DFR0021-G
DFR0021-G
    DFROBOT
    GRAVITY: DIGITAL GREEN LED LIGHT
DFR0021-G 数据手册
Part Number: DFR0021-G Description: Gravity: Digital Green LED Light Module INTRODUCTION This green LED light module has a shiny white color. It is ideal for Arduino starter. This module can be easy to be plugged on IO/Sensor expansion shield. NOTE: This LED is wired to light up when the Signal pin is set to low. The reason for this is to prevent the LED from demanding too much current from the microcontroller and damaging the I/O. If you wish to make this LED light up with a logic high, you can switch the Signal wire (Green) with the GND wire (Black) and the Voltage wire (Red) to the Signal wire's original spot. SPECIFICATION   Type:Digital LED light module pin definition : (1) control terminal (2) power supply (3) ground SHIPPING LIST   Sensor x1 Digital Sensor Cable (SKU:FIT0011) x1
DFR0021-G 价格&库存
很抱歉,暂时无法提供与“DFR0021-G”相匹配的价格&库存,您可以联系我们找货
