DRI0050
DRI0050
    DFROBOT
    伺服 DC 5 ~ 24VDC 电源 10A 负载
DRI0050 数据手册
SKU:DRI0050 (https://www.dfrobot.com/product-2429.html) (https://www.dfrobot.com/product-2429.html) 1. Introduction This is a PWM driver board with four adjustment methods, namely, Python code direct control, j , y, y PC host computer control, UART communication programming control, and potentiometer , manual control. It is used in application scenarios such as DC motor speed control and light adjustment. This product supports 5V~24V wide voltage input, and has a load capacity of 10A, which can drive a DC motor of about 50W or a LED strip light of about 5 meters. It is suitable for water pump water volume control, cooling fan speed control, light brightness adjustment, power tool transformation, motor/LED strip product testing, motor speed automation control, lighting effect automation control and other scenes. 2. Features Python code programming, no motherboard or adapter required. Directly connected to PC via a USB cable, simple and easy to use. Windows software control, no programming required, plug and play. UART communication control, convenient for long-term use of embedded equipment. External potentiometer control, manual control, no programming required. Standard MODBUS protocol. The protocol is public so you can flexibly customize your own control method. 5V~24V wide voltage support, suitable for various motors and light strips. Driven by high current MOS tube, load capacity of 10A 3. Applications Control by Python code 1. Connect the USB interface, you can directly use Python code to automatically control the motor speed and lighting effect. No additional motherboard or adapter is required. 2. Can be very conveniently used on Windows computers, Apple computers, Raspberry Pi, industrial computers or LattePanda. Control by Windows computer 1. When remaking a PC cooling fan, cooling water pump, etc, you can manually control the device on PC, or make it be automatically adjusted by reading the CPU temperature. 2. Because the host computer can accurately adjust the frequency and duty ratio, this driver can be used to test dc motor or light strip products, or to optimize small equipment. 3. Make a small fan whose wind speed can be automatically adjusted or controlled on the computer. Just plug in the USB to use. Control by programming mainboard 1. Create a project with special effects, or turn it on at a specific time, or adjust lighting effects, or use it with sensors. For example, a fan that automatically adjusts the wind force, and a light strip that automatically changes its brightness. 2. Automatic control of the water output of the fish tank or watering pump. 3. Automatic control of festival atmosphere lights. Manual control by potentiometer 1. Home appliance renovation, making adjustable fans. 2. Electric tool production, transformation, adjustable speed. 3. Lighting effects control of light strip. 4. Specification Input Voltage Range: 5~24V Max Control Current: 10A Max Control Current: 10A PWM Duty Ratio Adjustment Range: 0~255 PWM Frequency Adjustment Range: 183Hz ~ 46875Hz Number of PWM Channels:1 channel Stop/Start Button ×1 Control Mode: External potentiometer adjustment, UART communication control, USB port host computer control, Python control USB Interface: Type-C UART Interface: PH2.0-4P External Potentiometer Interface: 2.54 pin header, binding post Mounting Hole Size: 30mm × 50mm, diameter 3.1mm PCB Size: 37 × 57mm / 1.46 × 2.24 inches 5. Product Dimension 6. Board Overview 7. Control Peripheral via Windows The product allows users to configure its PWM parameters by Windows so as to control motor speed or light brightness. Note: Currently the product only passed the test on Windows. Other Systems are not tested yet. 1. Connect a device Before using the product, you have to prepare the following hardware: PC Windows 10 Motor or LED strip Type-C cable Power Source(Voltage: 5V~24V Power>2A Select the suitable power according to the devcie you used) Connect all parts together as shown below, dial the switch to UART/COM side. 2. Install USB driver Di D l d Driver Download When using this product for the first time, you may need to download and install the USB driver program. USB