DFR0588
DFR0588
    DFROBOT
    SHT30 湿度,温度 传感器 Gravity 平台评估扩展板
DFR0588 数据手册
SKU:DFR0588 (https://www.dfrobot.com/forum/) (https://www.dfrobot.com/) Introduction Gravity: Analog SHT30 Temperature & Humidity Sensor adopts the new generation SHT30 temperature and humidity sensor from Sensirion. Thanks to Sensirion's CMOSens® technology, highly integrated capacitive humidity sensing components and bandgap temperature sensing components, the SHT30 offers high reliability and long-term stability with low power consumption, fast response and immunity to interference. The sensor is internally calibrated, linearized and amplified to output analog voltages that are linear with temperature or humidity. It is compatible with 3.3V/5V controllers such as Arduino, micro:bit, ESP32. It is easy to achieve precise and high reliability temperature and humidity sensing for urban environment monitoring, intelligent buildings, industrial automation, smart home and other Internet of Things applications. Features Internal auto calibration, linear analog voltage output High precision, low power consumption, fast response Compatible with 3.3V/5V controller Application Urban Environmental Monitoring Intelligent Building, Home Industrial Automation Specification IC (Sensor): Sensirion SHT30 Input Voltage (VCC) : 3.3V - 5.5V Interface: Gravity Analog (PH2.0-3P,analog voltage output 0.3-2.7V) Quiescent Current: 2s Humidity Performance Range: 0 - 100 %RH Resolution: 0.006 %, 14bit Accuracy: ±3 %RH@10 - 90 %RH (typical),±8 %RH@0 - 100 %RH (typical) Response Time: >8s Response Time: >8s Board Overview No. Label Description 1 - Power GND 2 + Power VCC(3.3~5.5V) 3 RH Relative humidity analog output (0.3-2.7V) 4 T Temperature analog output (0.3-2.7V) 5 / 2.54mm-4P via pinout Output Characteristic When the module is powered within rated input voltage and works normally, it outputs a lt f 0 3 2 7V hi h i li ith t t h idit Th di voltage of 0.3~2.7V which is linear with temperature or humidity. The corresponding relationship is shown below. Arduino Tutorial This tutorial presents a basic usage of the module with Arduino UNO. Requirements Hardware DFRduino UNO R3 (https://www.dfrobot.com/product-838.html) (or similar) x 1 Gravity: Analog SHT30 Temperature & Humidity Sensor x 1 Gravity 3P sensor wire (or Dupont wires) x 1 Software Arduino IDE (https://www.arduino.cc/en/Main/Software) Connection Diagram Example Codes /**************************************************************************/ /* @file SHT30_TempRH_Read.ino @author Henry (DFRobot) @version V1.0 @date 2019-08-12 @copyright Copyright (c) 2010 DFRobot Co.Ltd (https://www.dfrobot.com) @licence The MIT License (MIT) @breif This example read and print the temperature and relative humidity. This demo and related libraries are for DFRobot Gravity: Analog SHT30 Temperature & Hu Check out the links below for tutorials and connection diagrams Product(CH): https://www.dfrobot.com.cn/ Product(EN): https://www.dfrobot.com/ */ /**************************************************************************/ // VREF: Analog reference // VREF: Analog reference // For Arduino UNO, Leonardo