DD-2832BE-2A
DD-2832BE-2A
    DENSITRON
DD-2832BE-2A 数据手册
OLED DISPLAY MODULE Product Specification CUSTOMER STANDARD PRODUCT NUMBER DD-2832BE-2A Date CUSTOMER APPROVAL INTERNAL APPROVALS Product Mgr Doc Control Electr. Eng Bruno Recaldini Anthony Perkins Bazile Peter Date: 21 Nov 06 Date: 21 Nov 06 Date: 21 Nov 06 Approval for Specification only Approval for Specification and Sample DENSITRON TECHNOLOGIES plc. – PROPRIETARY DATA – ALL RIGHTS RESERVED FORM NO: DT-029 TABLE OF CONTENTS 1 MAIN FEATURES .......................................................................................................... 4 2 MECHANICAL SPECIFICATION............................................................................... 5 2.1 2.2 3 ELECTRICAL SPECIFICATION................................................................................. 7 3.1 3.2 3.3 3.4 3.5 4 CONFORMITY ....................................................................................................... 18 DELIVERY ASSURANCE ..................................................................................... 18 DEALING WITH CUSTOMER COMPLAINTS .................................................... 23 RELIABILITY SPECIFICATION .............................................................................. 24 8.1 8.2 9 PACKAGING .......................................................................................................... 17 LABELLING & MARKING.................................................................................... 17 QUALITY ASSURANCE SPECIFICATION ............................................................. 18 7.1 7.2 7.3 8 COMMANDS .......................................................................................................... 12 POWER UP/DOWN SEQUENCE........................................................................... 12 RESET CIRCUIT..................................................................................................... 12 APPLICATION EXAMPLE .................................................................................... 13 DISPLAY DIRECTION SETTING ......................................................................... 14 APPLICATION CIRCUIT....................................................................................... 16 PACKAGING AND LABELLING SPECIFICATION.............................................. 17 6.1 6.2 7 OPTICAL CHARACTERISTICS............................................................................ 11 APPLICATION NOTES ............................................................................................... 12 5.1 5.2 5.3 5.4 5.5 5.6 6 ABSOLUTE MAXIMUM RATINGS ....................................................................... 7 ELECTRICAL CHARACTERISTICS ...................................................................... 7 INTERFACE PIN ASSIGNMENT ............................................................................ 8 BLOCK DIAGRAM .................................................................................................. 9 TIMING CHARACTERISTICS .............................................................................. 10 OPTICAL SPECIFICATION....................................................................................... 11 4.1 5 MECHANICAL CHARACTERISTICS .................................................................... 