DD-12864YO-5A
DD-12864YO-5A
    DENSITRON
DD-12864YO-5A 数据手册
OLED DISPLAY MODULE Product Specification CUSTOMER Standard PRODUCT NUMBER DD-12864YO-5A Date CUSTOMER APPROVAL INTERNAL APPROVALS Product Mgr Doc. Control Electr. Eng Elijah Ebo Anthony Perkins Bazile Peter Date: 03 Dec 07 Date: 03 Dec 07 Date: 03 Dec 07 Copyright ©2006 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data TABLE OF CONTENTS 1 MAIN FEATURES .......................................................................................................... 4 2 MECHANICAL SPECIFICATION ............................................................................... 5 2.1 2.2 3 ELECTRICAL SPECIFICATION ................................................................................. 7 3.1 3.2 3.3 3.4 4 ABSOLUTE MAXIMUM RATINGS ....................................................................... 7 ELECTRICAL CHARACTERISTICS ...................................................................... 8 INTERFACE PIN ASSIGNMENT ............................................................................ 9 TIMING CHARACTERISTICS .............................................................................. 12 OPTICAL SPECIFICATION ....................................................................................... 15 4.1 5 MECHANICAL CHARACTERISTICS .................................................................... 5 MECHANICAL DRAWING ..................................................................................... 6 OPTICAL CHARACTERISTICS ............................................................................ 15 FUNCTIONAL SPECIFICATION .............................................................................. 16 5.1 5.2 5.3 5.4 COMMANDS .......................................................................................................... 16 POWER UP/DOWN SEQUENCE ........................................................................... 16 RESET CIRCUIT ..................................................................................................... 16 ACTUAL APPLICATION EXAMPLE ................................................................... 17 6 PACKAGING AND LABELLING SPECIFICATION .............................................. 18 7 QUALITY ASSURANCE SPECIFICATION ............................................................. 19 7.1 7.2 7.3 8 RELIABILITY SPECIFICATION .............................................................................. 24 8.1 8.2 9 CONFORMITY ....................................................................................................... 19 DELIVERY ASSURANCE ..................................................................................... 19 DEALING WITH CUSTOMER COMPLAINTS .................................................... 23 RELIABILITY TESTS ............................................................................................ 24 LIFE TIME ............................................................................................................... 24 HANDLING PRECAUTIONS ...................................................................................... 25 Product No. DD-12864YO-5A REV. A Page 2 / 25 Copyright ©2006 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data REVISION RECORD Rev. Date A 03 Dec 07 Product No. Page Chapt. Comment ECR no. First Issue DD-12864YO-5A REV. A Page 3 / 25 Copyright ©2006 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 1 MAIN FEATURES ITEM CONTENTS Display Format 128 x 64 Dots Overall Dimensions 73.00 x 41.86 x 2.00 mm Colour Monochrome Yellow Active Area 61.41 x 30.69 mm Viewing Area 63.41 x 32.69mm Display Mode Passive Matrix (2.70”) Driving Method 1/64 duty Driver IC SSD1325 Operating temperature -30 ~ +70 Storage temperature -40 ~ +80 Product No. DD-12864YO-5A REV. A Page 4 / 25 Copyright ©2006 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 2 MECHANICAL SPECIFICATION 2.1 MECHANICAL CHARACTERISTICS ITEM Display Format Overall Dimensions CHARACTERISTIC UNIT 128 x 64 Dots Dots 73.00 x 41.86 x 2.00 mm Viewing Area 63.41 x 32.69 mm