DMT024QVNUCMI-2A
DMT024QVNUCMI-2A
    DENSITRON
    DENSITRON - DMT024QVNUCMI-2A - TFT LCD, 2.4 ", 240 x 320 Pixels, Portrait, RGB, 3.3V
DMT024QVNUCMI-2A 数据手册
TFT LCD DISPLAY MODULE Product Specification Customer Standard Product Number DMT024QVNUCMI-2A Customer Part Number Customer Approval Date: Internal Approvals Product Mgr Doc. Control Electr. Eng. Luo Luo Filip Kaczorowski Filip Kaczorowski Date: 17/12/2018 Date: 17/12/18 Date: 17/12/18 FORM DT-030 Iss 3 Product Specification | Product No: DMT024QVNUCMI-2A REV. A ©2018 Densitron Technologies Limited. All rights reserved. Proprietary data 1 of 32 Revision Record Rev. Date Page Chapt. Comment A 17/12/18 -- -- Initial Release FORM DT-030 Iss 3 Product Specification | Product No: DMT024QVNUCMI-2A REV. A ©2018 Densitron Technologies Limited. All rights reserved. Proprietary data ECR no. 2 of 32 Table of Contents 1.0 GENERAL DESCRIPTION 5 1.1 Introduction 5 1.2 Main Features 5 2.0 MECHANICAL SPECIFICATION 6 2.1 Mechanical Characteristics 6 2.2 Mechanical Drawing 7 3.0 ELECTRICAL SPECIFICATION 8 3.1 Absolute Maximum Ratings 3.1.1 TFT 3.1.2 PCT 8 8 8 3.2 Electrical Characteristics 3.2.1 TFT 3.2.2 PCT 9 9 9 3.4 Interface Pin Assignment 3.4.1 TFT Pin Assignment 3.4.2 PCT Pins Assignment 10 10 11 3.5 Block Diagram 12 3.6 Timing Characteristics 3.6.1 TFT 3.6.2 PCT 13 13 16 4.0 OPTICAL SPECIFICATION 18 4.1 Optical Characteristics 18 5.0 LED BACKLIGHT SPECIFICATION 20 5.1 LED Backlight Characteristics 20 5.2 Internal Circuit Diagram 21 6.0 QUALITY ASSURANCE SPECIFICATION 22 FORM DT-030 Iss 3 Product Specification | Product No: DMT024QVNUCMI-2A REV. A ©2018 Densitron Technologies Limited. All rights reserved. Proprietary data 3 of 32 6.1 Delivery Inspection Standards 6.1.1 Inspection Conditions 6.1.2 Environmental Conditions 6.1.3 Sampling Conditions 6.1.4 Zone Definition 6.1.5 Basic Principle 6.1.6 Inspection Criteria 22 22 22 22 23 23 24 6.2 Dealing with Customer Complaints 6.2.1 Non-conforming Analysis 6.2.2 Handling of Non-conforming Displays 28 28 28 7.0 RELIABILITY SPECIFICATION 29 7.1 Reliability Tests 29 8.0 HANDLING PRECAUTIONS 30 8.1 Handling Precautions 30 8.2 Storage Precautions 31 8.3 Designing Precautions 31 8.4 Operation Precautions 32 8.5 Other Precautions 32 FORM DT-030 Iss 3 Product Specification | Product No: DMT024QVNUCMI-2A REV. A ©2018 Densitron Technologies Limited. All rights reserved. Proprietary data 4 of 32 1.0 General Description 1.1 Introduction This is a colour active matrix TFT (Thin Film Transistor) LCD (liquid crystal display) that uses amorphous silicon TFT as a switching device. This model is composed of a Transmissive type TFTLCD Panel, driver circuit, back-light unit. The resolution of a 2.4’TFT-LCD contains 240X320 pixels and can display up to 65K/262K colours. 1.2 Main Features Item Contents Screen Size 2.4” Diagonal Display Format 240 x RGB x 320 Dots N° of Colour 65K/262K colours Overall Dimensions 42.72 mm(H) x 60.40 mm(V) x 3.57 mm (D) Active Area 36.72 mm (H) x 48.96 mm (V) Display Mode Transmissive / Normally Black Viewing Direction All TFT Interface 8/9/16/18 Bit MCU PCT Interface I2C TFT Driver IC ST7789V PCT Controller IC FT6336U Backlight Type LED, White, 4 chips Operating Temperature -20C ~ +70°C Storage Temperature -30°C ~ +80°C Module Bonding Technology Optical Bonding ROHS Compliant to 2011/65/EU FORM DT-030 Iss 3 Product Specification | Product No: DMT024QVNUCMI-2A REV. A ©2018 Densitron Technologies Limited. All rights reserved. Proprietary data 5 of 32 2.0 Mechanical Specification 2.1 Mechanical Characteristics Item Characteristic Unit Display