(https://www.dfrobot.com/product1534.html)
Introduction
This is an ultra small Dual DC motor
driver
(https://www.dfrobot.com/product1512.html) for some room limited
projects. UVLO (Under Voltage LatchOut) features a safe guard for your
system. It is very considerate to own an Photo Coupler isolation for all the signals in case of that
the motor's Reverse Current would interfere the control signals. Besides all, all the interfaces
i
l d
ESD ( l t
t ti di h
t ti
includes ESD (electro-static discharge) protection.
Specification
Voltage supply: DC 7 ~ 24 V
Voltage supply limit: 6.5 ~ 27 V
Control signal Level (Compatible 3.3V/5V)
High: DC 3.0 ~ 6.5 V
Low: DC0 ~ 0.8 V
Output Channel: 2
Control signal current: 3 ~ 11 mA (Each route)
Maximum continuous operating current: 7 A
Peak current: 50 A
Speed control: PWM
Minimum valid Pulse Width: 5 us
Working Temperature: -25 ~ 85 °C
Mounting Hole: M3
Dimension (Length * Width * Height): 55 x 55(mm)/2.165 x 2.165(in)
Weight: 32g
Board Overview
Num
Label
Description
1
9 - 24V
Power Supply, +
2
PGND
Power Supply, GND
3
OUT1
Motor1_+
4
OUT2
Motor1_-
5
OUT3
Motor2_+
6
OUT4
Motor2_-
7
ENA
Motor1 PWM
8
IN1
Motor1 control signal
8
IN1
Num
9
Label
IN2
Description
10
ENB
Motor2 PWM
11
IN3
Motor2 control signal
12
IN4
13
+5V
Voltage Reference Input, +5V OR 3.3V
Control Method
IN1
IN2
ENA/ ENB
Motor1/2 Behavior
x
Stop (brake)
1
1
x
Vacant
1
Forward 100%
1
Reverse 100%
IN1
1
IN2
ENA/ ENB
PWM
Motor1/2 Behavior
Forward at PWM speed
PWM
Reverse at PWM speed
In this table
IN1 & IN2: the control signal input to change the motor behavior
"0": TTL_Low
"1": TTL_High
"x": Any TTL, and it is default TTL_Low while no PWM signal.
"ENA/ ENB": PWM speed setting
Note:
IN1 & IN2
To protect your motor, before switching the motor steering direction, make sure firstly to BRAKE
motor by setting IN1 - 0 & IN2 - 0, especially when the PWM was set as 100%, full speed. And the
suggestion time to brake is >0.1S, depending on your motor.
+5V
When the microcontroller operation voltage is 5V/3.3V, then please connect the reference
voltage 5V/ 3.3V from the microcontroller. Or you will fail to control motors.
Tutorial
This tutorial will cover how to use PWM to control a motor using the shield. Do the wiring
according to the Connection Diagram below, and then upload the sample code below to the
Arduino card, here we use a arduino UNO (https://www.dfrobot.com/product-610.html) as the
controller, you could see your motor run forward for 3 second and then run reversely for another
3 seconds and repeat this behavior then.
Requirements
Hardware
1 x DFRduino UNO (or similar)
1 x This 7A Dual DC Motor Driver
2 x DC Motor
1 x Fuse@20A
Jumper wires
Software
Arduino IDE (https://www.arduino.cc/en/Main/Software) Click to Download Arduino IDE
from Arduino®.
Connection Diagram
Facility Safety and the Personal Safety:
Please add a fuse@20A between the Power source and
this shield.
Installation Tips
The backside of the driver, as right-hand picture shows, that its conducting layer can be very
wide, so you should take some measurements to ensure it won't short-circuit, like applying 1mm
layer conductive epoxy or any other similar materials.
Pluggable Connector
You may find that the connector is designed as pluggable type to adapt with Male or Female
wires.
Sample Code
* @file Motor driver DRI0042_Test.ino
* @brief DRI0042_Test.ino Motor control program
* control motor positive inversion
* @author bernie.chen@dfrobot.com
* @version V1.0
* @date 2016-8-10
const int IN1=5;
const int IN2=4;
const int ENA=6;
const int IN3=8;
const int IN4=7;
const int ENB=9;
void setup() {
void setup() {
pinMode(IN1, OUTPUT);
pinMode(IN2, OUTPUT);
pinMode(ENA, OUTPUT);
pinMode(IN4, OUTPUT);
pinMode(IN3, OUTPUT);
pinMode(ENB, OUTPUT);
void loop() {
Motor1_Brake();
Motor2_Brake();
delay(100);
Motor1_Forward(200);
Motor2_Forward(200);
delay(1000);
Motor1_Brake();
Motor2_Brake();
delay(100);
Motor1_Backward(200);
Motor2_Backward(200);
delay(1000);
void Motor1_Forward(int Speed)
digitalWrite(IN1,HIGH);
digitalWrite(IN2,LOW);
analogWrite(ENA,Speed);
void Motor1_Backward(int Speed)
digitalWrite(IN1,LOW);
digitalWrite(IN2,HIGH);
void Motor1_Brake()
void Motor2_Forward(int Speed)
digitalWrite(IN3,HIGH);
digitalWrite(IN4,LOW);
analogWrite(ENB,Speed);
void Motor2_Backward(int Speed)
digitalWrite(IN3,LOW);
digitalWrite(IN4,HIGH);
void Motor2_Brake()
FAQ
Q. General Arduino Problems/FAQ/Tips
A. Click the topic link (https://www.dfrobot.com/forum/viewtopic.php?
f=8&t=1869&p=8624#p8624) on DFRobot Forum.
For any questions, advice or cool ideas to share, please visit the DFRobot Forum
(https://www.dfrobot.com/forum/).
More Documents
DFshopping_car1.png Shopping from 15A Single DC Motor Driver
(https://www.dfrobot.com/product-1512.html) or DFRobot Distributor.
(https://www.dfrobot.com/index.php?route=information/distributorslogo)
Category: DFRobot (https://www.dfrobot.com/) > Sensors & Modules
(https://www.dfrobot.com/category-156.html) > Motors & Actuators & Drivers
(https://www.dfrobot.com/category-51.html) > DC Motor Drivers
(https://www.dfrobot.com/category-105.html)
Turn to the Top
很抱歉,暂时无法提供与“DRI0041”相匹配的价格&库存,您可以联系我们找货