Driver download link(Select one of the links below to download): https://github.com/DFRobot/CH_Driver (https://github.com/DFRobot/CH_Driver) http://download.dfrobot.top/CH_Drive/ (http://download.dfrobot.top/CH_Drive/) Driver Description Windows Driver: CH340/CH341 USB to Serial Windows Driver program. DLL and non-standard buad rate settings are included. It supports 32/64 bits Windows 10/8.1/8/7/VISTA/XP, SERVER 2016/2012/2008/2003, 2000/ME/98. Certificated by microsoft digital signature. Supporting USB to serial port 3-wire and 9-wire. Linux Driver: CH340/CH341 USB to serial port Linux Driver program, supporting 32/64bits. MAC Driver: CH340/CH341 USB to serial port MAC OS Driver program, supporting 32/64bits. Manual included. Android Driver: CH340/CH341 USB to serial port Android driver-free library, used for the USB Host mode of Android OS 3.1 and above. No need to load Android core driver and root operation privilege is unnecessary. It includes apk installtion program, lib files(Java Driver), and APP Demo(USB to UART Demo Engineering SDK). 3. Download program package for Windows Download link: https://github.com/DFRobot/DRI0050_soft_V1.0 (https://github.com/DFRobot/DRI0050_soft_V1.0) Download the file, unzip it, click the program "Light and Motor Driver.exe" to run. No need to install. Software Interface: 1. Connect the product to a PC via a USB Type-C cable. If the driver program is installed already, the software will automatically recognize it. 2. Click the start button, the PC communicates successfully with PWM module, and now the PWM frequency and duty ratio can be adjusted in real-time. 3. Adjustable Frequency ranges from 0 to 255. You can input manually or drag the control bar to revise. The frequency will be displayed on the right side of the interface. 4. The product supports single-channel PWM control, so only the duty ratio of Channel 1 can be adjusted. Enter the duty ratio into the input box. 5. Tick/untick to enable/disable PWM control. 8. Control Peripherial via Python Programming When connecting this board to a PC via a USB cable, you can not only directly control it on PC, but also program in Python on multiple platforms like Windows, MAC, Linux, etc. to control motor or LED strip. Note: Windows platform needs to install Python3.5+.(The newest version is recommended.) Most Linux platforms has pre-installed Python3, if not, please install Python3.5+. There are two ways provided for Python programming: 1. Program by Python Pinpong library: pinpong library is a Python library that integrates abundant hardware control functions, which aims to greatly simplify coding. 2. Program by Python directly: The codes will be a little bit cumbersome, but still, same functions can be realized in this way. Control prepherial by Python_pinpong library (All platforms) Input the following commands to install pinpong library: pip3 install pinpong Use pinpong library to control device (For Linux and Windows) Use pinpong library to control device (For Linux and Windows) The program provides the basic controllable commands. You can select your program control method and coding platform, etc, as your actual needs. # -*- coding: utf-8 -*- ''' PWM frequency higher than 2K, there may be relatively large difference between the frequen For frequency higher than 2K, please refer to the following frequency value: 46875HZ, 23437HZ, 15625HZ, 11718HZ, 9375HZ, 7812HZ, 6696HZ, 5859HZ, 5208HZ, 4687HZ, 4261HZ, 3906HZ, 3605HZ, 3348HZ, 3125HZ, 2929HZ, 2757HZ, 2604HZ, 2467HZ, 2343HZ, 2232HZ, 2130HZ, 2038HZ, ''' import time from pinpong.board import Board from pinpong.libs.dfrobot_dri0050 import DRI0050 # Import DRI0050 library from libs #Board("RPi").begin() #RPi Linux platform Board("Win").begin() #windows platform #pwmd = DRI0050(port="/dev/ttyUSB0") #RPi Linux platform pwmd = DRI0050(port="COM12") #Windows platform pwmd = DRI0050(port= COM12 ) #Windows platform print("version=0x{:x}, addr=0x{:x}".format(pwmd.get_version(), pwmd.get_addr())) print("pid=0x{:x}, vid=0x{:x}".format(pwmd.get_vid(), pwmd.get_pid())) while True: print("\n--------Inital Value------") print("freq={}, duty={:.2f} enable={}".format(pwmd.get_freq(), pwmd.get_duty(), pwmd.get print("--------Set a new