Format 240 x RGB x 320 Dots Dots Overall Dimensions 42.72 mm(H) x 60.40 mm(V) x 3.57 mm(D) mm Active Area 36.72 mm (H) x 48.96 mm (V) mm Pixel Pitch 0.153 (H) x 0.153 (V) mm Weight TBD g FORM DT-030 Iss 3 Product Specification | Product No: DMT024QVNUCMI-2A REV. A ©2018 Densitron Technologies Limited. All rights reserved. Proprietary data 6 of 32 2.2 Mechanical Drawing FORM DT-030 Iss 3 Product Specification | Product No: DMT024QVNUCMI-2A REV. A ©2018 Densitron Technologies Limited. All rights reserved. Proprietary data 7 of 32 3.0 Electrical Specification 3.1 Absolute Maximum Ratings 3.1.1 TFT Item Symbol Min. Max. Unit Note Power Supply Voltage VDD -0.3 4.6 V - Digital Interface Supply Voltage IOVCC -0.3 4.6 V - Operating Temperature TOP -20 +70 °C - Storage Temperature TST -30 +80 °C - (Ta=25 VSS=0V) Note: If the absolute maximum rating of even is one of the above parameters is exceeded even momentarily, the quality of the product may be degraded. Absolute maximum ratings, therefore, specify the values exceeding which the product may be physically damaged. Be sure to use the product within the range of the absolute maximum ratings. 3.1.2 PCT Item Symbol Min. Max. Unit Note Power Supply Voltage VDD -0.3 3.6 V 1 Operating Temperature TOP -20 +70 °C - Storage Temperature TST -30 +80 °C - Note 1: If used beyond the absolute maximum ratings, FT6336U may be permanently damaged. It is strongly recommended that the device be used within the electrical characteristics in normal operations. If exposed to the condition not within the electrical characteristics, it may affect the reliability of the device. FORM DT-030 Iss 3 Product Specification | Product No: DMT024QVNUCMI-2A REV. A ©2018 Densitron Technologies Limited. All rights reserved. Proprietary data 8 of 32 3.2 Electrical Characteristics 3.2.1 TFT Item Symbol Min. Typ. Max. Unit VCI 2.4 3.3 3.6 V IOVCC 1.65 1.8 3.3 V Normal Mode Current Consumption IDD - 5 - mA High Level Input VIH 0.7xIOVCC - IOVCC V Low Level Input VIL GND - 0.3xIOVCC V High Level Output VOH 0.8IOVCC - IOVCC V Low Level Output VOL GND - 0.2xIOVCC V Symbol Min. Typ. Max. Unit VDD 2.8 3.3 3.6 V Iopr - 4 - mA Imon - 1.5 - mA Sleep mode Current consumption Islp - 50 - µA High Level Input VIH 0.75xVDDIO - VDDIO V Low Level Input VIL -0.3 - 0.3xVDDIO V High Level Output VOH 0.7xVDDIO - - V Low Level Output VOL - - 0.3xVDD V Digital Supply Voltage Digital Interface Supply Voltage 3.2.2 PCT Item Supply Voltage Normal operation mode Current consumption Monitor mode Current consumption FORM DT-030 Iss 3 Product Specification | Product No: DMT024QVNUCMI-2A REV. A ©2018 Densitron Technologies Limited. All rights reserved. Proprietary data 9 of 32 3.4 Interface Pin Assignment 3.4.1 TFT Pin Assignment No. Symbol 1 GND 2 IM0 3 IM1 4 FMARK 5 GND 6-15 DB17-DB8 16 IOVCC 17-24 DB7-DB0 25 CS 26 RS 27 WR 28 RD 29 RESET 30 VCI 31 GND 32 LED+ 33 GND Function Ground of Logic Circuit. This is a ground pin, to be connected to external ground. MPU Parallel interface bus select. Fix this pin at IOVCC and GND. IM0 IM1 Mode Pins Used 1 0 8-bit DB10-DB17 1 1 9-bit DB9-DB17 DB1-DB8, 0 0 16-bit DB10-DB17 0 1 18-bit DB0-DB17 Tearing effect output pin to synchronise MPU to frame writing, activated by S/W command. When this pin is not activated this pin is low. If not used, leave open. Ground of Logic Circuit. This is a ground pin, to be connected to external ground. Data bus. If not used fix this pin at IOVCC and GND. Supply voltage for IO. (1.65V-3.3V). Data bus. If not used fix this pin at IOVCC and GND. Chip select input pin (“Low” enable). This pin is used