DFR0575
DFR0575
    DFROBOT
    ESP32 Combo Wireless Module Development Tool
DFR0575 数据手册
SKU:DFR0575 (https://www.dfrobot.com/product-1798.html) (https://www.dfrobot.com/product-1798.html) Introduction Beetle ESP32 is a simplified version of FireBeetle-ESP32. It is equipped with the powerful functions and extensive range of applications similar to FireBeetle-ESP32, which extremely suits for one-off DIY projects and wearable devices. The features of this product include: A small size of 35mm×34mm Enable users to directly download and debug programs through Micro USB, free from programmer. Large-scale I/O ports with gold plating, easy to screw wire on it or to sew the board on the clothes with wires, no need to solder. A group of gold plating power interfaces of honeycomb type, convenient to use. Integrate WIFI and Bluetooth Beetle Esp32 is compatible with Arduino , and the board type should be selected as “FireBeetle-ESP32”. Specification USB Supply Voltage: 5.0V VIN Supply Voltage: DC 3.5-6.5V Processor: Tensilica LX6 dual-core processor (One for high speed connection; one for independent programing ) Frequency: 240MHz SRAM: 520KB Flash: 16MB Wi-Fi Standard: FCC/CE/TELEC/KCC Wi-Fi Protocol: 802.11 b/g/n/d/e/i/k/r(802.11n, high speed can reach to 150 Mbps), converge A-MPDU and A-MSDU, supporting 0.4us protecting interval. Frequency Range: 2.4~2.5GHz Bluetooth Protocol: comply with BR/EDR/BLE standard of Bluetooth v4.2. On-chip Clock: 40MHz crystal and 32.768 KHz crystal Digital Interface: D2, D3, D4, D7 Analog Interface: A0, A1, A2, A3 I2C: 1 Serial Port: 1 Dimension: 35×34mm/1.38×1.34" Pinout Beetle ESP32 Pinout Table VIN Power Input GND Ground A0 Analog Input A1 Analog Input A2 Analog Input A3 Analog Input D2 Digital I/O Interface D3 Digital I/O Interface D4 Digital I/O Interface D7 Digital I/O Interface SCL I2C Clock Line SDA I2C Data Line RX Serial Incept TX Serial Transmission Tutorial Beetle ESP32 adopts CH340 serial chip that can be used without driver among most devices. If you find the driver is not installed automatically Beetle ESP32 adopts CH340 serial chip that can be used without driver among most devices. If you find the driver is not installed automatically after plugging into the device, you can install it manually: click to download the CH340 driver program (https://www.dfrobot.com.cn/images/upload/File/DFR0489/201709061014334z925t.zip). Set Arduino IDE Development Environment Plug FireBeetle to your computer, install the driver manually. Add FireBeetle Board URL to Arduino IDE Open Arduino IDE, File->Preferences, find Additional Boards Manager URLs, copy the below link, and paste in the blank. http://download.dfrobot.top/FireBeetle/package_esp32_index.json (http://download.dfrobot.top/FireBeetle/package_esp32_index.json) File->Preferences paste url here Click OK Open Tools->Board->Boards Manager, waiting automatic update. You'll find FireBeetle-ESP32 Now, the development environment has been installed, you can use it like a normal Arduino board. Sample Code - Blink The default LED for Beetle Board-ESP32 is D9, input following code: // the setup function runs once when you press reset or power the board void setup() { // initialize digital pin LED_BUILTIN as an output. pinMode(D9, OUTPUT); } // the loop function runs over and over again forever void loop() { digitalWrite(D9, HIGH); // turn the LED on (HIGH is the voltage level) delay(1000); // wait for a second digitalWrite(D9, LOW); // turn the LED off by making the voltage LOW delay(1000); // wait for a second FAQ Q&A Some general Arduino Problems/FAQ/Tips A For any questions, advice or cool ideas to share, please visit the DFRobot Forum (https://www.dfrobot.com/forum/). More Documents Arduino Course Library Files (https://github.com/DFRobot/Arduino-Course-LibraryFiles/raw/ba6d68d3e17088a9648186237965636479040f93/201705251608388bxa1v.rar) FireBeetle Arduino Bluetooth Examples (https://github.com/Chocho2017/DFRobot_ESP32_WiFiBLE) Schematic (https://github.com/Strictus/DFRobot/raw/master/DFR0575/%5BDFR0575%5D(V1.0)-SCH.PDF) User Manual (https://github.com/Robert-MARKII/Document/raw/master/FireBeetle%20Board-ESP32%20User%20Manual%20update.pdf) DFR0575-Schematics.pdf (https://dfimg.dfrobot.com/nobody/wiki/7b54fd959282196194c6370a9b2a8f2d.pdf) DFR0575-Dimension.png (https://dfimg.dfrobot.com/nobody/wiki/1e08b07556563f8df4db4bab7c9350db.png) Get Beetle ESP32 Microcontroller (https://www.dfrobot.com/product-1798.html) from DFRobot Store or DFRobot Distributor. (https://www.dfrobot.com/index.php?route=information/distributorslogo) Turn to the Top
DFR0575 价格&库存
很抱歉,暂时无法提供与“DFR0575”相匹配的价格&库存,您可以联系我们找货
DFR0575
  • 1+112.971941+14.59960
  • 5+101.604795+13.13060
