FIT0729
FIT0729
    DFROBOT
    IMX179 照相机 传感器 平台评估扩展板
FIT0729 数据手册
INTRODUCTION This is an 8000K pixels driver-free camera of USB port with up to 3264*2448 resolution. Based on the Sony IMX179 CMOS sensor, it supports autofocus, plug, and play, offering HD photos and video. Compatible with multiple systems like Windows, iOS, Android, and Linux, this camera module comes with a digital microphone that captures the sound of 5 meters around the camera when recording video. The design of the USB port also makes it easier to use with your Raspberry Pi and Jetson Nano mainboard when they are placed in a protective case. SPECIFICATION Photosensitive Element: CMOS Sensor: Sony IMX179 Lens Size:1/3.2inch Pixel Dimension: 1.4μm Image Area: 6.18mm*5.85mm Max Effective Resolution: 3264(H) X 2448(V) 8 Megapixel Image Output Format: JPEG Supported Resolution and Frame Rate: 3264X2448 @ 15fps / 2592X1944@ 15fps 1920x1080 @ 30fps / 1600X1200@ 30fps 1280X720 @ 30fps / 960X540@ 30fps 800X600 @ 30fps / 640X480@ 30fps S/N Ratio: 34dB Dynamic Range: 72.5dB Sensitivity: 0.65V/lux-sec@550nm Mini illumination: 0.5lux Shutter Type: Electronic rolling shutter / Frame exposure Interface Type: USB2.0 High Speed Driver-free Protocol: USB Video Class(UVC) OTG Protocol: USB2.0 OTG AEC/AEB/AGC Support Support photo taking by pressing button Adjustable Parameter: Brightness, Contrast, Saturation, Hue, Sharpness, Gamma, Gain, White balance, Backlight Contrast, Exposure Camera Parameter: high-speed photographic apparatus camera, distortionless, size of 1/3.2, Auto-focus, 75 degree Fill Light Power Supply Port: 4P-2.0 socket Power Supply: USB BUS POWER 4P-2.0mm Socket Operating Voltage: DC 5V Operating Current: 160mA~260mA Operating Temperature: -10~70℃ Storage Temperature: -20~85℃ Dimension: 38*38mm/1.50*1.50” OS Supported: WinXP/Vista/Win7/Win8 Linux with UVC(above linux-2.6.26) MAC-OS X 10.4.8 or later Wince with UVC Android 4.0 or above with UVC SHIPPING LIST · 8000K Pixel USB Camera(With Microphone) x1
FIT0729 价格&库存
很抱歉,暂时无法提供与“FIT0729”相匹配的价格&库存,您可以联系我们找货
FIT0729
    • 1+306.58337
    库存:73
