DFR0830
DFR0830
    DFROBOT
    倾斜开关 传感器 Arduino,Gravity 平台评估扩展板
DFR0830 数据手册
SKU:DFR0830 (https://www.dfrobot.com.cn/goods-3278.html) (https://www.dfrobot.com.cn/goods3278.html) Introduction This sensor contains a metal ball that moves along its special internal structure on the effect of gravitation force so as to make a connection or disconnection. Therefore, it can be used as a simple tilt switch. With digital input, this sensor can be used with Arduino expansion board to realize various fun interactive works, meanwhile, safer than mercury tilt switch. Compared with the traditional steel ball tilt switch that can only achieve single-direction tilt detection, this product adopts a cylindrical design to allow inclination detection in 360° directions directions. Note: As this product is a switch sensor and cannot measure the tilt angle, it can only guarantee to output switch when tilted from the horizontal plane to the specified angle. If you need to accurately measure the tilt angle, it is recommended to use the triple-axis acceleration sensor. Specification Working Voltage: 3.3/5V DC Interface Type: Digital Pin Defination: D: Digital output ; + : Power - : Ground Steel Ball Switch Closed Tilt Switch Angle: 45° Schematic diagram of internal structure: Schematic diagram of switch angle: Connection Diagram Sample Code int ledPin = 13; int switcher = 3; void setup() { pinMode(ledPin, OUTPUT); pinMode(switcher, INPUT); } // Connect LED to pin 13 // Connect Tilt sensor to Pin3 // Set digital pin 13 to output mode // Set digital pin 3 to input mode void loop() { if (digitalRead(switcher) == HIGH) //Read sensor value digitalWrite(ledPin, HIGH); // Turn on LED when the sensor is tilted else digitalWrite(ledPin, LOW); // Turn off LED when the sensor is not triggered } Mind+(Based on Scratch 3.0) Graphical Programming 1. Download and install software. Download address: http://mindplus.cc/en.html (http://mindplus.cc/en.html) Detailed tutotial: 2. Switch to "Upload" mode. Detailed tutorial: 3. In "Extensions", select "Arduino Uno" in "Board". Detailed tutorial: 4. Program as the picture below. 5. In menu "Connect Device", select "upload to device" FAQ For any questions, advice or cool ideas to share, please visit the DFRobot Forum (https://www.dfrobot.com/forum/). More Documents Get Gravity 360 degrees Tilt Sensor (https://www.dfrobot.com/product-203.html) from DFRobot Store or DFRobot Distributor. (https://www.dfrobot.com/index.php? route=information/distributorslogo) g Turn to the Top
DFR0830 价格&库存
很抱歉,暂时无法提供与“DFR0830”相匹配的价格&库存,您可以联系我们找货
DFR0830
    • 1+24.159501+3.14140