value------") #pwmd.pwm(freq=860,duty=0.82) # freq(183HZ-46875HZ) duty(0%-100%) pwmd.set_freq(860) #(183HZ-46875HZ) pwmd.set_duty(0.82)#(0%-100%) pwmd.set_enable(1) print("freq={}, duty={:.2f} enable={}".format(pwmd.get_freq(), pwmd.get_duty(), pwmd.get print("--------Restore to factory settings (366HZ, duty ratio 50%, disable output)-----pwmd.pwm(freq=366,duty=0.5) # freq(183HZ-46875HZ) duty(0%-100%) pwmd.set_enable(0) time.sleep(5) Control prepherial via Python (All platforms) Use the following commands to install serial library and modbus library: pip3 install serial pip3 install modbus_tk The program provides the basic controllable commands. You can select your program control method and coding platform, etc, as your actual needs. # -*- coding: utf-8 -*- ''' PWM frequency higher than 2K, there may be relatively large difference between the frequen For frequency higher than 2K, please refer to the following frequency value: 46875HZ, 23437HZ, 15625HZ, 11718HZ, 9375HZ, 7812HZ, 6696HZ, 5859HZ, 5208HZ, 4687HZ, 4261HZ, 3906HZ, 3605HZ, 3348HZ, 3125HZ, 2929HZ, 2757HZ, 2604HZ, 2467HZ, 2343HZ, 2232HZ, 2130HZ, 2038HZ, ''' import time import serial import modbus_tk import modbus_tk.defines as cst from modbus_tk import modbus_rtu PORT="COM12" #Windows platform #PORT="/dev/ttyUSB0" #Linux platform BAUDRATE=9600 BAUDRATE=9600 SLAVE_ADDR=0x32 PID_REG VID_REG = = 0x00 0x01 ADDR_REG VER_REG DUTY_REG FREQ_REG PWM_EN_REG = = = = = 0x02 0x05 0x06 0x07 0x08 ser = serial.Serial(port=PORT,baudrate=BAUDRATE, bytesize=8, parity='N', stopbits=1) master = modbus_rtu.RtuMaster(ser) time.sleep(0.5) def get_pid(): data = master.execute(SLAVE_ADDR, cst.READ_HOLDING_REGISTERS, PID_REG, 1) time.sleep(0.03) return data[0] def get_vid(): data = master.execute(SLAVE_ADDR, cst.READ_HOLDING_REGISTERS, VID_REG, 1) time.sleep(0.03) return data[0] def get_addr(): data = master.execute(SLAVE_ADDR, cst.READ_HOLDING_REGISTERS, ADDR_REG, 1) time.sleep(0.03) return data[0] def get_version(): data = master.execute(SLAVE_ADDR, cst.READ_HOLDING_REGISTERS, VER_REG, 1) time.sleep(0.03) return data[0] def get_duty(): data = master.execute(SLAVE_ADDR, cst.READ_HOLDING_REGISTERS, DUTY_REG, 1) time.sleep(0.03) return data[0]/255 def get_freq(): data = master.execute(SLAVE_ADDR, cst.READ_HOLDING_REGISTERS, FREQ_REG, 1) time.sleep(0.03) return int(12*1000*1000/256/(data[0]+1)) def get_enable(): data = master.execute(SLAVE_ADDR, cst.READ_HOLDING_REGISTERS, PWM_EN_REG, 1) time.sleep(0.03) t d t [0] return data[0] def set_duty(duty): master.execute(SLAVE_ADDR, cst.WRITE_SINGLE_REGISTER, DUTY_REG, output_value=int(duty*25 time.sleep(0.03) def set_freq(freq): master.execute(SLAVE_ADDR, cst.WRITE_SINGLE_REGISTER, FREQ_REG, output_value=int(12*1000 time.sleep(0.03) def set_enable(enable): master.execute(SLAVE_ADDR, cst.WRITE_SINGLE_REGISTER, PWM_EN_REG, output_value=enable) time.sleep(0.03) def pwm(freq, duty): v=[] v.append(int(duty*255)) v.append(int(12*1000*1000/256/freq) - 1) master.execute(SLAVE_ADDR, cst.WRITE_MULTIPLE_REGISTERS, DUTY_REG, output_value=v) time.sleep(0.03) print("version=0x{:x}, addr=0x{:x}".format(get_version(), get_addr())) print("pid=0x{:x}, vid=0x{:x}".format(get_vid(), get_pid())) print("\n--------Initial Value------") print("freq={}, duty={:.2f} enable={}".format(get_freq(), get_duty(), get_enable())) print("--------Set a new value------") #pwm(freq=860,duty=0.82) # freq(183HZ-46875HZ) duty(0%-100%) set_freq(860) #(183HZ-46875HZ) set_duty(0.82)#(0%-100%) set_enable(1) print("freq={}, duty={:.2f} enable={}".format(get_freq(), get_duty(), get_enable())) print("--------Restore to factory settings(366HZ, duty ratio 50%, diable output)-------\n" pwm(freq=366, duty=0.5) # freq(183HZ-46875HZ) duty(0%-100%) set_enable(0) 9. Control Prepherial via Arduino Programming Before using Arduino programming, you have to prepare the following hardware: Arduino UNO Motor or LED strip 4PIN Gravity sensor wire Power source(Voltage: 5~24V, power>2A Select the suitable power according to the devcie you used ) Connect all parts together as shown below, dial the switch to UART/COM side. Function Description: let the LED strip flash every 2s. #define #define #define #define #define #define PWM_ENABLE PWM_DISENABLE DEV_ADDR DUTY_REG_ADDR