5 MECHANICAL DRAWING ..................................................................................... 6 RELIABILITY TESTS ............................................................................................ 24 LIFE TIME............................................................................................................... 24 HANDLING PRECAUTIONS...................................................................................... 25 Product No. DD-2832BE-2A REV. D Page 2 / 25 DENSITRON TECHNOLOGIES plc. – PROPRIETARY DATA – ALL RIGHTS RESERVED REVISION RECORD Rev. Date Page Chapt. A Comment ECR no. Production Release B 23-Mar-06 15-16 17 18 C 16-May-06 10 3.5.1.1 D 21-Nov-06 17 6 Product No. Updated Display Direction Setting Updated Application circuit Updated Packaging and Labelling DD-2832BE-2A Chapter removed, no 6800 series MPU interface provided Packing details corrected REV. D Page 3 / 25 DENSITRON TECHNOLOGIES plc. – PROPRIETARY DATA – ALL RIGHTS RESERVED 1 MAIN FEATURES ITEM CONTENTS Display Format 128 x 32 Dots Overall Dimensions(W*H*T) Glass 33.4 x 14.5 x 1.8 mm Active Area(W*H) 27.50 x 6.06 mm Viewing Area(W*H) 29.50 x 8.06 mm Display Mode Passive Matrix (1.11”) Display Colour Blue Driving Method 1 / 32 duty Driver IC SSD1303 (COF) Operating temperature -20℃ ~ +70℃ Storage temperature -30℃ ~ +80℃ Product No. DD-2832BE-2A REV. D Page 4 / 25 DENSITRON TECHNOLOGIES plc. – PROPRIETARY DATA – ALL RIGHTS RESERVED 2 MECHANICAL SPECIFICATION 2.1 MECHANICAL CHARACTERISTICS ITEM CHARACTERISTIC UNIT 128 x 32 Dots 33.4 x 14.5 x 1.8 mm Display Format Overall Dimensions Glass Viewing Area(W*H) 29.50 x 8.06 mm Active Area(W*H) 27.50 x 6.06 mm Dot Size 0.195 x 0.17 mm Dot Pitch 0.215 x 0.19 mm 2.0 g Weight IC Controller/Driver Product No. SSD1303 ( COF ) DD-2832BE-2A REV. D Page 5 / 25 DENSITRON TECHNOLOGIES plc. – PROPRIETARY DATA – ALL RIGHTS RESERVED 2.2 MECHANICAL DRAWING Product No. DD-2832BE-2A REV. D Page 6 / 25 DENSITRON TECHNOLOGIES plc. – PROPRIETARY DATA – ALL RIGHTS RESERVED 3 ELECTRICAL SPECIFICATION 3.1 ABSOLUTE MAXIMUM RATINGS Item Symbol Min Max Unit Note Supply Voltage VDD -0.3 4 V Driver Supply Voltage Vcc 0 15 V Operating Temperature Top -20 70 °C - Storage Temperature Tst -30 80 °C - Static Electricity Be sure that you are grounded when handling displays. Note 1,2 Note 1: All the above voltages are on the basis of “GND=0V”. Note 2: When this module is used beyond the above absolute maximum ratings, permanent breakage of the module may occur. Also, for normal operations, it’s desirable to use this module under the conditions according to Section 3 “Electrical Characteristics”. If this module is used beyond these conditions, malfunctioning of the module can occur and the reliability of the module may deteriorate. 3.2 ELECTRICAL CHARACTERISTICS 3.2.1 DC CHARACTERISTICS Characteristics Symbol Min Typ Max Unit Supply Logic VDD 2.6 2.8 3.5 V Driver Supply Voltage VCC 7.0 7.5 8.0 V High Level Input VIH 0.8xVDD - VDD V Low Level Input VIL 0 - 0.2xVDD V High Level Output VOH 0.9xVDD - VDD V Low Level Output VOL 0 - 0.1xVDD V VDD Current IDD Note 1,2 300 450 µA VCC Current ICC Note 1 3.0 4.9 Note 2 5.0 7.5 mA (1) Note : VDD = 2.8V, VCC = 7.5V, Frame Rate = 100Hz, Contrast Setting = 0xFF, 50% pixels ON Note (2): VDD = 2.8V, VCC = 7.5V, Frame Rate = 100Hz, Contrast Setting = 0xFF, 100% pixels ON Product No. DD-2832BE-2A REV. D Page 7 / 25 DENSITRON TECHNOLOGIES plc. – PROPRIETARY