to select “Data or Command” in the parallel interface. Fix this pin at IOVCC or GND when not in use. Serves as a write signal and writes data at the rising edge. Fix this pin at IOVCC or GND when not in use. Serves as a read signal and MCU read data at the rising edge. Fix this pin at IOVCC or GND when not in use. This signal will reset the device and must be applied to properly initialize the chip. Supply voltage (3.3V) Ground of Logic Circuit. This is a ground pin, to be connected to external ground. Anode pin of backlight. Ground of Logic Circuit. This is a ground pin, to be connected to external ground. FORM DT-030 Iss 3 Product Specification | Product No: DMT024QVNUCMI-2A REV. A ©2018 Densitron Technologies Limited. All rights reserved. Proprietary data 10 of 32 No. Symbol Function 34 LED- Cathode pin of backlight. 35 GND Ground of Logic Circuit. This is a ground pin, to be connected to external ground. 3.4.2 PCT Pins Assignment No. Symbol Function 1 VDD Supply voltage. 2 SCL I2C clock input. 3 SDA I2C data input and output. 4 INT External interrupt to the host. 5 RST External Reset, Low is active. 6 GND Ground. FORM DT-030 Iss 3 Product Specification | Product No: DMT024QVNUCMI-2A REV. A ©2018 Densitron Technologies Limited. All rights reserved. Proprietary data 11 of 32 3.5 Block Diagram FORM DT-030 Iss 3 Product Specification | Product No: DMT024QVNUCMI-2A REV. A ©2018 Densitron Technologies Limited. All rights reserved. Proprietary data 12 of 32 3.6 Timing Characteristics 3.6.1 TFT 3.6.1.1 8080 Series MCU Parallel Interface Characteristics: 8/9/16/18-bit Bus VDDI=1.65 to 3.3V, VDD=2.4 to 3.3V, AGND=DGND=0V, Ta=-30 to 70°C Signal Symbol Parameter Min. Max. Unit TAST D/CX TAHT TCHW TCS TRCS CSX TRCSFM TCSF WRX TCSH TWC Address setup time Address hold time (Write/Read) Chip select “H” pulse width Chip select setup time (Write) Chip select setup time (Read ID) Chip select setup time (Read FM) Chip select wait time (Write/Read) Chip select hold time Write cycle Description 0 - ns - 10 - ns - 0 - ns - 15 - ns - 45 - ns - 355 - ns - 10 - ns - 10 66 - ns ns - FORM DT-030 Iss 3 Product Specification | Product No: DMT024QVNUCMI-2A REV. A ©2018 Densitron Technologies Limited. All rights reserved. Proprietary data 13 of 32 TWRH TWRL TRC RDX (ID) TRDH TRDL RDX (FM) D[17:0] TRCFM TRDHFM TRDLFM TDST TDHT TRAT TRATFM TODH Control pulse “H” duration Control pulse “L” duration Read cycle (ID) Control pulse “H” duration (ID) Control pulse “L” duration (ID) Read cycle (FM) Control pulse “H” duration Control pulse “L” duration Data setup time Data hold time Read access time (ID) Read access time (FM) Output disable time • Rising and Falling Timing for I/O Signal • Write-to-Read and Read-to-Write Timing 15 15 160 - ns ns ns - 90 - ns When read ID data 45 - ns 450 90 355 10 10 20 40 340 80 ns ns ns ns ns ns ns ns When read from frame memory For CL=30pF Note: The rising time and falling time (Tr, Tf) of input signal and fall time are specified at 15 ns or less. Logic high and low levels are specified as 30% and 70% of VDDI for input signals. FORM DT-030 Iss 3 Product Specification | Product No: DMT024QVNUCMI-2A REV. A ©2018 Densitron Technologies Limited. All rights reserved. Proprietary data 14 of 32 3.6.1.2 Reset Timing Related Pins RESX Symbol Parameter Min. Max. Unit TRW Reset pulse duration TRT Reset cancel 10 - 5(Note 1,5) 120(Note 1,6,7) µs ms ms Note: 1. The reset cancel includes also required time for loading ID bytes, VCOM setting and other settings from NVM (or similar device) to registers. This loading is done every time when there is HW reset