DFR0799
DFR0799
    DFROBOT
    DFROBOT - DFR0799 - Evaluation Board, 2-Channel, Audio Amplifier, Bluetooth 5.0, 15 m, 5 VDC to 24 V...
DFR0799 数据手册
INTRODUCTION This mini Bluetooth Amplifier can be connected to your mobile phone, Raspberry Pi, and other main-boards with Bluetooth to DIY your unique speaker! With standard audio quality, the cost-effective amplifier offers 50W output power, volume adjustable knob, Bluetooth 5.0 input, and dual-channel output. It can be powered at DC 5~24V, and compatible with 4-8Ω, 30W-200W passive speakers. The Bluetooth Amplifier comes with bottom/top protective covers and supports overheat and short-circuit protection. Operation Instruction Connect the board with a speaker, power it on. Rotate the volume knob then the indicator LED lights up. Turn on the Bluetooth of your phone or Raspberry Pi, the “BT-WUZHI” will be searched, and then click to connect it. It connects successfully with a ding-dong tone, and now it can play music. The Bluetooth will be connected automatically when the module is powered on next time. Note The board will output adequate power only when the audio input and power source voltage/current are sufficient. The higher the power supply voltage, the larger the output power. Besides that, speaker impedance also changes the amplifier board power output. Please note that in the case of enough voltage and current, the larger the speaker impedance in ohms, the smaller the output power. SPECIFICATION Power Supply: 5-24V Input: Bluetooth 5.0 Audio Quality: standard Output Power: 50W*2 Compatible Speakers: 30W-200W, 4Ω-8Ω Channel: left/right (stereo) Bluetooth Transmission Distance: 15m(Without any obstacle) Protection: overheat, short-circuit Power Voltage: 12V--8Ω Speaker/12W(left)+12W(right), 4Ω Speaker/20W+20W 15V----8Ω/18W+18W,4Ω/>30W+30W 19V----8Ω/32W+32W,4Ω/>45W+45W 24V----8Ω/38W+38W,4Ω/>50W+50W SHIPPING LIST · · · · · · · Mini Digital Bluetooth Amplifier-50W*2 x1 Acrylic Protective Case x2 Screwdriver x1 20cm Power Wire x1 Knob x1 Accessories Package x1 Heat Sink x1
DFR0799 价格&库存
很抱歉,暂时无法提供与“DFR0799”相匹配的价格&库存,您可以联系我们找货
