Sunflower: Solar Power Manager 5V
SKU: DFR0559
Sunflower Solar Power Series
Introduction
DFRobot Sunflower is a brand new series focusing on high-efficiency micro to middle power solar
energy harvesting and management for makers, renewable energy and IoT projects. All Sunflower
modules feature as MPPT ( Maximum Power Point Tracking ) maximizing solar collection efficiency
under different sun light, and a variety of battery and power protections. These features provide
makers' solar projects efficient and reliable power management.
Selection Guide
Name
Solar Power Manager
Solar Power Manager 5V ★
SKU
DFR0535
DFR0559
Solar Power Management
IC
LTC3652
CN3065
Solar Input Voltage
7V ~ 30V
4.4V ~ 6V
Maximum Charge Current
2A
900mA
Topology
DC-DC Buck
Linear Regulator
Battery
3.7V Lithium Battery
MPPT
Yes (9V/12V/18V Optional)
Yes(Fixed 5V)
Battery Protections
Over Charge/Over Discharge/Over
Current/Reverse Connection Protections
Over Charge/Reverse Connection
Protections
Output Protections
Short Circuit/Over Current/Over Heat
Protections
Protections
USB Charge IN
Yes
Yes
USB OUT
5V 1.5A
5V 1A
Regulated OUT
Three Regulated Outputs
3.3V 1A;5V 1.5V;9V/12V 0.5A
One Regulated Output
5V 1A
Dimension
78.0mm×68.0mm
33.0mm×63.0mm
A complete multifunction solar power
management module.
Features
Applications: Small Solar Street Lamp,
Solar Powered Robots
For 9V/12V/18V Solar Panels within
20W
A small and easy-to-use 5V solar
power management module.
Applications: Solar Power Bank,
Solar Environment Monitors
For 5V Solar Panels within 10W
Introduction
DFRobot Sunflower is a new series focusing on high-efficiency small power solar energy harvesting
and management for makers, low-power applications and IoT projects. Solar Power Manager 5V is a
small power and high-efficiency solar power management module designed for 5V solar panel. It
features as MPPT (Maximum Power Point Tracking) function, maximizing the efficiency of the solar
panel. Apart from serving as a solar charger, the module can provide up to 900mA charging current
to 3.7V Li battery with USB charger. The ON/OFF controllable DC-DC converters with 5V 1A output
satisfies the needs of various solar power projects and low-power applications. The module also
employs various protection functions, such as battery/solar panel reverse connection protection,
output over temperature and over current/short circuit protection, which greatly improves the stability
and safety of the system.
Features
Constant Voltage MPPT Algorithm, Maximizing Solar Panel Efficiency
Designed for 5V Solar Panel
Double Charging Mode: Solar/USB Charger (900mA Max Charge Current)
5V ON/OFF Controllable Regulated Power Supply for Low-Power Applications
Various Protection Functions
USB Connector with ESD Shell
Specifications
Solar Power Management IC: CN3065
Solar Input Voltage (SOLAR IN): 4.5V~6V
Battery Input (BAT IN): 3.7V Li-Polymer/Li-ion Battery
Charge Current (USB/SOLAR IN): 900mA Max Trickle Charging, Constant Current, Constant
Voltage Three Phases Charging
Charge Cutoff Voltage (USB/SOLAR IN): 4.2V±1%
USB IN Voltage: 5V
Regulated Power Supply: 5V 1A
Regulated Power Supply Efficiency (3.7V Battery IN)
5V/USB OUT: 89%@10%Load, 86%@50%Load, 83%@90%Load
USB/Solar Charge Efficiency: 73%@3.7V 900mA BAT IN
Maximum Quiescent Current:
很抱歉,暂时无法提供与“DFR0559”相匹配的价格&库存,您可以联系我们找货