cancel time (tRT) within 5 ms after a rising edge of RESX. 2. Spike due to an electrostatic discharge on RESX line does not cause irregular system reset according to the table below: RESX Pulse Action Shorter than 5µs Longer than 9µs Between 5µs and 9 µs Reset Rejected Reset Reset starts 3. Suring the Resetting period, the display will be blanked (The display is entering blanking sequence, which maximum time is 120 ms, when Reset Starts is Sleep Out-mode. The display remains the blank state in Sleep In-mode.) and then return to Default condition for Hardware Reset. 4. Spike Rejection also applies during a valid reset pulse as shown below: 5. When Reset is applied during Sleep In Mode. 6. When Reset applied during Sleep Out Model. 7. It’s necessary to wait 5msec after releasing RESX before sending commands. Also Sleep Out command cannot be sent for 120 ms. FORM DT-030 Iss 3 Product Specification | Product No: DMT024QVNUCMI-2A REV. A ©2018 Densitron Technologies Limited. All rights reserved. Proprietary data 15 of 32 3.6.2 PCT 3.6.2.1 AC Characteristics AC Characteristics of Oscillators AC Characteristics of sensor 3.6.2.2 I2C Interface The I2C is always configured in the Slave mode. The data transfer format is shown in figure 4-1. Table 4-3 lists the meanings of the mnemonics used in above figures. FORM DT-030 Iss 3 Product Specification | Product No: DMT024QVNUCMI-2A REV. A ©2018 Densitron Technologies Limited. All rights reserved. Proprietary data 16 of 32 I2C Interface Timing Characteristics are shown in table 4-4. FORM DT-030 Iss 3 Product Specification | Product No: DMT024QVNUCMI-2A REV. A ©2018 Densitron Technologies Limited. All rights reserved. Proprietary data 17 of 32 4.0 Optical Specification 4.1 Optical Characteristics Measuring instruments: Driving condition: Backlight: Measured temperature: Characteristics Response time LCD-5100, Eldim, Topcon BM-7 VDD = 3.3V, VSS = 0V IF = 75mA Ta = 25°C Symbol Conditions Min Typ Max Unit Note TR+TF θ=Ф=0° Normal Viewing Angle - 35 45 ms 2 640 800 - - 3 % CR Uniformity S(%) - 70 - Left θL - 80 - Right θR - 80 - Up θU - 80 - Down θD - 80 - Rx 0.5931 0.6331 0.6731 Ry 0.2936 0.3336 0.3736 Gx 0.2822 0.3222 0.3622 0.5718 0.6118 0.6518 0.1084 0.1484 0.1884 By 0.0034 0.0434 0.0834 Wx 0.3585 0.2985 0.3385 Wy 0.2786 0.3186 0.3586 Viewing Angle Contrast Ratio Colour Chromaticity Red Green Gy Bx Blue White Option View Direction CR≥10 CR≥10 deg 4 - 5 All FORM DT-030 Iss 3 Product Specification | Product No: DMT024QVNUCMI-2A REV. A ©2018 Densitron Technologies Limited. All rights reserved. Proprietary data 18 of 32 Note Item Test method The display should be stabilised at a given temperature for 30 minutes to avoid abrupt temperature change during measuring. To stabilise the luminance, measurements should be executed after lighting the backlight for 30 minutes in a windless room. 1 Setup Measure output signal waveform by the luminance meter when raster of window pattern is changed from white to black and from black to white. 2 Response time Measure maximum brightness and minimum brightness at the centre of the screen by displaying raster or window pattern. Then calculate the ratio between these two values. 