DD-9664FC-2A
DD-9664FC-2A
    DENSITRON
DD-9664FC-2A 数据手册
OLED DISPLAY MODULE Product Specification CUSTOMER STANDARD PRODUCT NUMBER DD-9664FC-2A CUSTOMER APPROVAL INTERNAL APPROVALS Product Mgr Doc Control Electr. Eng Bruno Recaldini Anthony Perkins Bazile Peter Date: 01/02/07 Date: 01/02/07 Date: 01/02/07 DENSITRON TECHNOLOGIES plc. – PROPRIETARY DATA – ALL RIGHTS RESERVED FORM NO: 0199 Issue 2.0 TABLE OF CONTENTS 1 MAIN FEATURES .......................................................................................................... 4 2 MECHANICAL SPECIFICATION............................................................................... 5 2.1 2.2 3 MECHANICAL CHARACTERISTICS .................................................................... 5 MECHANICAL DRAWING ..................................................................................... 6 ELECTRICAL SPECIFICATION................................................................................. 7 3.1 ABSOLUTE MAXIMUM RATINGS ....................................................................... 7 3.2 ELECTRICAL CHARACTERISTICS ...................................................................... 8 3.3 INTERFACE PIN ASSIGNMENT .................................................................................. 9 3.4 BLOCK DIAGRAM....................................................................................................... 11 3.5 TIMING CHARACTERISTICS .................................................................................... 12 4 OPTICAL SPECIFICATION....................................................................................... 15 4.1 OPTICAL CHARACTERISTICS............................................................................ 15 5 APPLICATION NOTES ............................................................................................... 16 6 SOFTWARE INITIAL SETTING ............................................................................... 19 7 PACKAGING AND LABELLING SPECIFICATION.............................................. 20 7.1 7.2 8 QUALITY ASSURANCE SPECIFICATION ............................................................. 22 8.1 8.2 8.3 9 CONFORMITY ....................................................................................................... 22 DELIVERY ASSURANCE ..................................................................................... 22 DEALING WITH CUSTOMER COMPLAINTS .................................................... 27 RELIABILITY SPECIFICATION .............................................................................. 28 9.1 9.2 9.3 10 PACKAGING .......................................................................................................... 20 LABELLING & MARKING.................................................................................... 21 CONTENTS OF RELIABILITY TESTS................................................................. 28 FAILURE CHECK STANDARD ............................................................................ 28 LIFE TIME............................................................................................................... 28 HANDLING PRECAUTIONS.................................................................................. 29 Product No. DD-9664FC-2A REV. A REV. Page 2 / 29 DENSITRON TECHNOLOGIES plc. – PROPRIETARY DATA – ALL RIGHTS RESERVED REVISION RECORD Rev. Date A Feb 2007 Product No. Page Chapt. Comment ECR no. Production Release DD-9664FC-2A REV. A REV. Page 3 / 29 DENSITRON TECHNOLOGIES plc. – PROPRIETARY DATA – ALL RIGHTS RESERVED 1 MAIN FEATURES ITEM CONTENTS Display Format 96 (R.G.B.) x 64 Dots Overall Dimensions(W*H*T) Glass 25.70 x 22.20 x 1.5 mm Active Area(W*H) 20.14 x 13.42 mm Viewing Area(W*H) 22.14 x 15.42 mm Display Mode Passive Matrix (0.95”) Display Colour 65,536 Colour Driving Method 1 / 64 duty Driver IC SSD1331 Operating temperature -30℃ ~ +70℃ Storage temperature -40℃ ~ +80℃ Product No. DD-9664FC-2A REV. A REV. Page 4 / 29 DENSITRON TECHNOLOGIES plc. – PROPRIETARY DATA – ALL RIGHTS RESERVED 2 MECHANICAL SPECIFICATION 2.1 MECHANICAL CHARACTERISTICS ITEM CHARACTERISTIC UNIT 96 ( RGB x 64 Dots 25.70 x 22.20 x 1.50 mm Active Area(W*H) 20.14 x 13.42 mm Viewing Area(W*H) 22.14 x 15.42 mm Dot Size 0. 