead style: L、J、 见引线形状 see the lead style Figure1-2 and figure 1-3 位引线长度/包装方法/ Lead length/package: B=20min.mm, 6=6.0±0.5mm D=4.5±0.5mm,8=8.0±0.5mm, W=3.4±0.3mm, A=7.0±0.5mm, F=12.7mm 编带/扇折,V=15.0mm 编带/扇折 引线直径 Lead diameter: CP 线: 6=0.55±0.05mm 5=0.48±0.05mm 脚型 Lead style 规格Specification 产品尺寸(mm) 额定电 压 Rated voltage (KV) 标称容量 Nominal capacitance (pF) 电容量允许 偏差范围 Tolerance (%) 温度特性 Temperature Characteristic DCT101K20Y5PF6FJ5A0 50VDC 100 ±10% Y5P 5.0 3.0 5.0 0.55±0.05 DCT101K20Y5PF6FJ5BU 50VDC 100 ±10% Y5P 5.0 3.0 5.0 0.55±0.05 DCT101K20Y5PF6FL5A0 50VDC 100 ±10% Y5P 5.0 3.0 5.0 0.55±0.05 DCT102K20Y5PF6FJ5A0 50VDC 1000 ±10% Y5P 5.0 3.0 5.0 0.55±0.05 DCT102K20Y5PFEFJ5A0 50VDC 1000 ±10% Y5P 5.0 3.0 5.0 DCT102K20Y5PFEFL5A0 50VDC 1000 ±10% Y5P 5.0 3.0 5.0 0.58±0.05 镀锡铜线 0.58±0.05 镀锡铜线 DCT102K20Y5PH6FL5A0 100VDC 1000 ±10% Y5P 5.0 3.0 5.0 0.55±0.05 DCT102M20Y5UF6FJ5A0 50VDC 1000 ±20% Y5U 5.0 3.0 5.0 0.55±0.05 DCT103M22Y5UF6AJ5A0 50VDC 10000 ±20% Y5U 5.5 3.0 5.0 0.55±0.05 DCT103M22Y5UF6FJ5A0 50VDC 10000 ±20% Y5U 5.5 3.0 5.0 0.55±0.05 DCT103Z22Y5VF6BL5A0 50VDC 10000 +80% to -20% Y5V 5.5 3.0 5.0 0.55±0.05 DCT103Z22Y5VF6FJ5A0 50VDC 10000 +80% to -20% Y5V 5.5 3.0 5.0 0.55±0.05 DCT103Z22Y5VF6FL5A0 50VDC 10000 +80% to -20% Y5V 5.5 3.0 5.0 0.55±0.05 DCT151K20Y5PF6FJ5A0 50VDC 150 ±10% Y5P 5.0 3.0 5.0 0.55±0.05 SHM 产品代码 SHM Part No. 直径 厚度 引线 引线直径 Dmax. Tmax 间距 d (mm) (mm) (mm) F(mm) 散 件/ 编 带 编 带 编 带 编 带 编 带 编 带 编 带 编 带 编 带 散 件 编 带 散 件 编 带 编 带 编 带 DCT152K20Y5PF6FJ5A0 50VDC 1500 ±10% Y5P 5.0 3.0 5.0 0.55±0.05 DCT221K20Y5PF6FJ5A0 50VDC 220 ±10% Y5P 5.0 3.0 5.0 0.55±0.05 DCT221K20Y5PFEFJ5A0 50VDC 220 ±10% Y5P 5.0 3.0 5.0 0.58±0.05 镀锡铜线 DCT222K22Y5PF6FJ5A0 50VDC 2200 ±10% Y5P 5.5 3.0 5.0 0.55±0.05 DCT222K22Y5PF6FJ5B8 50VDC 2200 ±10% Y5P 5.5 3.0 5.0 0.55±0.05 DCT331K20Y5PF6FJ5A0 