and mega2560, etc. change VREF to 5 // For Arduino Zero, Due, MKR Family, ESP32, etc. 3V3 controllers, change VREF to 3.3 #define VREF 5.0 #define TEMPERATURE_PIN A1 #define HUMIDITY_PIN A0 #define ADC_RESOLUTION 1024 float Tc, Tf, RH, analogVolt; void setup() { Serial.begin(115200); Serial.println("SHT30 Starts up."); } void loop() { analogVolt = (float)analogRead(TEMPERATURE_PIN) / ADC_RESOLUTION * VREF; // Convert voltage to temperature (℃, centigrade) Tc = -66.875 + 72.917 * analogVolt; // Convert voltage to temperature (°F, fahrenheit ) Tf = -88.375 + 131.25 * analogVolt; Serial.print("Termperature:" ); Serial.print(Tc, 1); S i l i t(" C / " ) Serial.print(" C / " ); Serial.print(Tf, 1); Serial.println(" F" ); analogVolt = (float)analogRead(HUMIDITY_PIN) / ADC_RESOLUTION * VREF; // Convert voltage to relative humidity (%) RH = -12.5 + 41.667 * analogVolt; Serial.print("Humidity:" ); Serial.print(RH, 1); Serial.println(" %RH" ); Serial.println(); delay(2000); } Results Temperature or relative humidity is printed every 2s. micro:bit Tutorial This tutorial presents a basic usage of the module with micro:bit. Requirements Hardware micro:bit - an Educational & Creative Tool for Kids (https://www.dfrobot.com/product1587.html) x 1 Micro:Mate - A Mini Expansion Board for micro:bit (https://www.dfrobot.com/product1699.html) x 1 Gravity: Analog SHT30 Temperature & Humidity Sensor Gravity 3P sensor wire (or Dupont wires) x 1 Software Microsoft MakeCode for micro:bit (https://makecode.microbit.org/) Connection Diagram Example Codes Results Temperature and relative humidity are printed from serial every 2s. FAQ For any questions, advice or cool ideas to share, please visit the DFRobot Forum (https://www.dfrobot.com/forum/). More Documents Schematic Schematic (https://github.com/DFRobot/Wiki/raw/master/DFR0588/res/DFR0588%20(V1.0)%20Schemat ic.pdf) Layout & Dimension (https://github.com/DFRobot/Wiki/raw/master/DFR0588/res/DFR0588%20(V1.0)%20Layout% 20with%20dimension.pdf) Sensirion SHT3x-ARP Datasheet (https://github.com/DFRobot/Wiki/raw/master/DFR0588/res/SHT30-ARP-B.PDF) DFshopping_car1.png Get DFR0588 Gravity: Analog SHT30 Temperature & Humidity Sensor (https://www.dfrobot.com/product-1908.html) from DFRobot Store or DFRobot Distributor. (https://www.dfrobot.com/index.php?route=information/distributorslogo) Turn to the Top
DFR0588
物料型号:DFR0588
器件简介:Gravity: Analog SHT30温湿度传感器采用了Sensirion公司的新一代SHT30温湿度传感器。该传感器基于CMOSens®技术,集成了电容式湿度感应元件和带隙温度感应元件,具有高可靠性、长期稳定性、低功耗、快速响应和抗干扰能力。传感器内部已校准、线性化和放大,输出与温度或湿度成线性关系的模拟电压。兼容3.3V/5V控制器,如Arduino、micro:bit、ESP32等,易于实现精确和高可靠性的温度和湿度监测。
引脚分配: - 1. Power GND - 2. Power VCC (3.3~5.5V) - 3. RH:相对湿度模拟输出 (0.3-2.7V) - 4. T:温度模拟输出 (0.3-2.7V) - 5. 2.54mm-4P通孔引脚排列
参数特性: - 温度范围:-40 - 125℃ - 温度分辨率:0.01℃,14位 - 温度精度:±0.2℃@10 - 55℃ (典型),±1.5℃@-40 - 125℃ (典型) - 湿度范围:0 - 100%RH - 湿度分辨率:0.006%,14位 - 湿度精度:±3%RH@10 - 90%RH (典型),±8%RH@0 - 100%RH (典型)
功能详解:模块在额定输入电压下工作时,输出与温度或湿度成线性关系的0.3~2.7V电压。
应用信息: - 城市环境监测 - 智能建筑、家居 - 工业自动化
封装信息: - 尺寸:30×32 mm / 1.18×1.26 英寸 - 重量:4g
DFR0588 价格&库存
很抱歉,暂时无法提供与“DFR0588”相匹配的价格&库存,您可以联系我们找货
DFR0588
  • 1+62.31498
DFR0588
  • 1+60.992291+7.89098
库存:74