DATA – ALL RIGHTS RESERVED 3.3 INTERFACE PIN ASSIGNMENT No. Symbol I/O 1 N.C. - 2 VCC I/O 3 VCOMH I/O 4 IREF I 5~12 D7~D0 I/O 13 E/RD# I 14 R/W# I 15 D/C# I 16 RES# I 17 CS# I 18 VDD I 19 VSS I 20 N.C. - Product No. DD-2832BE-2A Function Reserved Pin (Supporting Pin). The supporting pin can reduce the influences from stresses on the function pins. Power Supply for Panel. This is the most positive voltage supply pin of the chip. It can be supplied externally or generated internally by using internal DC/DC voltage converter. Voltage Output High Level for COM Signal. This pin is the input pin for the voltage output high level for COM signal. A capacitor should be connected between this pin and VSS. Current Reference for Brightness Adjustment. This pin is segment current reference pin. A resistor should be connected between this pin and VSS. Set the current at 10uA. Host Data Input/Output Bus. These pins are 8-bit bi-directional data bus to be connected to the microprocessor’s data bus. Read/Write Enable or Read. This pin receives the Read (RD#) signal. Data read operation is initiated when this pin is pulled low and CS# is pulled low. Read/Write Select or Write. This pin is the Write (WR#) input. Data write operation is initiated when this pin is pulled low and CS# ispulled low Data/Command Control. This pin is Data/Command control pin. When the pin is pulled high, the input at D7~D0 is treated as display data. When the pin is pulled low, the input at D7~D0 will be transferred to the command register. For detail relationship to MCU interface signal, please refer to the Timing Characteristics Diagrams. Power Reset for Controller and Driver. This pin is reset signal input. When the pin is low, initialization of the chip executed. Chip Select. This pin is the chip select input. The chip is enabled for MCU communication only when CS# is pulled low. Power Supply for Logic circuit This is a voltage supply pin It must be connected to an external source. Ground This is a ground pin. It also acts as a reference for the logic pins, the OLED driving voltages, and the analogue circuits. It must be connected to external ground. Reserved Pin (Supporting Pin). The supporting pin can reduce the influences from stresses on the function pins. REV. D Page 8 / 25 DENSITRON TECHNOLOGIES plc. – PROPRIETARY DATA – ALL RIGHTS RESERVED 3.4 BLOCK DIAGRAM ~ COM63 ~ ~ ~ COM33 SEG127 SEG0 ~ COM32 COM62 Active Area 1.11" 128 x 32 Pixels ~ D0 E/RD# R/W# D/C# RES# CS# VDD VSS VCC VCOMH IREF D7 SSD1303 C1 R1 C3 C2 Pins connected to MCU interface: D7~D0, E/RD#, R/W#, D/C#, RES#, and CS# C1, C3: 4.7μF C2: 10μF R1: 910kΩ, R1 = (Voltage at IREF - BGGND) / IREF Product No. DD-2832BE-2A REV. D Page 9 / 25 DENSITRON TECHNOLOGIES plc. – PROPRIETARY DATA – ALL RIGHTS RESERVED 3.5 TIMING CHARACTERISTICS 3.5.1 AC CHARACTERISTICS 3.5.1.1 8080-Series MPU Parallel Interface Timing Characteristics: Characteristics Symbol Min Max Unit Clock Cycle Time tcycle 300 - ns Address Setup Time tAS 0 - ns Address Hold Time tAH 0 - ns Write Data Setup Time tDSW 40 - ns Write Data Hold Time tDHW 15 - ns Read Data Hold Time tDHR 20 - ns Output Disable Time tOH - 70 ns Access Time tACC - 140 ns Chip Select Low Pulse Width (Read) Chip Select Low Pulse Width (Write) PWCSL 120 60 - ns Chip Select High Pulse Width (Read) Chip Select High Pulse Width (Write) PWCSH 60 60 - ns Rise Time tR - 15 ns Fall Time tF - 15 ns * All the timing should be based on 30% and 70% of VDD-GND. Product No. DD-2832BE-2A REV. D Page 10 / 25 DENSITRON TECHNOLOGIES plc. – PROPRIETARY DATA – ALL RIGHTS RESERVED 4 OPTICAL SPECIFICATION 4.1 OPTICAL CHARACTERISTICS Characteristics Symbol Condition Min Typ Max Unit Brightness Lbr With Polarizer 35 60 - cd/m2 0.12 0.16 0.20 (X) C.I.E.