Active Area 61.41 x 30.69 mm Dot Size 0.45 x 0.45 mm Dot Pitch 0.48 x 0.48 mm 21 g Weight IC Controller/Driver Product No. SSD1325 DD-12864YO-5A REV. A Page 5 / 25 Copyright ©2006 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 2.2 MECHANICAL DRAWING Product No. DD-12864YO-5A REV. A Page 6 / 25 Copyright ©2006 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 3 ELECTRICAL SPECIFICATION 3.1 ABSOLUTE MAXIMUM RATINGS VSS = 0 V, Ta = 25 °C Item Symbol Min Max Unit Supply Voltage for logic VDD -0.3 4.0 V Supply voltage for Display VCC 0 16 V Operating Temperature Top -30 70 °C Storage Temperature Tst -40 80 °C Note Note 1, 2 Static Electricity Be sure that you are grounded when handling displays. Note 1: All the above voltages are on the basis of “GND=0V”. Note 2: When this module is used beyond the above absolute maximum ratings, permanent damage to the module may occur. Also for normal operations it’s desirable to use this module under the conditions according to Section 3.2 “Electrical Characteristics”. If this module is used beyond these conditions the module may malfunction and the reliability could deteriorate. Copyright ©2006 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 3.2 ELECTRICAL CHARACTERISTICS Characteristics Symbol Supply Voltage VDD Supply Voltage for Display VCC High Level Input VIH Low Level Input VIL High Level Output VOH Low Level Output VOL Operating current for VDD IDD Operating current for VCC ICC Conditions Min Typ Max Unit 2.4 2.8 3.5 V 14.25 15 15.75 V 0.8xVDD - VDD V 0 - 0.2 x VDD V 0.9 x VDD - V 0 - Note 4 - 250 VDD 0.1 x VDD 400 Note 5 - 250 400 Note 4 - 31 39 Note 5 - 53 66 Note 3 IOUT=0.1mA, 3.3MHz V µA mA Sleep mode current for VDD IDD SLEEP - 1 2 µA Sleep mode current for VCC ICC SLEEP - 1 2 µA Note 3 Brigthness (Lbr) and Supply Voltage for Display (VCC) are subject to the change of the panel characteristics and the customers request Note 4 VDD = 2.8V, VCC = 15V, 50% display area turned on. Note 5 VDD = 2.8V, VCC = 15V, 100% display area turned on. Product No. DD-12864YO-5A REV. A Page 8 / 25 Copyright ©2006 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 3.3 INTERFACE PIN ASSIGNMENT No. Symbol 1 N.C.(GND) Function Reserved Pin (Supporting Pin) The supporting pins can reduce the influences from stresses on the function pins. These pins must be connected to external ground. Power Supply for OEL Panel VCC 2 This is the most positive voltage supply pin of the chip. It can be supplied externally or generated internally by using internal DC/DC voltage converter. Voltage Output High Level for COM Signal 3 VCOMH 4 IREF This pin is the input pin for the voltage output high level for COM signals. It can be supplied externally or internally. When VCOMH is generated internally, a capacitor should be connected between this pin and VSS. Current Reference for Brightness Adjustment This pin is segment current reference pin. A resistor should be connected between this pin and VSS. Set the current at 10µA. Host Data Input/Output Bus 5~12 D7~D0 These pins are 8-bit bi-directional data bus to be connected to the microprocessor’s data bus. When serial mode is selected, D1 will be the serial data input SDIN and D0 will be the serial clock input SCLK. Read/Write Enable or Read 13 E/RD# This pin is MCU interface input. When interfacing to a 68XX-series microprocessor, this pin will be used as the Enable (E) signal. Read/write operation is initiated when the pin is pulled high and the CS# is pulled low. When connecting to an 80XX-microprocessor, this pin receives the Read (RD#) signal. Data read operation is initiated when this pin is pulled low and CS# is pulled low. Read/Write Select or Write 14 R/W# This pin is MCU interface input. When interfacing to a 68XX-series microprocessor, this pin will be used as Read/Write (R/W#) selection input. Pull this pin to “High” for read mode and pull it “Low” for write mode. When 80XX interface mode is selected, this pin will be the Write (WR#) input. Data write operation is initiated when this pin is pulled low and the CS# is pulled low. Data/Command Control 15 