INTRODUCTION
This 40W high power DC-DC Buck converter offers a 6~14V input voltage range and up to
5V/8A output. Featuring a small body, high conversion ratio, strong heat dissipation, and
large current output, the module is compatible with all 5V main-boards, and can work as an
SMD element to be directly soldered onto PCB. With steady output, this buck converter is
able to work for a long time without voltage shift, which can be suitable for projects of high
requirements like smart homes, small robot car power sources, etc.
FEATURES
Small in size
40W high power output
Over 96% conversion ratio
Can be used as SMD component
SPECIFICATION
Input Voltage Range: 6V-14V
Output Voltage: 5V
Output Current: 0-8A
Voltage Accuracy: ±1%
Full-load Output Ripple: <30mV
Conversion Ratio: >96% (12V input, full-load output)
Static Current:
很抱歉,暂时无法提供与“DFR0753”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+77.120361+9.98390