(Blue) Without Polarizer (Y) 0.22 Frame Rate Dark Room Contrast 0.26 0.30 100 CR Shown as below View Angle F/sec - >1:100 - - >160 - - degree Note 3: Optical measurement taken at 1/32 duty, 100Hz Frame Rate, 0xFF Contrast Setting. Product No. DD-2832BE-2A REV. D Page 11 / 25 DENSITRON TECHNOLOGIES plc. – PROPRIETARY DATA – ALL RIGHTS RESERVED 5 APPLICATION NOTES 5.1 COMMANDS Please refer to the Technical Manual for the SSD1303. 5.2 POWER UP/DOWN SEQUENCE To protect panel and extend the panel life time, the driver IC power up/down routine should include a delay period between high voltage and low voltage power sources during turn on/off. It gives the panel enough time to complete the action of charge and discharge before/after the operation. 5.2.1 POWER UP SEQUENCE: VDD ON VCC ON Display On 1. Power up VDD 2. Send Display off command 3. Clear Screen 4. Power up VCC 5. Delay 100ms (When VDD is stable) 6. Send Display on command VCC VDD VSS/Ground 5.2.2 POWER DOWN SEQUENCE: 1. Send Display off command 2. Power down VCC 3. Delay 100ms (when VCC is reach 0 and panel is completely discharges) 4. Power down VDD Display off VCC off VDD off VCC VDD VSS/Ground 5.3 RESET CIRCUIT When RES# input is low, the chip is initialized with the following status: 1. Display is off 2. 132x64 Display Mode 3. Normal segment and display data column and row address mapping (SEG0 mapped to column address 00H and COM0 mapped to row address 00H) 4. Shift register data clear in serial interface 5. Display start line is set at display RAM address 0 6. Column address counter is set at 0 7. Normal scan direction of the COM outputs 8. Contrast control register is set at 80H 9. Internal booster is selected Product No. DD-2832BE-2A REV. D Page 12 / 25 DENSITRON TECHNOLOGIES plc. – PROPRIETARY DATA – ALL RIGHTS RESERVED 5.4 APPLICATION EXAMPLE Command usage and explanation of an actual example < Initialization Setting > Set Display Clock Divide Ratio / Oscillator Frequency ( 11010101 with XXXXXXXX ) Set Display Offset ( 11010011 with **XXXXXX ) * XXXXXX = 64 – Dummy Line from Common 0 Set Multiplex Ratio ( 10101000 with **XXXXXX ) Set DC/DC On/Off ( 10101101 with 1000101X ) 10001010 => 0x8A ( Off ) Set Area Colour Mode & Low Power Display Mode ( 11011000 with 00XX0X0X ) 00000101 => 0x05 ( Mono & Low Power Save Mode ) Set Display Start Line ( 01XXXXXX ) Set Segment Re-map ( 1010000X ) Set COM Output Scan Direction ( 11011010 with 000X0010 ) 00010010 => 0x12 ( Alternative Mode ) Set Contrast Control Register ( 10000001 with XXXXXXXX ) Set Entire Display On/Off ( 1010010X ) 10100100 => 0xA4 ( Normal ) Set Normal/Inverse Display ( 1010011X ) 10100110 => 0xA6 ( Normal ) Set Display On/Off ( 1010111X ) 10101111 => 0xAF ( Turns On ) < Display Boundary Setting > Set Page Address ( 1011XXXX ) 10110000 => 0xB0 Set Lower Column Address ( 0000XXXX ) Set Higher Column Address ( 0001XXXX ) If the noise is accidentally occurred at the displaying window during the operation, please reset the display in order to recover the display function. Product No. DD-2832BE-2A REV. D