DFR0806
DFR0806
    DFROBOT
    DFROBOT - DFR0806 - Evaluation Board, 2-Channel, Audio Amplifier, AUX, Bluetooth 5.0, 10 m, 9 V to 2...
DFR0806 数据手册
INTRODUCTION With bass and treble tone independent control, this powerful Bluetooth Amplifier has AM interference and filtering function that makes the board THD as low as 0.1% even when working for a long time at large power output, while bringing you clear and round sound. The board features DC9-24V power supply, AUX+Bluetooth 5.0 audio input, and 50W output power. It has 3 adjustable knobs that are used to power on/off and control the main volume, bass, and treble. This product works well with 4-8Ω, 15W-100W passive speakers. You can connect it to Raspberry Pi, mobile phones, and other main-controllers with Bluetooth to DIY your projects. The Bluetooth Amplifier board comes with bottom/top protective panels and supports protection mechanisms including over-voltage, under-voltage, overheating, short-circuit protection, and DC detection. Operation Instruction Connect the board with a speaker, power it on. Rotate the main volume knob then the indicator LED lights up. Turn on the Bluetooth of your phone or Raspberry Pi, the “BT-WUZHI” will be searched, and then click to connect it. It connects successfully with a ding-dong tone, and now it can play music. The Bluetooth will be connected automatically when the module is powered on next time. Note 1.The board will output adequate power only when the audio input and power source voltage/current are sufficient. The higher the power supply voltage, the larger the output power. Besides that, speaker impedance also changes the amplifier board power output. Please note that in the case of enough voltage and current, the larger the speaker impedance in ohms, the smaller the output power. 2.When adjusting treble and bass sound: when the TRBLE or BASS sounds are right-rotated to near maximum, if the sound is distorted, it means that the gain of the Bass/Treble sound is too large. Now you have to turn the TRBLE or BASS knob to the left to lower the gain or rotate the MAIN-VOLUME Knob on the right to the left to reduce the overall volume. SPECIFICATION Power Supply: 9-24V/2A above Input: AUX+Bluetooth 5.0 Output Power: 50W*2 Compatible Speaker: 15W-100W, 4Ω-8Ω Channel: left/right channel (Stereo) Bluetooth Transmission Distance: 10m (Without any obstacle) Protection Mechanism: over-voltage, under-voltage, overheating, short-circuit protection, and DC detection SHIPPING LIST · · · · · · · Bass Treble Bluetooth Amplifier-50W*2 x1 Acrylic Protective Case x2 Screwdriver x1 20cm Power Wire x1 Knob x3 Heat Sink x1 Accessories Package x1
DFR0806
物料型号:ZK-5021
器件简介:这是一个功能强大的蓝牙放大器,具有独立的低音和高音控制,具备AM干扰和滤波功能,即使在长时间大功率输出下,板的总谐波失真(THD)也能低至0.1%,带来清晰圆润的声音。它支持DC9-24V电源,AUX+蓝牙5.0音频输入,输出功率为50W。产品配备3个可调节旋钮,用于电源开关和控制主音量、低音和高音。适用于4-8Ω、15W-100W的被动扬声器,可与树莓派、手机等蓝牙主控设备连接,用于DIY项目。
引脚分配:文档中未明确列出引脚分配,但提到了"DC Input Range: DC9-24V(5.52.1mm)",可能指的是电源输入端子的尺寸。
参数特性: - 电源:9-24V/2A以上 - 输入:AUX+蓝牙5.0 - 输出功率:50W2 - 兼容扬声器:15W-100W,4Ω-8Ω - 通道:左右声道(立体声) - 蓝牙传输距离:10米(无障碍) - 保护机制:过压、欠压、过热、短路保护和直流检测
功能详解:文档中提供了操作说明,包括如何连接扬声器、开机、连接蓝牙设备以及如何调整音量和音质。
应用信息:适用于与被动扬声器配合使用,可以连接到树莓派、手机等设备,用于DIY项目。
DFR0806 价格&库存
很抱歉,暂时无法提供与“DFR0806”相匹配的价格&库存,您可以联系我们找货