05 x (RGB) x 0.19 mm Dot Pitch 0.07 x (RGB) x 0.21 mm 1.8 g Display Format Overall Dimensions Weight IC Controller/Driver Product No. SSD1331 DD-9664FC-2A REV. A REV. Page 5 / 29 DENSITRON TECHNOLOGIES plc. – PROPRIETARY DATA – ALL RIGHTS RESERVED 2.2 MECHANICAL DRAWING Product No. DD-9664FC-2A REV. A REV. Page 6 / 29 DENSITRON TECHNOLOGIES plc. – PROPRIETARY DATA – ALL RIGHTS RESERVED 3 ELECTRICAL SPECIFICATION 3.1 ABSOLUTE MAXIMUM RATINGS Item Symbol Min Max Unit Note Supply Voltage VDD -0.3 4 V Driver Supply Voltage Vcc 0 15 V VCC Supply Current ICC - 25 mA Operating Temperature Top -30 70 °C - Storage Temperature Tst -40 80 °C - Static Electricity Be sure that you are grounded when handling displays. Note 1,2 Note 1: All the above voltages are on the basis of “GND=0V”. Note 2: When this module is used beyond the above absolute maximum ratings, permanent breakage of the module may occur. Also, for normal operations, it’s desirable to use this module under the conditions according to Section 3 “Electrical Characteristics”. Product No. DD-9664FC-2A REV. A REV. Page 7 / 29 DENSITRON TECHNOLOGIES plc. – PROPRIETARY DATA – ALL RIGHTS RESERVED 3.2 ELECTRICAL CHARACTERISTICS 3.2.1 DC CHARACTERISTICS Characteristics Symbol Conditions Min Typ Max Unit Supply Logic Supply Voltage for I/O pins Driver Supply Voltage VDD 2.4 2.8 3.5 V VDDIO 1.6 2.8 3.5 V VCC - 14.0 - V Operating Current for VDD IDD Note 1 - 0.2 0.6 mA Note 2 - 0.2 0.6 mA Operating Current for VCC ICC Note 1 - 8 11 mA Note 2 - 13.5 18 mA IDD sleep - 1 2 µA ICC sleep - 1:1000 - - >160 - - degree Optical measurement taken at VDD = 2.8V, VCC = 14V and software configuration follows Section 6 “Software Initial Setting” Note 1: Brightness (Lbr) and Driver Supply Voltage (VCC) are subject to the change of the panel characteristics and the customer’s request. Product No. DD-9664FC-2A REV. A REV. Page 15 / 29 DENSITRON TECHNOLOGIES plc. – PROPRIETARY DATA – ALL RIGHTS RESERVED 5 APPLICATION NOTES 5.1 COMMANDS Please refer to the Technical Manual for the SSD1331. 5.2 POWER UP/DOWN SEQUENCE To protect panel and extend the panel life time, the driver IC power up/down routine should include a delay period between high voltage and low voltage power sources during turn on/off. It gives the panel enough time to complete the action of charge and discharge before/after the operation. 5.2.1 POWER UP SEQUENCE: VDD /VDDIO ON 1. Power up VDD & VDDIO 2. Send Display off command 3. Clear Screen 4. Power up VCC 5. Delay 100ms (When VDD& VDDIO is stable) 6. Send Display on command VCC ON Display On VCC VDD/ VDDIO VSS/Ground 5.2.2 POWER DOWN SEQUENCE: Display off VCC off VDD/ VDDIO off 1. Send Display off command 2. Power down VCC 3. Delay 100ms (when VCC is reach 0 and panel is completely discharges) 4. Power down VDD& VDDIO VCC VDD/ VDDIO VSS/Ground 5.3 RESET CIRCUIT When RES# input is low, the chip is initialized with the following status: 1. Display is off 2. 64MUX Display Mode 3. Display start line is set at display RAM address 0 4. Display offset set to 0 5. Normal segment and display data column address and row address mapping ( SEG0 mapped to address 00H and COM0 mapped to address 00H) 6. Column address counter is set at 0 7. Master contrast control register is set at 0FH 8. Individual contrast control registers of colour A, B and C are set at 80H. 9. Shift register data clear in serial interface 10.Normal display mode ( Equivalent to A4 command ) Product No. DD-9664FC-2A REV. A REV. Page 16 / 29 DENSITRON TECHNOLOGIES plc. – PROPRIETARY DATA – ALL RIGHTS RESERVED 5.4 APPLICATION EXAMPLE Command usage and explanation of an actual example < Initialization Setting > Set Display On/Off (1010111X) 10101110=>0xAE ( Display Off) Set Display Mode (101001XX) 10100100=>0xA4 ( Normal Display Mode ) Set Display Clock Divide Ratio / Oscillator Frequency (10110011 with XXXXXXXX) Set Display Offset (10100010 with XXXXXXXX) Set Multiplex Ratio (11001000 with XXXXXXXX) Set