DCM221K20Y5PL6AJ5A0
DCM221K20Y5PL6AJ5A0
    SHM(南方宏明)
    插件,P=5mm
    220PF ±10% 500V
DCM221K20Y5PL6AJ5A0 数据手册
DCM 型中压圆片瓷介电容器 Type DCM middle voltage disc ceramic capacitors 特性 Feature ■容量范围 Wide capacitance range from 100pF to 10000pF ■工作温度 Operating Temperature: -40℃~125℃ ■存储温度 Storage Temperature: -10℃~40℃ 应用 Applications DCM 型中压圆片瓷介电容器的Ⅰ类(温度特性 CO 和 SL)适用于调谐回路和需要补偿温度效 应的电路中,Ⅱ类(温度特性 Y5P、Y5U、Z5U、Y5V)适用于旁路、滤波、耦合、隔直流等电路 中。 In the class I (CO and SL Temperature characteristic),DCM capacitors allow the Temperature compensating disc capacitors to be used in critical circuit application such as tuned circuits, CLASS II(Y5P,Y5U,Z5U,Y5V Temperature characteristic) capacitors are fit for the circuit such as bypass, filter, coupling etc, Where a large amount of Capacitance is required and the circuit is less sensitive to Capacitance change with Temperature variations. 产品型号Part Number DCM 101 K 20 Y5P L 6 B L 5 □□ 型号 Type: DCM:中压圆片瓷介电容器 电容量(Capacitance): 470:47pF 内部管理代码 Interior managing 471:470pF 472:2200pF 103:10000pF 电 容 量 允 许 偏 差 Capacitance Tolerance: M=20% Z=+80%-20% K=±10% J=±5% 尺寸代码 Size: 见规格详情 See the specification 温度特性 temperature characteristic: Y5P,Y5U,Y5V 额定电压 Rated voltage: L=500VDC 位引线间距 Lead spacing: 5=5.0mm 7=7.5mm 0=10mm 引线式样 Lead style: L、J、 见引线形状 see the lead style Figure1-2 and figure 1-3 位引线长度/包装方法/ Lead length/package: B=20min.mm, 6=6.0±0.5mm 0=10.0±0.5mm,8=8.0±0.5mm, W=3.4±0.3mm, A=7.0±0.5mm, 3=3.0±0.3mm F=12.7mm 编带/扇折,V=15.0mm 编带/扇折 引线直径 Lead diameter: CP 线: 6=0.55±0.05mm 5=0.48±0.05mm 脚型 Lead style 规格Specification 产品尺寸(mm) 额定电 压 Rated voltage (KV) 标称容量 Nominal capacitance (pF) 电容量允 许偏差范 围 Tolerance (%) 温度特性 Temperature Characteristic DCM101K20Y5PL6FJ5A0 500VDC 100 ±10% Y5P 5.0 4.0 5.0 0.55±0.05 DCM102K22X7RL6FJ5B8 500VDC 1000 ±10% X7R 5.5 4.0 5.0 0.55±0.05 DCM102K22Y5PL5WL5A0 500VDC 1000 ±10% Y5P 5.5 4.0 5.0 0.48±0.05 DCM102K22Y5PL6FJ5A0 500VDC 1000 ±10% Y5P 5.5 4.0 5.0 0.55±0.05 DCM102K22Y5PLEFJ5A0 500VDC 1000 ±10% Y5P 5.5 4.0 5.0 0.58±0.05 镀锡铜线 DCM102M20Y5UL6FJ5A0 500VDC 1000 ±20% Y5U 5.0 4.0 5.0 0.55±0.05 DCM102M20Y5UL6WJ5A0 500VDC 1000 ±20% Y5U 5.0 4.0 5.0 0.55±0.05 DCM102M20Y5VL5WL5A0 500VDC 1000 ±20% Y5V 5.0 4.0 5.0 0.48±0.05 DCM102M22Y5UL6WL5A0 500VDC 1000 ±20% Y5U 5.5 4.0 5.0 0.55±0.05 DCM103M30Y5VL6FJ5A0 500VDC 10000 ±20% Y5V 7.5 4.0 5.0 0.55±0.05 DCM103M30Y5VL6WL5A0 500VDC 10000 ±20% Y5V 7.5 4.0 5.0 0.55±0.05 DCM103Z30Y5VL6BL5A0 500VDC 10000 +80% to -20% Y5V 7.5 4.0 5.0 0.55±0.05 DCM103Z30Y5VL6FJ5A0 500VDC 10000 +80% to -20% Y5V 7.5 4.0 5.0 0.55±0.05 DCM152K26Y5PL6FJ5A0 500VDC 1500 ±10% Y5P 6.5 4.0 5.0 0.55±0.05 SHM 产品代码 SHM Part No. 