D/C# 16 RES# 17 CS# 18 N.C. This pin is Data/Command control pin. When the pin is pulled high, the input at D7~D0 is treated as display data. When the pin is pulled low, the input at D7~D0 will be transferred to the command register. For detail relationship to MCU interface signals, please refer to the Timing Characteristics Diagrams. When the pin is pulled high and serial interface mode is selected, the data at SDIN is treated as data. When it is pulled low, the data at SDIN will be transferred to the command register. Power Reset for Controller and Driver This pin is reset signal input. When the pin is low, initialization of the chip is executed. Chip Select Product No. This pin is the chip select input. The chip is enabled for MCU communication only when CS# is pulled low. No Connection DD-12864YO-5A REV. A Page 9 / 25 Copyright ©2006 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 19 Communicating Protocol Select BS1 20 BS2 21 VDD 22~28 N.C. These pins are MCU interface selection input. See the following table: Power Supply for Logic Circuit This is a voltage supply pin. It must be connected to external source. Reserved Pin The supporting pins can reduce the influences from stresses on the function pins. These pins must be connected to external ground. Ground of OEL System 29 VSS 30 VSL Product No. This is a ground pin. It also acts as a reference for the logic pins, the OEL driving voltages, and the analog circuits. It must be connected to external ground. Voltage Output Low Level for SEG Signal This pin is the output for the voltage output low level for SEG signals. A capacitor should be connected between this pin and VSS. DD-12864YO-5A REV. A Page 10 / 25 Copyright ©2006 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data BLOCK DIAGRAM MCU Interface Selection: BS1 and BS2 Pins connected to MCU interface: D7~D0, E/RD#, R/W#, D/C#, RES# and CS#. C1, C3: C2, C6: C4: C5: R1: Product No. 0.1µF 4.7µF 10µF 4.7µF/25V Tantalum Capacitor 820 kΩ, R1 = (Voltage at IREF – BGGND) / IREF DD-12864YO-5A REV. A Page 11 / 25 Copyright ©2006 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 3.4 TIMING CHARACTERISTICS 3.4.1 AC CHARACTERISTICS 3.4.1.1 68XX-Series MPU Parallel Interface Timing Characteristics VDD = 2.8V, Ta = 25˚C Symbol Description Min Max Unit System Cycle Time Address Setup Time 300 0 - ns Address Hold Time 0 - ns ns tDSW Write Data Setup Time 40 - ns tDHW Write Data Hold Time 15 - ns tDHR Read Data Hold Time 20 - ns tOH Output Disable Time - 70 ns Access Time - 140 ns - ns - ns 15 15 ns ns tcycle tAS tAH tACC PWCSL PWCSH tR tF Product No. Chip Select Low Pulse Width (Read) Chip Select 120 Low Pulse width (Write) Chip Select High Pulse Width (Read) Chip Select 60 60 High Pulse Width (Write) 60 Rise Time Fall Time DD-12864YO-5A - REV. A Page 12 / 25 Copyright ©2006 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 3.4.1.2 80XX-Series MPU Parallel Interface Timing Characteristics Symbol tcycle tAS tAH tDSW tDHW tDHR tOH tACC PWCSL PWCSH tR tF Product No. Description Clock Cycle Time Address Setup Time Address Hold Time Write Data Setup Time Write Data Hold Time Read Data Hold Time Output Disable Time Access Time Chip Select Low Pulse Width (Read) Chip Select Low Pulse Width (Write) Chip Select Setup High Pulse Width (Read) Chip Select Setup High Pulse Width (Write) Rise Time Fall Time DD-12864YO-5A REV. A Min 300 0 0 40 15 20 120 60 60 60 - Max 70 140 15 15 Page Unit ns ns ns ns ns ns ns ns ns ns ns ns ns ns 13 / 25 Copyright ©2006 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 3.4.1.3 Serial Interface Timing Characteristics VDD = 2.8V , Ta = 25˚C Symbol tcycle tAS tAH tCSS tCSH tDSW tDHW tCLKL tCLKH tR tF Product No. Description Clock Cycle Time Address Setup Time Address Hold Time Chip Select Setup Time Chip Select Hold Time Write Data Setup Time Write Data Hold Time Serial Clock Low Time Serial Clock High Time Rise Time Fall Time DD-12864YO-5A Min 250 150 150 120 60 100 100 100 100 - REV. A Max 15 15 Unit ns ns ns ns ns ns ns ns ns ns ns Page 14 / 25 Copyright ©2006 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 4 OPTICAL SPECIFICATION 4.1 OPTICAL CHARACTERISTICS Characteristics Symbol Condition Min Typ Max Unit Brightness(White) Lbr With Polarizer (Note 3) 70 100 - cd/m2 0.44 0.48 0.52 (X) C.I.E.