50VDC 330 ±10% Y5P 5.0 3.0 5.0 0.55±0.05 DCT471K20Y5PF6FJ5A0 50VDC 470 ±10% Y5P 5.0 3.0 5.0 0.55±0.05 DCT471K20Y5PF6FL5A0 50VDC 470 ±10% Y5P 5.0 3.0 5.0 0.55±0.05 DCT471K20Y5PF6FL5BU 50VDC 470 ±10% Y5P 5.0 3.0 5.0 0.55±0.05 DCT471K20Y5PFEFJ5A0 50VDC 470 ±10% Y5P 5.0 3.0 5.0 0.58±0.05 镀锡铜线 DCT471K20Y5PH6FJ5A0 100VDC 470 ±10% Y5P 5.0 3.0 5.0 0.55±0.05 DCT472K30Y5PF6FJ5A0 50VDC 4700 ±10% Y5P 7.5 3.0 5.0 0.55±0.05 DCT472M20Y5UF6FJ5A0 50VDC 4700 ±20% Y5U 5.0 3.0 5.0 0.55±0.05 DCT472Z20Y5VF6FJ5A0 50VDC 4700 +80% to -20% Y5V 5.0 3.0 5.0 0.55±0.05 DCT561K20Y5PF6FJ5A0 50VDC 560 ±10% Y5P 5.0 3.0 5.0 0.55±0.05 DCT681K20Y5PF6FJ5A0 50VDC 680 ±10% Y5P 5.0 3.0 5.0 0.55±0.05 编 带 编 带 编 带 编 带 编 带 编 带 编 带 编 带 编 带 编 带 编 带 编 带 编 带 编 带 编 带 编 带 电性能指标 Electrical Performance 序号 No. 项目名称 Item 1 容量和误差 C @25℃, 1 kHz and 1 Vrms 参照规格表 See the specification 2 损耗系数 DF @25℃, 1 kHz and 1 Vrms 2.5% max. (Y5P, Y5U&Z5U) 3.5% max. (Y5V& Z5V) 3 绝缘电阻 IR @额定电压 VDC,60S 10000MΩmin 300%额定电压 无击穿或飞弧。 No visible damage 50VDC 耐电压 Rate Voltage 4 100VDC 温度特性 temperature characteristic 5 技术要求 Specification X7R/YR ±15% Y5P ±10% Y5U +22% to -56% Y5V +22% to -82% 标志 Marking 例如 e. g 22#号产品以下 ≤ 22# 正面 Front B 221 · 反面 Back 空白 Blank 26#号产品以下 =26# B 472 K · 空白 Blank 30#产品以上 ≥30# B 472 K SHM 空白 Blank 编带样式 Taping style 备注 1 DCT222K22Y5PF6FJ5B8 的编带 备注 2 DCT101K20Y5PF6FJ5BU 的编带
DCT102M20Y5UF6FJ5A0
物料型号:DCT型高介电常数圆片瓷介电容器,属于II类。
器件简介:DCT型圆片瓷介电容器具有高介电常数、大容量、小体积的特点,适用于旁路、耦合、隔直流和滤波等电路中。
引脚分配:引脚间距有5.0mm、7.5mm和10mm的选项,引脚样式包括L和J型,具体见图1-2和图1-3。
参数特性:容量范围从100pF到10000pF,工作温度为-40℃到125℃,存储温度为-10℃到40℃。电容量允许偏差有M=20%、Z=+80%-20%、K=±10%、J=±5%等选项。额定电压有50VDC和100VDC两种。
功能详解:电性能指标包括容量和误差、损耗系数、绝缘电阻和耐电压,具体数值参照规格表。
应用信息:DCT型圆片瓷介电容器适用于多种电路,包括旁路、耦合、滤波和隔离直流等。
DCT102M20Y5UF6FJ5A0 价格&库存
很抱歉,暂时无法提供与“DCT102M20Y5UF6FJ5A0”相匹配的价格&库存,您可以联系我们找货
