DFR0762
DFR0762
    DFROBOT
    Gravity 转 FireBeetle 2 互连适配器 FireBeetle 2 平台评估扩展板
DFR0762 数据手册
SKU:DFR0762 (https://www.dfrobot.com/product-2072.html) [ ](Product Link) Introduction Specially designed for FireBeetle 2 series, this Gravity IO expansion shield offers various ports including digital, analog, I2C, UART, SPI, etc. Also, it comes with power input socket for connecting external power supply as well as EN pin for cutting off the power supply to mainboard. The Gravity IO shield allows a convenient connection between DFRobot Gravity sensors and FireBeetle 2 series, no soldering required. Features Support FireBeetle 2.0 series mainboards, including M0 and ESP32-E. Support the pin sequence of Gravity series products. Support in-line SD card module. Support GDI display interface Support external power socket EN pin mainboard power switch Specification 12 groups of digital ports 5 groups of analog ports 3 groups of I2C ports in parallel 1 group of UART ports 1 group of SPI ports 1 group of sp ports GDI display interface External power supply cable socket EN jumper wire Dimension: 60 mm×25.4 mm/2.36×1.00" Fixed Hole Diameter: 2.0 mm/0.08" Function Description The following instructions are only for the Arduino environment. If use it in other operating environment, please adjust the usage according to the schematics. 3.1 Digital ports This IO expansion shield provides 12 groups of digital ports including 0~13 except 4 and 8, which can be used directly by IO number. Note: When ESP32 uses pins in the Arduino environment, you need to use Dx such as D0 instead of directly using IO number 0, or use IO number corresponding to the mainboard. 3.2 Analog ports This IO expansion shield provides 5 groups of analog ports including A0~A4, which can be used directly by IO number. 3.3 I2C ports This shield provides 3 groups of I2C ports in parallel. 3.4 UART ports This shield provides 1 group of UART ports. R corresponds to pin 0, T to pin 1. When using UART, please do not use pin 0 and pin 1. 3.5 SPI ports Thi hi ld id 1 f SPI t i t SD d d l i li d SS i This shield provides 1 group of SPI ports, supporing to use SD card module in-line, and SS is connected to pin 6. 3.6 SP pin The SP pin presents different functions on different mainboards, representing NC, RXD, TXD, A5 on M0, and I2C on ESP32-E. 3.7 GDI display interface This interface is a DFRobot dedicated GDI, with 18pin-FPC cable connection and single wire connection to the screen, providing you with the simplest way to use the screen. The following is a list of pins used by the GDI interface FPC PINS Standard IO Expansion Shield Line Sequence VCC display power 3.3 V BLK display backlight 12/D13 GND GND SCIK SPI clock 18/SCK MOSI SPI host output 23/MOSI MISO SPI host input 19/MISO DC data/command 25/D2 RES reset 26/D3 CS display chip select 14/D6 SDCS SD card chip select FPC PINS Standard 13/D7 IO Expansion Shield Line Sequence FCS font library chip select 0/D5 TCS touch chip select 4/D12 SCL I2C clock 22/SCL SDA I2C data 21/SDA INIT initialization 16/D11 BUSY-TE anti-tear pin 17/D10 X1 extensible pin 1 NC X2 extensible pin 2 NC When using the FPC to connect to the screen, configure the corresponding pin number according to the GDL demo, usually only three pins are required for configuring. Displays supporting GDI: 1.54 in 240x240 IPS TFT LCD Display with MicroSD Card (https://www.dfrobot.com/product2072.html) 2.0 in 320x240 IPS TFT LCD Display with MicroSD Card (https://www.dfrobot.com/product2071.html) 2.8 in 320x240 TFT LCD Resistive Touchscreen with MicroSD Card Slot (https://www.dfrobot.com/product-2106.html) 3.5 in 480x320 TFT LCD Capacitive Touchscreen with MicroSD Card Slot (https://www.dfrobot.com/product-2107.html) For specific usage, please refer to: GDL display wiki: https://wiki.dfrobot.com/2.0_Inches_320_240_IPS_TFT_LCD_Display_with_MicroSD_Card_Breakout_ SKU_DFR0664 (https://wiki.dfrobot.com/2.0_Inches_320_240_IPS_TFT_LCD_Display_with_MicroSD_Card_Breakout _SKU_DFR0664) NOTE: Please do not reuse related pins. The GDI on the expansion shield only supports ESP32-E. If you need to use GDI for M0, please use the GDI integrated on the development board. Power socket and EN switch VIN: Connect to the VCC pin on the mainboard. The terminal is convenient for connecting the spiral battery. Note: When VIN is connected to an external power supply, do not connect the main control to other power supply or USB. GND: Common ground EN: It can be designed as the maincontroller switch. When EN is grounded, the main controller will stop running. FAQ For any questions, advice or cool ideas to share, please visit the DFRobot Forum (https://www.dfrobot.com/forum/). More Documents DFshopping_car1.png Get FireBeetle Covers Gravity IO Expansion Shield (https://www.dfrobot.com/product-203.html) from DFRobot Store or DFRobot Distributor. (https://www.dfrobot.com/index.php?route=information/distributorslogo) Turn to the Top
DFR0762 价格&库存
很抱歉,暂时无法提供与“DFR0762”相匹配的价格&库存,您可以联系我们找货
