SKU:DFR0845 (https://www.dfrobot.com.cn/goods-807.html)
(https://www.dfrobot.com.cn/goods807.html)
Introduction
This active, isolated RS485 to UART signal transfer module comes with protection circuits such as
power isolation and TVS. Compatible with most main controllers, it has the characteristics of fast
communication speed, stable and reliable performance, high safety, etc., and can be applied to
various industrial sensors, industrial control equipment or applications that require RS485 signal
conversion.
Features
Adopt Jinshengyang's UART to RS485 module and power module to ensure signal isolation
and power isolation.
Industrial-grade RS485
Connector for easy connection
to various RS485 interface
devices.
12V power output, the maximum
output current is about 160mA,
convenient for testing small load
RS485 device.
3.3V, 5V level compatibility
function at UART, supporting
more main controllers.
Immersion gold technology,
high-quality PCB.
Onboard 120Ω terminal
matching resistance, which can
be connected and disconnected
through the switch control.
Support 12V external power supply.
Specification
Power Supply Voltage: 3.3~5V
Communication baud rate up to 1M bps
Up to 12V-2W power output (output current is about 160mA)
Isolation voltage 3000 VDC
Bus electrostatic protection capacity is up to 15kV
1/8 unit load, bus load capacity up to 256 nodes
Bus fail protection and bus drive short circuit protection
Operating temperature range: -40℃ to +105℃
Board Overview
(https://dfimg.dfrobot.com/nobody/wiki/370b17bef8b985261fc60a46cc6b6892.png )
[DFR0845 Gravity: Active Isolated RS485 to UART Signal Converter]()
Gravity-UART
Label
Name
Function description
1
Label
T
Name
UART data transmission-TX
2
R
UART data reception-RX
3
GND power supply negative
4
VCC power supply positive
Label
Name
1
12V
12V-2W output, connect to 485 device
2
GND
RS485 side isolated ground, connected to 485 device's GND
3
A
RS485 signal terminal A
4
B
RS485 signal terminal B
RS485
12V-IN
Label
Label
Name
Name
Function
description
1
12V
12V external power input
2
GND
External power supply GND
Tutorial
Use Gravity: Active Isolated RS485 to UART Signal Adapter Module () to connect the RS485 device
and the Arduino Leonardo main control, and test the transceiver function of the device through
the serial monitor.
Note:
If the power supply requirement of the RS485 device is greater than 12V-160mA, 12V
external power supply is required.
This product does not support hot pluggable.
Requirements
Hardware
DFRduino UNO R3 (https://www.dfrobot.com/product-838.html) (or similar) x 1
DFR0845 Gravity: Active isolation type RS485 to UART signal transfer module () ×1
RS485 device ×1
Software
Arduino IDE (https://www.arduino.cc/en/Main/Software)
SSCOM32 serial port debugging tool
Use serial port to read sensor data
Connection Diagram
(https://img.dfrobot.com.cn/wiki/5b973267c87e6f19943ab3ad/cac665bd42c1122c4346e5388828
4fec.png)
Sample code
Connect the module and Arduino Leonardo according to the connection diagram above. Of
course, you can also use it with Gravity I/O Expansion Board (), which can complete the
project prototype more conveniently and quickly.
Open the Arduino IDE and upload the following code to Arduino Leonardo.
Open the SSCOM32 serial port data debugger, adjust the baud rate to 9600, select the
corresponding port, tick HEX display and HEX sending, and observe the serial port printing
results.
void setup() {
//Communicate with PC through USB to UART, use Serial to call
Serial.begin(9600);
//Use Serial1 to call the serial UART of TXD and RXD marked on the development board
Serial1.begin(9600);
void loop() {
if (Serial.available())
Serial1.write(Serial.read());
if (Serial1.available())
Serial.write(Serial1.read());
Expected Results
Open the SSCOM32 serial port data debugger, send the Hex command, and get the data
feedback.
FAQ
For any questions, advice or cool ideas to share, please visit the DFRobot Forum
(https://www.dfrobot.com/forum/).
More Documents
TDH541S485H datasheet
(https://img.dfrobot.com.cn/wiki/5b973267c87e6f19943ab3ad/32725c6cf54f67066f04dcfa2d
24f49a.PDF)
Schematics
(https://img.dfrobot.com.cn/wiki/5b973267c87e6f19943ab3ad/9810c322218d9643776c845e
0c95d0d2.pdf)
Dimension and Component Layout
(https://img.dfrobot.com.cn/wiki/5b973267c87e6f19943ab3ad/f861cacb52fe79580017a8371
4640491.pdf)
DFshopping_car1.png Get Gravity Active Isolation Type RS485 to UART Signal Transfer
Module (https://www.dfrobot.com/product-203.html) from DFRobot Store or DFRobot
Distributor. (https://www.dfrobot.com/index.php?route=information/distributorslogo)
Turn to the Top
很抱歉,暂时无法提供与“DFR0845”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+178.395841+23.10850
- 国内价格 香港价格
- 1+175.396111+22.71993