3 Contrast ratio Brightness of unselected position (white) Contrast Ratio (CR) = Brightness of selected position (black) Move the luminance meter from right to left and up and down and determinate the angles where contrast ratio is 10 4 Viewing angle Horizontal θ Vertical Ø 5 Colour chromaticity 6 Brightness distribution Measure chromaticity coordinates x and y of CIE1931 colorimetric system (Brightness distribution) = 100 x B/A % A: max. brightness of the 9 points B: min. brightness of the 9 points FORM DT-030 Iss 3 Product Specification | Product No: DMT024QVNUCMI-2A REV. A ©2018 Densitron Technologies Limited. All rights reserved. Proprietary data 19 of 32 5.0 LED Backlight Specification 5.1 LED Backlight Characteristics The back-light system is edge-lighting type with 4 chips LED Characteristics Symbol Min Typ. Max Unit Note Forward Current IF 15 20 - mA - Forward Voltage VF - 12.8 - V - LCM Luminance LV 330 380 - Cd/m2 3 LED life time Hr 50000 - - Hour 1,2 Uniformity Avg 80 - - % 3 Note 1: LED life time (Hr) can be defined as the time in which it continues to operate under the condition: Ta=25±3 ℃, typical IL value indicated in the above table until the brightness becomes less than 50%. Note 2: The “LED life time” is defined as the module brightness decrease to 50% original brightness at Ta=25℃ and IL=80mA. The LED lifetime could be decreased if operating IL is larger than 80mA. The constant current driving method is suggested. Note 3: Luminance Uniformity of these 9 points is defined as below: FORM DT-030 Iss 3 Product Specification | Product No: DMT024QVNUCMI-2A REV. A ©2018 Densitron Technologies Limited. All rights reserved. Proprietary data 20 of 32 5.2 Internal Circuit Diagram FORM DT-030 Iss 3 Product Specification | Product No: DMT024QVNUCMI-2A REV. A ©2018 Densitron Technologies Limited. All rights reserved. Proprietary data 21 of 32 6.0 Quality Assurance Specification 6.1 Delivery Inspection Standards 6.1.1 Inspection Conditions Inspection distance: Viewing angle: 30 cm - 50cm ±45° 6.1.2 Environmental Conditions Ambient temperature: Ambient humidity: Ambient illumination: 25°C ± 5°C 65±10% RH 300~700 lux 6.1.3 Sampling Conditions 1. 2. Lot size: quantity of shipment lot per model Sampling method: Sampling plan Major Defect Minor Defect AQL No. Items to be inspected 1 Functional defects 2 Missing 3 Outline dimension 4 Colour tone 5 Spot Line defect 6 7 Soldering appearance LCD/Polarizer/TP GB/T 2828-2003 Normal inspection, Class II 0.65% 1.5% Criteria 1) No display, Open or miss line 2) Display abnormally, Short 3) Backlight no lighting, abnormal lighting. 4) TP no function Missing component Overall outline dimension beyond the drawing is not allowed Colour unevenness, refer to limited sample Light dot, Dim spot, Polarizer bubble; Polarizer accidented spot. Good soldering, peeling off is not allowed. Black/White spot/line, scratch, crack, etc. FORM DT-030 Iss 3 Product Specification | Product No: DMT024QVNUCMI-2A REV. A ©2018 Densitron Technologies Limited. All rights reserved. Proprietary data Classification of defects Major Minor 22 of 32 6.1.4 Zone Definition Zone A: Effective Viewing Area (Character or Digit can be seen) Zone B: Viewing Area except Zone A Zone C: Outside (ZoneA+ZoneB) which can’t be seen after assembly by customer. Zone D: IC Bonding Area Note: Generally, visual defects in Zone C can be ignored when it doesn’t affect product function or appearance after assembly by customer. 6.1.5 Basic Principle A set of sample to indicate the limit of acceptable quality level shall be discussed should a dispute occur. FORM DT-030 Iss 3 Product Specification | Product No: DMT024QVNUCMI-2A REV. A ©2018 Densitron Technologies Limited. All rights reserved. Proprietary data 23 of 32 6.1.6 Inspection Criteria Number Items Criteria (mm) 1.0 LCD Crack/ Broken (1) The edge of LCD broken X Note: X: Length Y: Width Z: Height L: Length of ITO T: Height of LCD ≤3.0mm Y
DMT024QVNUCMI-2A 价格&库存
很抱歉,暂时无法提供与“DMT024QVNUCMI-2A”相匹配的价格&库存,您可以联系我们找货
