EVK-CONNECT-022
EVK-CONNECT-022
    DENSITRON
    Module
EVK-CONNECT-022 数据手册
OLED DISPLAY MODULE Application Notes PRODUCT NUMBER DD-2832BE-2A with EVK board Copyright ©2006 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data TABLE OF CONTENTS 1 EVK SCHEMATIC.......................................................................................................... 4 2 SYMBOL DEFINITION ................................................................................................. 5 3 TIMING CHARACTERISTICS .................................................................................... 6 4 CONNECTION BETWEEN OLED AND EVK ........................................................... 7 5 HOW TO USE THE DD-2832BE-2A ............................................................................. 9 5.1 RECOMMENDED INITIAL CODE .................................................................................. 10 Product No. DD-2832BE-2A REV. A Page 2 / 11 Copyright ©2005 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data REVISION RECORD Rev. Date A 20-June-06 Product No. Page Chapt. Comment ECR no. First Issue DD-2832BE-2A REV. A Page 3 / 11 Copyright ©2005 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 1 EVK Schematic Product No. DD-2832BE-2A REV. A Page 4 / 11 Copyright ©2005 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 2 Symbol Definition Note: The EVK is hard wired to 8080 Parallel interface. D0-D7:These pins are 8-bit bi-directional data bus to be connected to the MCU’s data bus. E/RD#:This pin is MCU interface input. When connecting to an 8080-microprocessor, this pin receives the Read (RD#) signal. Data read operation is initiated when this pin is pulled low and the chip is selected. R/W#:This pin is MCU interface input. When 8080 interface mode is selected, this pin will be the Write (WR#) input. Data write operation is initiated when this pin is pulled low and the chip is selected. D/C#:This pin is Data/Command control pin. When the pin is pulled high, the data at D7D0 is treated as display data. When the pin is pulled low, the data at D7-D0 will be transferred to the command register. For detail relationship to MCU interface signals, please refer to the timing characteristics diagrams. RES#:This pin is reset signal input. When the pin is low, initialization of the chip is executed. CS#:This pin is the chip select input. The chip is enabled for MCU communication only when CS is pulled low. VCC:This is the most positive voltage supply pin of the chip. VDD:Power Supply pin for logic operation of the driver. VSS:This is a ground pin. It also acts as a reference for the logic pins and the OLED driving voltages. It must be connected to external ground. VCOMH:This is an input pin for the voltage output high level for COM signals. A capacitor should be connected between this pin and VSS. NC:Dummy pad. Do not group or short NC pins together. Product No. DD-2832BE-2A REV. A Page 5 / 11 Copyright ©2005 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 3 Timing characteristics VDD = 2.4 to 3.5V, TA= -40to 85°C Table 2 8080-Series MPU Parallel Interface Timing Characteristics Figure 1 8080-series MPU parallel interface characteristics Product No. DD-2832BE-2A REV. A Page 6 / 11 Copyright ©2005 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 4 Connection Between OLED and EVK Figure 2 EVK PCB and DD-2832BE-2A Module Figure 3 the DD-2832BE-2A and EVK assembled (Top view) REV. A DD-2832BE-2A Product No. Page 7 / 11 Copyright ©2005 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data Figure 4 control MCU (not supplied ) connected with EVK Note 1:It is the external most positive voltage supply. In this sample is connected to power supply. Product No. DD-2832BE-2A REV. A Page 8 / 11 Copyright ©2005 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 5 How to use the DD-2832BE-2A Reset Set RES#=0; Delay 10ms; RES#=1 Initial IC code Suggest all registers set again Display on Clear RAM Start sending data Product No. DD-2832BE-2A REV. A Page 9 / 11 Copyright ©2005 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 5.1 Recommended Initial code void initial(void) { BS1=1; // use 8080 interface BS2=1; DC=0; WR=0; RD=0; CS=0; RES=0; delay(100); RES=1; write_c(0xAE); //display off write_c(0x81); //set contrast write_c(0xff); //max current write_c(0xa8); //set duty write_c(0x1F); //duty 31 write_c(0xA0); //Set Segment Re-map write_c(0xd3); //display offset write_c(0x20); //set 32 write_c(0x40); //Start line write_c(0xC8); //Set COM Output Scan Direction write_c(0xda); //Set COM pins hardware configuration write_c(0x12); //Set COM pins hardware configuration write_c(0xD9); //Set precharge write_c(0xf1); //precharge=fh , discharge=1h write_c(0xDB); //Set VcomH write_c(0x49); //VcomH=73 write_c(0xA4); //Normal Mode write_c(0xA6); //No Inverse write_c(0xAF); //display on } void write_c(unsigned char ins_c) { DC=0; CS=0; RD=1; /*tell system only write*/ WR=0; d_bus=ins_c; WR=1; CS=1; DC=1; } Product No. DD-2832BE-2A REV. A Page 10 / 11 Copyright ©2005 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data void write_d(unsigned char ins_d) { DC=1; CS=0; RD=1; /*tell system only write*/ WR=0; d_bus=ins_d; CS=1; WR=1; DC=1; } void delay(int count) { int i,j; for(i=0;i
EVK-CONNECT-022 价格&库存
很抱歉,暂时无法提供与“EVK-CONNECT-022”相匹配的价格&库存,您可以联系我们找货