Master Configuration (10101101 with 1000111X) 10001110=>0x8E (External VCC supply selected) Set Display Start Line (10100001 with XXXXXXXX) Set Segment Re-map & Data Format (10100000 with XXXXXXXX) Set Master Current Control (10000111 with ****XXXX) Set Contrast Control for Colour “A” (10000001 with XXXXXXXX) Set Contrast Control for Colour “B” (10000010 with XXXXXXXX) Set Contrast Control for Colour “C” (10000011 with XXXXXXXX) Set Pre-charge Level (10111011 with **XXXXXX) Set Second Pre-charge speed of colour A (10001010 with XXXXXXXX Set Second Pre-charge speed of Colour B (10001011 with XXXXXXXX) Set Second Pre-charge speed of Colour C (10001100 with XXXXXXXX) Set VCOMH (10111110 with 00XXXXX0) Set Phase 1 & 2 Period Adjustment (10110001 with XXXXXXXX) Product No. DD-9664FC-2A REV. A REV. Page 17 / 29 DENSITRON TECHNOLOGIES plc. – PROPRIETARY DATA – ALL RIGHTS RESERVED Set Power Saving Mode (10110000 with 000XXXXX) Set Display On/Off (1010111X) 10101111=> 0xAF (Display On) Set Colum Address (00010101 with XXXXXXXX for Start & XXXXXXXX for End ) Set Row Address (01110101 with XXXXXXXX for Start & XXXXXXXX for End) If the noise is accidentally occurred at the displaying window during the operation, please reset the display in order to recover the display function. Product No. DD-9664FC-2A REV. A REV. Page 18 / 29 DENSITRON TECHNOLOGIES plc. – PROPRIETARY DATA – ALL RIGHTS RESERVED 6 SOFTWARE INITIAL SETTING Product No. DD-9664FC-2A REV. A REV. Page 19 / 29 DENSITRON TECHNOLOGIES plc. – PROPRIETARY DATA – ALL RIGHTS RESERVED 7 PACKAGING AND LABELLING SPECIFICATION 7.1 PACKAGING 7.1.1 Material Item 1 2 3 4 5 6 Module Tray Inner box Carton Inner box bag Total weight Dimensions (mm) Part code DD-9664FC-2A 25.7*22.1*1.5 *** *** *** *** ***** ***** ***** ***** 7.54 Kg Unit weight (kg) 0.002 0.010 0.250 1.100 *** ± 5% Quantity 2520 4 1 *** 7.1.2 Specification and quantity Modules x tray Modules per box Total no. of modules Product No. Quantity per row Quantity per tray Quantity per box DD-9664FC-2A 6 42 630 x Quantity per column x Quantity of trays x Quantity of boxes REV. A REV. 7 15 4 = 42 = 630 = 2520 Page 20 / 29 DENSITRON TECHNOLOGIES plc. – PROPRIETARY DATA – ALL RIGHTS RESERVED 7.2 LABELLING & MARKING DENSITRON DD-9664FC-2A TW YY MM Product No. DD-9664FC-2A REV. A REV. Page 21 / 29 DENSITRON TECHNOLOGIES plc. – PROPRIETARY DATA – ALL RIGHTS RESERVED 8 QUALITY ASSURANCE SPECIFICATION 8.1 CONFORMITY The performance, function and reliability of the shipped products conform to the Product Specification. 8.2 DELIVERY ASSURANCE 8.2.1 Delivery inspection standards • IPC-AA610 rev. C, class 2 electronic assemblies standard 8.2.2 Zone definition A Viewing area B Outside viewing area Product No. DD-9664FC-2A REV. A REV. Page 22 / 29 DENSITRON TECHNOLOGIES plc. – PROPRIETARY DATA – ALL RIGHTS RESERVED 8.2.3 Visual inspection • • • • Inspect under 30W fluorescent lamp leaving 50 cm between the module and the lamp and 30 cm between the module and the eye (measuring position). Appearance is inspected at the best contrast voltage (best contrast is adjusted considering clearness and crosstalk on screen). Inspect the module at 45° right and left, top and bottom. Use the optimum viewing angle during the contrast inspection. eye 45° Product No. DD-9664FC-2A 45° REV. A REV. Page 23 / 29 DENSITRON TECHNOLOGIES plc. – PROPRIETARY DATA – ALL RIGHTS RESERVED 8.2.4 Standard of appearance inspection Units: mm Class Item Criteria Minor Critical Packing & Label Major Dimension Outside & inside package Presence of product no., lot no., quantity Product must not be mixed with others and quantity must not be different from that indicated on the label Product dimensions must be according to specification and drawing Major Electrical Product electrical characteristics must be according to specification Critical OLED Display Black spot, white spot, dust Minor Missing lines or wrong patterns on display are not allowed Round type: as per following drawing ∅ = (X+Y)/2 Y X Acceptable quantity Size Zone A Zone B Any number ∅
DD-9664FC-2A 价格&库存
很抱歉,暂时无法提供与“DD-9664FC-2A”相匹配的价格&库存,您可以联系我们找货