Page 13 / 25 DENSITRON TECHNOLOGIES plc. – PROPRIETARY DATA – ALL RIGHTS RESERVED 5.5 DISPLAY DIRECTION SETTING 5.5.1 Normal Display Mode Set Display Offset 0xD3 with 0x20 Set Multiplex Ratio 0xA8 with 0x1F Set Display Start Line 0x40 Set Segment Re-map 0xA0 (Normal Mode) Set COM Output Scan Direction 0xC8 (Remapped Mode) Set Lower Column Address 0x00 Set Higher Column Address 0x10 Product No. DD-2832BE-2A REV. D Page 14 / 25 DENSITRON TECHNOLOGIES plc. – PROPRIETARY DATA – ALL RIGHTS RESERVED 5.5.2 Inverted Display Mode * The pattern shown in active area is the same as that in normal display mode but setting the COM Output Scan Direction as remapped mode. Set Display Offset 0xD3 with 0x20 Set Multiplex Ratio 0xA8 with 0x1F Set Display Start Line 0x40 Set Segment Re-map 0xA1 (Remapped Mode) Set COM Output Scan Direction 0xC0 (Normal Mode) Set Lower Column Address 0x04 Set Higher Column Address 0x10 Product No. DD-2832BE-2A REV. D Page 15 / 25 DENSITRON TECHNOLOGIES plc. – PROPRIETARY DATA – ALL RIGHTS RESERVED 5.6 APPLICATION CIRCUIT 5.6.1 Components List Item Driver IC DC/DC Converter Inductor Schottky Diode Resistor Capacitor Connector Product No. Silk Name SSD1303 TPS61041 L1 D1 R1 R2 R3 C1 C2, C5 C3 C4 C6 FH12A-20S-0.5SH FH19S-20S-0.5SH DD-2832BE-2A Value 4.7μH 150kΩ 24kΩ 910kΩ 0.1μF 4.7μF 10μF 0.1μF 4.7μF REV. D Remark (Solomon Systech) Step-up Type (TI) 2A 1A, 20V 1%, 1/4W 1%, 1/4W 1% 6.3V, Low ESR 6.3V, Low ESR 16V, Low ESR 16V, Low ESR 16V, Low ESR Top Contact Type (HRS) Bottom Contact Type (HRS) Page 16 / 25 DENSITRON TECHNOLOGIES plc. – PROPRIETARY DATA – ALL RIGHTS RESERVED 6 PACKAGING AND LABELLING SPECIFICATION 6.1 PACKAGING 6.1.1 Material Item 1 2 3 4 5 6 Dimensions (mm) Part code Module Tray Inner box Carton Inner box bag Total weight DD-2832BE-2A 33.4*14.5*1.8 *** *** *** *** ***** ***** ***** ***** 7.54 Kg Unit weight (kg) 0.002 0.010 0.250 1.100 *** ± 5% Quantity 2880 64 4 1 *** 6.1.2 Specification and quantity Modules x tray Modules per inner box Modules in outer box = = = 48 720 2880 6.2 LABELLING & MARKING DENSITRON DD-2832BE-2A TW YY MM Product No. DD-2832BE-2A REV. D Page 17 / 25 DENSITRON TECHNOLOGIES plc. – PROPRIETARY DATA – ALL RIGHTS RESERVED 7 QUALITY ASSURANCE SPECIFICATION 7.1 CONFORMITY The performance, function and reliability of the shipped products conform to the Product Specification. 7.2 DELIVERY ASSURANCE 7.2.1 Delivery inspection standards • IPC-AA610, class 2 electronic assemblies standard 7.2.2 Zone definition A Viewing area B Outside viewing area Product No. DD-2832BE-2A REV. D Page 18 / 25 DENSITRON TECHNOLOGIES plc. – PROPRIETARY DATA – ALL RIGHTS RESERVED 7.2.3 Visual inspection • • • • Inspect under 30W fluorescent lamp leaving 50 cm between the module and the lamp and 30 cm between the module and the eye (measuring position). Appearance is inspected at the best contrast voltage (best contrast is adjusted considering clearness and crosstalk on screen). Inspect the module at 45° right and left, top and bottom. Use the optimum viewing angle during the contrast inspection. eye 45° Product No. DD-2832BE-2A 45° REV. D Page 19 / 25 DENSITRON TECHNOLOGIES plc. – PROPRIETARY DATA – ALL RIGHTS RESERVED 7.2.4 Standard of appearance inspection Units: mm No Item Criteria Round type: as per following drawing ∅ = (X+Y)/2 Y X 1 Black spot, white spot, dust Size ∅
DD-2832BE-2A 价格&库存
很抱歉,暂时无法提供与“DD-2832BE-2A”相匹配的价格&库存,您可以联系我们找货