FREQ_REG_ADDR PWM_EN_REG_ADDR 0x01 0x00 0x32 0x0006 0x0007 0x0008 static uint16_t CheckCRC(uint8_t *data, uint8_t len){ uint16_t crc = 0xFFFF; for(uint8_t pos = 0; pos < len; pos++){ crc ^= (uint16_t)data[pos]; for(uint8_t i = 8; i != 0; i-- ){ if((crc & 0x0001) != 0){ crc >>= 1; crc ^= 0xA001; }else{ crc >>= 1; } } } } crc = ((crc & 0x00FF) > 8); return crc; } static void WriteRegValue(uint16_t regAddr, uint16_t value){ uint8_t tempData[8]; uint16_t crc; tempData[0] = DEV_ADDR; tempData[1] = 0x06; tempData[2] = (regAddr >> 8) & 0xFF; tempData[3] = regAddr & 0xFF; tempData[4] = (value >> 8) & 0xFF; tempData[5] = value & 0xFF; crc = CheckCRC(tempData, 6); tempData[6] = (crc >> 8) & 0xFF; tempData[7] = crc & 0xFF; for(uint8_t i = 0 ;i < 8; i++){ Serial.print((char)tempData[i]); } Serial.flush(); } static void setPwmDuty(uint8_t duty){ WriteRegValue(DUTY_REG_ADDR, (uint16_t)duty); } static void setPwmFreq(uint8_t freq){ WriteRegValue(FREQ_REG_ADDR, (uint16_t)freq); } static void setPwmEnable(uint8_t pwmStatus){ WriteRegValue(PWM_EN_REG_ADDR, (uint16_t)pwmStatus); } void setup() { // put your setup code here, to run once: Serial.begin(9600); delay(1000); setPwmFreq(10); delay(50); setPwmDuty(0); delay(50); setPwmEnable(PWM_ENABLE); delay(50); } } void loop() { setPwmDuty(200); delay(2000); setPwmDuty(0); delay(2000); } 10. Control Peripherial via Potentiometer We can also connect a "Potentiometer module" or "Potentiometer element" to control PWM value so as to control motor speed or light brightness. Before using potentiometer to control, you need to prepare the following hardware and tool: Gravity Potentiometer module or potentiometer element with wires soldered. Motor or LED strip Screwdriver Power source(Voltage: 5~24V, power>2A Select the suitable power according to the devcie you used) you used) Connect all parts together as shown below, dial the switch to Analog IN side. Connect with Gravity Potentiometer Module Use the Gravity 3PIN sensor cable to connect the DFRobot Potentiometer with the driver board. (Pay attention to the wire order when connecting.) Connect with Potentiometer element The diagram on the left is the connection for potentiometer element. You have to solder wires for the potentiometer first and then attach the wires to the binding post. The right diagram shows how to connect a real potentiometer to the driver board. Normally the middle pin of a potentiometer is the wiper that gives us the variable of resistance value, and should be connected to port "A". Find the right wiper on your potentiometer before connecting. Available potentiometer vlaue: 4.7K~470K 11 Mind+ 11. Mind+ 12. Register Table (ModBus RTU Communication Protocol) Data Range Default Value R 0×C032 0×C032 VID R 0×3343 0×3343 VI 0×0002 Device Address R 0×0032 0×0032 Mo A Holding Register 0×0003 Reserve R 0×0000~0×FFFF 0×FFFF Holding Register 0×0004 Reserve R 0×0000~0×FFFF 0×FFFF Type Address Name Holding Register 0×0000 PID Holding Register 0×0001 Holding Register Read/Write Desc PI Fi Holding Type Register Holding Register 0×0005 Address 0×0006 Version Name PWM0 Duty Ratio R Read/Write R/W 0×0000~0×00FF Data Range 0×0000~0×00FF Default 0×1000 Value 0×007F Firm 0 Desc PW Duty fo PW Freq frequ Holding Register 0×0007 PWM0 Frequency fa R/W 0×0000~0×00FF 0×007F fr 12M cor th Type Holding Register Address Name 0×0008 PWM Output Enable/Disable Read/Write R/W Data Range 0×0000~0×0001 Status FAQ For any questions, advice or cool ideas to share, please visit the DFRobot Forum (https://www.dfrobot.com/forum/). More Documents Schematics PDF Default Value 0×0000 th 4 Desc Ena PW Schematics.PDF (https://dfimg.dfrobot.com/nobody/wiki/e56242dc316eb1db47799bca7e05bff2.PDF) DRI0050-V1.0-3D-STEP File.rar (https://dfimg.dfrobot.com/nobody/wiki/46c98ea706e831286a9cb0c265c0f61a.rar) DRI0050-V1.0-2D-DXF File.rar (https://dfimg.dfrobot.com/nobody/wiki/d08ff6fcb58626bec2af453dcc113eb8.rar) Get Light and Motor Driver for Python (https://www.dfrobot.com/product-2429.html) from DFRobot Store or DFRobot Distributor. (https://www.dfrobot.com/index.php? route=information/distributorslogo) Turn to the Top
DRI0050 价格&库存
很抱歉,暂时无法提供与“DRI0050”相匹配的价格&库存,您可以联系我们找货
DRI0050
  • 1+99.172141+12.83680
库存:13
DRI0050
库存:8
