INTRODUCTION
This immersible pump can be used to water your plants, make a fountain or waterfall,
even change your fish tank water. It works quietly with the sound level under 40db.
The pump has a filter inside as well as a suction cup which can help stick it to smooth
surfaces tightly.
Note: This pump is intended for use UNDER the water ONLY! (Brown/Red-Positive;
Blue/Black-Negative)
APPLICATIONS
It’s widely used for solar products, fountain, rockery, air-Conditioner, refrigerator
and refrigeration industrial equipment etc.
SPECIFICATION
Power supply: 4.5~12V DC
Interface: Brown +; Blue -
Pumping head:40-220cm
Capacity: 100~350L/H
Power range: 0.5~5W
Dimensions: 38x38x29mm(1.49x1.49x1.14")
Weight: 125g
Cable length: 1m (39.37")
DOCUMENTS
Dimension
SHIPPING LIST
Immersible pump x1
Water tube x1
PROJECTS
Project 1. How to Make An Automatic Water Changing System
Main Components:
DFRduino UNO R3 *1
Gravity: IO Expansion Shield for Arduino V7.1 *1
Gravity: Analog Turbidity Sensor For Arduino *1
Immersible Pump & WaterTube *1
Gravity: Analog pH Sensor / Meter Kit For Arduino *1
Wall Adapter Power Supply 12VDC *1 Solenoid Valve *1
Gravity: Digital 5A Relay Module *1
Water Pipe *2m
Interface (for solenoid valve) *2
I2C 16x2 Arduino LCD Display Module
很抱歉,暂时无法提供与“FIT0200”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+86.491801+11.24366