直径 厚度 引线 引线直径 Dmax. Tmax 间距 d (mm) (mm) (mm) F(mm) 散 件/ 编 带 编 带 编 带 散 件 编 带 编 带 编 带 散 件 散 件 散 件 编 带 散 件 散 件 编 带 编 带 DCM152K26Y5PL6FL5A0 500VDC 1500 ±10% Y5P 6.5 4.0 5.0 0.55±0.05 DCM221K20Y5PL6AJ5A0 500VDC 220 ±10% Y5P 5.0 4.0 5.0 0.55±0.05 DCM222K26X7RL5BL5A0 500VDC 2200 ±10% X7R 6.5 4.0 5.0 0.48±0.05 DCM222K26X7RL6FJ5B8 500VDC 2200 ±10% X7R 6.5 4.0 5.0 0.55±0.05 DCM222K26X7RL6FL5A0 500VDC 2200 ±10% X7R 6.5 4.0 5.0 0.55±0.05 DCM222K26Y5PL6FJ5A0 500VDC 2200 ±10% Y5P 6.5 4.0 5.0 0.55±0.05 DCM222K26Y5PL6FL5A0 500VDC 2200 ±10% Y5P 6.5 4.0 5.0 0.55±0.05 DCM222M20Y5UL6FJ5A0 500VDC 2200 ±20% Y5U 5.0 4.0 5.0 0.55±0.05 DCM223M39Y5VL6FJ5A0 500VDC 22000 ±20% Y5V 10.0 4.0 5.0 0.55±0.05 DCM223M39Y5VL6WJ5A0 500VDC 22000 ±20% Y5V 10.0 4.0 5.0 0.55±0.05 DCM471K20Y5PL6FJ5A0 500VDC 470 ±10% Y5P 5.0 4.0 5.0 0.55±0.05 DCM472K39X7RL6FL5A0 500VDC 4700 ±10% X7R 10.0 4.0 5.0 0.55±0.05 DCM472K39Y5PL6FJ5A0 500VDC 4700 ±10% Y5P 10.0 4.0 5.0 0.55±0.05 DCM472K39Y5PL6FL5A0 500VDC 4700 ±10% Y5P 10.0 4.0 5.0 0.55±0.05 DCM472M26Y5UL6FJ5A0 500VDC 4700 ±20% Y5U 6.5 4.0 5.0 0.55±0.05 DCM472M26Y5UL6WJ5A0 500VDC 4700 ±20% Y5U 6.5 4.0 5.0 0.55±0.05 DCM472M30Y5UL6FJ5A0 500VDC 4700 ±20% Y5U 7.5 4.0 5.0 0.55±0.05 DCM472Z22Y5VL6FJ5A0 500VDC 4700 +80% to -20% Y5V 5.5 4.0 5.0 0.55±0.05 编 带 散 件 散 件 编 带 编 带 编 带 编 带 编 带 编 带 散 件 编 带 编 带 编 带 编 带 编 带 散 件 编 带 编 带 电性能指标 Electrical Performance 序号 No. 项目名称 Item 1 容量和误差 C @25℃, 1 kHz and 1 Vrms 参照规格表 See the specification 2 损耗系数 DF @25℃, 1 kHz and 1 Vrms 2.5% max. (Y5P, Y5U&X7R) 3 绝缘电阻 IR @500 VDC,60S 10000MΩmin 300%额定电压 无击穿或飞弧。 No visible damage 耐电压 Rate Voltage 4 500VDC 温度特性 temperature characteristic 5 技术要求 Specification SL ﹢140~-1100(10-6/℃) X7R ±15% Y5P ±10% Y5U +22% to -56% Y5V +22% to -82% 标志 Marking 例如 e. g 22#号产品以下 ≤ 22# 26#号产品以下 =26# 30#产品以上 ≥30# 正面 Front 反面 Back 空白 Blank 空白 Blank 空白 Blank 编带样式 Taping style 备注 1 DCM102K22X7RL6FJ5B8 的编带
DCM221K20Y5PL6AJ5A0 价格&库存
很抱歉,暂时无法提供与“DCM221K20Y5PL6AJ5A0”相匹配的价格&库存,您可以联系我们找货