(White) Dark Room Contrast Without Polarizer - (Y) 0.47 0.51 0.55 CR - >1000:1 - - >160 - - degree Viewing Angle Optical measurement taken at VDD = 2.8V, VCC = 15V. Software configuration follows Section 4.4 Initialization Product No. DD-12864YO-5A REV. A Page 15 / 25 Copyright ©2006 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 5 FUNCTIONAL SPECIFICATION 5.1 COMMANDS Please refer to the Technical Manual for the SSD1325 5.2 POWER UP/DOWN SEQUENCE To protect panel and extend the panel lifetime, the driver IC power up/down routine should include a delay period between high voltage and low voltage power sources during turn on/off. It gives the panel enough time to complete the action of charge and discharge before/after the operation. 5.2.1 POWER UP SEQUENCE VDD ON 1. Power up VDD 2. Send Display off command 3. Initialization 4. Clear Screen 5.Power up VCC 6. Delay 100ms (when VDD is stable) 7. Send Display on command VCC ON Display On Vcc VDD VSS Ground 5.2.2 POWER DOWN SEQUENCE Display off 1. Send Display off command 2. Power down VCC 3. Delay 100ms (When VPP reach 0 and panel is completely discharges) 4. Power down VDD VCC off VDD off VCC VDD VSS Ground 5.3 RESET CIRCUIT When RES# input is low, the chip is initialized with the following status: 1. Display is OFF 2. 128x80 Display mode 3. Normal segment and display data column and row address mapping (SEG0 mapped to column address 00H and COM0 mapped to row address 00H) 4. Shift register data clear in serial interface 5. Display start line is set at display RAM address 0 6. Column address counter is set at 0 7. Normal scan direction of the COM outputs 8. Contrast control register is set at 80H 9. Normal display mode (Equivalent to A4h command) Product No. DD-12864YO-5A REV. A Page 16 / 25 Copyright ©2006 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 5.4 ACTUAL APPLICATION EXAMPLE Command usage and explanation of an actual example If the noise is accidentally occurred at the displaying window during the operation, please reset the display in order to recover the display function. Product No. DD-12864YO-5A REV. A Page 17 / 25 Copyright ©2006 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 6 PACKAGING AND LABELLING SPECIFICATION DENSITRON DD-12864YO-5A TW YY MM 54 Pieces per tray 15 trays per box ( 810 pieces ) 4 boxes per carton (3240 pieces ) Product No. DD-12864YO-5A REV. A Page 18 / 25 Copyright ©2006 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 7 QUALITY ASSURANCE SPECIFICATION 7.1 CONFORMITY The performance, function and reliability of the shipped products conform to the Product Specification. 7.2 DELIVERY ASSURANCE 7.2.1 DELIVERY INSPECTION STANDARDS IPC-AA610, class 2 electronic assemblies standard 7.2.2 Zone definition A Active B Outside Active 7.2.3 Visual inspection Test and measurement to be conducted under following conditions: Temperature: Humidity: Fluorescent lamp: 23±5℃ 55±15%RH 30 W Distance between the Panel & Eyes of the Inspector: Distance between the Panel & the lamp: Product No. DD-12864YO-5A REV. A ≧30cm ≧50cm Page 19 / 25 Copyright ©2006 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 7.2.4 Standard of appearance inspection Units: mm Class Item Criteria Minor Critical Packing & Label Major Dimension Outside & inside package Presence of product no., lot no., quantity Product must not be mixed with others and quantity must not be different from that indicated on the label Product dimensions must be according to specification and drawing Major Electrical Product electrical characteristics must be according to specification Critical OLED Display Black spot, white spot, dust Minor Missing lines, short circuits or wrong patterns on OLED display are not allowed Round type: as per following drawing ∅ = (X+Y)/2 Acceptable quantity Size Zone A Zone B Any number ∅
DD-12864YO-5A 价格&库存
很抱歉,暂时无法提供与“DD-12864YO-5A”相匹配的价格&库存,您可以联系我们找货
